Results 1 to 10 of 19
Thread: Help ABS Basic Settings Audi Q3 8U 4WD. 1.9 Tdi 135Kw
    Oct 2017
    Italy
    Hello. I had to disassemble the rear brake calipers and after having reassembled them I carried out a scan with the vdcs and I get the following errors on block 03 ABS:
    Wednesday,26,June,2019,22:55:17:54661
    VCDS Version: Release 19.6.0 (x64) Running on Windows 10 x64
    Address 03: ABS Brakes Labels: 5N0-614-109-V1.clb
    Control Module Part Number: 5N0 614 109 CF HW: 5N0 614 109 CF
    Component and/or Version: ESC-EBC460iV1 H10 0013
    Software Coding: 22F124A14928E3702077440724C792C704365700508B4885
    Work Shop Code: WSC 12345 123 12345
    ASAM Dataset: EV_Brake1ESCEPBTRW 006353 (AU21)
    ROD: EV_Brake1ESCEPBTRW_006.rod
    VCID: 71C6878AA07C9FC76A-8024
    0383 - Brake Pressure Sensor 1
    C107A 54 [137] - Missing Calibration / Basic Setting
    0360 - Steering angle sensor
    0522 - Inertial Sensor Package
    C115E 54 [137] - Missing Calibration / Basic Setting
    0559 - No Basic Setting
    B2010 00 [137] - -
    Reset counter: 149
    Mileage: 65339 km
    Date: 2019.06.26
    Time: 22:07:36
    Additional_Codes: 00 00 00 0D 7D 1E 00 4A 0A
    DTC: 00 02 2F
    Additional2: 01 04 01 07 05 00 1C 00 1C 00
    can anyone tell me how to recalibrate and eliminate these errors?
    Thanks a lot!
    Oct 2017
    Italy
    this is my full scan of the different modules:
    Wednesday,26,June,2019,22:01:10:54661
    VCDS Version: 19.6.0.6 (x64)
    VIN: WAUZZZ8U2GR084074   License Plate:
    Chassis Type: 8U-AU21 (8U0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 25 2B 42 44 46 52 55 56
              57 5F 62 6C 6D 72
    VIN: WAUZZZ8U2GR084074   Mileage: 65330km-40594miles
    Address 01: Engine (J623-DFUA)       Labels: None
       Part No SW: 04L 906 016 FL    HW: 04L 907 309 AB
       Component: R4 2.0l TDI   H20 3201
       Revision: 8EH20---
       Coding: 02250012042601083000
       Shop #: WSC 50982 001 1048576
       ASAM Dataset: EV_ECM20TDI01104L906016FL 004003
       ROD: EV_ECM20TDI011_AU21.rod
       VCID: 78D0BAAEC306CE8FAD-802C
    4815 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [167] - -
                        Mileage: 65339 km
                        Date: 2019.06.26
                        Time: 21:43:50
                        Engine speed: 999.00 /min
                        Normed load value: 25.5 %
                        Coolant temperature: 86 °C
                        Intake air temperature: 71 °C
                        Voltage terminal 30: 13.340 V
                        Requested transmission torque: 1000.0 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 7
                        selected gear-Bits 0-7: 0
                        Transmission torque intervention status-Bits 0-7: 80
                        Transmission torque intervention status-Bits 0-7: 0
                        Calculated reducing transmission intervention torque: 1000.0 Nm
    14413 - Implausible Data Received from ABS Control Module
              U0415 00 [039] - -
                        Mileage: 65339 km
                        Date: 2019.06.26
                        Time: 21:43:50
    5250 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
                        Mileage: 65339 km
                        Date: 2019.06.26
                        Time: 21:43:50
                        Longitudinal acceleration: raw value: 32.767 m/s²
                        Vehicle inclination acceleration angle: raw value: -0.001 m/s²
                        Status: incline angle-Bits 0-7: 0
                        Longitudinal acceleration: 0.000 m/s²
                        Longitudinal acceleration sensor: status-Bits 0-7: 1
                        Vehicle lateral acceleration: raw value: 327.67 g
                        Vehicle lateral acceleration: 0.00 g
       Part No SW: 0BH 300 012 Q    HW: 0BH 927 711 G
       Component: DSG DQ500-7A  H11 5206
       Revision: 00H11V01
       VCID: 3146478A60FCDFC72A-8064
    Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
       Part No SW: 5N0 614 109 CF    HW: 5N0 614 109 CF
       Component: ESC-EBC460iV1 H10 0013
       Serial number: A013316
              B2010 00 [137] - -
                        Reset counter: 149
                        Mileage: 65339 km
                        Date: 2019.06.26
                        Time: 21:45:35
                        Additional_Codes: 00 00 00 0D 6E 1E 00 4A 0A
                        DTC: 00 02 2F
                        Additional2: 01 04 01 07 05 00 2C 00 2C 00
       Revision: 00092000    Serial number: 0392607153
       Coding: 030C0C
       ROD: EV_KESSYPQ35G_A02_VW32.rod
       VCID: 375279928E9801F764-8062
       Part No SW: 8U0 820 043 F    HW: 8U0 820 043 F
       Component: E87  Klimavoll      0210
       Revision: 00H05000    Serial number: 8U0820043F
       VCID: 34484E9E57EEEAEF41-8060
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 AB    HW: 8X0 907 063 AB
       Component: BCM PQ35  M   113 0817
       Revision: AC113817
       Coding: 46000A2FE837F3C4241849C1218401CC53F327AA217F81FBE400879CE0C5
       Shop #: WSC 00049 070 00112
       VCID: 7CD8A6BEFF3EE2AFC9-8028
       Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS316 160113  H38 0090
       Serial number:         160124054245
       Coding: 0047F7
       Serial number: 61217126
       Coding: 02006E
       Subsystem 3 - Part No: 8X0 951 177 A
       Component: Sensor, DWA 0  005 0002
    Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
       Part No SW: 8X0 919 475 AD    HW: 4H0 919 475 AG
       Component: PARKHILFE 8K  H01 0070
       Revision: 11001001    Serial number: 61031602305174
       Coding: A8C304
       ASAM Dataset: EV_EPHVA18AU21X0000 003008
       ROD: EV_EPHVA18AU21X0000_003.rod
       VCID: 0830CA6EB3E6BE0FDD-805C
    13637396 - Databus
                        Reset counter: 189
                        Mileage: 65339 km
                        Date: 2019.06.26
                        Time: 19:54:28
    13637397 - Databus
                        Reset counter: 189
                        Mileage: 65339 km
                        Date: 2019.06.26
                        Time: 19:54:28
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8U0 959 655 D    HW: 8U0 959 655 D
       Component: AirbagVW-AU10 H10 0910
       Serial number: 003S0R0DR5L
       Coding: 304D3232333030303030554A304C38553053
       Shop #: WSC 00049 770 00117
       ASAM Dataset: EV_AirbaAU10SMEAU316 001010
       ROD: EV_AirbaAU10SMEAU316_001.rod
       VCID: 48B00A6EF3667E0F1D-801C
       Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3496KSME3D637F3BZZZE
       Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3506KSME0D266A3BZZZ$
       Serial number: 3516KSME1F19753BZZZ+
       Serial number: 3526KSME184C093CZZZ$
       Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
       Serial number: 3555USME367C503BZZZ6
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 501 H    HW: 5K0 953 569 AP
       Revision: FF010018    Serial number: 20160128300766
       Coding: 1114204000
       VCID: 3FA211B2A6A839B7AC-806A
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Serial number: 28 10 2015  A0075262
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8U0 920 940 H    HW: 8U0 920 940 H
       Component: KOMBI_COLOUR  H02 0380
       Coding: 12CF01
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
       VCID: 3D5E6BBAACA42BA7BE-8068
    16776988 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 189
                        Mileage: 65339 km
                        Date: 2019.06.26
                        Time: 19:29:04
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 AS    HW: 8U0 907 468 J
       Component: GAT 4CAN 2L M H13 0090
       Revision: 1R160041    Serial number: 4141R161150156
       Coding: FBCF1A5A050B0D610253
       VCID: 130AED02F2A00DD738-8046
       Subsystem 1 - Part No SW: 8U0 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS11.403  H03 0004
