Results 1 to 9 of 9
Thread: 063 Error Not Available (Auto Trans) - MK5 Jetta (2.5L)
    Jun 2019
    California, USA
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWRZ71K99M0xxxxx   Mileage: 200150km-124367miles
    Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 M    HW: 07K 906 055 M
       Component: 2,5l R5/4V      G   9203
       Revision: G6H02---    Serial number: VWX7Z0HN2431AD
       Coding: 0000075
       VCID: 38292B354E583907321-806C
    Readiness: 0000 0100
       Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
       Component: AQ 250 6F           1377
       Revision: 00H76000    Serial number:
       Coding: 0000072
       VCID: 7DA7FA2121FADC2FA17-8028
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Revision: 00H45001
       Coding: 113B400D492A0000880E02E6921E00413000
       Shop #: WSC 36555 002 104857
       VCID: 7EA5FD2D20FCC737B8D-802A
                        Fault Status: 00100011
                        Reset counter: 100
                        Mileage: 200084 km
                        Count: 12800
                        Count: 83
                        Count: 50184
                        Reset counter: 100
                        Mileage: 200084 km
                        Count: 12800
                        Count: 67
                        Count: 50184
       Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
       Component: Climatic PQ35   142 1212
       Revision: 00142032    Serial number: 00000000000000
       VCID: 78A9EB350ED8F907F21-802C
       Revision: 00H54000    Serial number: 00000001126957
       Coding: 14058E234004100007140000001400000008730B5C000120000000000000
       Shop #: WSC 00066 123 12345
       VCID: 323D191DA824D3570C5-8066
       Component: Wischer 111108 021  0501
       Coding: 00038805
       Shop #: WSC 00066
                        Reset counter: 103
                        Mileage: 200087 km
                        Voltage: 10.50 V
       Revision: 00000000    Serial number: AUZ4Z7H0474413
       Coding: 0000100
       VCID: 33331C19573EDA5F073-8066
                        Fault Frequency: 9
                        Reset counter: 57
                        Mileage: 200012 km
                        Time: 23:05:21
       Revision: 05034000    Serial number: 003B6M07MLDJ
       Coding: 0013889
       VCID: 6C81C7654A8045A7069-8038
       Subsystem 2 - Serial number: 6332MSME41145001U
       Subsystem 3 - Serial number: 6342MSME3F645540E
       Subsystem 4 - Serial number: 6351HSME184928504
       Subsystem 5 - Serial number: 6361HSME184970478
       Subsystem 6 - Serial number: 63727SME19085068/
       Subsystem 7 - Serial number: 63827SME19084108Z
       Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
       Coding: 0010021
       VCID: 03538CD9471EAADFD73-8056
    00576 - Terminal 15
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    00885 - Ignition Switch (D) Terminal 50
       Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
       Component: KOMBIINSTRUMENT 3HL 1222
       Revision: V0003000    Serial number: VWX7Z0HN2431AD
       Coding: 0023203
       VCID: 3C2137257A601527D69-8068
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 220908F2000138
       Coding: ED807F070003021002
       Shop #: WSC 11111 123 12345
       VCID: 35372201594AC46F297-8060
       Component: IMMO            3HL 1222
       Revision: 72009005    Serial number: 00000766589028
       Coding: 0001205
       VCID: 6FBBD0697B96BEBF23B-803A
                        Fault Status: 01111000
                        Reset counter: 64
                        Mileage: 190135 km
    00105 - Signal Central Locking SAVE/LOCK Drivers Side
                        Reset counter: 64
                        Mileage: 190135 km
       Part No: 1K0 909 144 C
       Revision: 00H15000
       VCID: 2A0D017D80F49B97B45-807E
                        Fault Status: 00101101
                        Reset counter: 110
                        Mileage: 200084 km
                        Time: 17:17:05
                        Voltage: 14.00 V
                            DU
                        Temperature: 35.0C
                        RPM: 688 /min
                        Speed: 9.0 km/h
                        Speed: 9.0 km/h
       Coding: 13900F880186281B0904058FB0880F0488DCA0
       VCID: 04518FC54210ADE7EE9-8050
       Revision: 72009005    Serial number: 08100814090904
       Coding: 0001204
       VCID: 70B9D31566A8A1473A1-8024
       Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
       Component: MIB2-S-R-CN   036 0317
       Revision: -----001    Serial number: VWZ6Z2R7301947
       Coding: 1600040004000A
       Shop #: WSC 00081 790 00120
