2009 Audi A5 SRI reset not working
manzp
Australia
C?ID=274140
Hi All,
I am having trouble resetting the SRI on my Audi A5. I have used the auto SRI reset and also tried the more manual method after searching google.
I have completed this reset before on this car without problems several times but this time it is resetting everything but the service reminder on the cluster will not go away.
When I check everything all the settings look right. In the MMI it says I have lots of km's to go until the service and/or inspection.
I have also checked that the Service reminder is set to 0 which should mean that it doesn't show on the dash.
Usually this is a 5 minute job, but after 2 hours I am frustrated.
Can anyone offer advice?
If I need to pull the settings from the car and add to here I can do it later.
Thanks in advance.
It would be good to post an Auto-Scan so we can see exactly what cluster and engine you have.
In addition, please click [SRI Reset], wait for VCDS to read the SRI-Relevant channels, then click [Add to logfile] and post the resultant log.
manzp
Australia
C?ID=274140
thanks for your reply. I have tried again this morning with same result. Below are my SRI logs and full scan logs.
Sunday,30,June,2019,09:45:13:19418
VCDS Version: 19.6.0.4 (x64)
VIN:    License Plate: A5-SRI
VCDS Release 19.6.0:  SRI Reset
Control Module Part Number: 8T0 920 931 C       Labels:  .8T0-920-xxx-17.clb
Component:KOMBIINSTR.   H33 0253, Coding:AF06190002000008010000
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	0             	---
40       	Distance since Service                            	km x100   	0             	---
41       	Time since Service                                	Days      	0             	---
42       	Minimum Distance to Service                       	km x100   	150           	---
43       	Maximum Distance to Service                       	km x100   	150           	---
44       	Maximum Time to Service                           	Days      	365           	---
45       	Oil Quality                                       	          	1             	---
47       	Soot Quantity                                     	DIST x100 	0             	---
48       	Thermal Load                                      	DIST x100 	0             	---
49       	Minimum Time to Service                           	Days      	365           	---
50       	Basic Distance Value for Oil Change               	km x100   	150           	---
51       	Basic Time Value for Oil Change                   	Days      	365           	---
52       	Basic Distance Value for Inspection               	km x100   	300           	---
53       	Distance since Inspection                         	km x100   	5             	---
54       	Basic Time Value for Inspection                   	Days      	730           	---
55       	Time since Inspection                             	Days      	23            	---
56       	Day Counter                                       	Days      	3678          	---
Full log
Sunday,30,June,2019,09:55:17:19418
Chassis Type: 8F-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 26 36 42 46 52 53 55
          56 5F 62 72
VIN: WAUZZZ8F6AN006171   Mileage: 129730km-80610miles
0E-Media Player 1 -- Status: Malfunction 0010
Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AJ    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0002
   Revision: E1H14---
   Coding: 011C000C240F0160
   Shop #: WSC 33512 000 1048576
   ASAM Dataset: EV_ECM20TFS0118K2907115AJ 001002
   ROD: EV_ECM20AVS.rod
   VCID: 77FD9AE7CE869EF7A6-8022
   Part No SW: 8K0 927 156 F    HW: 0B5 927 156 D
   Component: 0B5 20TFSIRdW H02 0014
   Revision: --H02---    Serial number: 0000001173
   Coding: 000001
   Shop #: WSC 02145 785 00200
   ROD: EV_TCMDL501.rod
   VCID: 377D5AE78E065EF766-8062
   Part No SW: 8K0 907 379 AL    HW: 8K0 907 379 AL
   Component: ESP8 quattro  H04 0080
   Coding: 090500
   Shop #: WSC 02391 823 56573
   VCID: 0305FE37825EC2578A-8056
   Part No SW: 8K0 907 064 DT    HW: 8K0 907 064 DT
   Component: BCM2 1.1      H02 0321
   Coding: 05130F
   Shop #: WSC 02399 823 56573
   VCID: 0501E02F8C6AFC67A4-8050
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000034253001
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 142
                    Mileage: 129047 km
                    Date: 2019.04.13
                    Time: 07:43:56
   Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
   Component: MEM-BFS       H10 0073
   Revision: AA000000    Serial number: 00001001274112
   Coding: 08217025002400001000
   VCID: 43853E37C2DE0257CA-8016
   Part No SW: 8T2 820 043 AG    HW: 8T2 820 043 AG
   Component: KLIMA 3 ZONEN H08 0160
   Revision: D1000000    Serial number: 01270520091787
   Coding: 64176000
   VCID: 77FD9AE7C6869EF7A6-8022
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000382467
   Coding: 260050914034AF010009000300005D5D0F1D438800010141000000
   VCID: 3C7745CBBF207DAF8B-8068
   Subsystem 1 - Part No SW: 8F2 955 119     HW: 8K2 955 119   Labels: 1KX-
955-119.CLB
   Component: WWS 250509  H05 0021
   Serial number: SWF09050255094
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-
955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10484468
   Coding: 02562A
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001605090864
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
   Component: CDC-MP3-Pana  H48 0050
   Revision: 00000014
   VCID: 214994BF38823047B8-8074
                    Reset counter: 40
                    Mileage: 129032 km
