Results 11 to 20 of 40
Thread: 2004 Audi A4 Cabriolet 3.0 no Dash illumination No AC No convertible top op
    I can't see it from here........... gypsy locksmiths usually dont have lawful or proper tools and could damage a cluster too!
  2. #12
    Jun 2019
    GA, USA
    Hi Jack I would like to take you up on your offer to pull the pin out of my used cluster. The gypsy locksmith pulled the pin from my ecu so that should be the same for my current cluster. Is there a reason that you would need the old cluster? Sorry I have not responded sooner. Have been under the weather. I can ship the cluster to you but need to know the hoops that you need me to jump through to prove ownership. The car is in my wife's name. I bought the used cluster from lkq on Ebay. Please give me an idea for your donation also. Don't want to insult you.
    Wayne
    awthompson1@bellsouth.net if you want to direct email me
  3. #13
    All inquiries are required in writing & started at the contact form & we will need all credentials + lawful receipts
    https://europeanpartsemporium.com/contact/
  4. #14
    Responded to query......
  5. #15
    HQ
    If the pin was pulled from the ECM, then you would have PIN for the original cluster since they will be matching PIN values. Have you tested said PIN yet? If you verify it works, then you would only need to get the PIN from the used cluster. Jack loves paperwork, I suspect he is just being very sure he can document he did everything within his powers to verify he isn't involved stolen parts/vehicles.... once PINs are provided, it is super trivial to just drive a car off a lot.
    Jef
  7. #16
    Jun 2019
    GA, USA
    I ran autoscan first with the replacement cluster shown below
    VIN: WAUAT48H74K015115   License Plate:
    Mileage: 117680km-73122mi   Repair Order: new cluster0711
    Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
              63 65 67 73 75 76 77
    VIN: WAUAT48H74K015115   Mileage: 117680km-73122miles
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
       Part No SW: 8E0 909 559 L    HW: 8E0 909 059
       Component: 3.0L V6/5V      G   0020
       Coding: 0016584
       Shop #: WSC 00672 785 00200
       VCID: 3E253F152C6D9CF7F85-5160
    18043 - Powertrain Data Bus
                P1635 - 008 - Missing Message from A/C Controller - Intermittent
    18107 - Powertrain Data Bus
                P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent
    16502 - Engine Coolant Temp. Sensor (G62)
                P0118 - 002 - Signal too High
                P1570 - 008 -
    Readiness: 0110 1101
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 8E2 910 156     HW: 01J 927 156 JK
       Component: V30 01J 3.0l 5V USA 3261
       Revision: 00000008    Serial number: 00000002100924
       Shop #: WSC 04940 001 00001
       VCID: 6597B079E97BEF2F59F-5160
       Part No: 8E0 614 517
       Component: ABS/ESP front       3429
       Coding: 04499
       Shop #: WSC 00672
       VCID: 6597B079EC7BEF2F59F-51F2
                35-00 - -
       Part No: 8E0 820 043 AC
       Component:   A4 Klimaautomat   1323
       Coding: 00100
       Shop #: WSC 00672
       VCID: 629DAB65FD559817BCD-513C
    6 Faults Found:
                27-00 - Implausible Signal
    00830 - Convertible Top Control Module (J256)
                49-00 - No Communications
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  USA 0517
       Coding: 01013
       Shop #: WSC 00672
       VCID: 353720391C5B5FAF29F-4B00
    6 Faults Found:
                57-00 - Electric Circuit Failure
    01502 - Bulb for Rear Fog; Left (L46)
                79-10 - Please Check Fault Codes - Intermittent
    Address 15: Airbags        Labels: 8H0-959-655-84.lbl
       Part No: 8H0 959 655 B
       Component: Airbag 8.4EC        2015
       Coding: 0010105
       VCID: 392F2C093543BBCFCD7-5184
    01217 - Side Airbag Igniter; Driver Side (N199)
                001 - Upper Limit Exceeded - Intermittent - MIL ON