       Serial number: 0000FST000R9WC800000
       Coding: 901E00
       Subsystem 2 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0180
       Serial number: 43026528291491452594
       Subsystem 3 - Part No SW: 8U0 959 591 A    HW: 8V3 959 591 A
       Component: J394 PS11.403  H03 0004
       Serial number: 0000FST000R9W0W00000
       Coding: 801E00
       Subsystem 4 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
       Serial number: 15102100000000000043
       Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7540
       Serial number: HA1-00004.01.16
       Coding: 0001
       Shop #: WSC 00049 770 00152
       VCID: 52842806053AC4DF73-8006
    16656 - Databus
                        Fault Frequency: 7
                        Reset counter: 189
                        Mileage: 65339 km
                        Date: 2019.06.26
                        Time: 19:28:58
       Component: IMMO          H02 0380
       Coding: 000007
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
       ROD: EV_Immo_UDS_VDD_AU10.rod
       Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
       Component: ELV-PQ35      H22 0240
       Revision: 00000000    Serial number: 16000011137002
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Component: TSG FA        H11 0415
       Coding: 011E12205C00000000
       VCID: 528428060D3AC4DF73-8006
       Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.377 1401
       Revision: 1BH04841    Serial number: 00160050059101
       Coding: 0000258
       VCID: 41A6174A185C4F47DA-8014
                        Fault Status: 00101101
                        Fault Frequency: 7
                        Reset counter: 189
                        Mileage: 65339 km
                        Date: 2019.06.26
                        Time: 19:31:29
                        RPM: 1000 /min
                        (no units): 7.0
                        Voltage: 14.20 V
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Component: TSG BF        H11 0415
       Coding: 011E12201E00000000
       VCID: 5186270A083CBFC74A-8004
    Address 55: Headlight Range (J745)       Labels:| 5M0-907-357-V3.clb
       Part No SW: 5M0 907 357 G    HW: 7P6 907 357 B
       Component: AFS-ECU       H01 0031
       Coding: 08AA00102B230200
       ASAM Dataset: EV_HeadlRegulLEDAFSPt 001001
       ROD: EV_HeadlRegulLEDAFSPt.rod
       VCID: 38507AAE83860E8F6D-806C
       Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0003
       Coding: E02500
       Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0003
       Coding: E02500
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 7050
       Coding: E02500
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 7050
       Coding: E02500
    13705985 - Databus
                        Reset counter: 189
                        Mileage: 65339 km
                        Date: 2019.06.26
                        Time: 19:28:59
    13705987 - Databus
                        Reset counter: 189
                        Mileage: 65339 km
                        Date: 2019.06.26
                        Time: 19:28:59
       Part No SW: 4G0 035 061 S    HW: 4G0 035 061
       Component: Radio U DAB   H60 0154
       Revision: AB001007    Serial number: 109A.0G2526568
       Coding: 010105020100000002
       VCID: 2D7E5BFA74C4BB270E-8078
    Address 57: TV Tuner (R78)       Labels: None
       Part No SW: 4G0 919 129 C    HW: 4G0 919 129
       Component: NGTV-DVB      H04 0690
       Revision: R0043000    Serial number: 06801302079401
       Coding: 02000000
       Part No SW: 8U1 035 670 C    HW: 8U1 035 670
       Component: H-BNT-EU      H41 1034
       Revision: --------    Serial number: 486A00H7523239
       Coding: 0E010006000AE1EB0580033600000001000000000000000000
       VCID: 364C74968192F8FF7F-8062
       Subsystem 1 - Part No: 8R0 060 884 FK
       Component: EUR 2018/2019  2702
       Subsystem 2 - Part No SW: 8U0 919 604 A    HW: 8U0 919 604 A
