Results 1 to 10 of 13
Thread: ABS Fault 00285
    Jun 2019
    ABS Fault 00285
    I'm new to the forum, and to VCDS, so there is a lot I don't know. I appreciate any help I can get with this diagnosis. It appears that there are several issues with my car. I've included 2 scans here. The first one is immediately after clearing the codes, the second one is before clearing the codes.
    My main concern right now is the ABS/Slip light that is activated.
    With the scans I did today, I see a new error about communication with the ABS Brake Module. I did not see that on my previous scan a few days ago.
    I purchased a new ABS sensor for the front right wheel, and replaced it last week, but it did not clear the error. I also attempted to measure voltage at the sensor while I moved the wheel to see if the sensor was working, but that test came back negative. Not sure I was able to get a good connection to the sensor, so inconclusive right now. It doesn't make sense that a brand new sensor would be bad.
    I visually inspected the wire and the connector, and no obvious damage.
    What would be a good way to test the harness? Does anyone have a diagram of the connector to show where to test the sensor wires for continuity? How do I determine if sensor, harness, abs module are good or bad?
    fyi-measure blocks show measurement for the other 3 wheels. Nothing for the right front.
    Excerpt from full scan:
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 008 -  - Intermittent
                        Mileage: 251679 km
                        Temperature: 29.0°C
                        Temperature: -40.0°C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 12.192 V
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 P
       Component: ASR FRONT MK70      0105
       Coding: 0017025
       Shop #: WSC 01279 785 00200
       VCID: 3FDB42265B75F50FF3B-806A
    Saturday,22,June,2019,09:47:22:33951
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WVWAA71K38W240338   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 65
    VIN: WVWAA71K38W240338   Mileage: 252350km-156803miles
    Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 BK    HW: 07K 906 032 Q
       Component: 2,5l R5/4V      G   1568
       Revision: 1NH01---    Serial number: VWX7Z0H03NL95V
       VCID: 73B3DE1627BD616FC73-8026
    006481 - Radiator Fan 2 (V177)
                   P1951 - 002 - Movement Restricted / Jammed - Intermittent
                        Fault Frequency: 9
                        Mileage: 251659 km
                        Time: 06:30:15
                        RPM: 1312 /min
                        Load: 36.1 %
                        Speed: 10.0 km/h
                        Temperature: 90.0°C
                        Temperature: 34.0°C
                        Voltage: 13.970 V
    001152 - Coolant Fan Control Circuit 1
                   P0480 - 004 - Electrical Malfunction - Intermittent
                        Mileage: 251659 km
                        Time: 06:30:29
                        RPM: 2174 /min
                        Load: 17.2 %
                        Speed: 83.0 km/h
                        Temperature: 85.0°C
                        Temperature: 39.0°C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 14.097 V
    000275 - Intake Air Temp. Sensor (G42)
                   P0113 - 002 - Signal too High - Intermittent
                        Mileage: 251679 km
                        Time: 02:20:30
                        Temperature: 27.0°C
                        Voltage: 12.319 V
    000258 - Mass Air Flow Sensor (G70)
                   P0102 - 002 - Signal too Low - Intermittent
                        Mileage: 251679 km
                        Time: 02:20:49
                        RPM: 184 /min
                        Load: 78.4 %
                        Temperature: 27.0°C
                        Voltage: 10.795 V
                        Mileage: 251679 km
                        Temperature: 29.0°C
                        Voltage: 12.192 V
       Coding: 0017025
       Part No SW: 1K0 820 047 HJ    HW: 1K0 820 047 HJ
       Component: Climatic PQ35   141 1010
       Revision: 00141028    Serial number: 00000000000000
       Revision: 00H54000    Serial number: 00000007947775
       Coding: 108D8F214004150047140000001400000008730B5C000100000000000000
       Shop #: WSC 09460 444 53328
       VCID: 71BFD41E5DA1537F35F-8024
       Component: Wischer 180108 021  0501
       Coding: 00038805
       Shop #: WSC 09460
                        Fault Status: 00101100
