Results 1 to 10 of 10
Thread: Motor for intake manifold flap V157
    Mar 2017
    I have got an Audi A6 2008 and there is an issue with motor for intake manifold flap V157,as soon as I turn the ignition key on there is constant sound from it (is it normal) also engine management light was on I have cleared it and it looks ok for now but I am worried it comes sooner or later back on,
    Also before I cleared the fault the turning the engine was rough I am assuming it was because the flap is for shutting the engine off too,
    Please see the full scan below,
    Saturday,22,June,2019,15:34:57:05172
    VCDS Version: 18.9.1.0  HEX-NET CB: 0.4436.4
    VIN: WAUZZZ4F26N186455   License Plate: MA227DN
    Mileage: 304099   Repair Order: Matej
    Chassis Type: 4F (4F0)
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61 62
              72 76 77
    VIN: WAUZZZ4F26N186455   Mileage: 304090km-188952miles
    Address 01: Engine        Labels: 03G-906-016-BLB.clb
       Part No SW: 03G 906 016 HQ    HW: 028 101 255 5
       Component: R4 2,0L EDC G000SG  9672
       Revision: --H02---    Serial number:
       Coding: 0000072
       Shop #: WSC 66565 257 00032
       VCID: 79BA30A830CD66829A-802C
    012547 - Motor for Intake Manifold Flap (V157)
                   P3103 - 000 - Malfunction - Intermittent
                        Fault Frequency: 115
                        Mileage: 302638 km
                        Date: 2019.05.12
                        Time: 06:05:16
                        RPM: 945 /min
                        Voltage: 11.40 V
                        Bin. Bits: 00101000
                        Torque: 158.6 Nm
                        Torque: 0.0 Nm
    Readiness: 1 1 0 0 0
       Part No SW: 4F0 910 517 K    HW: 4F0 614 517 K
       Component: ESP 8.0 front   H05 0090
       Coding: 0020855
       Shop #: WSC 02325 785 00200
       VCID: 2C14D9FC8F1F032A51-8078
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601000411823
       Shop #: WSC 03972 202 82422
       VCID: 638672C0A2418C52A0-8036
       Subsystem 1 - Part No: 4F0 910 131 D
       Component: FBSAUDIC6 IDG   H39 0040
    Address 07: Control Head        Labels: Redir Fail!
       Part No SW: 4F0 910 769 A    HW: 4F0 035 769 A
       Component: MMI Cockpit     H35 0010
       Revision: C51100DE    Serial number: AUZ6Z3F4M43211
       Coding: 0004106
       Shop #: WSC 02323 785 00200
       VCID: 2B16DAE08A11041258-807E
       Component: Bedienteil MMIC6H08 0050
       Subsystem 2 - Serial number: 00000000400377
       Subsystem 3 - Serial number: 0126.04.060000000100010081ÿ
       Subsystem 4 - Serial number: 010081ÿ
       Part No SW: 4F0 910 043     HW: 4F1 820 043 R
       Component: KLIMABETAETIGUNGH12 0170
       Revision: 00000030    Serial number: 00000030118703
       VCID: 5BF64A209A31B492E8-800E
       Part No SW: 4F0 910 279 E    HW: 4F0 907 279 B
       Component: ILM Fahrer      H15 0190
       Coding: 0000101
       Shop #: WSC 02335 785 00200
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Component: REGENLICHTSENSORH12 0090
       Coding: 00141886
       Shop #: WSC 02335
    Address 0E: Media Player 1        Labels: Redir Fail!
       Coding: 0004106
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 42 AIRBAG AUDI8RH29 0280
       Revision: 08H29000    Serial number: 0037LD0E9PNT
       Coding: 0013362
       VCID: 291A20E880ED1602AA-807C
       Subsystem 1 - Serial number: 6332CSME0E3A3B6DL
       Subsystem 2 - Serial number: 6342CSME0F3E6046A
       Subsystem 3 - Serial number: 6352QSME0E113429B
       Subsystem 4 - Serial number: 6362QSME0E361D7F.
