First post, error codes, S5 2014. Code 00458, 03705
Robbie73w
C?ID=370271
Hi guys, can any body help with the errors I have below.
I carried out a scan as my auto start/stop no longer works.
This happened after replacing the battery.
I've checked the coding for the battery and it seems ok.
I've also checked all fuses and examined all the wiring including the connection for monitoring at the battery itself.
I'm at a loss now as I can't get rid of these codes.
The car starts and runs fine, just no start/stop.
Monday,27,May,2019,17:40:30:30223
VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4505.4
VIN: WAUZZZ8T1FA014375   License Plate:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 30 36 42 44 46 52 53 56 5F
          6C A9
VIN: WAUZZZ8T1FA014375   Mileage: 67190km-41749miles
Address 01: Engine (J623-CREC)       Labels: None
   Part No SW: 8K2 907 551 A    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0003
   Revision: --H10---
   Coding: 1A2500340427010B2800
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K2907551A 002003
   ROD: EV_ECM30TFS0218K2907551_002.rod
   VCID: 313EE07241AE3A7F213-8064
Readiness: 1110 0001
   Part No SW: 8K0 927 166     HW: 0B5 927 156 K
   Component: 0B5 30TFSIRdW H02 0002
   Revision: --H02---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001019
   ROD: EV_TCMDL501021.rod
   VCID: 72BC2F7E84284167989-8026
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Coding: 291DCC01
   VCID: 094E6892893E22BFC93-805C
   Part No SW: 8K0 907 064 JE    HW: 8K0 907 064 JE
   Component: BCM2 2.0      H14 0650
   Coding: 01B04040000000000000
   VCID: 7CA00146D6EC0717C25-8028
   Subsystem 1 - Part No SW: 8K0 959 754 AH    HW: 8K0 959 754 AH
   Serial number: 0514000090953012
   Serial number: 0214000132448012
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0077
   Revision: AA000000    Serial number: 00000108711556
   Coding: 01237025002C00000000
   VCID: 45D6A4A2E5A686DFEDB-8010
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01140720142252
   Coding: 6626028000
   VCID: 78A81D56E2D42B37A6D-802C
   Revision: 08016001    Serial number: 00000862216101
   Coding: 260000108034AFC00081404300001D0D0F1D438A27090201000008004400030100000034000000
   Shop #: WSC 06325 123 12345
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 040714  H13 0080
   Serial number: SWF14077045112
   Coding: 00FD11
   Serial number: 22912803
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001607140946
   Serial number: F3D80C37000000000001
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC2VBS6
   Coding: 30533933363030303030554A305238543053
   VCID: 48C8AD96D2349BB716D-801C
   Serial number: 6334MSME47695463H
   Serial number: 6344MSME4769541DN
   Serial number: 6352QSME4944056EN
   Serial number: 6362QSME544316528
   Serial number: 63732SME26433E40Z
   Serial number: 63832SME36430054P
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NGF0008J
   Coding: 000036
   VCID: 48C8AD96D2B49BB716D-801C
   Part No SW: 8T0 920 984 C    HW: 8T0 920 984 C
   Component: KOMBIINSTR.   H35 0564
   Revision: 00000000    Serial number: Z9J367F7F
   Coding: 33AF010003012600010400
   VCID: 3FDAB64A877ADC0FA77-806A
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y1471211C5
   Coding: 80CF07FF00
   VCID: 4ACC979ECCB869A7009-801E
00458 - Control Module for Battery Monitoring (J367)
                    Fault Frequency: 14
                    Reset counter: 45
                    Mileage: 66277 km
                    Date: 2019.05.24
                    Time: 12:29:19
                    Bin. Bits:    11111
                    Voltage: 14.00 V
                    Count: 6
                    Bin. Bits:    10000
03705 - Voltage Regulator
                    Fault Frequency: 14
                    Reset counter: 45
                    Mileage: 66277 km
                    Date: 2019.05.24
                    Time: 12:29:19
                    Bin. Bits:    11111
                    Voltage: 14.00 V
                    Count: 6
                    Bin. Bits:    10000
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000105843