                    Date: 2019.04.01
                    Time: 20:36:07
   Part No SW: 8K0 919 475 H    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0050
   Revision: 11001001    Serial number: 39940915003942
   Coding: 000101
   VCID: 3E734FC3A93C6FBFA5-806A
Address 15: Airbags (J234)       Labels:* 8F0-959-655.clb
   Part No SW: 8F0 959 655     HW: 8F0 959 655
   Component: AirbagVW-AU10 H08 0430
   Serial number: 003A4D042LKY
   Coding: 30363635353130303030554A305238463053
   ASAM Dataset: EV_AirbaAU10SMEAU485 001004
   ROD: EV_AirbaECUVWAUDI010.rod
   VCID: 75E190EFD48AECE7B4-8020
   Serial number: 6334MSME48357078F
   Serial number: 6344MSME48354B44H
   Serial number: 6352QSME412C45128
   Serial number: 6362QSME63253E14G
   Serial number: 63732SME7D29361EB
   Serial number: 63832SME042B361E+
   Revision: --------    Serial number: 90319IEP0009A
   Coding: 000036
   VCID: 3D7148CFA43A74A7BC-8068
   Part No SW: 8T0 920 931 C    HW: 8T0 920 931 C
   Component: KOMBIINSTR.   H33 0253
   Revision: 00000000    Serial number: BYF231T59
   Coding: AF06190002000008010000
   VCID: 377D5AE786065EF766-8062
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0101
   Revision: EB700052    Serial number: 5200E095128183
   Coding: 00C303
   VCID: 52AB0B730DA49BDF71-8006
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0160
   Serial number: 1907C558070509
                    Fault Frequency: 29
                    Reset counter: 142
                    Mileage: 127586 km
                    Date: 2018.08.24
                    Time: 09:42:58
                    Bin. Bits:    10000
                    Voltage: 11.90 V
                    Count: 10
Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
   Part No SW: 8F0 959 255     HW: 8F0 959 255
   Component: VSG-AUDI-B8   H09 0160
   ASAM Dataset: EV_ElectRoofContr 001007
   ROD: EV_ElectRoofContr.rod
   VCID: 71E9A4FFA0E2C0C768-8024
   Component: MEM-FS        H10 0073
   Revision: AA000000    Serial number: 00001001274328
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000008907786
   Coding: 011C52724009330C03
   VCID: 4581202FCCEA3C67E4-8010
                    Reset counter: 142
                    Mileage: 129047 km
                    Date: 2019.04.13
                    Time: 07:44:01
   Revision: 00002001    Serial number: 0118698588
   Coding: 01000EA0003104210030030000000000
                    Fault Status: 00101100
                    Fault Frequency: 9
                    Reset counter: 152
                    Mileage: 127947 km
                    Date: 2018.10.09
                    Time: 07:59:56
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000008920106
   Coding: 011C52324C09330C03
   VCID: 44873D2BC7D0056FF3-8010
                    Reset counter: 142
                    Mileage: 129047 km
                    Date: 2019.04.13
                    Time: 07:44:01
                    Fault Frequency: 26
                    Reset counter: 126
                    Mileage: 129255 km
                    Date: 2019.05.25
                    Time: 21:35:57
   Component: EPB Audi B8   H09 0090
   Revision: 00000003    Serial number: 00000000367384
   VCID: 34676DEB9770B5EF43-8060
   Part No: 8K5 907 357
   VCID: 77FD9AE706869EF7A6-8022
   Part No SW: 4F0 035 056 B    HW: 4F0 035 056
   Component: Radio U STD   H45 0020
   Revision: AB001007    Serial number: 342ES097610619
   Coding: 040003020100000101
   VCID: 1F4D92470EF606B78E-804A
   Part No SW: 8T2 035 754 D    HW: 8T2 035 754 D
   Component: H-BN-RW       H41 0047
   Revision: --------    Serial number: 485EL097500102
   Coding: 010A0103000681ED01000B0E000000010101
   VCID: 3A7B43D3B514439F99-806E
   Subsystem 1 - Part No: 8R0 060 884 D
   Component: ROW 2009/2010  5103
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356EQ091103765
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000289244
   Subsystem 4 - Part No: 8R0 906 961 A
   Component:   CD-Database  1293
   Part No SW: 8K0 959 795 E    HW: 4F0 959 795 L
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000101188979
   Coding: 010C12324009370C03
                    Reset counter: 142
                    Mileage: 129018 km
                    Date: 2019.04.01
                    Time: 19:04:33
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000101188976
                    Reset counter: 142
                    Mileage: 129018 km
                    Date: 2019.04.01
                    Time: 19:04:32
End-------------------------(Elapsed Time: 03:41)--------------------------
OK, I'm stumped. All those values look correct / reasonable. :confused:
manzp
Australia
C?ID=274140
Thx for the reply. Anyone else had this issue?
Fredrick Awuor
Kenya
C?ID=309834
I think you need to manually reset 53, 55?....and 56
53 is less than 52, so that should not be causing a service reminder.
55 is less than 53, so that also should not be causing a service reminder.
However, there's no harm in trying to zero these out.
56 cannot be changed. That's the number of days since the car was manufactured.
audivwauto1
South Africa
C?ID=260881
rather to be safe on all clusters adaption on the kick down menu do it manually.
resat service due (2)
then srcoll down to the bottom time sine service, and distance covered ..
set both to 0
manzp
Australia
C?ID=274140
Thanks for your input guys. Tried again on another day and did what you said. I reset channel 53 and channel 55 to 0 then went to channel 2 and set the service reminder to 0 as well. Finally got the service message to go away. Very happy
