VW Scricco ABS Pump Code lost (MK60EC1)
VAGMAN
C?ID=374246
My nephew has recently purchased a 2009 VW Scricco from an auction site, the car runs and drives however it had the ABS, Tracation control and brake light displayed and beeping along with other items. We wanted to resolve the ABS pump issue first for obvious reasons and then work through the other items.
I did some online research and it seems the ABS pumps on these vehicles are prone to fail, we sent the unit off to be repaired however it turns out it that it's beyond repair so we purchased a second hand unit with the same part numbers.
The mechanic said that the original ABS pump does not have a code and therefore he cannot code the second hand unit. I've got the following scan from the car when the original ABS pump was connected and it does show the code to be missing. The car is currently with the mechanic.
Is there anyway of getting the ABS pump coding given where we are with it? let me know if you any other information is required and I'll try to provide that.
thanks in advance!
Friday,10,May,2019,18:32:18:25558
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ13Z9V015910   License Plate:
Mileage: 157570km-97909mi   Repair Order: VW scirroco
Chassis Type: 13 (1K0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 42 44 46 52 56
VIN: WVWZZZ13Z9V015910   Mileage: 157570km-97909miles
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 KD    HW: 03L 906 022 G
   Component: R4 2.0l TDI 0000SG  9979
   Revision: 13H01---    Serial number: VWX7Z0H93NM1BO
   Coding: 0001072
   Shop #: WSC 55776 001 1048576
   VCID: 71EF931B68CACCC222-8024
008598 - Oxygen (Lambda) Sensor B1 S1
               P2196 - 000 - Signal too High (Rich) - MIL ON
                    Fault Status: 11100000
                    Mileage: 154672 km
                    Time: 17:24:23
                    RPM: 2185 /min
                    Speed: 129.0 km/h
                    Lambda: 51.3 %
                    Mass Air / Rev.: 580.0 mg/str
                    Voltage: 0.375 V
                    (no units): 16.0
                    Voltage: 0.975 V
Readiness: 1 1 0 0 0
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0120
   Revision: 00H35001
   VCID: 76E5A007C1A4EBFAF7-8022
                    Reset counter: 130
                    Count: 4608
                    Count: 195
                    Count: 43008
   Part No SW: 1K0 820 047 JD    HW: 1K0 820 047 JD
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 6FEB95637EFEDA3234-803A
   Revision: 00H54000    Serial number: 00000008403739
   Coding: EC880F0300041A0067960E001900000000087B075C400124000000000000
   Shop #: WSC 00020 790 00000
   VCID: 326D5C17AD4CB7DA1B-8066
   Subsystem 1 - Part No: 1K8 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 180808 022  0602
   Coding: 00038805
   Shop #: WSC 00020
   Component: RLS     291008 054  0402
   Coding: 00209133
   Shop #: WSC 00020
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 F    HW: 1K0 919 475 F
   Component: PARKHILFE     005 1506
   Revision: 00005000    Serial number: 0 263 004 300
   Coding: 100001
   VCID: 3567670B9C22A0E23E-8060
   Part No SW: 3C0 907 376     HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serial number: 16100802910001
   Coding: 000180
   VCID: 66C5F04791041B7A47-8032
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 130
                    Mileage: 157571 km
                    Time: 18:34:25
                    Bin. Bits: 00000000 00001000
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0H AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D00EWZP
   Coding: 0012360
   Subsystem 1 - Serial number: 6332MSME413147584
   Subsystem 2 - Serial number: 6342MSME40304B04+
   Subsystem 3 - Serial number: 6352QSME46104B0EH
   Subsystem 4 - Serial number: 6362QSME46102B3CH
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000004
   VCID: 0303C9D34276CE52C0-8056
   Part No SW: 1K8 920 960 E    HW: 1K8 920 960 E
   Component: KOMBIINSTRUMENT VDD 1244
   Revision: V0003000    Serial number: VWX7Z0H93NM1BO
   Coding: 0003403
   VCID: 336359135256BED210-8066
   Component: J533__Gateway   H-- 0210
   Revision:   H--       Serial number: 3400K08A2303B2
   Coding: E9A81F06000212004001
   VCID: 377B6D03462E52F22C-8062
   Component: IMMO            VDD 1244
   Revision: A1001003    Serial number: 7661137131
   Coding: 020000
   Shop #: WSC 00040 040 00001
   VCID: 295FBB7B409AF402AA-807C
                    Reset counter: 130
                    Mileage: 157571 km
                    Time: 18:37:34
   Part No SW: 1Q0 959 701 F    HW: 1Q0 959 701 F
   Component: Tuer-SG         008 2022
   Coding: 0016949
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 175    2301
   Revision: 00H15000
   VCID: 2A5D4477859CFF1AA3-807E
   Component:    KSG PQ35 G2  020 0205
   Coding: 81900A0002830C7F3F04840570085ACE903CA0
   Subsystem 2 - Part No: 1K8 951 171
   Component: DWA-Sensor      001 0104
   Part No SW: 1Q0 959 702 F    HW: 1Q0 959 702 F
   Coding: 0016948
   VCID: 38796E3F4B305D8A25-806C
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3H3374556
   Coding: 0100040004
   VCID: 65C7F74B6C0210624E-8030
End-------------------------(Elapsed Time: 01:42)--------------------------
OP is now verified. Moving to Car Repair Support.
