Results 1 to 5 of 5
Thread: Audi A4 B7 2005 Automatic to Manual transmission programming
    Pirate
    Jun 2019
    Estonia
    Hello
    Im fresh user here and i have this Audi A4 B7 2.0TDI 6gear manual box installed by previous owner but he said they didn't program ECUs etc. Since i have the cable and program,is there possible to do it myself? Ive tried to change codes but it doesn't allow to change transmission from Automatic to Manual. ABS started to give errors too that it doesn't read from airbag ECU. It gives me CAN Line error too, like there is no connection.
    Could someone help me with programming??
    I have some errors in airbag ecu (passenger seat sensor), in engine ECU there is Oil sensor fault and it gives me brake pad error and i think nothing else. I did manage to activate Cruise control switch (not installed yet) and thats all.
    Maybe. Some ECUs can readily be coded between Auto and Manual, while other cannot. In any case we'll need to see a complete Auto-Scan to know exactly how this car is equipped and configured.
    Pirate
    Jun 2019
    Estonia
    Removed.  Data from a clone/pirate version of VCDS is not welcome here.
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php
  5. Likes Dana liked this post
    Pirate
    Jun 2019
    Estonia
    Didn't know it was pirated/cloned one,though it has right stickers etc. Lended it from a friend. Ill ask from other friend if he has the original one,so i can do the legitimate Auto-Scan
  7. Likes Dana, PetrolDave liked this post
