Results 11 to 20 of 23
Thread: 2011 A8 4.2, intermittent P0420 code
    Incorrect & indeed it does.........
  2. #12
    Jan 2017
    What? Do you mean I should take an autoscan right now? How would it be any different from the one I just posted?
  3. #13
    Let's see if it is & I will point out what if it is, you being argumentative only shows me you didn't JPPSG, now did you?
    Additionally please post the OBD2 data too......
    0x33-MODES 01-01 , 03, 07 & 09
    Give before it hurts!
  4. #14
    Jan 2017
    Argumentative? I'm sorry if that's how you feel, was not my intention. I'm just having really hard time following you.
    Anyhoo, here are two scans from Friday, first one's wit the MIL on, second after resetting the fault.
    Will check the OBDII data tonight:
    Friday,28,June,2019,16:18:36:32117
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAURVAFD5BN023530   License Plate:
    Mileage: 181599km-112840mi   Repair Order:
    Chassis Type: FD-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 34 36 3B 3C 42 46
              47 52 53 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F 90
    VIN: WAURVAFD5BN023530   Mileage: 181599km-112840miles
    Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
       Part No SW: 4H0 907 560 C    HW: 4H0 907 560
       Component: 4.2l V8/4V    H07 0004
       Revision: N5H07---
       Coding: 0106000A290F0268
       Shop #: WSC 22104 444 80447
       ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
       ROD: EV_ECM42FSI0114H0907560C.rod
       VCID: 2A5B040F4D825C1FE7-807E
    10434 - Catalyst System; Bank 1
              P0420 00 [237] - Efficiency Below Threshold
                        Mileage: 181562 km
                        Date: 2019.06.28
                        Time: 06:10:02
                        Engine speed: 1535.50 /min
                        Normed load value: 28.6 %
                        Vehicle speed: 36 km/h
                        Coolant temperature: 50 °C
                        Intake air temperature: 24 °C
                        Voltage terminal 30: 13.735 V
                        AFS dm: 60.4 kg/h
                        Median injection timing: 1.181 ms
                        Engine operating condition: Part. load
                        Engine operating condition-Test_Program_Channel 87: 6
       Part No SW: 4H1 927 158 AD    HW: 0BK 927 156 K
       Component: 0BK 42 FSIUSA H08 1006
       Revision: --H08---
       Coding: 000002
       ROD: EV_TCMALX51011_002_AU64.rod
       VCID: 72EBDC6FA5D254DF9F-8026
    Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
       Part No SW: 4H0 907 379 C    HW: 4H0 907 379 C
       Component: ESP PREMIUM   H10 0273
       Coding: 44E6F20022674F00E200
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ESPPremi 005006
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 326B1C6F655214DF5F-8066
       Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 AD
       Component: BCM2 2.0      H24 0510
       Coding: 0D872000000000000000
       Shop #: WSC 61482 000 1048576
       VCID: 6ED3C81FB9EA703F7B-803A
       Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Component: J764 ELV MLB  H38 0044
       Serial number: 2311000064898013
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Component: MEM-BFS       H08 0153
       Revision: AA000000    Serial number: 00000006069555
       Coding: C018320085043201010001010101112131313333283333
       Shop #: WSC 02313 785 00200
       VCID: 356127739C3C03E77A-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
       Component: Klima 3 Zonen H14 0063
       Coding: 4801222E8C
       ROD: EV_AirCondiFront_001_AU64.rod
       VCID: 224BEC2F35B2845FAF-8076
       Part No SW: 4H0 907 063 G    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0092
       Revision: 11012002    Serial number: 00000001002653
       Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
       VCID: 2C5702174F76422F15-8078
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 110308  H32 0040
       Serial number:         110322012421
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 10073237
       Coding: 025523
       Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
       Component: E1 - LDS  H07 0044
       Serial number: 24 03 2011  00000037
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
       Serial number: 0000001805569R0EA506
       Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Component: A31 LED Mod1L  H03 0006
       Serial number: 00000016031100010977
       Coding: 100000
       Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Component: A27 LED Mod1R  H03 0006
       Serial number: 00000018031100010501
       Coding: 100000
       Subsystem 7 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0280
       Serial number: WA101140000000229363
       Coding: 020300
       Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 6C38CB95000000000001
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 D    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0180