   VCID: 2D06FC025D165E9F05B-8078
   Component: MEM-FS        H10 0077
   Revision: AA000000    Serial number: 00000110471872
   Coding: 01237125002C00000000
   Component: TSG FA        H09 0305
   Coding: 011C02224021120102
   VCID: 56F473EE08003D47941-8002
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0010758141
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3828DD56A2D4EB3766D-806C
   Revision: 00002001    Serial number: 0341817723
   Coding: 011B068280B908008330003680000047
   Component: TSG BF        H09 0305
   Coding: 011C02224821120102
   VCID: 55F674E21506365F9DB-8000
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 10000000406951
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2CC75E9CD8F927909-806E
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109G%0E7951328
   Coding: 010103020100000001
   Part No SW: 8R2 035 666 L    HW: 8R2 035 666 C
   Component: H-BN-EU       H47 1036
   Revision: --------    Serial number: 206G30EB009498
   Coding: 140101020206A1EF41808B5E00000403E40000020000000000
   VCID: 42DCBFBEF488B1E7C89-8016
   Subsystem 1 - Part No: 8R0 060 884 GA
   Component: EUR 2019  2802
   Component: DU7 High  H42 0104
   Serial number: A130GN0E3090910
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001933313
   Component: CD-Database  5950
            000 -  -
                    Reset counter: 42
                    Mileage: 66277 km
                    Date: 2019.05.24
                    Time: 12:19:50
                    Text: DUA130,Front,M,0,0,6
03623 - Invalid Secruity/Release Code
            000 -  -
                    Reset counter: 42
                    Mileage: 66277 km
                    Date: 2019.05.24
                    Time: 12:19:49
                    Hex Value: 0x0004
                    Hex Value: 0x000B
                    Count: 6
   Revision: --H09---    Serial number: 525PA8-J45935G
   Coding: 1020008
   VCID: 3828DD56AE54EB3766D-806C
   Component: SAS-GEN 2     H06 0006
   Serial number: 140624200300
End----------(Elapsed Time: 01:40, VBatt start/end: 13.9V/13.9V)-----------
MasterTommy
Amsterdam
C?ID=295586
Is there a sensor on the battery negative terminal connector, and is it plugged in or was it damaged during battery replacement?
Robbie73w
C?ID=370271
The sensor is fine. The plug is also connected and wiring looks good to. The battery was disconnected for quite a while though during the change
Robbie73w
C?ID=370271
Could it be a coding issue?
Did you recode the battery management after replacing the battery? - it need to know that you have fitted a new battery (just change the serial number if the battery is the same type and capacity).
DV52
C?ID=194404
Robbie: whilst acknowledging that anything is possible- isn't it a tad strange that the Battery control module doesn't appear as a slave device on the gateway module @ address hex19 on your auto-scan?
I'm not familiar with the wiring arrangement for SS on a MY14 S5, but the standard arrangement is for the Battery control module to communicate with the hex19 module via a LIN wire. The other module that is the subject of the second DTC on the hex19 module in your auto-scan can (is likely to?) be also a LIN device.
So according to your auto-scan, the voltage regulator and the battery control module both ain't talking LIN- speak. Doesn't this tend to suggest that there is a physical problem with either the LIN wire, or one of the interposing connector pins at a position on the loom which is physically upstream of both modules?
I hear you say that the wiring loom and the interposing connectors are OK - but with the greatest respect (and with entirely no offense intended) - how have you convinced yourself that this is so?
Robbie73w
C?ID=370271
Hi Don, no offense taken.
To be honest I've only looked at the wiring loom within the battery bay as I thought that since its the only area which has recently been disturbed, then the fault must be around there.
Im a complete novice with vcds hence the reason I've asked for some guidance.
Can you suggest any other areas that I should be looking at
