Results 1 to 10 of 14
Thread: C7 Audi S6 N75 Duty cycle?
    Jun 2019
    Greetings,
    I own a 2013 Audi S6. I am deep into a diagnostic process to determine the root cause of a P0299 boost target not reached. I am trying to determine how to log the duty cycle of the solenoid that controls the wastegates. These cars have vacuum controlled wastegates controlled by a pressure converter valve and I am not able to find a way to measure the duty cycle.
    I have pressure checked vacuum lines, replaced the pressure converter valve and many other things but I am unable to figure out the log function for the wastegate.
    I don't have an autoscan because I dont have one saved and it takes several back to back runs to trigger the P0299 code, which is the only code on the car and I am focused on understanding how to log duty cycle at this stage.
    Thank you in advance!
    Jun 2019
    I have done fairly extensive diagnostic, I did not share above because of my focus on the N75 duty cycle. I have had many audi's and the N75 duty cycle has always been an option but not with the S6.
    JPPSG answers:
    1. 2013 Audi S6 Prestige
    2. Modified - EPL Stage 3, SRM 4mm+ hybrid turbos, APR downpipes, APR intake cooler
    3. Autoscan included
    4.Issue: car is EPL tuned and I am running about 20psi but should be seeing 23psi. Every once in a while I'll get a P0299 after a few long Full throttle runs. It takes a bit for the ECU to register the boost deviation. I have triple checked all vacuum lines ( I even pulled the front clip and removed the intake manifold and manually vacuum checked the WG lines including WG) The lines held vacuum for 2+ hours with a hand pump device.
    Therefore, my hypothesis is that the solenoid is not opening enough.
    Diagnosis steps:
    A. GOPRO Wastegate actuators under full throttle run
    RESULT: Wastegate arms creep open
    B. Vacuum Test wastegate lines at idle
    RESULT: Roughly ~ 10 – 11 in Hg
    C. Test source vacuum (with gauge while car running)
    RESULT:~ 22 – 25 in Hg - This was tested near the vacuum pump and downstream of the WG solenoid
    D. Remove Charge cooler/ Intake plenum & smoke & vacuum test all lines (with mechanical hand pump)
    RESULT: Pass - vacuum held
    E. Replace Pressure converter solenoid
    F. Vacuum Test wastegate lines under full throttle run
    RESULT: ~ 10-11 in Hg under normal operating
    RESULT: ~15 in Hg under full throttle/ boost conditions
    Wastegate vacuum tests were conducted with factory tune and the vacuum amount was same as with tune. The vacuum amount was enough to hold full factory boost - no P0299.
    6. I am trying to identify what duty cycle the wastegate control solenoid is operating at. Most guides refer to block 114 for N75 logging but I have no such block available in my advanced measuring options. In searching the list within VCDS, it appears I have no duty cycle option for the WG solenoid. What am I missing?
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
              46 47 52 53 55 56 5F 62 6C 72 82 84 85 8B 8E 8F 90 A9 BA
    VIN: WAUJ2AFC5DN077510   Mileage: 105022km-65257miles
  4. Likes Uwe liked this post
    UN-Tune vehicle, to do a repair that comports & to get a valid diagnostic stack without AECD defeats.
    Check WG hold spring tension of WG actuator "mechanical valve" & for ability to hold boost & with a measuring tool that shows the force needed to be exerted on the actual spring installed height + gauge to make the WG open or maintain a seal under boost load!
    Search ADV VCDS blocks for requested and actual boost you will find it....
    ( note Hey Uwe maybe an idea this should just be cheat button in any force induced controller in VCDS added & to observe it, along with timing CF and misfire or HPP PSI & lift pump DC )
    Auto-scan is incomplete .......
    OP: 150 to 200 MBAR deviations negative or positive will result in a boost code!
    You are dismissing helpful information I pointed you too.
    FOCUS!
