Bad replace of ABS pump Passat B6
koket
Romania
C?ID=327557
Hi guys, today I've done a s**t job, i've replaced without to check before ABS pump on an Passat b6.
Problem is the original pump code is
Address 03: ABS Brakes
Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 109 A    HW: 3C0 614 109 A
Component: ESP 440 C4     H018 0001
Revision:  H018       Serial number: 0775106675
Coding: 0013602
Shop #: WSC 05311 000 00000
VCID: 1C6129085AAC0DA736E-8048
And the pump i've putted in is
Labels: 3C0-614-109-C4.clb
Control Module Part Number: 3C0 614 109 D    HW: 3C0 614 109 D
Component and/or Version: J104    C4 440 V2   0003
Software Coding: 0002333
Work Shop Code: WSC 00028 028 00001
VCID: 1F1B1E044BBA16BFD3C-804A
There's any chance to make it work?
Fredrick Awuor
Kenya
C?ID=309834
Coding: 0013602
Kindly check on official parts catalog ,either ETKA or Partslink24.com with VIN to see if compatible
koket
Romania
C?ID=327557
Partslink only shows me the A ending model for that VIN
koket
Romania
C?ID=327557
Solved , I've putted 3C0 614 109 with Q in end, coded and all done!
golfi_vend
Tartu, Estonia
C?ID=195131
Are You sure it was 109 Q and not 095 Q?
109 D and 109 Q are newer ABS and don't work together with older EPB.
koket
Romania
C?ID=327557
Yes, it was 095, my bad. Also 095 has long coding *aka coding helper, and was easier to code, chosen car engine and gearbox, perform basic settings, brake bleeding and all done.