       Revision: AA001001
       VCID: 2149E32338B49F47B6-8074
       Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0030
       Revision: 11001001    Serial number: 55901106603314
       Coding: 300902
       ASAM Dataset: EV_EPHVA18AU57X0000 001002
       ROD: EV_EPHVA18AU57X0000_001.rod
       VCID: 377D2D7B8E30F1F768-8062
       Part No SW: 4H0 907 561 A    HW: 4H0 907 561
       Component: ACC3          H15 0160
       Coding: 3601020201
       ASAM Dataset: EV_AdaptCruisContrAU64X 001012
       ROD: EV_AdaptCruisContrAU64X_001.rod
       VCID: 2959FB0348845707EE-807C
       Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
       Component: Airbag10.43   H41 0041
       Revision: --------    Serial number: 003JS00133R+
       Coding: 303143303230303030314A55304C34483053
       Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
       Serial number: 5850000R1130301CJR
       Serial number: 3575HRB40690C15I802B
       Serial number: 3585HRB40530BI7UAG3B
       Serial number: 3515JRB405P0ESASIGGK
       Serial number: 3525JRB40650G2I2M8P8
       Serial number: 3554VRB405R0BEE6H9BW
       Serial number: 3564VRB405R0BEE6J1GW
       Part No SW: 4H0 953 568 A    HW: 4H0 953 568 A
       Component: Lenks.Modul   H08 0007
       Revision: --------    Serial number: 90815KCB0001D
       Coding: 0000BC
       VCID: 3169136368542FC726-8064
       Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
       Component: E221 - MFL  H04 0009
       Serial number: 07 01 2011  33039122
       Part No SW: 4H0 920 980 C    HW: 4H0 920 980
       Component: TBenUSAACC--- H30 0312
       Revision: 31110017    Serial number: 658180311592007
       Coding: 0B4608015700D705020000
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K_AU64.rod
       VCID: 2B55010B427845171C-807E
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0224
       Serial number: 1110315001168
       Part No SW: 4H0 907 468 E    HW: 4H0 907 468 C
       Component: J533--Gateway H08 0204
       Revision: --------    Serial number: 00000000122075
       Coding: 00C1034A00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 3365196B9A481DD754-8066
       Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650035262
       Part No SW: 4H0 907 553 C    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0096
       Coding: 008002
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2C5702174776422F15-8078
       Revision: AA000000    Serial number: 00000006070295
       Coding: C0183B0085053201010001010101112131313333203333
    Address 3B: Sensor Elect. (J849)       Labels: None
       Part No SW: 4H0 907 637     HW: 4H0 907 637
       Component: SARA 6D       H02 0015
       Revision: --------    Serial number: EJ1BPA3100GDL50
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6CD7C21787F6822F55-8038
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4H0 907 566     HW: 4H0 907 566
       Component: J769  SWA MasterH02 0100
       Revision: 00H02000    Serial number: 6PZ 010 287-00
       Shop #: WSC 64705 000 1048576
       VCID: 6DD1CF1374EC8B2742-8038
       Subsystem 1 - Part No: 4H0 907 568
       Component: J770  SWA Slave H01 0100
       Subsystem 2 - Serial number: 6PZ 010 287-20
       Subsystem 3 - Serial number: 5F29.03.1100H010003CH10624˙
       Subsystem 4 - Serial number: H10624˙
       Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Component: TSG FA        H02 0162
       Revision: --------    Serial number: 0000114641356
       Coding: 011F1F205E0062C202000007
       Shop #: WSC 02312 785 00200
       VCID: 3B75314BBA18D5978C-806E
       Revision: 00002001    Serial number: 0146933976
       Coding: 0106023A00FA7585B0B0C7C0020100000000000000000000000000000000
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0070
       Serial number: 00000000000000024443
       Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
       Component: J245 PS50.028  H07 0006
       Serial number:     WOO11692171
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
       Component: Dachelektroni  H11 0080
       Serial number: A2011000000000360183
       Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
       Component: V252 PS009  H05 0004
       Serial number:     WOO1000DH05
       Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0070
       Revision: CJ007000    Serial number: 00000000026722
       VCID: 1B35D1CB1AD8B5976C-804E
       Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
       Component: TSG BF        H02 0162
       Revision: --------    Serial number: 0000114639450
       VCID: 3A7B344FB522EC9F97-806E
       Revision: --------    Serial number: 00000000056576
       ROD: EV_ParkiBrake_VW51.rod
       Part No SW: 4H0 035 082 A    HW: 4H0 035 082
       Component: Radio U SIRIU H51 0068
       Revision: AB001007    Serial number: 155CR0B7501832
       Coding: 020007010000000001
       VCID: 1F4DE5DB0EC0A9B780-804A
       Part No SW: 4H0 035 664 B    HW: 4H0 035 664
       Component: H-BN-NA       H48 0294
       Revision: --------    Serial number: 098CU0B7503035