    00591 - Seat Belt Switch; Driver (E24)
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0611
       Coding: 02041
       Shop #: WSC 00672
       VCID: 3E253F15296D9CF7F85-4B00
    01304 - Radio
       Part No: 8H0 920 950 HX
       Component: KOMBI+WEGFAHRS. RB4 D22
       Coding: 00231
       VCID: 094F9CC920236B4F9D7-5160
       WAUAC48H84K016676     AUZ6Z0C0422796
                29-10 - Short to Ground - Intermittent
    01177 - Engine Control Unit
                65-10 - Unauthorized - Intermittent
    01176 - Key
    01304 - Radio
    Address 26: Auto Roof        Labels: 8H0-959-255.lbl
       Part No: 8H0 959 255
       Component:  VSG  B6 CABRIO     6286
       VCID: 73B3DE2157AF019FC7B-5160
    02000 - Switch Position
       Part No: 8H0 959 760
       Component: Sitzmemory EE H05   X014
       Coding: 00002
       Shop #: WSC 00065
       VCID: 74B1DD3D579106A7DE1-4B1E
    02010 - Left Entry Assistance Control Module (J572)
                79-00 - Please Check Fault Codes
       Part No: 8H0 959 433 C
       Component: Komfortgerát T7B    1412
       Coding: 11788
       Shop #: WSC 00672
       VCID: 34311D3D172146A71E1-4B00
       Subsystem 1 - Part No: 8H1959801
       Component: Tõrsteuer.FS BRM 0001
       Subsystem 2 - Part No: 8H1959802
       Component: Tõrsteuer.BF BRM 0001
       Subsystem 3 - Part No: 8H0959801A
       Component: Tõrsteuer.HL BRM 0001
       Subsystem 4 - Part No: 8H0959802A
       Component: Tõrsteuer.HR BRM 0001
    7 Faults Found:
    00955 - Key 1
                35-10 - - - Intermittent
    00532 - Supply Voltage B+
                37-10 - Faulty - Intermittent
    Address 63: Entry Assist,D        Labels: None
       Part No: 8H0 959 760 A
       Component: EasyEntry F M H12   X024
       Coding: 00006
       Shop #: WSC 00065
       VCID: 353720391C6B5FAF29F-4B1E
    Address 73: Entry Assist, P        Labels: None
       Component: EasyEntry BF  H12   X024
       Coding: 00005
       Shop #: WSC 00065
    End----(Elapsed Time: 05:55, VBatt start/end: 11.6V/11.6V. VIgn 11.7V)-----
    I cleared codes and reinstalled the original cluster and ran auto scan shown below
    Mileage: 115910km-72023mi   Repair Order: old cluster 0711
    VIN: WAUAT48H74K015115   Mileage: 115910km-72023miles
       Coding: 0016584
    Address 03: ABS Brakes        Labels: None
       VCID: 55F780B9BC1B7FAFC9F-51F2
    No Faults Found
       Coding: 00100
       Shop #: WSC 00672
       VCID: 629DAB65FD559817BCD-5160
    No Faults Found
       Coding: 01013
       Shop #: WSC 00672
    6 Faults Found:
       Coding: 0010105
       Coding: 02041
       Shop #: WSC 00672
    01304 - Radio
       Coding: 00231
       VCID: 313F1429E833738F757-5160
       WAUAT48H74K015115     AUZ6Z0C0421820
    10 Faults Found:
    01304 - Radio
       Coding: 00002
       Shop #: WSC 00065
       Coding: 11788
       Shop #: WSC 00672
       Coding: 00006
       Shop #: WSC 00065
       Coding: 00005
       Shop #: WSC 00065
    End----------(Elapsed Time: 05:58, VBatt start/end: 12.6V/12.5V)-----------
    I also attempted to login to the Instrument cluster with the pin code from the ecu. I selected the 17 instrument and then hit login
    I put in the pin
    I did not get an error The screen just looked the same but had a changing latency spinner so was not sure of success since I am a newbie
    The replacement cluster says SAFE when the ignition switch is turned on but displays the mileage on that cluster when the door is just opened before turning on ignition.
    Thoughts?
  8. #17
    Original
    Vehicle Identification No. WAUAT48H74K015115
    Model Audi A4 Cabrio. 3,0
    AA4C
    Date of production 02.12.2003
    Model year 2004
    Sales type 8H75FH
    Engine Code AVK
    Transmission Code GHS
    INDEED A MATCH
    PART NUMBER DESCRIPTION REMARK MODEL
    * 8H0 920 950 HX instrument cluster 160MPH "USA"+
    PR-9Q2
    Dropped: Apr 1, 2014 (EKZ: M)
    Vehicle intelligent genuine part.
    Order only with additional instructions.
