Skoda supereb ECU recoding
Is this ECU could be changed from coding from manual to autoamtic , i tried and it give me code rejected
thanks in advance
Saturday,29,June,2019,03:07:25:22511
VCDS Version: 18.2.0.3 HEX-NET CB: 0.4437.4
VIN: TMBAA83T4C9041592 License Plate:
Mileage: 97760km-60745mi Repair Order:
Chassis Type: 3T-SK46 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 55 56 62 72 77
VIN: TMBAA83T4C9041592 Mileage: 97760km-60745miles
Address 01: Engine (CAX) Labels: 03C-906-016-CAX.clb
Part No SW: 03C 906 016 AQ HW: 03C 906 016 C
Component: MED17.5.5 G 9061
Revision: LCH12--- Serial number:
Coding: 0000072
Shop #: WSC 33361 790 00999
VCID: EE908A9CF9C06A347A-80BA
Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 843D6016092600FB211006ED901B0040340000
Shop #: WSC 33361 790 00097
VCID: F9BAA9C0708E3D8CDF-80AC
02214 - Tire Pressure Warning
Reset counter: 29
Mileage: 96019 km
Date: 2013.10.22
Time: 23:40:58
Count: 32768
Count: 4608
Count: 397
Count: 49152
Count: 768
Part No SW: 3T0 907 044 BK HW: 3T0 907 044 BK
Component: Climatronic H18 0506
Revision: 00001007
Coding: 0000000002
ROD: EV_ClimaAutoBasis_SK46.rod
VCID: FCB4B0D477BC08A4C4-80A8
Part No SW: 1K0 937 087 AB HW: 1K0 937 087 AB
Component: BCM PQ35 H+ 110 0651
Revision: 00110 AC
Coding: 40990AB8E00508C040080080310089E4437000AE732089605C8040000040
VCID: F1AA91E028FE75CC67-80A4
Subsystem 1 - Part No: 3T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 30111 26 0602
Coding: 00D7B7
Component: RLS 251111 05 54 0403
Coding: 0730ED
Fault Status: 00101010
Fault Frequency: 15
Reset counter: 34
Mileage: 95537 km
Date: 2013.10.15
Time: 02:19:26
Voltage: 12.40 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0005
Revision: --H11--- Serial number: 32901133002184
Coding: 108011
ASAM Dataset: EV_EPHVA14SKxxx0000 001001
ROD: EV_EPHVA14SKxxx0000_001.rod
VCID: B3265BE81A6207DC55-80E6
Part No SW: 3T0 959 655 C HW: 3T0 959 655 C
Component: J234__LA5 VW10 HI 1918
Revision: 21016000 Serial number: 003K2PQDPN8G
Coding: 0016693
VCID: C1CA012098DEA54CD7-8094
Subsystem 1 - Serial number: 6332MTS611583151
Subsystem 2 - Serial number: 6342MTS611623151
Subsystem 3 - Serial number: 6351HTS67JPP0AKR
Subsystem 4 - Serial number: 6361HTS6IVLF1AKJ
Subsystem 5 - Serial number: 63727TS62CDK0AKR
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Revision: FF010040 Serial number: 20111127200906
Coding: 008A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: F6A0A2FC499052F4B2-80A2
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 820000
Part No SW: 3T1 920 841 J HW: 3T1 920 841 J
Component: KOMBI H05 0607
Coding: 110F01
VCID: BA3876CC3D08F69496-80EE
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 011211F2001759
Coding: 353302
VCID: BA3876CC3508F69496-80EE
Component: IMMO H05 0607
VCID: EA98868C0D28861426-80BE
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 E HW: 8X0 959 793 E
Component: TSG FA H09 0410
Coding: 01110220D000001000
VCID: CFEE37189E8A433C51-809A
00109 - Left Mirror Turn Signal Lamp (L131)
Fault Status: 00101100
Reset counter: 41
Mileage: 96798 km
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 193 3301
Revision: 00H22000
VCID: B52265F0DC1619EC7B-80E0
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.3 V
PD
Temperature: 31.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 E HW: 8X0 959 792 E
Component: TSG BF H09 0410
VCID: CED02A1C99804A345A-809A
Reset counter: 2
Mileage: 96822 km
Component: AFS-Steuergeraet 0148
Coding: 1376839
VCID: B42458F4D76C00E44C-80E0
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0005
Coding: 00000021
Subsystem 2 - Part No: ID-R fehlt Labels: ID-55-02.CLB
Component: AFS-Lst.-Modul r ....
Coding: 00000255
8 Faults Found:
Fault Status: 11100100
Reset counter: 31
Mileage: 95359 km
Date: 2013.10.11
Time: 11:03:51
Voltage: 13.77 V
ABS 1
000 - - - MIL ON
Reset counter: 205
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Reset counter: 205
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Reset counter: 205
Invalid
Invalid
Invalid
Fault Status: 11100101
Reset counter: 205
Invalid
Invalid
Invalid
02631 - Voltage Supply for Swivel Module Position Sensor; Left
Fault Status: 00100110
Reset counter: 36
Mileage: 96612 km
Date: 2013.10.31
Time: 23:02:48
Voltage: 13.92 V
ABS 1
02233 - Left Headlight Power Output Stage (J667)
Fault Status: 00101110
Reset counter: 61
Mileage: 96895 km
Date: 2013.11.05
Time: 22:55:57
Voltage: 14.06 V
ABS 1
Reset counter: 61
Mileage: 96895 km
Date: 2013.11.05
Time: 22:55:57
Voltage: 14.06 V
ABS 1
Part No SW: 3T0 035 156 F HW: 3T0 035 156 F
Component: BOLERO 001 0008
Revision: -----08S Serial number: SKZ4Z3L1154492
Coding: 0D0004000004
VCID: B12A51E0E87E35CC27-80E4
Part No SW: 8X0 959 795 B HW: 8X0 959 795 B
Component: TSG HL H06 0409
Coding: 010000200000001000
Component: TSG HR H06 0409
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661366175
Coding: 0200000000010110
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: A71EBFB8DEBA7B7CF9-80F2
End----------(Elapsed Time: 01:18, VBatt start/end: 12.3V/12.3V)-----------
Reason: CODE tags
Some ECUs can not be re-coded. It would be good to check affiliation on the basis of the VIN number.
Post Thanks / Like - 3 Likes
I ran the VIN through PL24, it doesn't seem to imply specific ECM part number for manual VS automatic, so it might be possible. But honestly, I"d be a bit surprised if it does allow for it.... it has been my experience that most ECM part numbers are specific to trans applications.
Jef
Post Thanks / Like - 2 Likes
NostraJackAss
or
Gateway!
Certified Master Trained NY/BAR/BAD 7076062/ASE/SAE/NASTF Legal Factory Authorized/Licensed
GeKo/FaZit # 403738
www.FixMyEuro.com <<<<<CLICK HERE! or
vwemporium@aol.com ( JPPSG & Unverified members need not PM me & Please don't email or call facility for free tech support...use the forum )