       Coding: 020200000001F9EF7D128B0E00000003F400010000000000
       VCID: 2643F03F519A787FC3-8072
       Subsystem 1 - Part No: 8R0 060 884 AC
       Component: NAR 2011  0503
       Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
       Component: DU8 D4 SV NB  H46 0021
       Serial number: AUZ8ZDB1100HNDP
       Subsystem 3 - Part No SW: 4H1 919 600 D    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0063
       Serial number: 00000000034204
       Subsystem 4 - Part No: 8R0 060 961 A
       Component: CD-Database  2712
                        Fault Frequency: 22
                        Reset counter: 39
                        Mileage: 181264 km
                        Date: 2019.06.22
                        Time: 11:13:21
                        Bin. Bits: 10111111 11100010
                        Bin. Bits: 10001110 10011111
                        Bin. Bits: 00000000 00000001
                        Bin. Bits: 00000000 00000000
                        Reset counter: 39
                        Mileage: 181264 km
                        Date: 2019.06.22
                        Time: 11:13:21
                        Bin. Bits: 00000001 00010000
                        Bin. Bits: 00000000 00001010
       Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
       Component: TSG HL        H04 0162
       Revision: --------    Serial number: 0000114553594
       Coding: 010F1F20400062C202000007
       VCID: 39792B43B024E7879E-806C
       Part No SW: 4H0 907 441     HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0030
       Revision: --H04---    Serial number: 525 PA8J13D05L
       Coding: 1020003
       Shop #: WSC 02391 785 00200
       VCID: 65C1B733AC1CB3670A-8030
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0036
       Revision: 10011001    Serial number: 082100281
       Coding: 0210044100
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3B75314BB218D5978C-806E
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Part No SW: 4H0 907 412     HW: 4H0 907 412
       Component: ALM           H05 0004
       Revision: --------    Serial number: 000000028356
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 63C5A92B6A28CD57E4-8036
       Component: TSG HR        H04 0162
       Revision: --------    Serial number: 0000114553595
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H05 0081
       Revision: 0L0D5012    Serial number: SN110209  0208
       ASAM Dataset: EV_GSM2x3Mono 001014
       ROD: EV_GSM2x3Mono.rod
       Part No SW: 4G0 907 217     HW: 4H0 907 217 A
       Component: DPC-SG        H24 0034
       Coding: E9060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 65C1B733641CB3670A-8030
    Address 88: Multicont. Seat Driver (J873)       Labels:* None
       Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
       Component: IVB           H07 0042
       Serial number: 00000171269101
       Coding: 764FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F6D151B7660393730-807A
    Address 89: Multicont. Seat Pass. (J872)       Labels:* None
       Serial number: 00000171254501
       Coding: 364FF2
       Part No SW: 4H0 907 541 A    HW: 4H0 907 541
       Coding: 3601020201
       ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
       ROD: EV_AdaptCruisContr2AU64X_001.rod
       VCID: 275DFD3B5E906177F8-8072
       Part No SW: 4G0 907 107 B    HW: 4H0 907 107
       Component: BV-SG         H28 0034
       Serial number: 000040181703117
       Coding: 02A19A000111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       VCID: 2541F733249C7367CA-8070
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 0066F609031F007E070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 6FEDD51BB6E0793770-803A
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70EFD667ABDE66CF69-8024
    End-------------------------(Elapsed Time: 06:53)--------------------------
       Revision: N5H07---
                        Mileage: 181562 km
                        Date: 2019.06.28
                        Time: 06:10:02
                        AFS dm: 60.4 kg/h
       Revision: --H08---
       Coding: 000002
       Coding: 4801222E8C
       Coding: 0045F7
       Coding: 025523
       Coding: 100000
       Coding: 100000
       Coding: 020300
       Revision: AA001001
       Coding: 300902
       Coding: 3601020201
       Coding: 0000BC
       Analog_clock:
       Coding: 00C1034A00
       Coding: 008002
       Coding: 020200
                        Fault Frequency: 22
                        Reset counter: 39
                        Mileage: 181264 km
                        Date: 2019.06.22
                        Time: 11:13:21
                        Reset counter: 39
                        Mileage: 181264 km
                        Date: 2019.06.22
                        Time: 11:13:21
       Coding: 1020003
       Coding: 0210044100
       ROD: EV_Ambie.rod
       Coding: E9060000
       Coding: 764FF2
       Coding: 364FF2
       Coding: 3601020201
       ROD: EV_BC7.rod
       ROD: EV_RGS_L.rod
       ROD: EV_RGS_R.rod
    Thanks for your help.
