- Joined
- Jan 16, 2017
- Messages
- 5
- Reaction score
- 11
- Location
- Bethlehem, PA
- VCDS Serial number
- C?ID=42162
I have a 2003 Eurovan that has been sitting for 6 months. It had a dead battery and I installed a new one. Fired it up and the Check Engine light is flashing intermittently, the ABS and TC lights are on, oil pressure light is on, no transmission indicator and the tach was sort of working but after a minute, it quit. I scanned it and came up with this:
After spending the day, unhooking each item one at a time and scanning, I was still getting oddball errors. Finally I was going to start checking the CAN wiring and see if there's a problem. I knew the colors of the CAN and that they are twisted pairs. I started by pulling the fuse panel down. I found a bridge that was plugged in to the right of relay 18. It had four twisted pairs plugged into it and I figured they were the four different items (ECU, TCU, ABS, Instrument Cluster) that are for the CAN. I unplugged them and one had green corrosion on it. Cleaned all of them (just to be safe) plugged them back in and everything went back to normal. The plug with the corrosion was the one that went to the instrument cluster.
Previously, I found that the G201 brake pressure sensor was throwing a code. On the Eurovan, that sensor is mounted on the precharge pump and the same as on a e46 BMW IX model (they use a Bosch ABS system). It was not the sensor, that wire is in the perfect spot for mice to chew through, thus they did.
Many people do not cover Eurovans, so this is just put here because inevitably, it's going to happen to someone else down the road. I've already read some things that sound similar but they were a few years old and never resolved. Typically the responses were "You got to replace the (insert part name here)."
Tuesday,25,June,2019,09:55:54:65315
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4437.4
Note: All modules plugged in
VIN: License Plate: BR-549
Chassis Type: 70 (7D - VW Transporter/Multivan (1996 > 2004))
Scan: 01 02 03 08 15 17 18 19 22 25 35 37 56
VIN: Mileage: 221610km-137702miles
Address 01: Engine Labels: 022-906-032-AXK.lbl
Part No: 022 906 032 AF
Component: MOTRONIC ME7.1 G01 0003
Coding: 00013
Shop #: WSC 02757
VCID: 4FEEA2388F220F3214-51CE
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
18058 - Powertrain Data Bus
P1650 - 35-00 - Missing Message from Instrument Cluster
Readiness: 0110 1101
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 603 CK
Component: AIRBAG VW3 - V04
Coding: 17227
Shop #: WSC 02757
VCID: 74A40DD446440CEAC9-4B7A
32-00 - Resistance Too High
Address 17: Instruments Labels: 7D0-920-xxx-17.lbl
Part No: 7D0 920 902 T
Component: T4-KOMBIINSTR. VDO V01
Coding: 02435
Shop #: WSC 02757
VCID: 3522F0D00DBE55E23E-5160
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00003
Shop #: WSC 02757
VCID: 70AC01C4325C30CA2D-5160
Address 25: Immobilizer Labels: 6X0-953-257.lbl
Part No: 6X0 953 257
Component: IMMO 0008
Coding: 00001
VCID: 7DB228F0750E4DA2B6-4B00
WV2NB47043H006579 VWZ1Z0B2085499
Address 35: Centr. Locks Labels: 7D0-959-800.lbl
Part No: 7D0 959 800 C
Component: Funksteuergerát 0001
Coding: 00001
Shop #: WSC 02757
VCID: 2D12D8B0E5EE1D2246-4B1E
End----(Elapsed Time: 02:21, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
