Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: ABS Fault 00285
    Jun 2019
    Okay great OP.
    See the T26 designation?
    That's the plug at ABS module known as AKA J104 or in VCDS as hex address word 0x03
    Don't worry about the D186 or 187 & commence a check with DVOM and load light to ABS connector T26a PIN 5 & 6 and should correlate to PIN's 1 & 2 at ABS G45 sensor, understand?
    I see...pin 5 and pin 6...duh. I should have figured that out.
    I want to check continuity from pin 5 to #1 and pin 6 to #2, right?
  2. Likes Uwe, NZDubNurd liked this post
  3. #12
    Yeah it's only two wires ya dope
    Not just continuity,,,,,,nein! because one stand of copper can make a tone and not carry the current needed for the controller to read the voltage of wheel speed, that is why load light!
    Meet MR. 123 LOAD LIGHT's in this 2 min video....
  4. Likes Uwe, tclark18 liked this post
  5. #13
    Jun 2019
    I was expecting a diagram of the plug to know which pins to check....got it now.
    Thank you for the information about how to load test the wire. I need that.
    I will check it out next opportunity. Thanks.
  6. Likes Uwe, NZDubNurd liked this post