Vehicle Identification No.WVWZZZ13Z9V015910
ModelScirocco 2.0
SCI
Date of production07.11.2008
Model year2009
Sales type13726L
Engine CodeCBDB
Transmission CodeKRM
Part No SW: 03L 906 022 KD HW: 03L 906 022 G <<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
Coding: 0001072
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD <<<<<<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
Revision: 00H35001
Coding: 763B00F5092300FF6E1400E5901900000000 VIN STRIP RHD
Coding: 763BC0F5092300FF6E1403E5901900813000 RHD TRY THIS
Welcome OP please try the green and report back .........
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PEWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components7KBVehicle class differentiation -130-
drive-off assistanceUG0Without hill start assist/hill descent control/comfort driving assist
Emission standard7MGEmission standard EU5
Trailer hitch1D0without trailer towing
airbag4UFAirbag for driver and front passenger with front passenger airbag deactivation
Aktivkohlebehälter / Ottopartikelfilter1E0Without activated charcoal canister
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SJLeft exterior mirror, convex
Right exterior mirror5RVRight exterior mirror, aspherical
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WLJack for external audio source
Equipment levelsA8FSports equipment
Brake type in rear1KDDisc brakes in rear
batteriesJ0NBattery 330 A (61 Ah)
Brake type, front1ZEDisc brakes in front (Geomet D)
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0NComponent parts set, complying with vehicle type for Great Britain, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VFInformation kit in English
brake wear indicator9U1brake wear indicator
Heated washer nozzles9T0Without heated washer nozzles
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H1"drive select"
General operating permit, alterationsC03Operating permit, alteration
Roof insert/convertible top3FAroof without cut out
Suspension system in rearUB7Rear shock absorption for sports version
Suspension system in frontG03Shock absorption in front
Insert for the filling up of unleaded fuel/fuel type2G5Filler neck module 1 without insert
Installation differentiation for components0ENInstallation differentiation for transmission MQ 350 -- vehicle components --
Theft protection system7ALAnti-theft alarm system, interior monitoring, backup horn and towing protection
Park distance control7X1Park distance control
Electric interface for external useUF6Electric interface for external use (MEDIA-IN jack)
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedal clusterVF0Standard pedal cluster
Headlight activation8K3Daytime headlights with automatic headlight control and coming home function
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YAWeight range 1 installation control only, no requirement forecast
Weight category front axleL55Suspension range 55 installation control only, no requirement forecast
Base engineTU34-cylinder diesel engine 2.0 l unit 03L.H
Luggage netting/pocket on backrest(s)4U0Without luggage nets/pockets on backrests
Luggage compartment cover3U1Folding trunk cover
cruise control system8T0Without cruise control system (CCS)
Transmission specificationsG0K6-speed manual transmission
handle for hand brake lever6PChandbrake lever grip (leather)
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Rear seats3KCRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9APClimatic air-conditioning system (semi-automatic)
Headlamps8BKTwin headlamps for driving on the left, with integrated high beam
Customized installationFC0Without individual installation
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5BInstrument insert, mph speedometer Great Britain
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8CCoupe
coolbox1W2Glove compartment cooling system
Climatic zones0Y1Standard climatic zones
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
Head restraints3J1Hight-adjustable head restraints for front seats
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems0F5Fuel system for diesel engine
Body measures5C0Without special body measures
Rear license plate bracket6P1Rear license plate carrier (ECE)
Front license plate bracket6W1Front license plate carrier (large)
Paint preservative/transit coating5K5Transport protection film with additional transport protection measures
Steering system arrangementL0RRight-hand drive
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H9Backrest release for front seats with Easy Entry feature
Lumbar support7P0Without lumbar support in seat backrests
steering wheels1XULeather steering wheel with aluminium trim
Speaker installation8RM8 speakers (passive)
Headlight range control8Q1Headlight range control
Center armrest6E3Center armrest in front
Multi-function display/trip computer9Q1Multi-function display/trip computer
Engine cooling8Z5not hot country
Engine specificationsD914-cyl. turbo diesel engine 2.0 L/103 KW (4 V) TDI common rail TG3/TJ3/TU3/TL4/TP4/TM3/TW3/TR4/TS1/TN5
Left vanity mirror4SDVanity mirror, left, illuminated
Right vanity mirror4TDVanity mirror, right, illuminated
Navigation device7Q0without navigation system
rear fog lamp8TDRear fog light for driving on the left
Front fog lamp/additional headlamp8WAWithout fog lights
