Results 1 to 6 of 6
Thread: Passat 3C lost ABS and EPB coding
    Mar 2016
    Passat 3C, other shop fitted new EPB without making a note of the old codings, they have tried some other codings without luck. Attached autoscan, if someone has coding I can try it's much appreciated!
    VIN: WVWZZZ3CZ8E054331   License Plate:
    Mileage: 252690km-157014mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ8E054331   Mileage: 252690km-157014miles
    Address 01: Engine        Labels: 03G-906-018-BMN.clb
       Part No SW: 03G 906 018 AS    HW: 03G 906 018 AS
       Component: R4 2.0l PPD1.2      9971
       Revision: --H42---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 00591 210 83198
       VCID: 76E3B117019C3DFAF7-8022
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 008 -  - Intermittent
                        Reset counter: 40
                        Mileage: 252676 km
                        Time: 14:26:58
                        Torque: 144.0 Nm
                            0.00 %
                        Voltage: 12.32 V
                        Bin. Bits: 00000100
                        Torque: 1016.0 Nm
    Readiness: N/A
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 C    HW: 3C0 614 109 C
       Component: J104    C4 440 V1   0003
       Revision: --020---    Serial number: 00000775843338
       Coding: 0000282
       Shop #: WSC 05311 000 00000
       VCID: 1E3389B7C9ECD5BACF-804A
                        Fault Priority: 9
                        Reset counter: 45
                        Mileage: 252690 km
                        Time: 09:19:05
                        Hex Value: 0x0000
                        Voltage: 14.25 V
                        Bin. Bits: 00011110
                        Count: 228
                        Reset counter: 45
                        Mileage: 252690 km
                        Time: 09:19:05
                        Hex Value: 0x0000
                        Voltage: 14.25 V
                        Bin. Bits: 00011110
                        Count: 149
                        Reset counter: 45
                        Mileage: 252690 km
                        Time: 09:19:05
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 BT    HW: 3C0 907 044 BT
       Component: ClimatronicPQ46 122 0707
       Revision: 00122021    Serial number: 00000000000000
       VCID: 74E78B1F17E02FEAC9-8020
                        Fault Status: 00111110
                        Fault Frequency: 9
                        Reset counter: 85
                        Mileage: 252676 km
                        Time: 13:32:23
       Revision: 00H54000    Serial number: 01000007353195
       Coding: E1800F0700041A00470A00000F00000000085D435C000100000000000000
       Shop #: WSC 05124 000 00000
       VCID: 71E9820B68F21AC222-8024
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 190707 022  0601
       Coding: 00046997
       Shop #: WSC 05124
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     180707 046  0204
       Coding: 00208933
       Shop #: WSC 05124
       Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
       Component: 0C AIRBAG VW8   032 2522
       Revision: 12032000    Serial number: 003B1PEBRGYD
       Coding: 0012355
       VCID: 306F470FA37853CA6D-8064
       Subsystem 1 - Serial number: 6332MSME18636956
       Subsystem 2 - Serial number: 6342MSME1C0D485E
       Subsystem 3 - Serial number: 6351HTS618LCSMK6
       Subsystem 4 - Serial number: 6361HTS618LCM5N6
       Part No SW: 3C0 953 549 J    HW: 3C0 953 549 J
       Component: Lenksäulenmodul 006 0010
       Revision: 00006000    Serial number: 3C5953507BC
       Coding: 0000003
       VCID: 33654803526E68D210-8066
       Part No SW: 3C0 920 960 N    HW: 3C0 920 960 N
       Component: KOMBIINSTRUMENT VD1 1216
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0007405
       Shop #: WSC 00591 067 57207
       VCID: 2E535977B94C453A7F-807A
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 E    HW: 3C0 907 951
       Component: J533__Gateway   H10 0080
       Revision:   H10       Serial number: 1200P077180947
       Coding: F9807F060002021003
       VCID: 2345B843E28EF852E0-8076
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       Shop #: WSC 00488 210 01865
       VCID: 39797A2B70029282DA-806C
       Component: J386  TUER-SG FT    1132
