Results 1 to 4 of 4
Thread: Fabia Lateral Acceleration Sensor and Longitudinal Acceleration Sensor
    Dec 2016
    Hi
    Have a 2014 Skoda Fabia 1.6tdi here that had faulty ABS module. Got coding from original which replacement has accepted ok. No problem to re adapt brake pressure sensor, but no option for Lateral Acceleration Sensor and Longitudinal Acceleration Sensor like on other models.
    Anyone know how to do it on these?
    Wednesday,26,June,2019,13:47:32:46000
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
    VCDS Version: 19.6.0.4
    VIN: TMBFJ6NH8E4514347   License Plate: AFTER NEW
    Mileage: 197840km-122932mi   Repair Order:
    Chassis Type: NH-SK25 (6N0)
    Scan: 01 02 03 04 09 15 17 19 25 44 56
    VIN: TMBFJ6NH8E4514347   Mileage: 197840km-122932miles
    Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 QK    HW: 03L 906 023 LK
       Component: 1,6l R4 CR td H33 5397
       Revision: --H33---    Serial number:
       Coding: 00254010000500080000
       Shop #: WSC 73430 031 00053
       ASAM Dataset: EV_ECM16TDI02103L906023QK 003002
       ROD: EV_ECM16TDI02103L906023LL.rod
       VCID: 7F07757DE64ECCB7EE-802A
    Readiness: 0110 0000
       Part No SW: 0AM 300 061 S    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 5110
       Revision: 00043014    Serial number: CU501311145368
       Shop #: WSC 73430 790 00053
       VCID: 3B7F416D79D6109782-5102
       Part No SW: 6R0 614 517 BD    HW: 6R0 614 517 BD
       Component: EBC 460 ESP   H08 0004
       Serial number: A00L985
       Coding: 4229481489B200B8424A12D691A70080490900
       ASAM Dataset: EV_Brake1ESPAEntryTRW 002011
       ROD: EV_Brake1ESPAEntryTRW.rod
       VCID: 76E99059C9748DFFBD-8022
    0361 - Lateral Acceleration Sensor
              C1079 54 [137] - Missing Calibration / Basic Setting
    0362 - Longitudinal Acceleration Sensor
              C1017 54 [137] - Missing Calibration / Basic Setting
    0363 - Turn Rate Sensor
              C107D 54 [137] - Missing Calibration / Basic Setting
       Part No SW: 6R0 937 087 P    HW: 6R0 937 087
       Component: BCM PQ25 H+4  H34 0411
       Revision: BF034001    Serial number: 0581 323130193
       Coding: 7B980B0000010000000000302C0B0CC00E00400F60020000020000004000
       VCID: 4A9114A9E50CB91F09-801E
       Part No SW: 34D 959 655 B    HW: 34D 959 655 B
       Component: AirbagVW20    004 0365
       Serial number: 003K7R02A5C0
       Coding: 88CCC00000000000540000C8008000000065
       ASAM Dataset: EV_AirbaVW20SMEVW253 001108
       ROD: EV_AirbaVW20SMEVW253_VW25.rod
       VCID: 346D6A519F88DFEF43-8060
       Subsystem 1 - Part No SW: -----------    HW: 480 411 111 13
       Component: SideSensor_Df  003 0148
       Serial number: 349650A25B89FEB24F15
       Subsystem 2 - Part No SW: -----------    HW: 480 411 111 13
       Component: SideSensor_Pf  003 0148
       Serial number: 350650A25AC5BED46C71
       Subsystem 3 - Part No SW: -----------    HW: 480 411 111 13
       Component: SideSensor_Dr  003 0148
       Serial number: 351650A25A6E3CC44C5X
       Subsystem 4 - Part No SW: -----------    HW: 480 411 111 13
       Component: SideSensor_Pr  003 0148
       Serial number: 352650A25A6E31F49D5W
       Part No SW: 5JA 920 800 C    HW: 5JA 920 800 C
       Component: KOMBI         H04 0709
       Coding: 110200
       VCID: 3669505989F4CDFF7D-8062
       Part No SW: 6N0 909 901     HW: 6R0 937 087
       Component: GW-K-CAN TP20 H34 0411
       Revision: BF034001
       Coding: 932300
       VCID: 70E5A641A310A3CF67-8024
       Component: IMMO          H04 0709
       VCID: 6AD1B4298DCC591F29-803E
       Part No SW: 6R2 909 144 R    HW: 6R2 909 144 E
       Component: EPS_TRW_ALow  321 3111
       Serial number: CDBT0522
       Coding: 0003
       Shop #: WSC 26751 001 1048576
       ASAM Dataset: EV_SteerAssisUDSTRW 011021
       ROD: EV_SteerAssisUDSTRW_011.rod
       VCID: 47972D9DFE1E447716-8012
    Address 56: Radio (J503)       Labels: None
       Part No SW: 5J0 035 152 C    HW: 5J0 035 152 C
       Component: Radio         H05 0015
       Revision: R0000000    Serial number: SKZAZ6N6444888
       Coding: 000002000007
       VCID: 22419C093D7C415FA1-8076
    End-------------------------(Elapsed Time: 02:18)--------------------------
    16.4905 S, 151.7375 W
    Have you tried the [Basic Settings-04] in the [03-ABS Brakes] controller "Basic setting of ESP sensor unit", use the 'pull-down' menu to select this Basic Settings.
    - If needed you can also try the "Steering angle sensor" Basic Setting.
    (Turn the steering wheel to each lock then center the wheels, steering wheel needs to be level)
    Also when in the Basic Settings, select the following by pressing [Show Measuring Values].
    Traction control system sensor - Longitudinal acceleration sensor
    Traction control system sensor - Steering angle: offset
    Traction control system sensor - Longitudinal acceleration sensor: offset
    Traction control system sensor - Steering angle sensor
    Note:
    - If required, you may need to enter in the Security Access code of "40168" to enable the Basic Settings functions. A parking lot road test before and or afterward maybe necessary to initialize / finalize the Basic settings. Also a flat level surface should be used as well.
    Let us know how this worked for you,
    drpeter
  3. Likes Uwe liked this post
    Dec 2016
    Hi Peter,
    Thanks soo much for the help. Tried these few ideas. No problem with steering angle sensor. When I go into Basic setting of ESP sesnor unit, I just get "unknown". Will try going to parking lot now to see if it makes any difference when I try to reset.
    Dec 2016
    Hi Peter
    Still can't seem to get this reset. Entered security access code, went into "Basic setting of ESP sensor unit", and pressed go. It says "unknown", sometimes when I drive after this it changes to "not running". I have tried driving around in both directions, braking, turning etc, but nothing seems to change. Is there another procedure to reset this?