                        Reset counter: 127
                        Mileage: 251664 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.40 V
       Component: 6K AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D0ADA2P
       Coding: 0013899
       Shop #: WSC 01269 785 00200
       VCID: 6C81C56A7A83BE97069-8038
       Subsystem 1 - Part No: 1K0 959 339 G
       Component: BF-Gewichtsens. 007 0007
       Subsystem 2 - Serial number: 6332MSME3802486BD
       Subsystem 3 - Serial number: 6342MSME327361330
       Subsystem 4 - Serial number: 6352QSME4C77273DW
       Subsystem 5 - Serial number: 6362QSME45334E01C
       Subsystem 6 - Serial number: 63727SME12764F465
       Subsystem 7 - Serial number: 63827SME12765619+
       Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
       Component: J0527           051 0100
       Coding: 0000042
       VCID: 7F5B02261BF5350FB3B-802A
    00576 - Terminal 15
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
       Part No SW: 1K0 920 974 J    HW: 1K0 920 974 J
       Component: KOMBIINSTRUMENT VDD 1216
       Revision: V0002000    Serial number: VWX7Z0H03NL95V
       Coding: 0007203
       Shop #: WSC 00000 067 57207
       VCID: 3537200E69493F5F297-8060
                        Reset counter: 120
                        Mileage: 251679 km
                        Time: 02:30:07
       Component: J533__Gateway   H15 0180
       Revision:   H15       Serial number: 1400K081230695
       Coding: E9801F070002020000
       VCID: 3039111A962B1A777A1-8064
                        Reset counter: 120
                        Mileage: 251679 km
                        Time: 02:30:07
       Component: IMMO            VDD 1216
       Component: Tuer-SG         006 1207
       Coding: 0001077
       VCID: 3829293A7E5BC237321-806C
    00105 - Signal Central Locking SAVE/LOCK Drivers Side
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.135 H08 1901
       Shop #: WSC 00028 028 00001
    00625 - Vehicle Speed Signal
                        Mileage: 251660 km
                        Temperature: 23.0°C
                        Voltage: 12.10 V
                        Voltage: 11.90 V
       Coding: 139006885103281B0904058FB0080A04889C00
       Shop #: WSC 00000 785 00200
       VCID: 04518DCA721356D7EE9-8050
       Coding: 0001076
       VCID: 392F2C3E4551DB3FCDF-806C
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 C    HW: 1K0 035 161 C
       Component: Radio DE2       015 0019
       Revision: 00015000    Serial number: VWZ4Z7G6309362
       Coding: 0040402
       VCID: 1F1BE2A6FBB5950FD3B-804A
       Coding: 0100101
                        Fault Status: 00111000
                        Reset counter: 120
                        Mileage: 251679 km
                        Time: 02:30:08
    End----------(Elapsed Time: 00:59, VBatt start/end: 12.1V/12.1V)-----------
    Been here?
    http://wiki.ross-tech.com/wiki/index.php/00285
    PS: That fault is not "P00285". "P" codes are SAE/ISO standardized Powertain faults. This is a VAG specific/proprietary 00285 fault. On newer cars, there might be a "C" code equivalent (C being chassis). I've fixed the thread tile.
    Hello and welcome to the VCDS forum OP
    Verify wiring from sensor to ABS module using DVOM and test overlay using WD by RTFB.
    Load test the circuits.
    Check charging system and battery or change due to being weak.
    JPPSG
  5. Likes Uwe liked this post
  6. #4
    Jun 2019
    plug diagram?
    JPPSG
    I was able to find the electrical drawings on erwin, but I don't see plug detail.
    I need more info for inexperienced person.
    Post the WD lets see............
    Jun 2019
    Wire Diagram
    I don't have permission to post attachments.
    Tried to paste in a screen shot....no luck.
    Please see: How to Post Pictures
  11. #8
    Jun 2019
    Wire Diagram-trying again
    [QUOTE=Uwe;168454]Please see: How to Post Pictures
  12. #9
    Jun 2019
  13. Likes Jack@European_Parts, Uwe liked this post
  14. #10
    Okay great OP.
    See the T26 designation?
    That's the plug at ABS module known as AKA J104 or in VCDS as hex address word 0x03
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl ( J104 )
    Fault Found:
    00285 - ABS Wheel Speed Sensor; Front Right (G45) <<<<<<<<<<<<<<<<<< See that in WD G45 that's the sensor
    Don't worry about the D186 or 187 & commence a check with DVOM and load light to ABS connector T26a PIN 5 & 6 and should correlate to PIN's 1 & 2 at ABS G45 sensor, understand?
  15. Likes Uwe liked this post