    Vehicle Identification No. WAUJ2AFC5DN077510
    Model Audi S6 quattro 4.0
    A6
    Date of production 09.11.2012
    Model year 2013
    Sales type 4G253Y
    Engine Code CEUC
    Transmission Code NSK
    Emission standard 7GB Emission standard ULEV 2
    Quote Originally Posted by cdoug3 View Post
    What you posted is not a complete Auto-Scan; it's just the Gateway Installation List (the list of installed modules). We need the detailed info below that, particularly from 01-Engine in order to be able to tell you what data is available in it.
    UN-Tune vehicle
    /\ Uwe..............
    OP
    Maybe detune boost request tables to match hardware than?
    Maybe have tuner alter boost deviation threshold offset a tad?
    Is that better Uwe?
  9. #8
    Jun 2019
    My apologies ..... I am a rookie at this forum
    Wednesday,19,June,2019,19:50:43:12166
    VCDS Version: 19.6.0.2 (x64)  HEX-NET CB: 0.4505.4
    VIN: WAUJ2AFC5DN077510   License Plate:
    Mileage: 105022km-65257mi   Repair Order:
    Address 01: Engine (------CEUC)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 906 014 B    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H61 0008
       Revision: NCH61---
       Coding: 0A2500326546000E1000
       ASAM Dataset: EV_ECM40TFS0114G0906014B 001008
       ROD: EV_ECM40TFS0114G0906014B.rod
       VCID: 210AE4E630E66C47BE-8074
       Part No SW: 4G1 927 156 S    HW: 0B5 927 156 J
       Component: 0B5 40TFSINAR H01 0010
       Revision: --H01---
       Shop #: WSC 02391 785 00200
       ROD: EV_TCMDL501021.rod
       VCID: 3D323896AC5E28A7BA-8068
       Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
       Component: ESP PREMIUM   H09 0361
       Coding: 65B64F01A66DF2809B00
       VCID: 383C2982837C0D8F69-806C
    0732 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [SCL_QSP_Ist_Moment_Error]
       Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 CR
       Component: BCM2 2.0      H32 0510
       Coding: 0D882006000000000000
       Shop #: WSC 08185 444 92428
       VCID: 7CB4F592FFC4E1AFCD-8028
       Serial number: 2312000228393016
       Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
       Component: KLIMA 4 ZONEN H13 0076
       Serial number: 19101200041401
       Coding: 688120B85D
       ASAM Dataset: EV_AirCondiComfoUDS 002036
       VCID: 6288ABEA7560375FE7-8036
       Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
       Revision: 11012002    Serial number: 00000001638972
       Coding: 09072091073C9FE2A90000C7A0003800CF9CD308A20802218001085C7B00
       VCID: 6FAED2DEBEB28A3778-803A
       Component: WWS57X 120906  H36 0080
       Serial number:         120926222547
       Coding: 0045F7
       Serial number: 20673932
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 H    HW: 4G0 941 531 H
       Component: E1 - LDS  H07 0044
       Serial number: 10 10 2012  00000723
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R3FMN02
       Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Component: A31 LED Mod1L  H03 0006
       Serial number: 00000012101200010601
       Coding: 110000
       Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Component: A27 LED Mod1R  H03 0006
       Serial number: 00000011101200010485
       Coding: 110000
       Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA104223000002084519
       Coding: 020300
       Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 29380456000000000001
       Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
       Revision: 11001001    Serial number: 61061229700188
       Coding: A8E90A
       VCID: 71AAD4A6A0869CC76E-8024
       Part No SW: 4G0 907 561 A    HW: 4G0 907 561
       Component: ACC3          H19 0400
       Coding: 7601010102
       VCID: 281CF9C253DC9D0FF9-807C
    95232 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_QEPBACC_FAIL]
       Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
       Component: Airbag10.43   H33 0033
       Revision: --------    Serial number: 003D8002H7CJ
       Coding: 303234373131303030324A55304C34473053
       VCID: 33261EAE9A1AEED75C-8066
       Serial number: 6940000Y120000L9TR0D
       Serial number: 3575HRB404T1G1DMA9KW
       Serial number: 3585HRB405T1G7FAG1FN
       Serial number: 3515JRB40164UO12OPI
       Serial number: 3525JRB40124UO12DOSX
