Results 1 to 7 of 7
Thread: 1993 Eurovan - 098 Auto Trans - VCDS scan does not find 02-Auto Trans
    Dec 2017
    San Diego, USA
    1993 Eurovan Auto Transmission - 098
    TCM part number - 098927731 B (photos of my TCM)
    Main question - if an Auto-Scan for Chassis type 70 - VW Transporter/Multivan 91-96 (01 Digifant, 02 Auto Trans, 03, 08, 15, 22, 25) only detects the 01-Digifant (no other items detected, especially the 02-Auto Trans), would that typically indicate that the TCM or wiring to the TCM is bad? If it can be something else, what are the other possibilities?
    Background
    On a road trip about 8 years ago, I made the mistake of taking 395 in California/Nevada with my Eurovan loaded heavy. It had a difficult time with the passes. I also had a coolant leak that got worse on the trip, and the transmission got hot enough to melt the Auto Transmission connection wire because it had rested on a part of the trans block.
    The Eurovan went into Limp Mode (stuck in 3rd gear). I made it to Reno, and I went to a local shop that said they'd take a look. They initially couldn't diagnose until finally they discovered the wire melted mess. After exhausting all attempts to find a wire harness, I asked if they could install a set of replacement wires to remove the bad 6" section. It was/is only 10 wires, and the tech successfully repaired it. At first, it didn't seem like it took. But I found that there is an Auto Transmission reset procedure on the 1993 Eurovan, and to my surprise it worked.
    I drove with that repair for nearly 8 years. The wire is a part of a large harness that would be expensive and difficult to replace. Finally, the repair fatigued and corroded. My transmission went weird and I limped (3rd gear) into Transmission Repair shop, and they performed a basic service (fluid, filter). They didn't see anything to indicate damage to the mechanical (shavings were normal).
    I thought maybe I should just find a perfect match portion of wire/connection. I was advised that a 90's Jetta would be a perfect match. So I redid the repair simply matching colors. Once again, something was off. I pinned out again, and it was a match with the 2001. Hmm. Maybe my 1993 Eurovan wire/connector pin out from the hacked repair wire/connector was wrong. I checked and double checked using a voltmeter. There was still a difference from the Jetta and the 2001 Eurovan.
    I could really use an diagram expert with a Bentley to tell me the 1993 Eurovan wire/connector pinouts. Anybody?
    Anyway, I realized that I had been very careless when performing this wire reconnection work. I had left the battery connected, and it is very likely that some wires might have touched and possible shorted.
    With this said, I'm very new to TCM/ECM stuff. I would assume that this could damage the TCM. Am I correct that this is a possibility?
    I ask, because I have previous VCDS scans from my Eurovan where the 098 Auto Transmission - 02 module is detected.
    But now, it doesn't find it. Nothing for 02-Auto Trans.
    It really makes me wonder that my TCM is shot. They aren't very easy to come by (I've seen them advertised for as high as $1000+). I did see that the same part number (but without a B designation) is available from a Passat B3 for a reasonable cost (about $100). I've also seen other TCMs advertised with other letter designations. Yet, I'm curious if that is a simple revision, or an actual design variation.
    I'm in the process of examining my TCM again (located near passenger footwell).
    Any Eurovan Auto Trans TCM/wire/connector 098 experts on here? And know of any compatible other VW models with compatible TCM 098927731?
    Dec 2017
    San Diego, USA
    Latest scan
    Saturday,01,June,2019,14:53:32:15635
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    Chassis Type: 70 - VW Transporter/Multivan (1991 > 1996)
    Scan: 01 02 03 08 15 22 25
    Address 01: Engine        Labels: None
       Part No: 023 906 023 A
       Component: DIGIFANT 1.5        1147
       VCID: 0A4DA178752C9867945-0962
    Readiness: N/A
    End----(Elapsed Time: 01:53, VBatt start/end: 14.2V/14.1V. VIgn 0.0V)------
    Dec 2017
    San Diego, USA
    Scan from before the more recent rewiring project (possible short). Notice how the 02-Auto Trans is detected
    Sunday,30,December,2018,14:08:07:15635
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
       VCID: 0A4DA178752C9867C01-0962
    Readiness: N/A
    Address 02: Auto Trans        Labels: 098-927-731.lbl
       Part No: 098 927 731 B
       Component: DIGIMAT 0842
       VCID: 2019E3D0E3D03237BE5-0964
    8 Faults Found:
    00258 - Solenoid Valve 1 (N88)
    00260 - Solenoid Valve 2 (N89)
    00262 - Solenoid Valve 3 (N90)
    00264 - Solenoid Valve 4 (N91)
    00266 - Solenoid Valve 5 (N92)
    00270 - Solenoid Valve 7 (N94)
    00300 - Transmission Fluid Temp. Sensor (G93)
                34-10 - No Elaboration Available - Intermittent
    00641 - ATF Temperature
                06-10 - Signal too High - Intermittent
    End----(Elapsed Time: 01:53, VBatt start/end: 12.0V/12.0V. VIgn 0.0V)------
    Sunday,30,December,2018,14:11:35:15635
    Dec 2017
    San Diego, USA
    I think I may have found the issue... good thing I decided to do another check of the TCM. The photos in the original post ^ show the TCM in good condition.
    But take a look at these photos from today
    You can tell that there is serious water damage. Makes sense with the rainy winter we had here in California (and the slight rust I have around the windshield that probably let water in).
    I had heard about water damage on the TCM... I just never thought it would happen to me
    Ok. So I definitely need a replacement. Still would prefer to spend as little as possible to get a suitable replacement.
    If anybody has any suggestions, please let me know... and please don't suggest Car-Part.com unless you know a specific reliable vendor... because I've already tried several and they are not very helpful or responsive.
  5. Likes Uwe, Jack@European_Parts, jyoung8607 liked this post
    I have them new and reman.
    Dont screw around with incorrect applications and hardware, you will destroy your trans.
    https://www.ebay.com/itm/VW-Eurovan-...YAAOSw27lcBvG2
    You will get the forum discount too.
    Let me know.
    I may be able to fix what you have for less but need to see what happened on scope and breadboard.
    Check this post of a very bad damaged board on 01P.
    #159
    https://forums.ross-tech.com/showthr...l=1#post168196
  7. Likes jyoung8607 liked this post
    I replied to this inquiry in eBay with discount offer & if you want me to check microfiche application please provide VIN number?
    Thank you
    Example OP of what we can see with a VIN......
    https://forums.ross-tech.com/showthr...l=1#post168580
