Results 1 to 2 of 2
Thread: VW POLO 9N AIRBAG LOGIN CODE NEEDED !
    Oct 2017
    Macedonia
    Exclamation VW POLO 9N AIRBAG LOGIN CODE NEEDED !
    Hello member i have a polo 9n 1.4tdi i have changed the airbag ecu and now i need the login code to code the ecu !
    If someone can help me please ?!
    Best Regards .
    Monday,24,June,2019,14:36:41:42762
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
    VIN: WVWZZZ9NZ9Y038788   License Plate: TE-4105-AF
    Mileage: 227910km-141616mi   Repair Order:
    Chassis Type: 9N (9N - VW Polo (2002 > 2010))
    Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ9Y038788   Mileage: 227910km-141616miles
    Address 01: Engine        Labels: 045-906-013-BMS.clb
       Part No SW: 045 906 013 E    HW: 045 906 013 E
       Component: R3 1,4L EDC G000SG  4271
       Revision: --H03---    Serial number: VWZ5Z0H5301058
       Coding: 0003071
       Shop #: WSC 66565 257 00032
       VCID: 916AC17789CEF0C2C2-5184
    005769 - Powertrain Data Bus
                   P1689 - 000 - Implausible Message from Elect. Load Controller
                        Mileage: 227918 km
                        Load: 0.0 %
                        Voltage: 12.16 V
                        Bin. Bits: 11001100
                        Bin. Bits: 10000000
                        (no units): 255.0
    049472 - Body Control Module (Central Electric)
                   U0140 - 000 - No Communications
                        Mileage: 227918 km
                        Load: 0.0 %
                        Voltage: 12.16 V
                        Bin. Bits: 11001100
                        Bin. Bits: 10000000
                        (no units): 0.0
    049489 - No Communications with Airbag Control Module
                   U0151 - 000 -  - Intermittent
                        Fault Frequency: 50
                        Mileage: 227918 km
                        Load: 0.0 %
                        Voltage: 12.24 V
                        Bin. Bits: 11001100
                        Torque: 0.0 Nm
                        Torque: 87.0 Nm
    053273 - Control Module for Instrument Cluster
                   U1019 - 000 - Missing Signal for Oil Level/Temperature - Intermittent
                        Mileage: 227918 km
                        RPM: 861 /min
                        Load: 0.0 %
                        Voltage: 14.21 V
                        Temperature: 28.8°C
                        Temperature: 27.0°C
                        Temperature: 27.9°C
    Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
       Part No SW: 6Q0 907 379 BC    HW: 6Q0 907 379 BC
       Component: ABS 8.0 front   H06 0003
       Coding: 0002136
       Shop #: WSC 00788 785 00200
       VCID: FF4E77CFAF5AF6B224-50D0
    Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
       Part No: 6Q0 820 045
       Component: Klimaanlage        X0850
       VCID: EA98B69B94D8631AE3-50F4
    7 Faults Found:
                31-10 - Open or Short to Ground - Intermittent
                28-10 - Short to Plus - Intermittent
    00898 - Control Circuit A/C compressor
    00705 - Relay for Coolant Fan; Stage 1 (J279)
    00706 - Relay for Coolant Fan; Stage 2 (J513)
    Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
       Part No: 6Q2 937 049 F
       Component: 0009 BN-SG.         2S36
       Coding: 01038
       Shop #: WSC 00788
       VCID: BFCE37CFBFDA36B264-50F4
    00906 - Horn (H1)
       Part No: 1C0 909 605 K
       Component: 18 AIRBAG VW51 0P   0010
       Coding: 12600
       Shop #: WSC 00788
       VCID: AC1470835EACBD2AD1-50F4
    01222 - Crash Sensor Side Airbag; Passenger Side (G180)
                62-00 - No or Incorrect Adjustment
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
                32-00 - Resistance Too High
    Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
       Part No: 6Q0 920 804 J
       Component: KOMBIINSTRUMENT AGD V04
       Coding: 01132
       Shop #: WSC 00788
       VCID: B83C5CD39AF4018AA5-50F4
       Part No: 6N0 909 901
       Component: 01K1 GATEWAY CAN    2S36
       Coding: 00014
       Shop #: WSC 00788
       VCID: F0ACA4F3B20499CAAD-50F4
    No Faults Found
    Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
       Component: IMMOBILIZER     AGD V04
       Coding: 01132
       Shop #: WSC 00788
       WVWZZZ9NZ9Y038788     VWZ5Z0H5301058
       Part No: 6Q0 423 156 Q
       Component: LenkhilfeTRW        V250
       Coding: 10140
       Shop #: WSC 00788
       VCID: BD324DC7B5D624A276-50F4
    Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
       Part No: 6Q0 959 433 G
       Component: 40 Komfortgerát     0002
       Coding: 00017
       Shop #: WSC 00788
       VCID: BFCE37CFBFDA36B264-4B3C
       Part No SW: 6Q0 035 152 G    HW: 6Q0 035 152 G
       Component: Radio 9NK           0008
       Revision: 00005000    Serial number: VWZ4Z4H4211466
       Coding: 0020200
       VCID: AE107A8B38B0CF3AFF-50F4
    End----(Elapsed Time: 02:57, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
    HQ
    As per Partslink24.com, your car takes airbag module 1C0-909-605-K-017. I would appear you have installed 1C0-909-605-K-018 which is for the 4 door body. This isn't a matter of a login, but rather a wrong part for the VIN you are working on.
    Airbag modules have a hidden part number, the "index code". That is what the "017" and 018" values are. This isn't printed on the control module itself and it may not report via a scan tool. Most airbag modules that use these index codes have the soft coding locked down to 1 specific value, it can't be changed. So while your original airbag module soft coding was most likely 12599, this used replacement module with index of 018 will not accept that soft coding value... it will forever only accept 12600.
    Due to liability concerns, Ross Tech does not offer assistance for installing used airbag components.
    http://wiki.ross-tech.com/wiki/index.php/Airbag_Coding
    My official suggestion would be to purchase a new unit from the dealer.
    Jef
  3. Likes Uwe liked this post