       Serial number: 3554VRB40144UN5GLGSN
       Serial number: 3564VRB40144UN5GOQ09
       Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
       Revision: --------    Serial number: 90372LJI0013V
       Coding: 0004FC
       VCID: 383C29828B7C0D8F69-806C
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Serial number: 29 09 2012  D0122486
       Part No SW: 4G0 920 981 M    HW: 4G0 920 981 M
       Component: TBenUsaAccNv  H76 0515
       Revision: 28460208    Serial number: 658221012596046
       Coding: 03CF09059F51CF05020200
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K_AU57.rod
       VCID: 352220B6946EF0E772-8060
       Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
       Component: J533--Gateway H12 0037
       Revision: --------    Serial number: 00000000728330
       Coding: 00E1034800
       ASAM Dataset: EV_GatewPkoUDS 001018
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790363663
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H15 0013
       Serial number: 001610120001021
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
       VCID: 271EFAFE5EC29277F0-8072
       Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
       Component: KLIMA FOND    H07 0076
       Serial number: 22101200040471
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
       VCID: 373E2ABE8E6202F760-8062
    0036 - Motor for Rear Right Upper Body Vent
              B10D4 31 [009] - No Signal
    0075 - Button or Switch in Operating Unit
              B10C7 07 [008] - Mechanical Failure
       Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
       Coding: 008002
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2E100FDA7138C33F33-807A
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000041094819
       Coding: 00581B0000002001000001010101102030303232203232
       VCID: 77BEEABEC6E2C2F7A0-8022
       Component: SARA 6D red   H02 0053
       Revision: --------    Serial number: EJ1BPA7E0067B$
       ASAM Dataset: EV_SARA2 005011
       ROD: EV_SARA2.rod
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4G0 907 566 D    HW: 4G0 907 566
       Component: J769  SWA MasterH01 0040
       Revision: 00H01000    Serial number: 6PZ 010 287-03
       Coding: 0000001
       VCID: 302C11A2A30CD5CF21-8064
       Subsystem 1 - Part No: 4G0 907 568 D
       Component: J770  SWA Slave H01 0040
       Subsystem 2 - Serial number: 6PZ 010 287-23
       Subsystem 3 - Serial number: 5F18.10.1200H01000AMS16193˙
       Subsystem 4 - Serial number: S16193˙
       Component: TSG FA        H04 0506
       Coding: 011F17005E00628002000013
       VCID: 45C25076CC8E6067E2-8010
       Component: RCEPS         H36 0010
       Revision: 00001000    Serial number: 0007947600
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 32281BAA6500E7DF57-8066
       Revision: 00002001    Serial number: 0186058594
       Coding: 0106063A00FA418580B00880020503000000000000000000000000000000
       Shop #: WSC 01814 444 28888
       Component: GTO BF  H01 0080
       Serial number: 00000000000000114969
       Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
       Component: J245 PS40.039  H01 0008
       Serial number:     WOO1871404%
       Coding: 101F00
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00002179334
    02616 - Fuel Tank Cap; Unlock
                009 - Open or Short to Ground
       Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
       Component: BOSE-G3C7-ANC H02 0540
       Revision: CJ002700    Serial number: 00000000004675
       Coding: 030000
       VCID: 1C74D5121F8441AF6D-8048
       Component: TSG BF        H03 0506
       Coding: 011F17005E00628002000002
       VCID: 46C0577AF1886B7FEB-8012
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000507909
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B1606CE422AB61714-807E
       Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
       Serial number: 121022-0002-133
       Coding: 12216F601002A400
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2D1208D67C3EB8270A-8078
       Part No SW: 4G0 035 082 E    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0121
       Revision: AB001007    Serial number: 156J40C7658227
       Coding: 020007010000000001
       VCID: 2208EBEA3DE0775FA7-8076
       Part No SW: 4G0 035 746 D    HW: 4G0 035 746 B
       Component: H-BNT-NA      H50 0622
