Results 1 to 6 of 6
Thread: Limp mode overboost intermintant
    Jun 2019
    Missouri, USA
    Wednesday,26,June,2019,18:38:52:53135
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
    Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
    VIN: 3VWCP21C72M401376   Mileage: 359800km-223569miles
    Address 01: Engine        Labels:
       VCID: 55F780BC5C0DAE5FC97-FFFE
       Part No: 6Q0 909 605 A
       Component: 25 AIRBAG VW5  0E   0006
       Coding: 12853
       Shop #: WSC 00066
       VCID: 3537203CFC5D8E5F297-4B3C
    Address 17: Instruments        Labels: 1C0-920-x4x.lbl
       Part No: 1C0 920 921 B
       Component: KOMBI+WEGFAHRS. M73 V07
       Coding: 03232
       Shop #: WSC 07431
       VCID: 1D67D89C64AD361FC17-4B1E
       3VWCP21C72M401376     VWZ5Z0Z5031104
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V072
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70B9D128C3BFEB773A1-4B1E
       Part No: 1C0 959 799 G
       Component: 2K Komfortgerát HLO 0004
       Coding: 00064
       Shop #: WSC 00066
       VCID: 3B233604DA79582FDF3-4B1E
       Subsystem 1 - Part No: 1C2959802A
       Component: 2K Tőrsteuer.FS KLO 0202
       Subsystem 2 - Part No: 1C2959801A
       Component: 2K Tőrsteuer.BF KLO 0002
                80-00 - Single-Wire Operation
    Address 56: Radio        Labels: 1J0-035-18x-56.lbl
       Part No: 1C0 035 157 D
       Component:  Radio DE2         0006
       Coding: 06031
       VCID: 1D67D89C64AD361FC17-51CE
    00856 - Radio Antenna
                35-00 - -
    End----------(Elapsed Time: 03:53, VBatt start/end: 13.9V/13.8V)-----------
    I repaired a hole in the side of the tube running to the intercooler and now at highway speeds I feel the limp mode start about 3000 RPM. I can cycle the key and get normal power again until I reach 3000 and it engages limp again. I do not have the problem at lower speeds only highway. I have used VAG COM to make sure the N75 is functioning correctly. I have replaced the vacuum lines one at a time to make sure I didn't route them incorrectly. I checked the travel of the actuator and have full travel and the rod moves freely. I have screen shots of the graph while driving when limp mode starts and the boost is stuck at 92.4% on the graph.
    Dec 2016
    Amsterdam
    Limp mode means some sort of fault was logged. However, i see none in your scan. And im not a big fan of guessing games...
    Current:
    Jun 2019
    Missouri, USA
    Previous to this scan I had an intermittent overboost code show. I cleared the codes after checking the N75 valve. The code didn’t show again but I experienced and sudden loss of boost and power at 3000 RPM that returned when I turned the key off and restarted the engine. I understood that sequence to be limp mode, maybe I misunderstood. I am new to this issue.
    Nov 2015
    Your autoscan appears to be incomplete. Controller 1 (engine) is part present, and a few others after are missing.
  5. Likes Uwe liked this post
    Jun 2019
    Missouri, USA
    I will drive it like a bat out of hell today on my way to work and get some codes generated so I can repost the scan. Each time I scan the car it show partial information on different controllers I never know what I am going to get information wise with this thing.
    Jun 2019
    Missouri, USA
    Here is the full code list after driving 22 miles. I am not sure why the engine controller didn't show the codes on the earlier scan but it didn't. The MAF code came from driving the vehicle with the MAF unplugged to check and see if I had a MAF sensor going bad. The vehicle had considerably less power from 0-60 then it did with it plugged in. I assume the MAF is functioning correctly. so here is the newest scan. Any insight would be greatly appreciated.
    Thursday,27,June,2019,07:24:13:53135
    VIN: 3VWCP21C72M401376   License Plate:
    VIN: 3VWCP21C72M401376   Mileage: 359850km-223600miles
    Address 01: Engine        Labels: 038-906-012-AGR.clb
       Part No: 038 906 012 FF
       Component: 1,9l R4 EDC G400SG  4104
       Coding: 00002
       Shop #: WSC 03078
       VCID: 59EF8C8C30058A3FEDF-4B1E
    16618 - Boost Pressure Regulation
                P0234 - 35-10 - Limit Exceeded (Overboost Condition) - Intermittent
    16486 - Mass Air Flow Sensor (G70)
                P0102 - 35-10 - Signal too Low - Intermittent
    Readiness: 1 2 0 0 0
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
       Part No: 1C0 907 379 J
       Component: ABS FRONT MK60      0103
       Coding: 0004097
       Shop #: WSC 04042 551 00000
       VCID: 313F142C0D35A27F75F-5160
       Coding: 12853
       Shop #: WSC 00066
       Coding: 03232
       Shop #: WSC 07431
       Coding: 00006
       Shop #: WSC 00066
       Coding: 00064
       Shop #: WSC 00066
       VCID: 3B233604DA79582FDF3-4B00
       Coding: 06031
                35-00 - -
    End----(Elapsed Time: 03:43, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