Rear of platform module base4P0Rear floor panel module, type 1
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsCL9Alloy wheels 8J x 17
Radios8AIRadio "RCD510 MP3"
Smoker's/non-smoker's package9JANon smoker version
Tire pressure monitoring system7K0Without tyre pressure monitor
tireHK0Tires 235/45 R17 97W x1
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G6Space-saving spare wheel
Restraint systems, front3QT3-point seat belts in front, with tensioner and height adjustment
PDDAdaptive chassis control
PJ1"Donington" 4 alloy wheels 8J x 17 tires 235/45 R17
PJWSpace and weight saving spare wheel (16-inch)
PLA"Lights & Vision" package
RHC"RCD 510" 4 x 20 W, 8 speakers
WD2Anti-theft alarm system "Plus" incl. single door opening
WDIMultimedia socket MEDIA-IN
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SSLabels in English and French
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TGSports comfort seat in front, left
Front seat, right3SGSports comfort seat, front, right
Seat belt check9P3Seat belt reminder, electric contact in buckle
Outer rear seat belts3ZB3-point seat belts, outer rear with ECE label
seat coversN3ASeat trim covers in fabric
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A0without seat heater
Safety head restraint system3K0w/o safety head restraint system
Horns8Y1Two-tone horn
Side and rear windows4KCSide and rear windows in heat-insulating glass
power outlet7B212 volt socket in luggage compartment
Bumper2JCComfort bumpers
Rear stabilizer0BERear stabilizer
Front stabilizer bar0ADFront stabilizer bar
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N3intermittent windscreen wiper with rain sensor
Nameplate set0NDNameplate set "TDI"
Mass damper for steering wheels1Q0steering wheel without balance weight
Door and lid locking system4K3Central locking w/ radio remote control, interior controls and SAFELOCK
Type approval countries/countries with special requirementsB09Type approval country GB/Northern Ireland
Carrier frequency for remote control5D1Carrier frequency 433.92 to 434.42 Mhz
Partition3CAwithout partition
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
doors0A12 doors
TV reception/digital radio receptionQV0without TV/digital radio reception
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EXSpecial identification plate for EU
Delivery equipment2A0Without delivery equipment
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Telephone / telematics9W0Without car phone preparation/ installation
LongLife Service RegimeQG1LongLife Service Regime
Heat accumulator system/auxiliary heater7E6electric air additional heater
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W0without washer water level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TAwithout floor mats
Additional child seat anchors3B4Child seat anchors for child seat system ISOFIX
Auxiliary heating system9M0Without auxiliary heater/parking heater
VAGMAN
C?ID=374246
Thank you, I have forwarded the code to the mechanic and will report back with his feedback.
VAGMAN
C?ID=374246
Hi Jack, thanks for the code, unfortunately that didn’t work, are there any other that you suggest for me to try?
Thanks in advance
VAGMAN
C?ID=374246
Can Anyone assist or suggest anything else?
Find me auto-scans of other sciroccos of this region to observe.
VAGMAN
C?ID=374246
Hi Jack, thanks for replying, I won’t be able to get this unless there is someone else on here with a similar car?
VAGMAN
C?ID=374246
Thank you, I’ve forwarded it to my mechanic, will let you know either way.
VAGMAN
C?ID=374246
Thanks NEtech, however the code did not work.
Is there anyone with a RHD 2009 2.0 tdi CR scirocco that can read out the code from their car? Will be happy to pay a small fee?
ModelScirocco 2.0
SCI
Model year2009
Sales type13726L
Engine CodeCBDB
Coding: 0001072
Revision: 00H35001
Coding: 763BC0F5092300FF6E1403E5901900813000 RHD PRIOR FAIL
Coding: 763B40F5492300FF6E1402E5921900823000 NTECH FAIL
Coding: 763B40F5492300FF6E1402E5901900813000 RHD TRY THIS OP
Coding: 763B40F5492300FF6E1403E5901900813000 RHD TRY THIS OP
Coding: 763B40F5492300FF6E1403E5901900823000 RHD TRY THIS OP
VAGMAN
C?ID=374246
Thanks Jack, I’ll come back with feedback once I get a reply from the mechanic.
Please report if we get a login, not just that it doesn't work............
Since this car is from an auction.......... OP
Is the VIN consistent in advanced measuring blocks of immobilizer and engine ECU, is immobilizer status married and is the ( POWER CLASS ) PC set correct in the cluster & to correlate to the engine ECU PC?
VAGMAN
C?ID=374246
I’ve had some feedback from the mechanic, not sure how meaningful this is however he said he receives ‘error code 31’ and it stops there, appreciate this might be enough but I’m finding it difficult to get anymore info.
TIA
VAGMAN
C?ID=374246
Hi, to provide an update to this issue, We had another mechanic look into the issue and he was able to generated the code, all is well with the car and all of the lights and beeping sound has now gone. He mentioned that the code which was accepted had "...B3..." where the ones supplied by Jack had "...B4..".
I have asked him for the actual code and will update the thread once I receive it.
Thanks to all who contributed to the issue.
