Just picked up a new Q2 30 (1.6) tdi for the Wife, unfortunately my HEX+CAN interface isn't fully compatible with this vehicle so showing some errors. However most of the info appears to be present so here's the autoscan;
Friday,14,June,2019,23:30:05:24986
VCDS Version: 19.6.0.2
VIN: WAUZZZGA1KA073503 License Plate: Q2
Chassis Type: GA (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 42 44 52 5F 6D BB BC
Address 01: Engine (J623-DGTE) Labels: None
Part No SW: 04L 906 056 MR HW: 04L 907 445 G
Component: R4 1.6l TDI H01 6629
Revision: 22102001
Coding: 02194032432515092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI03004L906056MR 004007
ROD: N/A
VCID: 09181653A858D807C6-805C
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ECM16TDI03004L906056MR" ()
Readiness: N/A
Part No SW: 5Q0 614 517 EE HW: 5Q0 614 517 BN
Component: ESC H35 0107
Revision: 00000000 Serial number: 50759000000603
Coding: 34008A8D20270C6F4B7C0E0062C6242C510430D2704624F31241F078901B4A0300000633D2D21212FF35351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: N/A
VCID: 78FE6397C3B2D18FA9-802C
No ASAM data for: "EV_Brake1UDSContiMK100IPB" ()
Address 08: Auto HVAC (E87) Labels:. 8V0-820-047.clb
Part No SW: 8V0 820 047 F HW: 8V0 820 047 F
Component: AC Manuell el H03 0130
Revision: 20002000 Serial number: 00000000560802
Coding: 03100104002000001000000000000000
ASAM Dataset: EV_AirCondiFrontManAU37X 008018
ROD: N/A
VCID: 3978A693B838088796-806C
No ASAM data for: "EV_AirCondiFrontManAU37X" ()
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 DB HW: 5Q0 937 084 CE
Component: BCM MQBAB M H38 0273
Serial number: 01001912300762
ASAM Dataset: EV_BCMMQB 019001
ROD: N/A
VCID: 7BF47C9BF284FA97C4-802E
Subsystem 1 - Part No SW: 81A 955 559 A HW: 81A 955 559
Component: G397_RLS H06 0002
Serial number: 20236983X81A955559A0
Coding: 80005E
Subsystem 2 - Part No SW: 8V0 941 531 BE HW: 8V0 941 531 BE
Component: E1 - LDS MQB H06 0032
Serial number: 20 02 2019 20000608
Subsystem 3 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY190640M5T
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000047070381
Subsystem 5 - Part No SW: 82A 953 521 B HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000027041920240499
No ASAM data for: "EV_BCMMQB" ()
Address 10: Park/Steer Assist (J446) Labels:. 5Q0-919-283.clb
Part No SW: 5QA 919 283 C HW: 5QA 919 283
Component: PDC 4 KanalH07 0050
Serial number: 000308419619119
Coding: 0600040001
ASAM Dataset: EV_EPHVA14AU3700000 009037
ROD: N/A
VCID: 4A9AE95FEDDE931F0F-801E
No ASAM data for: "EV_EPHVA14AU3700000" ()
Address 13: Auto Dist. Reg (J428) Labels:. 2Q0-907-572.clb
Part No SW: 2Q0 907 572 Q HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0342
Coding: 2A00008150F78728747C61450040A700000000000000000008
ASAM Dataset: EV_ACCMRRCONTIVW376 003015
ROD: N/A
VCID: 428AC17FD5EE4B5FC7-8016
No ASAM data for: "EV_ACCMRRCONTIVW376" ()
Address 15: Airbags (J234) Labels:. 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BN HW: 5Q0 959 655 BN
Component: AirbagVW21 007 0403
Serial number: 003FHR5A95CH
Coding: 88CCF0C000000000585400DFC0C8000000C5
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
ROD: N/A
VCID: 0D102243DC30C427EA-8058
Subsystem 1 - Part No SW: ----------- HW: 480 000 905 19
Serial number: 35700000000CDA798B32
Subsystem 2 - Part No SW: ----------- HW: 480 000 905 19
Serial number: 358000000003FA798B3$
Subsystem 3 - Part No SW: ----------- HW: 480 401 105 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001B2EE9B786F48X
