Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: 2004 Audi A4 Cabriolet 3.0 no Dash illumination No AC No convertible top op
    Jun 2019
    GA, USA
    Hi
    First time Post
    Just purchased VCDS from Ross Tech (Newbie)
    Audi A4 Cabriolet 3.0 AVK aftermarket radio 2014 aftermarket radio amp 2014 no steering wheel radio control Rebuilt instrument cluster for gauge and error problems at Modulemasters 10/2015
    Symptoms: No Instrument Cluster illumination, no ac except with defrost button, no convertible roof operation, Turn signals operate on outside, No turn signal indicator in instrument cluster, No convertible light shows up in instrument cluster at any time
    I assumed with 10 faults on the instrument cluster and other instrument and immoblilizer related faults that the instrument cluster was bad. I sent the instrument cluster back to modulemasters. They were very nice about relooking at the cluster, but found no issues. Suggested that i isolate the other modules to see if the functionality returned. I tore the car apart to get to other modules and unplugged individually but no return of functionality. Was happy no water in floor at CCM . I ordered a used instrument cluster which will be here early next week. I am a little uncertain about adaptation and would like any opinions as to whether the cluster is actuallly the problem. My daughter is hounding me for a new car for college. Car is in good shape otherwise. Hate to give up.
    Thank you for any ideas
    Wayne
    Below is Auto scan from a couple of weeks ago after initial clearing of faults and a rescan
    Saturday,08,June,2019,09:38:44:41616
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WAUAT48H74K015115   License Plate:
    Mileage: 115850km-71985mi   Repair Order:
    Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
              63 65 67 73 75 76 77
    VIN: WAUAT48H74K015115   Mileage: 115850km-71985miles
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
       Part No SW: 8E0 909 559 L    HW: 8E0 909 059
       Component: 3.0L V6/5V      G   0020
       Coding: 0016584
       Shop #: WSC 00672 785 00200
       VCID: 3E253F152C6D9CF7F8D-5160
    18043 - Powertrain Data Bus
                P1635 - 008 - Missing Message from A/C Controller
    18107 - Powertrain Data Bus
                P1699 - 008 - Missing Message from Steering Wheel Electronics
    Readiness: 0110 1101
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 8E2 910 156     HW: 01J 927 156 JK
       Component: V30 01J 3.0l 5V USA 3261
       Revision: 00000008    Serial number: 00000002100924
       Shop #: WSC 04940 001 00001
       VCID: 6597B079E97BEF2F597-5160
       Part No: 8E0 614 517
       Component: ABS/ESP front       3429
       Coding: 04499
       Shop #: WSC 00672
       VCID: 6597B079EC7BEF2F597-51F2
       Part No: 8E0 820 043 AC
       Component:   A4 Klimaautomat   1323
       Coding: 00100
       Shop #: WSC 00672
       VCID: 629DAB65FD559817BC5-513C
                49-00 - No Communications
                27-00 - Implausible Signal
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  USA 0517
       Coding: 01013
       Shop #: WSC 00672
       VCID: 353720391C5B5FAF297-4B00
    01502 - Bulb for Rear Fog; Left (L46)
                57-00 - Electric Circuit Failure
                79-00 - Please Check Fault Codes
    Address 15: Airbags        Labels: 8H0-959-655-84.lbl
       Part No: 8H0 959 655 B
       Component: Airbag 8.4EC        2015
       Coding: 0010105
       VCID: 392F2C093543BBCFCDF-5184
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0611
       Coding: 02041
       Shop #: WSC 00672
       VCID: 3E253F15296D9CF7F8D-4B00
    01304 - Radio
       Part No: 8H0 920 950 H
       Component: KOMBI+WEGFAHRS. RB4 D22
       Coding: 00231
       Shop #: WSC 05127
       VCID: 313F1429E833738F75F-5160
       WAUAT48H74K015115     AUZ6Z0C0421820
    10 Faults Found:
    00830 - Convertible Top Control Module (J256)
    01304 - Radio
    Address 26: Auto Roof        Labels: 8H0-959-255.lbl
       Part No: 8H0 959 255
       Component:  VSG  B6 CABRIO     6286
       VCID: 73B3DE2157AF019FC73-5160
       Part No: 8H0 959 760
       Component: Sitzmemory EE H05   X014
       Coding: 00002
       Shop #: WSC 00065
       VCID: 74B1DD3D579106A7DE9-4B1E
    02010 - Left Entry Assistance Control Module (J572)
       Part No: 8H0 959 433 C
       Component: Komfortgerát T7B    1412
       Coding: 11788
       Shop #: WSC 00672
       VCID: 34311D3D172146A71E9-4B00
       Subsystem 1 - Part No: 8H1959801
       Component: Tõrsteuer.FS BRM 0001
       Subsystem 2 - Part No: 8H1959802
       Component: Tõrsteuer.BF BRM 0001
       Subsystem 3 - Part No: 8H0959801A
       Component: Tõrsteuer.HL BRM 0001
       Subsystem 4 - Part No: 8H0959802A
       Component: Tõrsteuer.HR BRM 0001
    Address 63: Entry Assist,D        Labels: None
       Part No: 8H0 959 760 A
       Component: EasyEntry F M H12   X024
       Coding: 00006
       Shop #: WSC 00065
       VCID: 353720391C6B5FAF297-4B1E
    Address 73: Entry Assist, P        Labels: None
       Component: EasyEntry BF  H12   X024
       Coding: 00005
       Shop #: WSC 00065
    End----------(Elapsed Time: 05:51, VBatt start/end: 12.7V/12.3V)-----------
    HQ
    At face value, it would seem that the instrument cluster is roached. Have you tried doing the Output Test functions on the instrument cluster to verify that it works as expected?