       Subsystem 5 - Serial number: 63734SME0D024B27/
       Subsystem 6 - Serial number: 63834SME09785209%
    00532 - Supply Voltage B+
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90054061050069
       Coding: 0002021
       VCID: 66806BD45173F97A47-8032
       Part No SW: 4F0 910 900 A    HW: 4F0 920 900 N
       Component: KOMBIINSTR. M73 H12 0660
       Revision: 00100000    Serial number: 4R519EK46
       Coding: 0262143
       Shop #: WSC 00001 001 00001
       VCID: 1E700334C9A3E1BACF-804A
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 13008064088006
       Coding: ECEE53C41B1104
       Shop #: WSC 02334 785 00200
       VCID: 271E26D096F92072BC-8072
       Part No SW: 4F0 910 793 F    HW: 4F0 959 793 F
       Component: TSG FA          H21 0050
       Coding: 0000522
       Shop #: WSC 02327 785 00200
       VCID: 2D12D4F8B4050A2246-8078
       Component: Komfortgeraet   H22 0170
       Revision: 01700022    Serial number: 01012693560000
       Coding: 0000241
       VCID: 2E10D3F4B903713A7F-807A
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 224
                        Mileage: 252545 km
                        Date: 2016.05.14
                        Time: 11:16:16
    02736 - Bulb for Tail/Fog Light; Left
                        Reset counter: 223
                        Mileage: 259571 km
                        Date: 2016.09.02
                        Time: 05:51:29
    Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
       Part No SW: 4F0 910 223 C    HW: 4F0 035 223
       Component: Amp.-ASK        H10 0320
       Revision: 35S00001    Serial number: 02404060262335
       Coding: 0000008
       Revision:             Serial number: 00000000225458
       Coding: 0001104
       VCID: 5EF043348923A1BA8F-800A
       Part No SW: 4F0 910 792 F    HW: 4F0 959 792 F
       Component: TSG BF          H21 0050
       Coding: 0000522
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
       Component: EPB  CDEC0080   H04 0080
       Revision: --H04---
       Coding: 0000111
       VCID: 200C3DCCF3D7D74AFD-8074
    Address 56: Radio        Labels: Redir Fail!
       Coding: 0004106
       Revision: 00000000    Serial number: 00000000019267
       Shop #: WSC 03972 202 07051
       VCID: 230632C0E2C1CC52E0-8076
       Subsystem 1 - Part No: 4F0 915 105 C
       Component: von VA0  1604100989
       Coding: 344630393135313035432056413031363034313030393839
       Shop #: WSC 00000 384 00290
    02272 - Quiescent Current Stage 1
                000 -  -  - Intermittent
                        Fault Frequency: 48
                        Mileage: 259571 km
                        Date: 2016.09.01
                        Time: 09:06:25
                        Fault Frequency: 14
                        Mileage: 259571 km
                        Date: 2016.09.01
                        Time: 09:09:51
    02274 - Quiescent Current Stage 3
                        Mileage: 301664 km
                        Date: 2019.04.11
                        Time: 08:49:05
                        Mileage: 301664 km
                        Date: 2019.04.11
                        Time: 08:49:15
       Part No SW: 4F0 910 795 F    HW: 4F0 959 795 F
       VCID: 2F2ECEF0BE09783274-807A
       Part No SW: 4F0 910 795 F    HW: 4F0 959 794 F
       Part No SW: 4F0 910 283 D    HW: 4F0 919 283 D
       Component: Parkhilfe 4-Kan H09 0020
       Revision: 00H09000    Serial number: 11720610903683
       Coding: 0000006
       VCID: 25022CD8ECF532628E-8070
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H16 1130
       Revision: 00000000    Serial number: 00000007641851
       Coding: 0020920
       Shop #: WSC 01062 202 93172
    End----(Elapsed Time: 01:35, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    Jun 2014
    Poland
    typical issue with that v157
    It help to shut off engine smooth
    during ign ON , it do some test ,
    you can remove it from ECU software, but better to fix it
  3. Likes Uwe, Jack@European_Parts liked this post
    Mar 2017
    Should I replace the whole unit?
    Jun 2014
    Poland
    Quote Originally Posted by Milan View Post
    well,, you can open your faulty first and look inside
    99% issue is damage gear in 0 position, and then can not move , do self test ... even if no need to use it, ECU must do some test of that
  6. Likes Milan liked this post
    Mar 2017
    And do I have to do some settings after cleaning or replacing it?
    Jun 2014
    Poland
    No, just replace,
    use proper tools ..... use proper parts.
    and of story
  9. Likes Uwe liked this post
  10. #7
    Mar 2017
    Ok I am going to replace it,
    There is also problem when I accelerate in first gear it feels like there is no power hope it is going to fix it,
    In any other gears there is power as it suppost to be,
  11. #8
  12. #9
    Mar 2017
    I have replaced the Motor for intake manifold flap V157 (fault P3103) and air flow meter but unfortunately there is no change regarding the power in the first gear however he has done about 500 km since and there are not fault codes at all now ,
    Could it be intale manifold flap position sensor even though there are not fault codes at all,
    Every help is very much appreciared,
    Milan
  13. #10
    Sounds like not getting codes due to FOD modified code in ECU or car could be carbon restricted.
    In some cases a MAF can be bad out of box and as a result cause a power loss with no DTC's.