       VCID: 46D555CD38AC5FF7B0D-8012
    7 Faults Found:
    00856 - Radio Antenna
                        Fault Status: 00100111
                        Reset counter: 57
                        Mileage: 191377 km
                        Time: 07:30:31
    00532 - Supply Voltage B+
                        Reset counter: 45
                        Mileage: 15 km
                        Date: 2003.14.26
                        Time: 05:20:26
                        Reset counter: 45
                        Mileage: 14 km
                        Date: 2003.14.26
                        Time: 08:20:45
                        Fault Status: 00101011
                        Reset counter: 35
                        Mileage: 2 km
                        Date: 2000.14.00
                        Time: 02:16:09
                        Reset counter: 35
                        Mileage: 2 km
                        Date: 2000.14.00
                        Time: 02:16:09
                        Reset counter: 35
                        Mileage: 2 km
                        Date: 2000.14.00
                        Time: 02:16:09
                        Reset counter: 35
                        Mileage: 2 km
                        Date: 2000.14.00
                        Time: 02:16:09
       Revision: 12006001    Serial number: 00000003626568
       Coding: 0001168
       VCID: 76B5E50D04CC8F77E0D-8022
       Coding: 0100100
                        Reset counter: 3
                        Mileage: 199154 km
                        Time: 14:14:37
    00625 - Vehicle Speed Signal
                        Reset counter: 102
                        Mileage: 200087 km
                        Time: 11:22:28
       Revision: 12006001    Serial number: 00000003588487
       Coding: 0001168
       VCID: 77ABE80903C6F67FFBB-8022
    End----------(Elapsed Time: 01:22, VBatt start/end: 11.8V/12.2V)-----------
    So I have been have harsh shift problems from 2nd to 3rd gear in my 2009 VW Jetta 2.5L for about awhile when the car reached running temp. I decided to do a 09G Valve Body Solenoid Replacement, and ATF Fluid Change to resolve the issue. After doing the repairs and servicing the transmission, I took the car for a drive and notice the shifting smooth through all the gears, but 3rd going to 4th gear. There is a slight jump in rpms when it switches from 3rd to 4th gear. So I decided to grab my VCDS kit to perform a transmission adaptation and it gives me and error all the time.
    Does anyone know why I get an error when trying to perform Auto Trans 02 -
    063 Kick-Down Alignment (Automatic Transmission)?
    Hi and welcome.
    Please post the whole scan, not just the Installation List.
    Jun 2019
    California, USA
    Hello Uwe,
    I have posted the whole scan, is it correct now?
    - SoCalJR
    Administrator Andy's Avatar
    Sector 7G
    In this engine/transmission, the kickdown is done in 01-Engine:
    First, make sure there are no fault codes in the Auto Trans. Then, with the key in the on position, and engine OFF. Do not touch the accelerator pedal.
    [Select]
    [01 - Engine]
    [Basic Settings - 04]
    Set Group to "063"
    [Go!]
    Press accelerator pedal all the way to the floor and count out loud 3 seconds.
    [Done, Go Back]
    Release the accelerator pedal.
  6. Likes Jack@European_Parts liked this post
    Quote Originally Posted by jdreid View Post
    Hello Uwe,
    Yep!
    That transmission has a two-step basic settings process.
    Basic Settings in Group 001 resets the learned values for Kickdown/Tiptronic etc
    Basic Settings in Group 002 resets the learned values for Pressures and such.
    I'm not sure why you think Group 063 is involved in the transmission itself.
  8. Likes Jack@European_Parts liked this post
  9. #6
    It would be advised to correct this mist first, nein?
    00576 - Terminal 15
  10. #7
    Jun 2019
    California, USA
    Thank you for your help! I have done the procedure and it stated "System in Grundeinstellung". So I'm going to take it for a drive now, and see how it goes.
    - SoCalJR
  11. #8
                        Reset counter: 100
                        Mileage: 200084 km
                        Count: 12800
                        Count: 83
                        Count: 50184
                        Reset counter: 100
                        Mileage: 200084 km
                        Count: 12800
                        Count: 67
                        Count: 50184
    Please fix this first.
  12. Likes Jack@European_Parts, Uwe liked this post
  13. #9
    Jun 2019
    California, USA
    I have resolved that issue. It was due to me having the car in the air on jack stands while in drive.