  5. #15
    FIRST SCAN
    Revision: N5H07---
    Mileage: 181562 km
    Date: 2019.06.28
    Time: 06:10:02
    AFS dm: 60.4 kg/h
    SECOND SCAN
    Revision: N5H07---
    Mileage: 181562 km
    Date: 2019.06.28
    Time: 06:10:02
    AFS dm: 60.4 kg/h
    Are you sure you reset it because the fault is still there and readiness is still present?
    Maybe go to OBD2 Mode 0x33- MODE 04 to try a reset?
  6. Likes Uwe liked this post
  7. #16
    Jan 2017
    I reset it because the MIL is on. I ran all the tests I could find under Engine module, all passed.
    I'll try the Mode 4 reset the next time the fault comes on.
    In the meanwhile, here are the OBDII results:
    Monday,01,July,2019,16:46:39:32117
    Mode 01 - PID 01 : Readiness  --  Address 7E8
    Number of DTCs stored: 0  --  MIL Status: MIL OFF
    Misfire monitoring:  Passed
    Fuel System:  Passed
    Comprehensive Components:  Passed
    Catalyst monitoring:  Passed
    Heated catalyst monitoring: Not installed.
    Evaporative system monitoring:  Passed
    Secondary air system monitoring:  Passed
    A/C system refrigerant monitoring: Not installed.
    Oxygen sensor monitoring:  Passed
    Oxygen sensor heater monitoring:  Passed
    Exhaust Gas Recirculation:  Passed
    Monday,01,July,2019,16:47:38:32117
    Mode 03: Emission related fault codes
    Address 7E8: No fault code found.
    Address 7E9: No fault code found.
    Monday,01,July,2019,16:48:05:32117
    Mode 07: Pending emission related fault codes
    Monday,01,July,2019,16:48:57:32117
    Type 02 - VIN : WAURVAFD5BN023530 (Address E8)
    Type 04 - Calibration ID : 4H0907560C Q0004 (Address E8)
    Type 04 - Calibration ID : 4H1158AD100622   (Address E9)
    Type 06 - Calibration Verification Number : 831BB1C6 (Address E8)
    Type 06 - Calibration Verification Number : B88C26AF (Address E9)
    Type 08 - In-use performance tracking :
        OBD Monitoring Conditions Encountered count : 3506
        Ignition cycle count : 9259
        Conditions completion count / Specified conditions encountered count
             Catalyst monitor bank 1 : 3002 / 3344
             Catalyst monitor bank 2 : 2945 / 3356
             O2 Sensor monitor bank 1 : 2260 / 3357
             O2 Sensor monitor bank 2 : 2215 / 3357
             EGR-VVT monitor : 7940 / 3503
             AIR monitor : 2118 / 1129
             EVAP monitor : 250 / 797
             Secondary O2 Sensor monitor bank 1 : 5252 / 3357
             Secondary O2 Sensor monitor bank 2 : 5306 / 3357
    Type 0A - Controller Name : ECM-EngineControl (Address E8)
    Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
  8. Likes Uwe liked this post
  9. #17
    CVN Spoofed...............
    I think you have missed the point of this......
  10. #18
    Jan 2017
    You're absolutely correct. Once again I have no idea what you're talking about. What does "CVN Spoofed" mean?
  11. #19
    CVN is a "Calibration Verification Number" -- it's basically a glorified checksum or hash of the software in your ECU. Its purpose is to allow an emissions inspection station to verify that the software in your ECU matches a list of them from the manufacturer, and that the software hasn't been fiddled with by a tuner.
    I'm not certain why Jack thinks yours is spoofed though.
  12. #20
    Oh I know it is and I'm keeping it close to my hip how I see it & because if I say how I see it and why, it will only be circumvented by the tuners.
    Tuners are indeed & for some time, like the last 15 years "some" of them, actively circumventing and spoofing a CVN and they even go out of their way to advertise it and this is in addition to just setting readiness status.
    Thank goodness VCDS still permits it to be detected to a degree.........
  13. Likes Fredrick Awuor liked this post