    Supersession
    PART NUMBER DESCRIPTION REMARK MODEL RRP
    8H0 920 950 H instrument cluster $1,330.00
    Salvage unit
    Vehicle Identification No. WAUAC48H84K016676
    Model Audi A4 Cabrio. 1,8
    AA4C
    Date of production 06.01.2004
    Model year 2004
    Sales type 8H752H
    Engine Code AMB
    Transmission Code GHX
    JPPSG redundancy check
    https://forums.ross-tech.com/showthr...l=1#post110617
    VINCheck Results
    VIN: WAUAC48H84K016676
    VINCheck Theft Record
    VIN: WAUAC48H84K016676 has not been identified as a vehicle listed in the VINCheck Theft Records.
    VINCheck is updated regularly as additional information is reported.
    VINCheck Total Loss Record
    VIN: WAUAC48H84K016676 has been identified as a vehicle listed in the VINCheck Salvage Records.
    Date of loss2018-08-22Cause of lossCollisionDate of loss2018-05-13Cause of lossCollision
    SCREENSHOT IN EMAIL DOESN'T SHOW A LOGIN SUCCEEDED!
  9. #18
    In custody of equipment and cross checking data, sub system redundancy check!
    3 keys.......one with note that went under water for remote.
    All 3 keys transponder indeed function.
    ECU present and communicates with continuity of identity.
    Clusters present and communicate with continuity of identities on record aforementioned of thread.
    Wait times are compounded and equipment is in lock up for clock times to commence in donor cluster & with count down from improper tampering!
    Units show physical & electronic tampering.
    OP: A "rouge" key is apparent, do you have this 4th rouge key?
    Thank you for the homemade roasted coffee, I will grind this and run in perk pot!
  10. Likes Uwe liked this post
  11. #19
    After wait times, observations determine a data transfer is indeed possible & after a repair.
    This preserves all keys including the rouge key if still functional or in possession.
  12. #20
    Success!
    DATA TRANSFER AS DETAILED BELOW TO TARGET!
    NO STRIP of prior identity! Discarded! No dual identities exist!
    NO IMMO DEFEAT!
    4 KEYS one rouge other 3 verified operation for transponders only!
    Mileage preserved & unaltered!
    FYI: Sometimes 0x17-10- gateway settings need to be reestablished upon installation or power down!
    Control Module Part Number: 8H0 920 950 HX
      Component and/or Version: KOMBI+WEGFAHRS. NJA D22
               Software Coding: 00231
                Work Shop Code: WSC 03738
               Additional Info: WAUAT48H74K015115     AUZ6Z0C0421820
                          VCID: 09126F0433632707CE-5120
                    Address 17: Instruments  (8H0 920 950 HX)
    13:00:57
      115910 km   Odometer
       1   Engine Start permitted
       1   Engine (ECU) responds
       1   Key Status
       4   Number of adapted Keys
       1   Variable Code authorized
       1   Key Status (Transponder)
       1   Fixed Code authorized
       6   Immobilizer Status
      0.0   Lock-Time Instrument Cluster
      0.0   Lock-Time Engine (ECU)
    Adaptation Channel 060:
    Stored value 1031
    CAN-Databus Powertrain (Installation List)
    Adaptation Channel 061:
    Stored value 3459
    CAN-Databus Comfort (Installation List)
    Adaptation Channel 062:
    Stored value 17
    CAN-Databus Infotainment (Installation List)
                    Address 01: Engine
    Control Module Part Number: 8E0 909 559 L
      Component and/or Version: 3.0L V6/5V      G   0020
               Software Coding: 0016584
                          VCID: 3E78CCD86A2DD0BFAB-513C
    Flash Status
         Programming Attempts: 0
         Successful Attempts: 0
         Programming Status: 00000000
         Required Conditions: 00000100
    Software
         P0000
         A4.0.3
    Misc.
         Hardware number: 8E0 909 059
    VCDS Info:
           Readiness: 06C-909-559-ASN.crd
    Mode 03: Emission related fault codes
    Address 10 (Engine): No fault code found.
    Mode 9 : Calibration Identification
    Type 04 - Calibration ID : 8E0909559L  0020 (Address 10)
    Type 06 - Calibration Verification Number : 2FEA55D1 (Address 10)
  13. Likes Uwe, PetrolDave, Fredrick Awuor liked this post
