Results 1 to 7 of 7
Thread: Can't access body control module with built in security access code.
    Jun 2019
    Hi I'm trying to access the the security part on body control module but the built in security codes don't seem to work.I'm trying to access auto rain closing but need to use the adaption and put the security code in but don't seem to work.I've had a quick google and apparently this is a common problem with this module.
    Please find enclosed my auto scan.
    Thanks
    Saturday,22,June,2019,17:19:58:05033
    VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
    Saturday,22,June,2019,17:17:55:05033
    VIN: WVGZZZ5NZGW812109   License Plate: MD16LYU
    Mileage: 24895km-15469mi   Repair Order: 3
    Chassis Type: 5N-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 42 44 52 55
              5F 6C 6D 82 A5 BB BC CA D6 D7
    VIN: WVGZZZ5NZGW812109   Mileage: 24895km-15469miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 EH    HW: 04L 907 309 M
       Component: R4 2.0l TDI   H23 2950
       Revision: B4H23---
       Coding: 0125003203671D083000
       ASAM Dataset: EV_ECM20TDI01104L906026EH 004002
       ROD: EV_ECM20TDI01104L906026EF_004.rod
       VCID: 74B1DD4B1E3A1537DED-8020
       Part No SW: 0DL 300 011 A    HW: 0DE 927 711
       Component: GSG DQ500     H12 1406
       Revision: 00H12V32
       VCID: 2615F703986637A7909-8072
       Part No SW: 5Q0 614 517 BH    HW: 5Q0 614 517 AD
       Component: ESC           H25 0507
       Revision: 00000000    Serial number: 60956000001281
       Coding: 0AEE929A34210B6E4778670062CC4950492CD0E2E646927D38625078C22A02
       VCID: 78A9E97B02527157F25-802C
       Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
       Component: VWKESSYMQB    036 0710
       Revision: 00036000    Serial number: 0401705353
       Coding: 030C0C0F03
       VCID: 3A2D33737CDEA347C41-806E
       Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
       Component: GEB.F.Heckoef  H17 0903
       Serial number: 98025967
       Part No SW: 5NC 907 044     HW: 5NC 907 044
       Component: AC Automat    H34 3902
       Revision: 20K07000    Serial number: 00000B00101934
       Coding: 00120124202110011105100C0010110A
       ASAM Dataset: EV_ACClimaPrehVW37X 002013
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 7EA5FF6320764F67B89-802A
       Subsystem 1 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
       Component: E265KlimaHeck  H02 0201
       Serial number: 00000000000000000000
    263425 - Air Quality Sensor
              B10AF 04 [008] - Internal System Fault
                        Reset counter: 204
                        Mileage: 24862 km
                        Date: 2019.06.22
                        Time: 09:15:50
                        Outside air temperature: 17.0 °C
                        Voltage terminal 30: 14.4 V
                        System run time-Engine running time: 253 s
                        Air quality status: ERROR
       Part No SW: 5Q0 937 084 BQ    HW: 5Q0 937 084 BQ
       Component: BCM MQBAB H   H32 0212
       Serial number: 00021611100453
       Coding: 03D11E46C24112FB17844094B11C172C1880000000000000000000000000
       ASAM Dataset: EV_BCMMQB 016001
       ROD: EV_BCMBOSCH_016_VW37.rod
       VCID: 084999BB72B201D7825-805C
       Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
       Component: 326 RL 160319  033 0372
       Serial number: 00000001603160302585
       Component: RLHS  037 0059
       Serial number: S4Y16M04D28H11M25S16
       Coding: 00A8DD
       Serial number: 000000000ZY1608213BL
       Component: Sirene, DWA  005 0313
       Serial number: 00000000000065695698
    204546 - Remote key 2
                        Reset counter: 163
                        Mileage: 24845 km
                        Date: 2019.06.21
                        Time: 14:46:18
    262912 - Sensor for Anti-Theft Alarm System
              B1330 F5 [008] - Alert Emergency Activation Stage 1
                        Reset counter: 204
                        Mileage: 24845 km
                        Date: 2019.06.21
                        Time: 14:46:18
       Part No SW: 3Q0 919 298     HW: 3Q0 919 298
       Component: PLA 3.0 12K   H09 0152
       Serial number: 002004167478070
       Coding: 0331263851
       ASAM Dataset: EV_EPHBO2CVW3260000 010015
       ROD: EV_EPHBO2CVW3260000.rod
       VCID: 7AADF3733C5E6347841-802E
       Part No SW: 2Q0 907 572 H    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H01 0155
       Coding: 320147C358FF8728749C806D304085
       ASAM Dataset: EV_ACCMRRCONTIVW376 001010
       ROD: EV_ACCMRRCONTIVW376_001.rod
       VCID: 392F2C7F79D8A85FCDB-806C
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0317
       Serial number: 003TDR2HR82%
       Coding: 98CCC0C00C0000005C5400CF008800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 1079B1DB0AE249175A5-8044
       Belt Pretensioner left:
       Serial number: 5NC857705C0113Q01277
       Coding: 80000D
       Belt Pretensioner right:
       Serial number: 5NC857706C0112Q00388
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 002 004 16
       Serial number: 357000000002F25C9A1S
       Subsystem 4 - Part No SW: -----------    HW: 480 002 304 16
       Serial number: 358000000008F7BCBA15
       Subsystem 5 - Part No SW: -----------    HW: 480 402 004 16
       Serial number: 3510001B9209F101055P
       Subsystem 6 - Part No SW: -----------    HW: 480 402 004 16
       Serial number: 3520001B9209F105344V
       Subsystem 7 - Part No SW: -----------    HW: 480 402 004 16
