Audi A6 2017 Headlight Range Fault
korky
Middlesbrough, UK
C?ID=212125
Good evening,
I have a 2017 Audi A6 that has a headlight range fault after a low battery, can anyone help?
It appears to have lost its basic setting.
Kind regards
Kirk
 Thursday,20,June,2019,16:43:15:30145
VCDS Version: 19.6.0.4
VIN: WAUZZZ4G5HN117027   License Plate:
Mileage: 46876km-29127mi   Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 47 52 53
          55 5F 62 72 AC
VIN: WAUZZZ4G5HN117027   Mileage: 46876km-29127miles
Address 01: Engine (J623-DDDA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 HA    HW: 04L 907 309 AA
   Component: R4 2.0l TDI   H20 4166
   Revision: 8DH20---
   Coding: 0A254012242401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021HA 004005
   ROD: EV_ECM20TDI01104L906021HA_004.rod
   VCID: 6BD5CA0882F0311752-803E
          U1113 00 [032] - -
                    Mileage: 46873 km
                    Date: 2019.06.20
                    Time: 17:21:04
                    Engine speed: 918.00 /min
                    Normed load value: 19.6 %
                    Coolant temperature: 23 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 9.340 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 0
                    Cruise Control System (CCS): status-Bits 0-7: 15
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
          U1113 00 [032] - -
                    Mileage: 46873 km
                    Date: 2019.06.20
                    Time: 17:21:04
Address 02: Auto Trans (J217)       Labels:| 0CJ-927-156.clb
   Part No SW: 4G1 927 153 B    HW: 0CJ 927 156
   Component: 0CK 20TDI RdW H03 0004
   Revision: --H03---    Serial number: 0000000561
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 2959F000488CE307E0-807C
   Manual Transmission Fluid Pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071170069001195
   Coding: 06A29E41604579829B00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 418948A0D0FC0B47D8-8014
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0825
   Coding: 01B8704E000000000000
   VCID: 7CF7F954FF9EA6AFCB-8028
   Serial number: 3217000053211014
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Component: KLIMA 4 ZONEN H14 0113
   Serial number: 27031700041339
   Coding: 34210978210000
   VCID: 63C5A2286A207957EA-8036
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 1502003S    Serial number: 00001622595402
   Coding: 0105001440349FE041014083800018000F9DC3082F08020100000894E100140200400024030000
   VCID: 74E7D174D7CEEEEF83-8020
   Component: WWS57X 170128  H38 0080
   Serial number:         170215010117
   Coding: 0045F7
   Serial number: 20160760X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 15 03 2017  00001305
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 68C80F8800PAG0MUFU03
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 161
                    Mileage: 46873 km
                    Date: 2019.06.20
                    Time: 17:18:13
   Component: Airbag10.43   H82 0092
   Revision: --------    Serial number: 003P100D6RA%
   Coding: 30333130313630323639554A305234473053
   VCID: 3B753A48B210619782-806E
   Serial number: 3575HRB405F4AN7QG8M0
   Serial number: 3585HRB40574CVFI90U$
   Serial number: 3515JRB400U59EU4QHVQ
   Serial number: 3525JRB400259EU45HMC
   Serial number: 3554VRB4053480F2F1U1
   Serial number: 3564VRB4053480F2EH7.
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 91560QCJ000G2
   Coding: 000034
   VCID: 3B753A48BA10619782-806E
   Serial number: 08 03 2017  B0019670
   Part No SW: 4G8 920 951 E    HW: 4G8 920 951 E
   Component: MDieGb        H43 0604
   Revision: 32450309    Serial number: 658190317592006
   Coding: 33A70D000B412600010000
   ASAM Dataset: EV_RBC7KMID 004050
   ROD: EV_RBC7KMID.rod
   VCID: 326B176C655AA0DF51-8066
   Part No SW: 4G5 907 468 H    HW: 4G0 907 468 AC
   Component: J533--Gateway H15 0096
   Revision: --------    Serial number: 00000002561154
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 002000
   VCID: 3A7B3F4CBD2A589F99-806E
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 7169693304
   Voltage stabilizer:
   Serial number: 17011300000000000745
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 67DDB6389618157736-8032
   Component: KLIMA FOND    H08 0113
   Serial number: 24031700041107
   Coding: 22
   VCID: 3D713450AC046FA7BC-8068
   Revision: AA000000    Serial number: 00000245041863
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77FDE678C6B885F7A6-8022
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720W30D8
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 336512689A40A9D75A-8066
   Component: TSG FA        H03 0511
   Coding: 011C16015E01620002080002
   VCID: 479D56B8F6D8357716-8012
   Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000711345
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   Revision: 00002001    Serial number: 0436464163
   Coding: 011B062280B90080C320088400010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00031386272
   Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
   Component: BOSE-G3-C7    H07 0160
   Revision: CJ007001    Serial number: 00000000207647
   Coding: 030000
   VCID: 1D31D4D004C40FA79C-8048
   VCID: 46835BBCF1D22C7FED-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002140524
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   Coding: 04FE02102A600200
   VCID: 346711749F4EAEEF43-8060
   Coding: E01E00
   Coding: E01E00
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 161
                    Mileage: 46873 km
                    Date: 2019.06.20
                    Time: 17:18:13
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G1 035 192 F    HW: 4G1 035 192 A
   Component: RMC Nav Plus  H62 0186
   Coding: 010100010141DB47082B060301020100000000
   VCID: 2643FB3C5192CC7FCD-8072
   Subsystem 1 - Part No: 8X0 919 884 K
   Component: P38-50-16.03  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464C$0H2805744
   Subsystem 3 - Part No SW: 4G2 919 610 E    HW: 4G2 919 610 E
   Serial number: 90349QCD0011D
   Component: TSG HL        H03 0511
   Coding: 010814004001620002080002
   VCID: 49995080E0CCC30700-801C
   Component: TSG HR        H03 0511
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 170650794
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F6D1E1876688D373E-807A
End-------------------------(Elapsed Time: 05:05)--------------------------
Oooh. You have the crazy Matrix lights. I don't think I've seen a procedure for those.
There are some promising looking Basic Settings in that module:
IDE03675-ENG103121 -- Basic headlamp setting
IDE03676-ENG103121 -- Acknowledge basic setting
But there may be more to it than that.
korky
Middlesbrough, UK
C?ID=212125
Is there a sequence to follow for relearning basic settings, this is something I have never done before
Zenerdiode
Newcastle, England
C?ID=24330
The information is in the Workshop Manual - which you may register and download from here. While you have your subscription, grab as much other info for your car; such as Wiring Diagrams etc.
The procedure may be roughly: use scan-tool to enter Basic Settings, carry out mechanical headlight alignment with the adjusting screws, leave basic settings. But please verify first with the official manual above.
