Results 1 to 7 of 7
Thread: Codare abs audi a3 8p
    New User
    Mar 2019
    Romania
    Buna ziua,
    O problemă cu abs ,apare eroarea 16352 modul comanda defect electric ,014 defect intermitent.
    A fost codat dar imi apar beculetele de la esp, volan si rana si piuie n bord din cand in cand,nu apar tot timpul.
    Pe tester imi apare această eroare.
    Aug 2016
    The Hague, NL
    Hi and welcome. Could you please (attempt to) write in English?
    And if you want to get proper help from us, and I'm sure many of us are very willing to, could you please post an autoscan? See below on how to do so. Thanks!
  3. Likes Uwe, Boki Ar, TTler liked this post
    New User
    Mar 2019
    Romania
    Ok, modul abs was coding but apare the eror cod 16352-the modul electric defect.
    What can i do?
    We DO need to see an Auto-Scan of your car to be able to help
  6. Likes Uwe, Boki Ar liked this post
    New User
    Mar 2019
    Romania
    I don't have , but the mechanic sayd 16352 is the eror and must to replace the modul abs(1k0907379AD),audi a3 8p 2009 BXE.
    My VIN is
    WAUZZZ8P19BO11400
    Oct 2014
    Arandjelovac, Serbia
    Lightbulb
    No Auto Scan, no possibilities to help. Thanks for understanding.
    May 2019
    The 8P from 08-10 got a Problem with the ABS Modul. AUDI send them back to the Dealer and put new Software on the Modul due to Overheat. However The only Thing you can do check the ABS Sensors at the Wheels and in VCDS . Also Check the Wiring from the Sensors. Sometimes they Fails. When you dont find any other Failures on these Items I explained change the ABS Module.
