Results 1 to 1 of 1
Thread: Active Lane Assist for Facelift A6 4G
    Jan 2016
    All,
    I have successfully retrofitted Active Lane Assist in my 2015 A6 4G, well it works but the 5F menus do not. For a facelift car I have used the following 5F adaptations which bring up a menu of Audi Lane Assist with one sub menu of Steering Vibration Soft/Medium/Stong. I cannot make any changes using the menu. Also the menu keeps disappearing or going grey when driving. I have missing messages errors on 5F and 85 modules.
    According to the manual I should get Audi Active Lane Assist with two sub menus (Steering Input, early/late and Vibration on/off). Clearly this points to incorrect adaptations on the 5F.
    The adaptation changes available for all the lane assistant and departure warning I have made are as below. I have fiddled with the ones for lane_assistant but this seems enable what I would call side assist. I have both on my A8 but that is not using MIB2 5F and just has green menu. I cannot find any other options the relate to Active Lane Assist.
    Guidance much appreciated
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant - not activated
    ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer - not activated
    ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off -not activated
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high - not activated
    ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill - not activated
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning - activated
    ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaim er - not activated
    ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off - not activated
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold _high - activated
    ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill - not activated
    Plus
    ENG122229-ENG117740-Car_Function_List_BAP.......LDW_HCA_0x19 : activate
    ENG122229-ENG117741-Car_Function_List_BAP.......LDW_HCA_0x19_msg_bus : Terminal 15
    Latest Scan is
    Sunday,23,June,2019,16:10:23:55272
    VCDS Version: 19.6.0.4 (x64)
    VIN: WAUZZZ4G8FN068483   License Plate:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 15 16 17 19 28 3B 42 44 46 52 53 55 5F 62
              69 6C 6D 72 85 8E AC
    VIN: WAUZZZ4G8FN068483   Mileage: 108775km-67589miles
    17-Instruments -- Status: Malfunction 0110
    Address 01: Engine (J623-CRTD)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G2 907 401 B    HW: 4G2 907 401
       Component: 3.0TDI EDC17  H33 0001
       Revision: 92H33---
       Coding: 12254012052601030000
       ASAM Dataset: EV_ECM30TDI0114G2907401B 001001
       ROD: EV_ECM30TDI0114G2907311C.rod
       VCID: 244720EF2F0C176FD3-8070
       Part No SW: 4G0 927 166 C    HW: 0B5 927 156 K
       Component: 0B5 30 TDIRdW H03 0007
       Revision: --H03---
       Coding: 100001
       ASAM Dataset: EV_TCMDL501021 001021
       ROD: EV_TCMDL501021.rod
       VCID: 2D51C5CB7CC6D6270C-8078
       Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
       Component: ESP9 Premium  H01 0420
       Coding: 17A69E41E86579829B00
       ASAM Dataset: EV_ESP9BOSCHAU57X 003019
       ROD: EV_ESP9BOSCHAU57X_003.rod
       VCID: 3F8D8F83A6AA54B7AE-806A
       Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0560
       Coding: 01B9704E000000000000
       VCID: 7AFB3E97F508B19FD9-802E
       Serial number: 3215000011387005
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 12021500040194
       Coding: 36A21178250000
       VCID: 63C563F36A825057EA-8036
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Revision: 15020001    Serial number: 00001008344002
       Coding: 0105001440349FE041014083000018000F9DE7082F08020100000894E100130200400034030000
       Shop #: WSC 53920 001 104857
       VCID: 71E919BBA87EF2C768-8024
       Component: WWS57X 150111  H37 0080
       Serial number:         150126014513
       Coding: 0045F7
       Serial number: 23730186
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 13 02 2015  00000883
       Serial number: F818C297000000000001
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P100390YW
       Coding: 30333130313730323737554A305234473053
       VCID: 3B75FB93B2B2489782-806E
       Serial number: 3575HRB401G52UQM71L
       Serial number: 3585HRB405133PKM68CD
       Serial number: 3515JRB40145358SI2AU
       Serial number: 3525JRB40145358SP91-
       Serial number: 3554VRB400Q534069H6.