       Serial number: 3550001C520A94F4232$
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 402 504 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001B72080C23B85$
       Subsystem 9 - Part No SW: -----------    HW: 480 402 504 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001BB2080C21D5D6
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 402 504 16
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001BB2080C21939V
       Subsystem 11 - Part No SW: -----------    HW: 480 001 104 16
       Serial number: I0M00000000A80348A1+
       Subsystem 12 - Part No SW: -----------    HW: 480 001 104 16
       Serial number: I0N00000000633F06A1%
       Part No SW: 3Q0 953 521 AN    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0205
       Revision: FF034034    Serial number: 20160413501553
       Coding: 0C10
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
       ROD: EV_SMLSVALEOMQBLRH.rod
       VCID: 7CA1F56B366A5D7796D-8028
       Part No SW: 5NA 920 791     HW: 5NA 920 791
       Component: KOMBI         119 1443
       Coding: 27A40018EF84260001886B031401000000000000
       VCID: 55F780CFF5806C3FC93-8000
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1244
       Revision: --------    Serial number: 0004784583
       Coding: 030500041F087300FB03225E1E0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 79AFEC7F3958685F8DB-802C
       Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
       Serial number: 0981609395901168AP2B
       Coding: 2F0000
       Subsystem 3 - Part No SW: 5QA 915 181 B    HW: 5QA 915 181 B
       Component: J367-BDMHella  H10 9052
       Serial number: 8278749903
       Serial number: HA1-00009.03.16
       Coding: 0101
       VCID: 4ACD63B32C3E33C7541-801E
    Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH05 0012
       VCID: 45D7508F0520DCBFB93-8010
       Serial number: 16000078756014
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BFD45F6128201F35B-8024
    Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
       Serial number: 220316ECJ10115
       Coding: 003F1A20D001048000001000
       VCID: 43D34E970B14E28F977-8016
       Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
       Component: EPS_MQB_ZFLS  128 1072
       Coding: 9307
       ROD: EV_SteerAssisMQB_013.rod
       Serial number: 020416ED130411
       Coding: 003F1020DE01048000001000
       VCID: 42DD4B93140EEB879C1-8016
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0051
       Coding: 08AE00104B210201
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
       VCID: 41DF449F1108F09F85B-8014
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 3G0 035 020 C    HW: 3G0 035 020
       Component: MU-H-ND-EU    H50 0343
       Serial number: A682D0GB020222
       Coding: 02730601FF00000051111101008808001F0100E6012000009F
       VCID: 176BCAC72F0C9E2F1BF-8042
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9SKL00Q1Y
       Subsystem 2 - Part No SW: V03 959 800 QT    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Component: Gracenote2  --- 1012
       Part No SW: 5Q0 907 556 A    HW: 5Q0 907 556
       Component: Areaview 2    H11 0422
       Serial number: C854706JG015035
       Coding: 01230601A20F200000204014
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 005013
       ROD: EV_CamSysRVAV2ARCE2MQBAB_005_VW37.rod
       VCID: 372B2A474FCCBE2F3BF-8062
       Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0253
       Revision: --------    Serial number: 30636838400000
       Coding: 0A08
       VCID: 3FDB426767FC866FF3F-806A
    Address 82: Heads Up Display (J898)       Labels:* None
       Part No SW: 5NA 919 608 A    HW: 5NA 919 608 A
       Component: HeadupDisplay 015 0207
       Coding: 574060
       ASAM Dataset: EV_HeadUpDisplContiVW481 001013
       ROD: EV_HeadUpDisplContiVW481.rod
       VCID: 46D557833826D7A7B09-8012
       Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0220
       Serial number: 19041611P22768
       Coding: 000307060000040100022344C050A10094000E200040
       Serial number: 110316EC90271C
       Coding: 002A10200100048000001000
       Serial number: 100316EC90233C
       Part No SW: 4M0 907 594 D    HW: 4M0 907 594
       Component: SAD_STG_1     011 0003
       Coding: 308040732602
       ASAM Dataset: EV_SunRoofCONTIAU736 004008
       ROD: EV_SunRoofCONTIAU736_004.rod
       Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
       Component: LED1L         H09 0003
       VCID: 1675C7C32806A727009-8042
       Component: LED1R         H09 0003
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
    End----------(Elapsed Time: 02:08, VBatt start/end: 12.2V/12.2V)-----------
    Dec 2016
    DE
    For this tweak to work you will require a Rain Light Recognition Sensor that is named RLFS.
    The RLHS inside your vehicle is not cappable of performing rain closing.
  3. Likes Uwe, Zenerdiode, PetrolDave liked this post
    Jun 2019
    I’m sure I have the sensor because I can access the module but can’t get security access as it won’t accept the code
    The sensor you have is:
       Coding: 00A8DD
    If TBAx says that's the wrong sensor, I would take his word for it.
  6. Likes PetrolDave liked this post
    Dec 2016
    Amsterdam
    Quote Originally Posted by Chiefegghead View Post
    I see the sensor in the scan, yeah. Still the wrong one.
    Current:
  8. Likes PetrolDave liked this post
  9. #6
    Jun 2019
    Thanks
    Thank yo, saved me a lot of time with this 👍
  10. #7
    Jun 2019
    Thanks I stand corrected thanks for all the feed back great forum
