Results 1 to 4 of 4
Thread: Label File Request
    Dec 2016
    Ohio
    Label File Request
    I'm not sure if this is the correct forum to ask... but... I'm hoping to find a label file for my 5F Information Electronics module on my 2014 Q7 TDI.
    The others would be nice as well, but 5F is of most interest to me at this time.
    Attached is my auto-scan.
    Let me know if there's anything else I can do.
    Thanks,
    Craig
    Tuesday,16,October,2018,15:01:07:03033
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WA1LMAFE2ED007343   License Plate:
    Chassis Type: FE-AU56 (4F0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
              55 56 5F 62 6C 6D 6F 72
    VIN: WA1LMAFE2ED007343   Mileage: 274180km-170367miles
    Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
       Part No SW: 4L2 910 401 A    HW: 4L0 907 401 E
       Component: 3.0TDI FSA    H23 0012
       Revision: 54H23---    Serial number:
       Coding: 2A2A4012252600050000
       Shop #: WSC 41251 001 1048576
       ASAM Dataset: EV_ECM30TDI0114L2910401A 001013
       ROD: EV_ECM30TDI0114L2910401A.rod
       VCID: 221DE94F344F4C87A81-8076
    Readiness: 0 0 0 1 1
       Part No SW: 0C8 927 750 AQ    HW: 0C8 927 750 AQ
       Component: AL1000 AISIN  002 3399
       Coding: 001378
       Shop #: WSC 62412 002 1048576
       ASAM Dataset: EV_TCMAL991031 002115
       ROD: EV_TCMAL991031_002.rod
       VCID: 7BA3F42BF365DD4FCB7-802E
       Revision: 00H02001
       Coding: 0099441
       Shop #: WSC 31414 790 00001
       VCID: 34311F17923BD2374AD-8060
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0200
       Revision: 00H08000    Serial number: 10603702090715
       Coding: 0000135
       VCID: 2517F25329E1BBBFCD3-8070
       Component: FBSAUDIC6 EZS   H04 0020
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
       Revision: 00---031    Serial number: 00000000396507
       Coding: 0304A036
       VCID: 2517F25325E1BBBFCD3-8070
       Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
       Component: ILM Fahrer      H31 0400
       Coding: 0139123
       VCID: 6E85CD7FBC97B8E77C9-803A
       Component: Wischer AU716   H18 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
    Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
       Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0011
       Revision: 11001001    Serial number: 55961326700715
       Coding: 24011E
       ASAM Dataset: EV_EPHVA18AU7160000 001001
       ROD: EV_EPHVA18AU7160000.rod
       VCID: 34311F179EBBD2374AD-8060
    1113107 - Front Parking Aid Sensor(s)
              B10FC 13 [008] - Open Circuit
                        Reset counter: 200
                        Mileage: 274187 km
                        Date: 2018.10.16
                        Time: 14:57:26
    1113873 - Parking Aid Indicator Lamp
              B10FF 11 [008] - Short to Ground
                        Reset counter: 240
                        Mileage: 274187 km
                        Date: 2018.10.16
                        Time: 14:57:27
       Component: 73 AIRBAG AUDI8RH44 0230
       Revision: 08H44000    Serial number: 0038QD0CCHY$
       Coding: 0014131
       VCID: 2B03046B4F058DCF1B7-807E
       Subsystem 1 - Part No: 4L0 959 339 C
       Component: BF-Gewichtsens. H05 0040
       Subsystem 2 - Serial number: 6332QSME023A0D44B
       Subsystem 3 - Serial number: 6342QSME43411D64C
       Subsystem 4 - Serial number: 6352QSME2E3B334CT
       Subsystem 5 - Serial number: 6362QSME023A3D72I
       Subsystem 6 - Serial number: 63734SME1E3750783
       Subsystem 7 - Serial number: 63834SME6A6D295CM
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
       Component: J0527               0830
       Revision: 00H09000    Serial number: 90026131900581
       Coding: 0012242
       VCID: 2809FB675EF3A6D7F65-807C
       Component: E0221           H03 0040
       Part No SW: 4L0 920 985 Q    HW: 4L0 920 985 Q
       Component: KOMBIINSTR.   H35 0317
       Revision: 00000000    Serial number: VJ4227V9E
       Coding: 8BD664040100CF05020205
       VCID: 42DD49CFD48F6C87C81-8016
       Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0058
       Revision: MB700037    Serial number: 3700M1390806CD
       Coding: 00C303
       VCID: 3FDB403BA77D016FA7F-806A
       Component: J367-BDM  H07 0125
       Serial number: 40250L48254121956877