       Serial number: 3564VRB400M5340670PY
       Revision: --------    Serial number: 90372OBC00036
       Coding: 0004F5
       VCID: 387FE49F8B84638F6F-806C
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Serial number: 06 01 2015  C0007902
       Part No SW: 4G8 920 985 L    HW: 4G8 920 985 L
       Component: TDieGb        H08 0043
       Revision: 04001037    Serial number: 658180215596026
       Coding: 33A612000B552600010000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 408F8C7FDB542B4FD7-8014
    1048578 - No Basic Setting
              B2010 00 [009] - -
                        Reset counter: 230
                        Mileage: 108745 km
                        Date: 2019.06.23
                        Time: 11:04:58
    16776980 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 16
                        Mileage: 108753 km
                        Date: 2019.06.23
                        Time: 12:20:17
       Part No SW: 4G8 907 468     HW: 4G8 907 468
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: 00000001729380
       Coding: C0CD078118
       ASAM Dataset: EV_GatewPkoUDS 001024
       VCID: 75E12DABD416DEE7B4-8020
       Serial number: 1900125603
       Voltage stabilizer:
       Serial number: 1412100000000000044B
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0112
       Serial number: 14021500040455
       Coding: 22
       VCID: 3D71F58BACA646A7BC-8068
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA8208ZJ6T
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3663EAA7899095FF7D-8062
       Coding: 011C16015001620002080002
       VCID: 479D9763F67A1C7716-8012
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0016426092
       Coding: 101001010001
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       VCID: 3365D3B39AE280D75A-8066
       Revision: 00002001    Serial number: 0360799116
       Coding: 013B0622A0B93080C320090420010F470000000000000000000000000000
       VCID: 46839A67F170057FED-8012
       Revision: --------    Serial number: 00000001368405
       ROD: EV_ParkiBrake_VW51.rod
       Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0081
       Coding: 04FE02202A130200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
       Coding: E01F00
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E01F00
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 021 D    HW: 4G1 035 021
       Component: MU-H-LND-EU   041 0389
       Serial number: A588B0F7505471
       Coding: 017502010000000013111102000A00132F0006E7F1700100DF
       VCID: 1B351B131272289762-804E
       Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Serial number: AUZ8Z9EY800PTF
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
       Serial number: 90349OBD0006Q
       Component: Gracenote2  --- 1012
    7961 - Control module
              B2001 00 [008] - Incorrect software version
                        Reset counter: 17
                        Mileage: 108771 km
                        Date: 2019.06.23
                        Time: 15:53:53
                        Voltage terminal 30: 14.5 V
       Part No SW: 4G8 959 795 D    HW: 4G8 959 795
       Component: TSG HL        H03 0212
       Coding: 01081C004001620000080002
       Shop #: WSC 02312 785 00200
       VCID: 43858373C2423057CA-8016
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
       Component: Anhaenger     H14 0113
       Serial number: 0000454261
       Coding: 0100000202000000
       Revision: --H04---    Serial number: 525 PA8J1XG2SO
       Coding: 1030005
       Shop #: WSC 98765 666 38384
       VCID: 26433AE79130E57FCD-8072
    03006 - Back-up Camera System not calibrated
                        Reset counter: 230
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0150
       Revision: 14005001    Serial number: 030500754
       Coding: 093205C010
       ROD: EV_HDSGAu571.rod
       Component: TSG HR        H03 0212
       Shop #: WSC 28100 141 104456
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: 71160000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C57C8CF47DCDF2F1B-8078
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H33 0090
       Serial number: 005000621903157
       Coding: 044239040111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    0025 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 230
                        Mileage: 108745 km
                        Date: 2019.06.23
                        Time: 11:50:49
                        Outside air temperature: 18.5 ∞C
                        Voltage terminal 15: 11.6 V
                        Control Module temperature: 30.0 ∞C
    0061 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 230
                        Mileage: 108745 km
                        Date: 2019.06.23
                        Time: 11:50:48
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 150210145
       ROD: EV_RDCMA00100_008.rod
    End-------------------------(Elapsed Time: 05:51)--------------------------