    Lets roll with a failed instrument cluster for now.... the big issue you will have is getting PINs for the immobilizer system.
    As noted in the video, VCDS does not get the PIN information. Getting the PINs can be tricky.... there are tools out there that do this, but the ones that work are expensive. The ones that are cheap lead to this question:
    Quote Originally Posted by cheap PIN tool user
    What does "def" in the odometer mean?
    def = defective.... we've seen a lot of cheap PIN tools brick instrument clusters.
    Having said all this... if the cluster is the issue, and you get a proper replacement, even without matching up the immobilizer you should be able to get the top to work.
    Jef
  3. Likes Uwe, Fredrick Awuor liked this post
    JPPSG and check fuses + for water ingress, sort communication errors with RTFB using WD and DVOM.
    Test overlay maybe helpful.
    RTFB can be found here.
  5. Likes Uwe liked this post
  6. #4
    Jun 2019
    GA, USA
    Thanks for your input. I have torn the car apart and have seen no water encroachment. I have checked fuses. I was hoping to change the cluster to eliminate that before tracing a lot of other areas but it sounds like getting the pins for the original and donor cluster may be my issue. Any good cheap ideas would be appreciated. Also not real great with wiring diagrams
    The cheapest is DVOM testing pin by pin just time.........no magic answers, only above majestic security clearance........
    Jun 2019
    GA, USA
    Hi
    Just an update. I received my replacement instrument cluster and switched out. It appears that all of the functionality has been corrected I have a blinking convertible light but that will probably be resolved with a top reset since I manually opened. I had no light at all with old cluster. Now the proverbial question of how to get programmed to the car. Spoke to a VW tech who said an Audi dealer could program for about an hour labor as he has access to audi database. Is that my best option? Scared of dealers. Any suggestions appreciated. I dont even care if the mileage is changed since mine has 72k and that one is 73k. It may have come from a 1.8 and mine is 3.0 but my daughter knows nothing about tachometers
    Wayne
    HQ
    The dealer may be in for a bit of a surprise. ODIS is like a Dyson vacuum cleaner. A lot of dealers won't get involved with used modules because they have been burned by ODIS not working as it should.
    Make some phone calls to automotive lock smiths and see what they would charge to pull PINs out of both instrument clusters. Because once you have those PINs, you can match things up yourself.
    Jef
  10. #8
    Jun 2019
    GA, USA
    Thanks Jef
    I appreciate the feedback. Do you or anyone know any such locksmiths in the North Atlanta area?
    I will call around but no use reinventing the wheel if the info is available.
  11. #9
    I'll do it for donation + freight through mail as long as you jump through hoops of fire to authenticate your credentials and the receipt for proof of purchase?
  12. Likes Uwe liked this post
  13. #10
    Jun 2019
    GA, USA
    Thanks for all your help, guys. Audi dealer would not touch anything pre 2008. I found an automotive locksmith locally who was willing to read the pins. He came on Saturday. He had several different computer tools. He was able to read the pin on the ecu but was not able to access either of the clusters. I would think that the old cluster has the same pin as the ecu but that does not solve my adaptation issue. Thanks, Jack for the offer of reading both cluster pins. My concern is that even with both pins that I will not be able to access the clusters to change over. It seems that all my functionality came back with the replacement cluster so I am not sure why the guy could not access. The locksmith seemed to think there was still some communication issue. Any thoughts? At this point, I dont want to throw good money after bad.
