- Jun 22, 2014
- 9
- 2
- Munich Airport - Germany
- C?ID=178722
I was asked to assist on a '95 A8 V8 petrol. Has been sat idly for a few months and now won't fire up.
Read fault codes and it's got an issue with pick up coil and wiring most likely, was going to try and re-match transponders just in case. Opened the immo box and read the 94c46, so I've got the login code. Box accepts the code but it keeps dropping the connection (you can hear something clicking away, the same note it makes when VCDS first connects), connection is flakey even without logging in and going into measuring blocks (recognises keys etc - first three values in measuring block 01 are 1).
Is this likely just an issue with battery voltage or should the garage be looking somewhere else (did tell them to replace the coil and wiring)?
Car was connected to a booster battery.
Cheers for your assistance.
EEPROM content
Login 019A = 00410
Wednesday,19,June,2019,17:29:39:58731
VCDS Version: 19.6.0.2 (x64) HEX-NET CB: 0.4505.4
VIN: WAUZZZ4DZTN002xxx License Plate: A8D2
Mileage: 236610km-147022mi Repair Order:
Chassis Type: 4D - Audi A8 D2 (1994 > 2003)
Scan: 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77
02
Mileage: 236610km-147022miles
Address 25: Immobilizer Labels: 4A0-953-234.lbl
Part No: 4A0 953 234
Component: IMMO AUZ9Z0S7465073 D76
Coding: 00000
VCID: 5F8E70CDDFD8F7B7C8-50AE
01176 - Key
Part No: 4D0 907 557 A
Component: 3,7L V8/4V MOTR AT D03
Coding: 04153
VCID: 2A18D119D41A421FEF-4B1E
P1602 - 35-00 - Voltage too Low
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 4D0-907-379-ASR.lbl
Part No: 4D0 907 379 N
Component: ABS/ASR-EZ BOSCH 5 7408
Coding: 00002
Shop #: WSC 02314
VCID: 393AFE5521BCF98796-51CE
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4D0 820 043 B
Component: D2-KLIMAVOLLAUTOMAT_D03
Coding: 00080
Shop #: WSC 02314
VCID: 1B7604DD8B40AB9764-2570
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Address 15: Airbags Labels: 8A0-959-655.lbl
Part No: 8A0 959 655 K
Component: Airbag V AUDI D00
Coding: 01022
Shop #: WSC 02314
VCID: 3B36E45D2B80CB9784-5184
01025 - Trigger for On Board Diagnostic Lamp; Malfunction
31-10 - Open or Short to Ground - Intermittent
Address 17: Instruments Labels: 4D0-919-033-MYW.lbl
Part No: 4D0 919 033 F
Component: D2-KOMBIINSTRUMENT__D18
Coding: 00083
Shop #: WSC 43681
VCID: 271E282DC7087F77F0-5042
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4D0 927 156 G
Component: AG5 01V 3.7lV8 RDW D59
Coding: 00000
VCID: 2D12DA05E5F455270A-4B3C
35-00 - -
27-00 - Implausible Signal
End----(Elapsed Time: 04:56, VBatt start/end: 11.5V/11.7V. VIgn 0.0V)------
EEPROM content
53 37 46 50 73 94 0C 02 03 32 00 00 00 00 00 00 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B A3 AE 00 00 03 03 05 19 02 53 FF 6B 9A 01 9A 01 02 53 76 20 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 48 06 B5 B5 71 06 B9 24 62 06 72 62 EC 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B 6B
Login 019A = 00410
