Can't access body control module with built in security access code.
Chiefegghead
C?ID=184246
Hi I'm trying to access the the security part on body control module but the built in security codes don't seem to work.I'm trying to access auto rain closing but need to use the adaption and put the security code in but don't seem to work.I've had a quick google and apparently this is a common problem with this module.
Please find enclosed my auto scan.
Thanks
Saturday,22,June,2019,17:19:58:05033
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
Saturday,22,June,2019,17:17:55:05033
VIN: WVGZZZ5NZGW812109   License Plate: MD16LYU
Mileage: 24895km-15469mi   Repair Order: 3
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 42 44 52 55
          5F 6C 6D 82 A5 BB BC CA D6 D7
VIN: WVGZZZ5NZGW812109   Mileage: 24895km-15469miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 EH    HW: 04L 907 309 M
   Component: R4 2.0l TDI   H23 2950
   Revision: B4H23---
   Coding: 0125003203671D083000
   ASAM Dataset: EV_ECM20TDI01104L906026EH 004002
   ROD: EV_ECM20TDI01104L906026EF_004.rod
   VCID: 74B1DD4B1E3A1537DED-8020
   Part No SW: 0DL 300 011 A    HW: 0DE 927 711
   Component: GSG DQ500     H12 1406
   Revision: 00H12V32
   VCID: 2615F703986637A7909-8072
   Part No SW: 5Q0 614 517 BH    HW: 5Q0 614 517 AD
   Component: ESC           H25 0507
   Revision: 00000000    Serial number: 60956000001281
   Coding: 0AEE929A34210B6E4778670062CC4950492CD0E2E646927D38625078C22A02
   VCID: 78A9E97B02527157F25-802C
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0401705353
   Coding: 030C0C0F03
   VCID: 3A2D33737CDEA347C41-806E
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98025967
   Part No SW: 5NC 907 044     HW: 5NC 907 044
   Component: AC Automat    H34 3902
   Revision: 20K07000    Serial number: 00000B00101934
   Coding: 00120124202110011105100C0010110A
   ASAM Dataset: EV_ACClimaPrehVW37X 002013
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 7EA5FF6320764F67B89-802A
   Subsystem 1 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
   Component: E265KlimaHeck  H02 0201
   Serial number: 00000000000000000000
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Reset counter: 204
                    Mileage: 24862 km
                    Date: 2019.06.22
                    Time: 09:15:50
                    Outside air temperature: 17.0 °C
                    Voltage terminal 30: 14.4 V
                    System run time-Engine running time: 253 s
                    Air quality status: ERROR
   Part No SW: 5Q0 937 084 BQ    HW: 5Q0 937 084 BQ
   Component: BCM MQBAB H   H32 0212
   Serial number: 00021611100453
   Coding: 03D11E46C24112FB17844094B11C172C1880000000000000000000000000
   ASAM Dataset: EV_BCMMQB 016001
   ROD: EV_BCMBOSCH_016_VW37.rod
   VCID: 084999BB72B201D7825-805C
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 160319  033 0372
   Serial number: 00000001603160302585
   Component: RLHS  037 0059
   Serial number: S4Y16M04D28H11M25S16
   Coding: 00A8DD
   Serial number: 000000000ZY1608213BL
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000065695698
204546 - Remote key 2
                    Reset counter: 163
                    Mileage: 24845 km
                    Date: 2019.06.21
                    Time: 14:46:18
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [008] - Alert Emergency Activation Stage 1
                    Reset counter: 204
                    Mileage: 24845 km
                    Date: 2019.06.21
                    Time: 14:46:18
   Part No SW: 3Q0 919 298     HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0152
   Serial number: 002004167478070
   Coding: 0331263851
   ASAM Dataset: EV_EPHBO2CVW3260000 010015
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 7AADF3733C5E6347841-802E
   Part No SW: 2Q0 907 572 H    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0155
   Coding: 320147C358FF8728749C806D304085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001010
   ROD: EV_ACCMRRCONTIVW376_001.rod
   VCID: 392F2C7F79D8A85FCDB-806C
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2HR82%
   Coding: 98CCC0C00C0000005C5400CF008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 1079B1DB0AE249175A5-8044
   Belt Pretensioner left:
   Serial number: 5NC857705C0113Q01277
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 5NC857706C0112Q00388
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 004 16
   Serial number: 357000000002F25C9A1S
   Subsystem 4 - Part No SW: -----------    HW: 480 002 304 16
   Serial number: 358000000008F7BCBA15
   Subsystem 5 - Part No SW: -----------    HW: 480 402 004 16
