Passat 2011 ECU coding
mohamed
Egypt
C?ID=211960
I have just changed a control unit for this car , and every trial to code it with coding helper it give me that the code rejected
could you help me with the correct code , as i dont have the old one ?
thanks in advance
auto-scan
Tuesday,25,June,2019,11:01:46:11183
VCDS Version: 18.2.0.3
VIN: WVWZZZ3CZCP029461   License Plate:
Mileage: 169240km-105160mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4F 52 53 56 62 72
VIN: WVWZZZ3CZCP029461   Mileage: 169240km-105160miles
Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 DH    HW: 03C 907 309 E
   Component: 1.4l R4 TSI   H15 7738
   Revision: L5H15---    Serial number: VWZCZ000000000
   Coding: 00000000000000000000
   Shop #: WSC 00028 028 00034
   ASAM Dataset: EV_ECM14TFS01103C906016BF 001006
   ROD: EV_ECM14TFS01103C906016BF.rod
   VCID: 68DA3AEF93587404B0-803C
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [175] - -
                    Mileage: 169243 km
                    Date: 2019.06.25
                    Time: 00:03:26
                    Engine speed: 707.50 /min
                    Normed load value: 19.6 %
                    Coolant temperature: 40 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 14.229 V
                    Mass flow through throttle valve: 8.7 kg/h
                    Median injection timing: 1.118 ms
10529 - Engine Control Module Incorrectly Coded
          P1612 00 [167] - -
                    Mileage: 169243 km
                    Vehicle speed: 255 km/h
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
Readiness: 1110 0101
   Part No SW: 0AM 300 048 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 9059
   Revision: 00043014    Serial number: CU501804246493
   Shop #: WSC 74565 000 00000
   VCID: 397CAFAB70723D8C1F-806C
Address 03: ABS Brakes        Labels: None
   Part No SW: 3AA 698 109     HW: 3AA 614 109 M
   Component: J104   C2 450M V441 0012
   Revision: --H07---    Serial number: 00000003620508
   Coding: 0000363
   Shop #: WSC 36002 360 89777
   VCID: 76E6649701EC92F432-8022
                    Reset counter: 65
                    Mileage: 169243 km
                    Date: 2013.11.15
                    Time: 00:03:44
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
                    Reset counter: 65
                    Mileage: 169243 km
                    Date: 2013.11.15
                    Time: 00:03:44
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000001002
   Shop #: WSC 00028 028 00021
   VCID: 6ED64CF7B1BCAA34FA-803A
   Part No SW: 3AA 937 087 A    HW: 3AA 937 087 A
   Component: BCM PQ47 H    413 0452
   Revision: BB413001
   Coding: 000000000000000000180280540081E443516488406C8D60648040200040
   Shop #: WSC 00028 028 00001
   VCID: 387AAAAF8B782484E0-806C
   Component: RLS 060111 05  54  0403
   Coding: 033028
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 65
                    Mileage: 169243 km
                    Date: 2013.11.15
                    Time: 00:03:27
                    Voltage: 13.95 V
00985 - Right Tail Light (M2)
                    Fault Status: 00101010
                    Reset counter: 105
                    Mileage: 169243 km
                    Date: 2013.11.15
                    Time: 00:06:55
                    Voltage: 12.15 V
                    Reset counter: 105
                    Mileage: 169243 km
                    Date: 2013.11.15
                    Time: 00:06:55
                    Voltage: 12.15 V
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
   Component: PARKHILFE PLA H04 0007
   Revision: --------    Serial number: 20431034402587
   Coding: 108105
   ASAM Dataset: EV_EPHVA2C000000000 001006
   ROD: EV_EPHVA2C000000000_001_VW36.rod
   VCID: 3C72B6BFB74008A404-8068
13638929 - Databus
                    Reset counter: 65
                    Mileage: 169243 km
                    Date: 2019.06.25
                    Time: 00:03:24
13679382 - Databus
          U1122 00 [009] - Implausible Message
                    Reset counter: 65
                    Mileage: 169243 km
                    Date: 2019.06.25
                    Time: 00:03:24
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PS1FKC
   Coding: 0012337
   Shop #: WSC 00028 790 00012
   VCID: 4C92E67F2FE0B824B4-8018
   Subsystem 1 - Serial number: 6332MTS668533480
   Subsystem 2 - Serial number: 6342MTS647193480
   Subsystem 3 - Serial number: 6351HTS6A1NGJ9KJ
   Subsystem 4 - Serial number: 6361HTS6U1JIJ9KJ
   Part No SW: 5K0 953 569 AS    HW: 5K0 953 569 AS
   Revision: --X01---    Serial number: 20151130300631
   Coding: 1992250000
   Shop #: WSC 54569 001 1048576
   VCID: 091C1F6BA812ED0C4F-805C
   Serial number: 70000000000000131901
   Coding: E30000
   Part No SW: 3AA 920 870     HW: 3AA 920 870
   Component: KOMBI         H20 0420
   Coding: 160F00
   VCID: 6FE851F3B6B6A33CF1-803A
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 040111F1002858
   Coding: 461006
   VCID: 34629E9F9710C0E4CC-8060
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0399
   Component: TUER-SG FT    002 0529
   Revision: 12110009    Serial number: 0002049417
   Coding: 0010B7
   Shop #: WSC 00028 028 00216
   VCID: 3564A39B946AD9ECFB-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000001873357
   Coding: 000090
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.3       1502
   VCID: 306A928FA308FCC4A8-8064
   Component:    KSG PQ47 ELV 043 0631
   Coding: 00910A0002860E763004941570084F0B607801
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: 6FE851F3BEB6A33CF1-803A
   Subsystem 1 - Part No SW: 3AA 919 204     HW: 3AA 919 204
   Component: Analoguhr  003 0003
   Component: TUER-SG BT    002 0529
   Revision: 14110009    Serial number: 0002034340
   Coding: 0010B6
   VCID: 3666A497896CD2F4F2-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000001864336
   Coding: 000090
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000109124
   Coding: 0022057
   VCID: 33609D83521EC7DCD5-8066
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  041 0167
   Revision: 00000001    Serial number: VWZ1Z3L5176448
   Coding: 0500040004
   VCID: 62CE28C77D641E546E-8036
                    Reset counter: 65
                    Mileage: 169243 km
                    Date: 2013.11.15
                    Time: 00:21:04
03138 - Input AUX IN
                    Reset counter: 65
                    Mileage: 169243 km
                    Date: 2013.11.15
                    Time: 00:03:38
End-------------------------(Elapsed Time: 03:07)--------------------------
MasterTommy
Amsterdam
C?ID=295586
I think you need to fix the immobilizer mismatch first.
Try something like this:
Address 01: Engine (J623-CAXA)       Labels: 03C-906-016-CAX2.clb
   Component: 1.4l R4 TSI   H18 7738
   Revision: L5H18---    Serial number: VWZCZ000000000
   Coding: 00250012002400000000
   Shop #: WSC 24287 001 1048576
   ASAM Dataset: EV_ECM14TFS01103C906016DH 001005
   ROD: EV_ECM14TFS01103C906016DH.rod
   VCID: 68DB5F7293DB4F7ED9-803C
What puzzles me about your current scan is that the ECU claims to be:
Yet the ASAM Dataset claims EV_ECM14TFS01103C906016BF
mohamed
Egypt
C?ID=211960
The code is worked thanks very much
as u asked about the software with DH
i have flashed the software of BF with the DH
