Results 1 to 2 of 2
Thread: 2012 A6 Avant. ESP/Tire Pressur/TPMS light on speedometer. Abs Parking break fault.
    Jun 2019
    Norway
    Hello
    This is my first post, and im no expert on VCDS. At start i did get the ESP/Tire pressur/TPMS light on speedometer random. But now im getting it at startup, all the time. Getting random ABS (Parking Break fault), but not all the time. Did a scan and getting fault codes. Did a Wheel speed test, and getting speed on all Wheels the same speed. Test light on ABS Module, and getting ground and Power to the ABS Module. Any tip on where to look ?? The car is working and no safe mode. If you getting same speed on the Wheel speed sensor on all Wheels, then you can rule out breaks in cable, wheel speed sensor or wheel bearing??
    Appreciate all the help tips.
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 3B 42 44 46 47 52 53 55
              5F 62 69 72 8F 90
    VIN: WAUZZZ4G0CN075391
    03-ABS Brakes -- Status: Cannot be reached 0100
    17-Instruments -- Status: Cannot be reached 0100
    3B-Sensor Elect. -- Status: Malfunction 0010
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9978
       Revision: 45H25---
       Coding: 12034012242401080000
       Shop #: WSC 24251 002 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018LB 003012
       ROD: EV_ECM20TDI01103L906018HA.rod
       VCID: 75D9A1AAD46031E7B6-8020
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 4G0 927 155 T    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H04 0005
       Revision: --H04---    Serial number: 0000000225
       Coding: 000001
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_TCMVL381 A02430
       ROD: EV_TCMVL381.rod
       VCID: 3C4F748EB7CAA0AF89-8068
       Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
       Component: ESP PREMIUM   H09 0250
       Coding: 06A187016085E180DB00
       ASAM Dataset: EV_ESPPremiAU57X 004017
       VCID: 345F5CAE9F9A68EF41-8060
       Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
       Coding: 01A93006000000000000
       VCID: 76DBA6A6C1663AFFBF-8022
       Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
       Component: KLIMA 2 ZONEN H10 0062
       Serial number: 27101100041208
       Coding: 34020008A0
       ASAM Dataset: EV_AirCondiBasisUDS 002037
       VCID: 247FACEE2F7AF86FD1-8070
       Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0100
       Revision: 20012002    Serial number: 00000001104388
       Coding: 2600E01040749FE08181008320001D0CCF9CC7082E090101000004602101
       VCID: 6DE989CAB430F9274E-8038
       Component: WWS57X 111004  H35 0051
       Serial number:         111008053654
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11740380
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 17 10 2011  00000434
       Component: Humidity_Sens  H02 0002
       Serial number: D318C4D5000000000001
       Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0050
       Revision: 11001001    Serial number: 55901129201780
       Coding: 090308
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: 3D49798AACD0A9A7BE-8068
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG00566DP
       Coding: 30323436313230303133554A304C34473053
       VCID: 365B66A689E67AFF7F-8062
       Serial number: 3575HRB405V0SM2M4P7A
       Serial number: 3585HRB405H0SM2MA0KY
       Serial number: 3515JRB405H0Q8K420O9
       Serial number: 3525JRB40650P7AOM92E
       Serial number: 3554VRB404P0P4N2E9M3
       Serial number: 3564VRB40530P4N2GOH
    1049600 - Databus
              U1121 00 [137] - Missing Message
                        Reset counter: 2
                        Mileage: 139629 km
                        Date: 2019.06.24
                        Time: 16:50:11
       Revision: 00000000    Serial number: 20111025000858
       Coding: 000015
       VCID: 305750BE638254CF25-8064
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Component: E221 - MFL  H08 0009
    Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 931 E    HW: 4G8 920 931 E
       Component: TDieRdw       H79 0375
       Revision: 26181120    Serial number: 658201011591011
       Coding: 13AF10000B010008010000
       ASAM Dataset: EV_RBD4K 004040
       ROD: N/A
       VCID: 305750BE6B8254CF25-8064
    Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
    No ASAM data for: "EV_RBD4K" (AU57)
       Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000287943
       Coding: 00CD074400
       ROD: EV_GatewUDS_AU57.rod
       VCID: 32535AB6658E66DF53-8066
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790810187
       Voltage stabilizer:
       Serial number: 11294002909011200410
    6151 - Instrument Cluster Control Module on Optical Bus
              U10C0 00 [009] - No Communication
                        Reset counter: 2
                        Mileage: 139629 km