       Component: DU High AU316  H43 0018
       Serial number: AUZ8ZDFCR00FJ37
       Subsystem 3 - Part No: 8R0 060 961 G
       Component: CD-Database  6890
                        Reset counter: 83
                        Mileage: 61530 km
                        Date: 2019.04.26
                        Time: 15:39:09
                        Text: DUA101,Front,M,0,0,6
                        Fault Frequency: 11
                        Reset counter: 189
                        Mileage: 65339 km
                        Date: 2019.06.26
                        Time: 21:33:34
                        Bin. Bits: 00000000 10000000
                        Bin. Bits: 00000000 00000000
    01524 - Antenna for Telephone
                        Reset counter: 83
                        Mileage: 61530 km
                        Date: 2019.04.26
                        Time: 15:39:18
                        Voltage: 14.20 V
    03623 - Invalid Security/Release Code
                        Reset counter: 83
                        Mileage: 61530 km
                        Date: 2019.04.26
                        Time: 15:39:08
                        Hex Value: 0x0004
                        Hex Value: 0x0009
                        Count: 7
       Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
       Component: TSG HL        H08 0415
       Coding: 010E12200000000000
       VCID: 4F8221721E08A9375C-801A
       Part No SW: 8U0 907 441     HW: 8U0 907 441
       Component: SG Rueckfahrkamera  0031
       Revision: --H11---    Serial number: 525 PA8JAZH15Z
       Coding: 1080015
       Shop #: WSC 02391 785 00013
       VCID: 76CCB4960112B8FFBF-8022
       Part No SW: 8U0 959 107     HW: 8U0 959 107
       Component: HDSG-Modul    H01 0549
       Revision: 15001001    Serial number: 011600882
       Coding: 183307C022
       ASAM Dataset: EV_HDSGAU316 001001
       ROD: EV_HDSGAU316.rod
       VCID: 7CD8A6BEF73EE2AFC9-8028
       Component: TSG HR        H08 0415
    End-------------------------(Elapsed Time: 03:37)-------------------------
    I pray that someone can help me understand what I have to do! Such a thing has never happened to me in 10 years !!
    Oct 2017
    Italy
    I basically reset the ABS Module by mistake with the VCDS:
    this is the VCDS message link:
    https://www.amazon.it/photos/share/0...braTmaLFWkc35Z.
    Can anyone tell me if I can solve with VCDS Thanks.
    Quote Originally Posted by walterc View Post
    238/5000
    No, not with VCDS. That's why the warning is there!
    Oct 2017
    Italy
    Restore Module ABS for VCDS Audi Q3 135Kw
    B2010 00 [137] - -
    Reset counter: 149
    Mileage: 65339 km
    Date: 2019.06.26
    Time: 22:07:36
    DTC: 00 02 2F
    Thanks a lot!
    Threads merged. Please do not start duplicate threads for the same question/problem in the same car.
  7. #7
    Oct 2017
    Italy
    Sorry:Grazie:
  8. #8
    Oct 2017
    Italy
    It is compulsory to bring the car in an Audi dealership or it is possible to use some other tool to re-align the ABS control unit with the others, especially even the engine that remains in error.
  9. #9
    What is the current state of the ABS module?
  10. Likes Dana liked this post
  11. #10
    United States
    We haven't received feedback specific to one of those ESC-EBC460iV1 after Resetting of all adaptations was selected but I would try running Basic Settings such as:
    [*IDE03650*] Basic setting for brake pressure sensor with your foot OFF of the pedal, meaning pedal at rest.
    [*MAS00815*] Steering angle sensor with the steering wheel perfectly straight.
    [*IDE05146*] Basic setting of ESP sensor unit with the vehicle on level ground.
    You may need to use SA code 40168 each time.
    Posing the scan after running those self-tests, starting the engine and holding the steering wheel at each end-stop for 10 + seconds and clearing faults would help us determine the current condition of the car.
  12. Likes Uwe liked this post