Subsystem 4 - Part No SW: ----------- HW: 480 401 105 19
Component: SideSensor_Pr 005 6149
Serial number: 3520001B2EE9B786444J
Subsystem 5 - Part No SW: ----------- HW: 480 400 405 19
Component: FrontSensor_D 005 6149
Serial number: 3550001C6EFE7852B91W
Subsystem 6 - Part No SW: ----------- HW: 480 400 405 19
Component: FrontSensor_P 005 6149
Serial number: 3560001C6EFE7852A22Q
No ASAM data for: "EV_AirbaVW20SMEVW37X" ()
Address 17: Instruments (J285) Labels:. 5G0-920-XXX-17.clb
Part No SW: 81A 920 941 C HW: 81A 920 941 C
Component: KOMBI H21 2700
Coding: 25A42204238006000180E8001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
ROD: N/A
VCID: 26427DEF5986977FCB-8072
No ASAM data for: "EV_DashBoardVDDMQBAB" ()
16777018 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 43
Mileage: 51 km
Date: 2019.06.14
Time: 23:05:46
Address 19: CAN Gateway (J533) Labels:. 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4368
Revision: -------- Serial number: 0009535366
Coding: 030100041F0873005B000048080B00000001010000000000000000000000
ROD: N/A
VCID: 6ED245CFB1F69F3F73-803A
Component: 1-01-13-01-04
Subsystem 2 - Part No SW: 81A 951 523 HW: 81A 951 523
Component: J453 MFL H04 0004
Serial number: 20190503200622 22770
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 758860039119050700C9
No ASAM data for: "EV_GatewNF" ()
Address 42: Door Elect, Driver (J386) Labels:. 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS002 0287
Serial number: YE007SDP1773A
Coding: 00108A204001000000001002
ROD: N/A
VCID: 4486C767CFFA456FF5-8010
No ASAM data for: "EV_DCU2DriveSideMAXHKLO" ()
Address 44: Steering Assist (J500) Labels:. 5Q0-909-144.clb
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 811F0000
ROD: N/A
VCID: 3C76BF87B70A3DAF8D-8068
No ASAM data for: "EV_SteerAssisMQB" ()
Part No SW: 5Q0 959 392 F HW: 5Q0 959 392 F
Component: TSG BFS002 0287
Serial number: YE007SDR1443B
Coding: 001082204001000000001002
ROD: N/A
VCID: 4188CE73D0E85047DE-8014
No ASAM data for: "EV_DCU2PasseSideMAXHKLO" ()
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 81A 035 192 E HW: 81A 035 192
Component: MU-HS-LND-EU 050 0235
Coding: 01720601FF00000011111101000A00102F0036C601F00100CE
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: N/A
VCID: 234464FB2AB46257AC-8076
Subsystem 1 - Part No SW: V03 959 802 LD HW: -----------
Component: ECE 2019 --- 0038
Subsystem 2 - Part No SW: 81A 919 604 B HW: 81A 919 604 B
Component: DU Std AU216 H42 0100
Serial number: INX00124011900020219
Subsystem 3 - Part No SW: 81C 919 614 A HW: 81C 919 614 A
Component: ControlUnit_B H20 0200
Serial number: APVAK118041900060273
No ASAM data for: "EV_MUHigScl6C3DELP" ()
Address 6D: Trunk Elect. (J605) Labels:. 5Q0-959-107.clb
Part No SW: 5Q0 959 107 S HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0271
Revision: -------- Serial number: A2-C737-6291-8
Coding: 1A00
ROD: N/A
VCID: 489ED357F3D2610F19-801C
No ASAM data for: "EV_DeckLidCONTIAU736" ()
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS004 0189
Serial number: YE007SDL08657
Coding: 000082004001000000001002
ROD: N/A
VCID: 4E92E54F11B6BF3F53-801A
No ASAM data for: "EV_DCU2RearDriveMAXHKLO" ()
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS004 0189
Serial number: YE007SDL08655
ROD: N/A
No ASAM data for: "EV_DCU2RearPasseMAXHKLO" ()
End-------------------------(Elapsed Time: 03:55)--------------------------
