Results 1 to 2 of 2
Thread: CONTROL MODULES - NO COMMUNICATIONS!?
    Mar 2019
    Unhappy CONTROL MODULES - NO COMMUNICATIONS!?
    Hi guys, first a friend of mine has been tracing wires on a 04 Skoda Fabia vRS for a completely un-related issue (for a headlight wire). Has been messing around today taking things apart in the engine bay, to try and get to the distribution box type thing behind the scuttle panel under the wiper motor. He didn't find anything interesting and didn't actually get to the box as he didn't want to take the wiper motor out, so put the car back together, but now it will not start. It cranks over, that's it. Can NOT hear fuel pump prime. Many dash lights are on (power steering, ABS, battery, handbrake etc) and some blinking, his generic code reader wouldn't communicate with the ECU so i came and had a look with my VCDS, i cant connect to engine ecu, and some others. Fault codes show as bellow from the cent. electrics module. Any suggestions? I haven't had a good look around the car as it was dark, but everything seems plugged in - any fuses to check that power the module, or relays? Thanks!
    I do not have a full auto scan, as it kept "trying attempt * " on the first engine module, so i cancelled it, thinking it was just going to saying no communications - however, these are the only fault codes in any other module i could get in.
    Cet. electrics:
    49-00 - No Communications
    01316 - ABS Control Module
    01598 - Drive Battery Voltage
    27-00 - Implausible Signal
    01117 - Generator Terminal DF Load Signal
    Wednesday,19,June,2019,22:26:44:56876
    VCDS Version: 19.6.0.5 (x64) HEX-V2 CB: 0.4505.4
    VIN: License Plate:
    Mileage: Repair Order: no-start
    Address 46: Central Conv. Labels: 6Q0-959-433.clb
    Control Module Part Number: 6Q0 959 433 E
    Component and/or Version: 33 Komfortgerát 0002
    Software Coding: 00067
    Work Shop Code: WSC 13765
    Additional Info: 6Q2959802A 33 Tőrsteuer.FS TFK 0004
    Additional Info: 6Q2959801A 33 Tőrsteuer.BF TFK 0004
    VCID: 3D273B53446C4C2FE10-4B3C
    01134 - Alarm Horn (H12)
    01312 - Powertrain Data Bus
    Hello OP and welcome to the VCDS forum.
    Only post full auto-scan's
    RTFB WD please and trace the issue....fuses?
    http://wiki.ross-tech.com/wiki/index...ir_Information
    JPPSG
  3. Likes Uwe liked this post