                        Date: 2019.06.24
                        Time: 16:50:10
                        Voltage terminal 30: 12.3 V
                        Voltage terminal 15: 12.3 V
                        Control Module temperature: 46 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    4228 - No Communication with ABS Brake Control Module
              U0121 00 [009] - -
                        Reset counter: 2
                        Mileage: 139629 km
                        Date: 2019.06.24
                        Time: 16:50:10
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Revision: AA001002
       Coding: 02018264747464545425363E
       VCID: 335D5FB292946FD758-8066
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0004
       Revision: --------    Serial number: EJ1BPA4202FGB10
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D6949CA7CB039270E-8078
    2097156 - Internal Control Module Memory Check Sum Error
              B2000 00 [109] - -
                        Fault Frequency: 0
                        DCU Temperature: 0 °C
                        Voltage Clamp 15: 0.0 V
                        Voltage Clamp 30: 12.5 V
                        Ignition Cycle Count: 41895
                        Voltage UBDZ: 12.5 V
                        Voltage VDD1: 1.5 V
                        Voltage VDD3: 3.3 V
                        Voltage VDD3_STUCK: 1.9 V
                        Voltage VDD5: 5.0 V
                        Voltage VBG2: 2.5 V
                        Voltage GNDA: 0.0 V
    2117632 - Internal Control Module Memory Check Sum Error
              B2000 00 [109] - -
                        Fault Frequency: 0
                        Voltage VDD1: 1.5 V
                        Voltage VDD3: 3.3 V
                        Voltage VDD5: 5.0 V
                        Voltage VBG2: 2.5 V
                        Voltage GNDA: 0.0 V
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011F16204000628002080002
       Shop #: WSC 02312 785 00200
       VCID: 42B30A76DD2ED65FC3-8016
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0016199948
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0161760730
       Coding: 013A062020B9040083200984080104000000000000000000000000000000
       Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Serial number: 0000000AP00000456055
       Revision: CJ007000    Serial number: 00000000032217
       Shop #: WSC 16009 000 1048576
       VCID: 1D09990A0410C9A79E-8048
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: 41B1057AD828CD47DA-8014
       Revision: --------    Serial number: 00000000169621
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A6342D64D5E2E1FEB-807E
       Serial number: 111021-0004-083
       Coding: 112296101002A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C6F44CE47AA302F19-8078
       Part No SW: 4G0 035 188 E    HW: 4G0 035 188 C
       Component: RMC Cnct P DR H51 0775
       Coding: 0100010101C15B47402B060301020100000000
       VCID: 2961BDDA40582507E2-807C
       Subsystem 1 - Part No SW: 4G0 919 603     HW: 4G0 919 603
       Component: DU6 Basic  H42 0084
       Serial number: 9464I-0B0066348
       Subsystem 2 - Part No SW: 4G1 919 610 B    HW: 4G1 919 610
       Component: E380 BDT C7  H08 0204
       Serial number: 90349KJD0007A
                        Reset counter: 2
                        Mileage: 139629 km
                        Date: 2019.06.24
                        Time: 16:50:10
                        Voltage: 11.90 V
    03278 - Functionality Limited due to Missing Messages
                        Reset counter: 42
                        Bin. Bits: 01110110 01100000
                        Bin. Bits: 00000000 00000001
                        Fault Frequency: 13
                        Reset counter: 2
                        Mileage: 139629 km
                        Date: 2019.06.24
                        Time: 16:50:43
                        Bin. Bits: 10110111 10000010
                        Bin. Bits: 10000000 10001110
                        Bin. Bits: 00000000 00000000
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F14204000628002080002
       VCID: 44BF0C6EC73AD86FF1-8010
    Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
       Part No SW: 4G8 907 383     HW: 4G8 907 383
       Component: Anhaenger     H07 0072
       Revision: 5G001001    Serial number: 00000135966549
       Coding: 0100000000000000
       VCID: 71D195BAA8081DC76A-8024
       Component: TSG HR        H04 0212
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 315155BA60885DC72A-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
    End-------------------------(Elapsed Time: 04:06)--------------------------
    IMO, either the ABS module itself is being flaky, or there's some problem with the connections to it.