   Serial number: 3510001B9209F101055P
   Subsystem 6 - Part No SW: -----------    HW: 480 402 004 16
   Serial number: 3520001B9209F105344V
   Subsystem 7 - Part No SW: -----------    HW: 480 402 004 16
   Serial number: 3550001C520A94F4232$
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 504 16
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001B72080C23B85$
   Subsystem 9 - Part No SW: -----------    HW: 480 402 504 16
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001BB2080C21D5D6
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 402 504 16
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001BB2080C21939V
   Subsystem 11 - Part No SW: -----------    HW: 480 001 104 16
   Serial number: I0M00000000A80348A1+
   Subsystem 12 - Part No SW: -----------    HW: 480 001 104 16
   Serial number: I0N00000000633F06A1%
   Part No SW: 3Q0 953 521 AN    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0205
   Revision: FF034034    Serial number: 20160413501553
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CA1F56B366A5D7796D-8028
   Part No SW: 5NA 920 791     HW: 5NA 920 791
   Component: KOMBI         119 1443
   Coding: 27A40018EF84260001886B031401000000000000
   VCID: 55F780CFF5806C3FC93-8000
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004784583
   Coding: 030500041F087300FB03225E1E0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 79AFEC7F3958685F8DB-802C
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 0981609395901168AP2B
   Coding: 2F0000
   Subsystem 3 - Part No SW: 5QA 915 181 B    HW: 5QA 915 181 B
   Component: J367-BDMHella  H10 9052
   Serial number: 8278749903
   Serial number: HA1-00009.03.16
   Coding: 0101
   VCID: 4ACD63B32C3E33C7541-801E
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH05 0012
   VCID: 45D7508F0520DCBFB93-8010
   Serial number: 16000078756014
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD45F6128201F35B-8024
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 220316ECJ10115
   Coding: 003F1A20D001048000001000
   VCID: 43D34E970B14E28F977-8016
   Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   Serial number: 020416ED130411
   Coding: 003F1020DE01048000001000
   VCID: 42DD4B93140EEB879C1-8016
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0051
   Coding: 08AE00104B210201
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
   VCID: 41DF449F1108F09F85B-8014
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 3G0 035 020 C    HW: 3G0 035 020
   Component: MU-H-ND-EU    H50 0343
   Serial number: A682D0GB020222
   Coding: 02730601FF00000051111101008808001F0100E6012000009F
   VCID: 176BCAC72F0C9E2F1BF-8042
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL00Q1Y
   Subsystem 2 - Part No SW: V03 959 800 QT    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Component: Gracenote2  --- 1012
   Part No SW: 5Q0 907 556 A    HW: 5Q0 907 556
   Component: Areaview 2    H11 0422
   Serial number: C854706JG015035
   Coding: 01230601A20F200000204014
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 005013
   ROD: EV_CamSysRVAV2ARCE2MQBAB_005_VW37.rod
   VCID: 372B2A474FCCBE2F3BF-8062
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30636838400000
   Coding: 0A08
   VCID: 3FDB426767FC866FF3F-806A
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 5NA 919 608 A    HW: 5NA 919 608 A
   Component: HeadupDisplay 015 0207
   Coding: 574060
   ASAM Dataset: EV_HeadUpDisplContiVW481 001013
   ROD: EV_HeadUpDisplContiVW481.rod
   VCID: 46D557833826D7A7B09-8012
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 19041611P22768
   Coding: 000307060000040100022344C050A10094000E200040
   Serial number: 110316EC90271C
   Coding: 002A10200100048000001000
   Serial number: 100316EC90233C
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 308040732602
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675C7C32806A727009-8042
   Component: LED1R         H09 0003
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:08, VBatt start/end: 12.2V/12.2V)-----------
TBAx
C?ID=287144
For this tweak to work you will require a Rain Light Recognition Sensor that is named RLFS.
The RLHS inside your vehicle is not cappable of performing rain closing.
Chiefegghead
C?ID=184246
I’m sure I have the sensor because I can access the module but can’t get security access as it won’t accept the code
The sensor you have is:
   Coding: 00A8DD
If TBAx says that's the wrong sensor, I would take his word for it.
Chiefegghead
C?ID=184246
Thanks
Thank yo, saved me a lot of time with this 👍
Chiefegghead
C?ID=184246
Thanks I stand corrected thanks for all the feed back great forum
