- Joined
- Jun 12, 2019
- Messages
- 5
- Reaction score
- 1
- Location
- Middlesbrough, UK
- VCDS Serial number
- C?ID=212125
Good evening,
I have a 2017 Audi A6 that has a headlight range fault after a low battery, can anyone help?
It appears to have lost its basic setting.
Kind regards
Kirk
Kind regards
Kirk
Thursday,20,June,2019,16:43:15:30145
VCDS Version: 19.6.0.4
VIN: WAUZZZ4G5HN117027 License Plate:
Mileage: 46876km-29127mi Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 47 52 53
55 5F 62 72 AC
VIN: WAUZZZ4G5HN117027 Mileage: 46876km-29127miles
Address 01: Engine (J623-DDDA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 HA HW: 04L 907 309 AA
Component: R4 2.0l TDI H20 4166
Revision: 8DH20---
Coding: 0A254012242401080000
ASAM Dataset: EV_ECM20TDI01104L906021HA 004005
ROD: EV_ECM20TDI01104L906021HA_004.rod
VCID: 6BD5CA0882F0311752-803E
U1113 00 [032] - -
Mileage: 46873 km
Date: 2019.06.20
Time: 17:21:04
Engine speed: 918.00 /min
Normed load value: 19.6 %
Coolant temperature: 23 °C
Intake air temperature: 24 °C
Voltage terminal 30: 9.340 V
Cruise Control System (CCS): switch position-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 15
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
U1113 00 [032] - -
Mileage: 46873 km
Date: 2019.06.20
Time: 17:21:04
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4G1 927 153 B HW: 0CJ 927 156
Component: 0CK 20TDI RdW H03 0004
Revision: --H03--- Serial number: 0000000561
Coding: 100001
ASAM Dataset: EV_TCMDL382021 002024
ROD: EV_TCMDL382021_AU57.rod
VCID: 2959F000488CE307E0-807C
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071170069001195
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 06A29E41604579829B00
ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
VCID: 418948A0D0FC0B47D8-8014
Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
Component: BCM2 2.0 H61 0825
Coding: 01B8704E000000000000
VCID: 7CF7F954FF9EA6AFCB-8028
Serial number: 3217000053211014
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 27031700041339
Coding: 34210978210000
VCID: 63C5A2286A207957EA-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 1502003S Serial number: 00001622595402
Coding: 0105001440349FE041014083800018000F9DC3082F08020100000894E100140200400024030000
VCID: 74E7D174D7CEEEEF83-8020
Component: WWS57X 170128 H38 0080
Serial number: 170215010117
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20160760X81A955547A0
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 15 03 2017 00001305
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 68C80F8800PAG0MUFU03
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 161
Mileage: 46873 km
Date: 2019.06.20
Time: 17:18:13
Component: Airbag10.43 H82 0092
Revision: -------- Serial number: 003P100D6RA%
Coding: 30333130313630323639554A305234473053
VCID: 3B753A48B210619782-806E
Serial number: 3575HRB405F4AN7QG8M0
Serial number: 3585HRB40574CVFI90U$
Serial number: 3515JRB400U59EU4QHVQ
Serial number: 3525JRB400259EU45HMC
Serial number: 3554VRB4053480F2F1U1
Serial number: 3564VRB4053480F2EH7.
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 91560QCJ000G2
Coding: 000034
VCID: 3B753A48BA10619782-806E
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Serial number: 08 03 2017 B0019670
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 951 E HW: 4G8 920 951 E
Component: MDieGb H43 0604
Revision: 32450309 Serial number: 658190317592006
Coding: 33A70D000B412600010000
ASAM Dataset: EV_RBC7KMID 004050
ROD: EV_RBC7KMID.rod
VCID: 326B176C655AA0DF51-8066
Part No SW: 4G5 907 468 H HW: 4G0 907 468 AC
Component: J533--Gateway H15 0096
Revision: -------- Serial number: 00000002561154
Coding: C0CD074418
VCID: 3A7B3F4CBD2A589F99-806E
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 7169693304
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 17011300000000000745
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 67DDB6389618157736-8032
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0113
Serial number: 24031700041107
Coding: 22
VCID: 3D713450AC046FA7BC-8068
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000245041863
VCID: 77FDE678C6B885F7A6-8022
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720W30D8
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 336512689A40A9D75A-8066
Component: TSG FA H03 0511
Coding: 011C16015E01620002080002
VCID: 479D56B8F6D8357716-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000711345
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
Revision: 00002001 Serial number: 0436464163
Coding: 011B062280B90080C320088400010E470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 B
Component: Sensor, DWA 005 0002
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Serial number: 0000000AP00031386272
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000207647
Coding: 030000
VCID: 1D31D4D004C40FA79C-8048
Component: TSG BF H03 0511
VCID: 46835BBCF1D22C7FED-8012
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: EPB-4 H01 0018
Revision: -------- Serial number: 00000002140524
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04FE02102A600200
VCID: 346711749F4EAEEF43-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01E00
5275220 - Headlight
Reset counter: 161
Mileage: 46873 km
Date: 2019.06.20
Time: 17:18:13
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 4G1 035 192 F HW: 4G1 035 192 A
Component: RMC Nav Plus H62 0186
Coding: 010100010141DB47082B060301020100000000
VCID: 2643FB3C5192CC7FCD-8072
Subsystem 1 - Part No: 8X0 919 884 K
Component: P38-50-16.03 0001
Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464C$0H2805744
Subsystem 3 - Part No SW: 4G2 919 610 E HW: 4G2 919 610 E
Serial number: 90349QCD0011D
Component: TSG HL H03 0511
VCID: 49995080E0CCC30700-801C
Component: TSG HR H03 0511
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 170650794
ROD: EV_RDCMA00100_008.rod
VCID: 2F6D1E1876688D373E-807A
End-------------------------(Elapsed Time: 05:05)--------------------------
