I'm new to the forum, and to VCDS, so there is a lot I don't know. I appreciate any help I can get with this diagnosis. It appears that there are several issues with my car. I've included 2 scans here. The first one is immediately after clearing the codes, the second one is before clearing the codes.
My main concern right now is the ABS/Slip light that is activated.
With the scans I did today, I see a new error about communication with the ABS Brake Module. I did not see that on my previous scan a few days ago.
I purchased a new ABS sensor for the front right wheel, and replaced it last week, but it did not clear the error. I also attempted to measure voltage at the sensor while I moved the wheel to see if the sensor was working, but that test came back negative. Not sure I was able to get a good connection to the sensor, so inconclusive right now. It doesn't make sense that a brand new sensor would be bad.
I visually inspected the wire and the connector, and no obvious damage.
What would be a good way to test the harness? Does anyone have a diagram of the connector to show where to test the sensor wires for continuity? How do I determine if sensor, harness, abs module are good or bad?
fyi-measure blocks show measurement for the other 3 wheels. Nothing for the right front.
Excerpt from full scan:
049441 - No Communication with ABS Brake Control Module
U0121 - 008 - - Intermittent
Mileage: 251679 km
Temperature: 29.0°C
Temperature: -40.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.192 V
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 01279 785 00200
VCID: 3FDB42265B75F50FF3B-806A
Saturday,22,June,2019,09:47:22:33951
VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4505.4
VIN: WVWAA71K38W240338 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 65
VIN: WVWAA71K38W240338 Mileage: 252350km-156803miles
Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BK HW: 07K 906 032 Q
Component: 2,5l R5/4V G 1568
Revision: 1NH01--- Serial number: VWX7Z0H03NL95V
VCID: 73B3DE1627BD616FC73-8026
006481 - Radiator Fan 2 (V177)
P1951 - 002 - Movement Restricted / Jammed - Intermittent
Fault Frequency: 9
Mileage: 251659 km
Time: 06:30:15
RPM: 1312 /min
Load: 36.1 %
Speed: 10.0 km/h
Temperature: 90.0°C
Temperature: 34.0°C
Voltage: 13.970 V
001152 - Coolant Fan Control Circuit 1
P0480 - 004 - Electrical Malfunction - Intermittent
Mileage: 251659 km
Time: 06:30:29
RPM: 2174 /min
Load: 17.2 %
Speed: 83.0 km/h
Temperature: 85.0°C
Temperature: 39.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
000275 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High - Intermittent
Mileage: 251679 km
Time: 02:20:30
Temperature: 27.0°C
Voltage: 12.319 V
000258 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - Intermittent
Mileage: 251679 km
Time: 02:20:49
RPM: 184 /min
Load: 78.4 %
Temperature: 27.0°C
Voltage: 10.795 V
Mileage: 251679 km
Temperature: 29.0°C
Voltage: 12.192 V
Coding: 0017025
Part No SW: 1K0 820 047 HJ HW: 1K0 820 047 HJ
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
Revision: 00H54000 Serial number: 00000007947775
Coding: 108D8F214004150047140000001400000008730B5C000100000000000000
Shop #: WSC 09460 444 53328
VCID: 71BFD41E5DA1537F35F-8024
Component: Wischer 180108 021 0501
Coding: 00038805
Shop #: WSC 09460
Fault Status: 00101100
Reset counter: 127
Mileage: 251664 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.40 V
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0ADA2P
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6C81C56A7A83BE97069-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME3802486BD
Subsystem 3 - Serial number: 6342MSME327361330
Subsystem 4 - Serial number: 6352QSME4C77273DW
Subsystem 5 - Serial number: 6362QSME45334E01C
Subsystem 6 - Serial number: 63727SME12764F465
Subsystem 7 - Serial number: 63827SME12765619+
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 051 0100
Coding: 0000042
VCID: 7F5B02261BF5350FB3B-802A
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Part No SW: 1K0 920 974 J HW: 1K0 920 974 J
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0H03NL95V
Coding: 0007203
Shop #: WSC 00000 067 57207
VCID: 3537200E69493F5F297-8060
Reset counter: 120
Mileage: 251679 km
Time: 02:30:07
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K081230695
Coding: E9801F070002020000
VCID: 3039111A962B1A777A1-8064
Reset counter: 120
Mileage: 251679 km
Time: 02:30:07
Component: IMMO VDD 1216
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1207
Coding: 0001077
VCID: 3829293A7E5BC237321-806C
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
Shop #: WSC 00028 028 00001
00625 - Vehicle Speed Signal
Mileage: 251660 km
Temperature: 23.0°C
Voltage: 12.10 V
Voltage: 11.90 V
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080A04889C00
Shop #: WSC 00000 785 00200
VCID: 04518DCA721356D7EE9-8050
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
VCID: 392F2C3E4551DB3FCDF-806C
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 C HW: 1K0 035 161 C
Component: Radio DE2 015 0019
Revision: 00015000 Serial number: VWZ4Z7G6309362
Coding: 0040402
VCID: 1F1BE2A6FBB5950FD3B-804A
Component: RDK 0450
Coding: 0100101
Fault Status: 00111000
Reset counter: 120
Mileage: 251679 km
Time: 02:30:08
End----------(Elapsed Time: 00:59, VBatt start/end: 12.1V/12.1V)-----------
