Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Adaptation Problem in 8E central electronics -09 with HEX V2 adapter
    Jun 2019
    Sweden
    Hey guys!
    With my HEX V2 unlimited adapter i'm unable to change any adaptation values in central electronics and the security access block is grayed out,
    with my friends AI adapter i'm able to access the security access block and change adaptation values on the same car with the same computer and vcds program!
    please tell me what the problem is!
    (Audi rs4 b7 8ec -2006)
    Oct 2014
    Arandjelovac, Serbia
    Lightbulb
    It would be nice to post an full Auto Scan.
    Jun 2019
    Sweden
    Wednesday,26,June,2019,14:58:27:20561
    VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WUAZZZ8E06N900140   License Plate:
              67 69 75 76 77
    VIN: WUAZZZ8E06N900140   Mileage: 222020km-137956miles
    Address 01: Engine        Labels:. 079-910-560-BNS1.lbl
       Part No SW: 8E1 910 560     HW: 8E1 907 560
       Component: 4.2L V8/4V FSI     Ş0080
       Revision: --H03---    Serial number: XXXXXXXXXXXXXX
       Coding: 01040003180F0160
       Shop #: WSC 00000 000 02400
       VCID: 6393AE3B0750BD0FB77-8036
    005241 - Brake Boost Vacuum System
                   P1479 - 008 - Mechanical Failure - Intermittent
                        Mileage: 221821 km
                        RPM: 964 /min
                        Load: 52.5 %
                        Speed: 7.0 km/h
                        Temperature: 42.0°C
                        Temperature: 33.0°C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.335 V
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
       Component: ESP8 quattro    H04 0150
       Coding: 0004533
       Shop #: WSC 06325 000 00000
       VCID: 2B03061B2F00354F4F7-807E
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2832
       Coding: 00001
       Shop #: WSC 06325
       VCID: 6D87C803D484FB7F113-50D0
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 L
       Component: int. Lastmodul  ECE 0504
       Coding: 01041
       Shop #: WSC 00012
       VCID: 3B23365BDA70A5CFDF7-4AA4
                30-00 - Open or Short to Plus
    Address 11: Engine II        Labels:. 079-910-560-BNS2.lbl
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
       Component:    Airbag 9.41  H11 3530
       Revision: 91H1135    Serial number: 0036M007J2L.
       Coding: 0430712
       VCID: 3B23365BDF60A5CFDF7-806E
       Subsystem 1 - Serial number: 6332DRB402004993A
       Subsystem 2 - Serial number: 6342DRB4021E0C8DY
       Subsystem 3 - Serial number: 6352ARB400984CAC.
       Subsystem 4 - Serial number: 6362ARB400984190E
       Subsystem 5 - Serial number: 63729RB400B1452DJ
       Subsystem 6 - Serial number: 63829RB400B14359H
    Address 16: Steering wheel        Labels: 8E0-953-549-T.lbl
       Part No: 8E0 953 549 T
       Component: Lenksáulenmodul     0201
       Coding: 14441
       Shop #: WSC 36256
       VCID: 44D14DA7A78EDA37AED-4AA4
    01301 - Control Module for Voice Recognition (J507)
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 931 G    HW: 8E0 920 931 G
       Component: KOMBI+WFS 4     H12 0030
       Revision: 0030        Serial number: 00000000000000
       Coding: 0023101
       Shop #: WSC 80093 222 69422
       VCID: 2C0105072A1E327746D-50F4
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0023101
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760 A
       Component: Sitzverstellung H01 0020
       Coding: 00001
       VCID: 323D1B7F0D0A64870C1-4B1E
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0804
       Coding: 00001
       VCID: 6B83C61BEA90F54F0F7-508A
       Part No: 8E0 959 433 CA
       Component: Komfortgerát T3B    3332
       Coding: 27224
       Shop #: WSC 06325
       VCID: 72BDDB7FCDBA2487CC1-4AA4
       Component: Tőrsteuer.FS BRM 0406
       Component: Tőrsteuer.BF BRM 0205
       Component: Tőrsteuer.HL BRM 0506
       Component: Tőrsteuer.HR BRM 0506
    01134 - Alarm Horn (H12)
                49-00 - No Communications
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Component: AFS 1           H01 0030
       Coding: 0000019
       Shop #: WSC 40951 222 94900
       VCID: 2615F72F34E20827909-8072
       Subsystem 1 - Part No: 8E0 941 329 A
       Component: AFS-Modul links H05 0030
       Subsystem 2 - Part No: 8E0 941 329 A
       Component: AFS-Modul rechtsH05 0030
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8E0 035 193 A    HW: 8E0 035 193 A
       Component: RNS-E PU EU SP  H06 0700
       Revision: 0000001S    Serial number: AUZBZ7N2900524
       Coding: 0301718
       VCID: 2313EE3B47F0FD0FF77-50D0
    00878 - Connection to Speaker Front Left
                        Reset counter: 87
                        Date: 2019.06.13
                        Time: 23:18:08
    00879 - Connection to Speaker Front Right
                        Reset counter: 87
                        Date: 2019.06.13
                        Time: 23:18:08
    Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
       Part No SW: 8E0 907 273     HW: 8E0 907 273
       Component: Reifendruck 3   H03 0110
       Coding: 0022523
       Shop #: WSC 40160 222 89032
       VCID: 698FBC13E55CE75F7DB-513C
    01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
                        Fault Status: 11100100
                        Reset counter: 40
                        (no units): 0.0
                        Voltage: 12.10 V
                        (no units): 130.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                        Resistance: 0.00 ohms
       Part No SW: 8P0 862 335 C    HW: 8P0 862 335 C
       Component: FSE_255x BT     H18 0160
       Revision: 00000001    Serial number: 00000000300895
       Coding: 0010822
       Shop #: WSC 67458 141 87521
       VCID: 3635276FE45278A7209-50D0
    End----(Elapsed Time: 04:40, VBatt start/end: 12.2V/12.2V. VIgn 0.0V)------
    there you go
  4. Likes Dana liked this post
    Quote Originally Posted by Egon View Post
    Hey guys!
    The CECM at address 09 in this car uses the older KW-1281 protocol which does not support the Security Access function.
    I do not see how that is possible. Please post screen shots.
  6. Likes Eric, PetrolDave liked this post
    Jun 2019
    Sweden
    My friend is in greece right now so i will borrow his adapter again when he gets back
    Jun 2019
    Sweden
    how do i post pictures so i can show you screen shots?
    Nov 2017
    Latvia
  10. Likes Uwe liked this post
  11. #8
    Jun 2019
    Sweden
    this is with the HEX adapter:
  12. #9
    Jun 2019
    Sweden
    this is with the AI adapter:
    - channel 16, the only channel i still couldn't change, and the one i really really wanted to change right now!!
    if the older, cheaper AI adapter can access more controllers and change more adaptation values than the HEX adapter in the car i'm going to use it in the most then i want to change mine right now..
  13. Likes Uwe liked this post
  14. #10
    Nov 2017
    Latvia
    Does hex-net has latest firmware installed and can you test it again with 19.6.1 for equal comparison?
    Didn't really see SA button in last screenshots
  15. Likes Dana liked this post
