Results 1 to 7 of 7
Thread: 2009 Caddy 1.9 TDI 5 Speed - Won't start
    Jan 2019
    1.9tdi bls engine code.New battery, new tandem pump. new temp sensor. new fuel pipes and clamps.new fuel filter and rings. waiting for a new injector harness to arrive. but one in looks fine and ohm resistance is 0.1 with continuity on all wiring. all earths cleaned from chassis and engine. Egr valve removed and cleaned. can hear pump in the tank running for 1-2 seconds. hard starting and idle seems fine. when driving seems ok then starts to juddering in 3,4th gears. then stalls and wont start up again until it cools but again it is hard starting. starting motor shows as 295rpm. The battery replaced was 62 amp and now 72 amp.
    van still struggles to start and once its started and hot, the engine wont start again.
    Monday,24,June,2019,21:18:02:18214
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WV1ZZZ2KZAX063763   License Plate:
    Chassis Type: 2K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 46 52 56
    VIN: WV1ZZZ2KZAX063763   Mileage: 246670km-153273miles
    Address 01: Engine        Labels: 03G-906-021-BLS.clb
       Part No SW: 03G 906 021 PD    HW: 03G 906 021 CG
       Component: R4 1,9L EDC  000SG  2387
       Revision: --H11---    Serial number: VWX7Z0I93NQ0KX
       Coding: 0000071
       Shop #: WSC 00000 256 01574
       VCID: 70B9D32AE6A761E73A1-8024
    000769 - Cylinder 1
                   P0301 - 000 - Misfire Detected - Intermittent
                        Fault Status: 00110000
                        Mileage: 246664 km
                        Time: 11:52:20
                        RPM: 819 /min
                        Voltage: 14.21 V
                        Inj. Quantity: 2.96 mg/str
                        Temperature: 67.5C
                        (no units): 0.0
    000258 - Mass Air Flow Sensor (G70)
                   P0102 - 000 - Signal too Low - Intermittent
                        Mileage: 246665 km
                        Time: 01:49:13
                        RPM: 840 /min
                        Duty Cycle: 100.6 %
                        Bin. Bits: 00000000
                        Mass Air / Rev.: 240.0 mg/str
                        Mass Air / Rev.: 0.0 mg/str
    000770 - Cylinder 2
                   P0302 - 000 - Misfire Detected
                        Fault Status: 01110000
                        Mileage: 246667 km
                        Time: 00:15:57
                        RPM: 798 /min
                        Voltage: 14.44 V
                        Temperature: 46.8C
                        (no units): 0.0
    008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
                   P2185 - 000 - Signal too High - Intermittent
                        Mileage: 246667 km
                        Time: 00:16:11
                        RPM: 819 /min
                        Voltage: 14.44 V
                        Bin. Bits: 00000100
                        Temperature: 66.6C
                        Temperature: 47.7C
    012295 - Camshaft Position Sensor (G40)
                   P3007 - 000 - No Signal - Intermittent
                        Mileage: 246677 km
                        Time: 06:29:59
                        RPM: 294 /min
                        Load: 100.0 %
                        Voltage: 11.17 V
                        Bin. Bits: 00000100
                        Idle Stabilization: 0.0KW
                        (no units): 32.0
    Readiness: 0 1 0 0 1
    Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
       Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
       Component: MABS MK70M          0104
       Revision: 00H32001
       Coding: 0020801
       Shop #: WSC 35110 377 00157
       VCID: 76B5E53284C34FD7E0D-8022
       Part No SW: 2K0 820 047 BM    HW: 2K0 820 047 BM
       Component: Climatic PQ35   143 1515
       Revision: 00143033    Serial number: 00000000000000
       VCID: 71BFD62EEDAD68EF35F-8024
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
       Revision: 00H54000    Serial number: 01000003455243
       Coding: 00804F030004100057000000000000000009FB075C000120000000000000
       Shop #: WSC 35110 377 08192
       VCID: 323D1922282B13F70C5-8066
       Subsystem 1 - Part No: 1T2 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 071009 021  0512
       Coding: 00038805
       Shop #: WSC 35110
    Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
       Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
       Component: 2Q AIRBAG VW52  025 2400
       Revision: 06025000    Serial number: 0037TR05HC4I
       Coding: 0012881
       VCID: 7DA7FA1EA1F51C8FA17-8028
       Part No SW: 1K0 953 549 CT    HW: 1K0 953 549 CT
       Component: J0527           053 0111
       VCID: 065595F2F4235F57F0D-8052
       Part No SW: 2K0 920 944 C    HW: 2K0 920 944 C
       Component: KOMBIINSTRUMENT VDD 1222
       Revision: V0002000    Serial number: VWX7Z0I93NQ0KX
       Coding: 0016401
       Shop #: WSC 00288 210 87232
       VCID: 2C01075A0A0F4507469-8078
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H07 0111
       Revision:   H07 01    Serial number: 221009F1000624
       Coding: 89801F06000202007401
       VCID: 698FBE4EC57D902F7DF-803C
       Component: IMMO            VDD 1222
    Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
       Part No: 1K0 959 793
       Component: Tuersteuergeraet 02 0160
       Coding: 0000000
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 CP
       Coding: 018A0C087F2D8C0D4858061000C0
       VCID: 005983EAD6077167CA1-8054
    Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
       Part No: 1K0 959 792
       Coding: 0000000
       VCID: 75B7E23E99C544CFE97-8020
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  013 0036
       Revision: 00000000    Serial number: VWZ1Z2I6759399
       Coding: 0000020001
       VCID: 6597B27E2565B44F597-8030
                        Fault Status: 00101011
                        Reset counter: 54
                        Mileage: 246617 km
                        Time: 20:59:35
                        Reset counter: 54
                        Mileage: 246617 km
                        Time: 20:59:35
    End----------(Elapsed Time: 00:52, VBatt start/end: 12.5V/12.5V)-----------
    once the faults are cleared, they stay clear. Some of these faults are from when ive had things unplugged.
    apologies for wording
  2. Likes Boki Ar liked this post
  3. #2
    G40 faulty....!
    Water ingress in ECU?
    HPP in head damaged or fuel port to injectors obstructed, possible harness chafe or short to other circuit
    G28 faulty?
    That's a lot if parts....
    Maybe buy RTFB can be found here.
    Quote Originally Posted by Gashhey View Post
    Even after attempting to start it?
    Jan 2019
    Yes, which is both annoying and confusing.
    I'm currently on replacing the injector wiring harness and ill get back to you to update you guys.
    ECU is dry and clean, all earths have been cleaned.
    EGR valve has been cleaned.
    tandem pump been replaced.
    no other fault codes.
    it seems when it gets hot, it wont start.
    Jan 2019
    just replaced wiring loom, still no different.
    It has now caused a Cylinder 2 Misfire fault code.
    If it doesn't start how does it misfire?
    Compression check?
  8. Likes Uwe, PetrolDave, Fredrick Awuor liked this post
    Jun 2019
    Check engine wire loom under the battery and air filter box.
    I have once repaired one of 1.9tdi altea xl there was 4 wires faulty wires that makes same kind of problems...
  10. Likes Uwe liked this post