       Revision: --------    Serial number: 194J10C7517228
       Coding: 060200000203FDEF7D16CB1E00000003100001000000000000
       VCID: 281CF9C25BDC9D0FF9-807C
       Subsystem 1 - Part No: 8R0 060 884 BA
       Component: NAR 2013  0703
       Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDC9402Q2Y5
       Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
       Serial number: 90349LJM000DO
       Component: CD-Database  4949
       Component: TSG HL        H03 0506
       VCID: 49DA5C46E096840706-801C
    01482 - Motors for Central Locking
    02131 - Child Safety Lock Motor
       Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
       Component: TopView       H05 0111
       Revision: 11001001    Serial number: 82330JF0058825
       Coding: 0201000001010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
       ROD: EV_CamerSysteTopViewAUDI_005_AU57.rod
       Component: TSG HR        H03 0506
    Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
       Part No SW: 4G0 919 604 G    HW: 4G0 919 604 G
       Component: HeadUpDisplay 006 0106
       Coding: D60000
       ASAM Dataset: EV_HUDContiC7 001020
       ROD: EV_HUDContiC7.rod
       VCID: 2F2E12DE7632CA3738-807A
    Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
       Part No SW: 4H0 907 547 F    HW: 4H0 907 547
       Component: NV-ECU-Gen1   H09 0042
       Serial number: 0K84AE40082377
       Coding: 1311
       ASAM Dataset: EV_NightVisioGen1 001002
       ROD: EV_NightVisioGen1.rod
       Night vision system camera:
       Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
       Component: NV-CAM-Gen1  H08 0008
       Serial number: 00000000001226200152
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H25 0038
       Coding: EA060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2600F7FA59C88B7FCB-8072
       Part No SW: 4G0 907 541 A    HW: 4G0 907 541
       Component: ACC3          H17 0400
       Coding: 7601010102
              U1113 00 [008] - -
       Part No SW: 4G0 907 107 D    HW: 4H0 907 107
       Component: BV-SG         H31 0038
       Serial number: 005000050110127
       Coding: 04C19A1A0111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    0165 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [QSP_Signal_Error]
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 312A14A66006DCC72E-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0010
       Serial number: 120919201010
       VCID: 2C1405D24724B12F1D-8078
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145     HW: 4H0 907 145
       Component: AEM - LEAR    H05 0006
       Revision: 00001001    Serial number: 97804000841604
       ASAM Dataset: EV_AEMLearAU64X 002014
       ROD: EV_AEMLearAU64X_AU57.rod
       VCID: 6680B7FA99484B7F0B-8032
    End----(Elapsed Time: 03:03, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
  10. #9
    OP
    Have you simulated a full duty cycle from zero range to 100% to see if your full boost range is possible to achieve by the mechanical spring tension of air motor regardless?
    I don't trust tuner or factory report tables by block data with a controller, I verify it by cross check of mechanicals and external electrical isolated tests, shouldn't you?
  11. #10
    Hmm, I couldn't find anything obvious for that ECU. So I dug up the SSP for the 4.0T. It's kinda interesting:
    Charge Pressure Regulation
    A new strategy of charge air pressure regulation is being used. Previously, charge pressure was regulated by means of a pressure actuator. A wastegate was held closed by spring force and opened if charge pressure was too high. The pressure required was diverted from the charge pressure and introduced directly to the pressure actuator using a solenoid. For the first time at Audi, vacuum is being used to regulate charge pressure. The wastegate is opened through mechanical spring force. If charge pressure is required, the flaps are closed using vacuum actuators activated simultaneously by Wastegate Bypass Regulator Valve N75. The signals from sensors G31 and G447 are detected for charge pressure regulation. This charge pressure data is included in the map calculation. Sensors G42 and G71 are used for calculating air mass.
    Maybe this measuring value?
    IDE04002-ENG167462 Charge press. ctrl.
  12. Likes Jack@European_Parts liked this post