       Revision: 32008001    Serial number: 00000513678801
       Coding: 0000693
       VCID: 3B7560237A3EA092C8-806E
                        Fault Status: 00100101
                        Reset counter: 85
                        Mileage: 252676 km
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.069 H08 1901
       Shop #: WSC 00591 210 71797
       VCID: 36637117411C7DFA37-8062
    02546 - Steering Limit Stop
                        Mileage: 252680 km
                        Temperature: 28.0°C
                        Voltage: 12.30 V
                        Voltage: 12.10 V
       Component:    KSG PQ46 ELV 042 0472
       Coding: 01910A0001860E763004941570085FCE107CA0
       Component: LIN BACKUP HORN H07 9001
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1132
       Revision: 32008001    Serial number: 00000028378717
       Coding: 0000692
       VCID: 3C77633F7F30A7AAC1-8068
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H21       Serial number: 00000000156805
       Coding: 0021156
       VCID: 387F7F2F4B088B8A25-806C
    03194 - Incompatible Interface
                        Reset counter: 45
                        Mileage: 252690 km
                        Voltage: 14.00 V
                        Count: 95
                        Hex Value: 0x1263
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Fault Status: 01110000
                        Reset counter: 45
                        Voltage: 13.90 V
                        Count: 41
                        Hex Value: 0x0140
                        Hex Value: 0x0082
                        Hex Value: 0x4040
       Part No: 1K0 035 186 AD
       Component: Radio GR0       033 0033
       Revision: 0003303S    Serial number: VWZ2Z2G2133720
       Coding: 0040400
       Shop #: WSC 05314 000 00000
       VCID: 68DFEF6F5B28DB0A75-803C
       Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
       Component: J388   TUER-SG HL   1118
       Revision: 11006001    Serial number: 00000002091642
       Coding: 0000144
       VCID: 3D716E3B642AAEA2F6-8068
                        Reset counter: 45
                        Mileage: 252690 km
       Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
       Component: J389   TUER-SG HR   1118
       Revision: 11006001    Serial number: 00000002080438
       Coding: 0000144
       VCID: 3E736937692CB5BAEF-806A
  2. Likes Uwe liked this post
  3. #2
    16.4905° S, 151.7375° W
    Based on the information you have provided and the VIN, the [03-ABS Brakes] (J104) coding should be as follows:
    Coding: [0001306]
    Follow the Basic Setting procedure found on the Ross-Tech wiki page linked below for the G85-Steering Angle Sensor.
    http://wiki.ross-tech.com/wiki/index...ke_Electronics
    Also you will need to perform the Function Test in the [53-Parking Brake]
    If you have any faults left or other concerns, post up a new Auto-Scan so we can see what is going on, thanks.
    Hope this helps,
    drp
    HQ
    Vehicle Identification No. WVWZZZ3CZ8E054331
    Model passat sedan
    PA
    Date of production 24.08.2007
    Model year 2008
    Sales type 3C2272
    Engine Code BMR
    Transmission Code KDS
    As per the VIN info, I come up with the same values, ABS coding of 0001306 and EPB coding of 0021156... but you can also try for the EPB coding 0021056.
    Just to verify, the ABS module is still the factory installed original unit?
    Jef
  5. Likes Jack@European_Parts, totaltuning liked this post
  6. #4
    Coding: 0013602 or Coding: 0004363
    Maybe these too?
    3C chassis is a tricky Dick........
  7. Likes DrPeter, Uwe, totaltuning liked this post
  8. #5
    Mar 2016
    Thanks guys, all sorted now, ABS coding 0001306 was correct. I had to change the EPB coding to 0021056 as Jef suggested (with the 0021156 coding I still had the dtc 03194 - Incompatible Interface and the yellow P lamp lit on the dash). Cheers again!
  9. Likes Uwe, Jack@European_Parts, DrPeter, Jef, Dana liked this post
  10. #6
    Cool,
    Did you try activating the EPB button on/off/on/off, switch the ignition off, lock the vehicle and wait about 5 minutes... Then start the vehicle and recheck for codes..
    Also make sure you switch ignition off for about 45 seconds after any EPB coding changes.
    Let us know if this helps,
    drpeter
  11. Likes Dana, Uwe, Jack@European_Parts liked this post