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
       Revision: 00---011    Serial number: 00000000395938
       Coding: 0000006
       VCID: 6889BB679E7366D7365-803C
       Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
       Component: MEM-FS        H08 0064
       Revision: AA000000    Serial number: 00000073514500
       Coding: 00581B00000011110000
       VCID: 323D190F642FDC07581-8066
       Component: J0769_SWA_MasterH02 0050
       Revision: 00H02000    Serial number: 6PZ 009 014-10
       VCID: 2E050D7F7C17F8E73C9-807A
       Component: J0770_SWA_Slave_H02 0050
       Subsystem 3 - Serial number: 5F26.09.1300H02000AMS15004˙
       Subsystem 4 - Serial number: S15004˙
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000077186101
       Coding: 011F57205E40440004
       VCID: 48C95BE7F2B346D7165-801C
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H12 0130
       Revision: 0130 ---    Serial number: 01938346700000
       Coding: 3569949
       VCID: 38292B278E533657665-806C
       Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
       Component: BOSE G3 Q7    H04 0160
       Revision: CH004001    Serial number: 00000000019314
       Coding: 030000
       VCID: 290FFE6349F99FDFE9B-807C
       Part No SW: 4F0 910 274 B    HW: 4F0 907 274
       Component: J793  RKA+      H04 0110
       Revision: 00000519    Serial number: 00005191022551
       Coding: 0758477
       VCID: 2313EC4B27D5458FA37-8076
       Component: ILM Beifahrer   H16 0100
       Revision:             Serial number: 00000000156899
       Coding: 0012001
       VCID: 5EE59DBF4C372867CC9-800A
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000077194928
       VCID: 47CB58DBFFAD49AF1FF-8012
       Serial number: 130926-0002-083
       Coding: 1147A71010020400
       ROD: EV_HeadlRegulBasic.rod
       VCID: 42DD49CFD40F6C87C81-8016
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156IE0D7909769
       Coding: 020007010000000000
       VCID: 2411EF572EDB42B7DAD-8070
       Part No SW: 4L2 035 746 D    HW: 4L2 035 746 D
       Component: H-BNT-NA      H40 0738
       Revision: --------    Serial number: 224H.0D7527209
       Coding: 180200060004E3EF510003456F632003140000000100000000
       Shop #: WSC 43665 000 1048576
       VCID: 2F3B107B771DF1EF37F-807A
       Subsystem 1 - Part No: 8R0 060 884 BD
       Component: NAR 2013/2014  0802
       Component: DU7 High  H42 0104
       Serial number: A130IV0D2836505
       Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
       Component: E0380 Bedient  H01 0060
       Serial number: 00000002138088
       Component: CD-Database  5298
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000077198583
       Coding: 010E57204040230004
       VCID: 46D555DFF8A750A7E49-8012
       Revision: --H08---    Serial number: 525PA8-J3940GH
       Coding: 1021201
       Part No SW: 4L0 910 945     HW: 4L0 827 851 E
       Component: ValeoHeckdeckel H57 0500
       Revision: --H57001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6C81C7778A8B4AF752D-8038
       Subsystem 2 - Serial number:  +
    ó
       Subsystem 3 - Serial number: RD27.09.13--H57001002F0420˙
       Subsystem 4 - Serial number: 2F0420˙
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 0076596984----
       Coding: 0003595
       VCID: 2615F55F54E7B0A7C49-8072
       Component: J_245_EE16_SKB10H14 0220
       Component: J_394_EE16_SKB10H14 0220
       Component: J_392_EE16_SKB10H14 0220
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000077198630
                        Reset counter: 200
                        Mileage: 274187 km
                        Date: 2018.10.16
                        Time: 14:54:36
    End----------(Elapsed Time: 02:03, VBatt start/end: 13.5V/14.3V)-----------
  2. Likes Dana liked this post
  3. #2
    United States
    Hi Craig,
    We received your maps. I'll reply to that e-mail with a file providing I can redirect 5F for you.
    P.S. I think Uwe was replying to https://forums.ross-tech.com/showthr...-Camera-Coding
  4. Likes craigldavis liked this post
  5. #3
    Dang it, I got the two threads mixed up.
    I can fix that though!
  6. Likes Dana liked this post
  7. #4
    United States
    I was able to redirect that 5F easily and sent you a 4L-5F.clb file.
  8. Likes Uwe, craigldavis liked this post
