Maps 2019 Atlas, 3.6L CDVC maps
Maps
Jef
HQ
Monday,17,June,2019,10:54:16:34333
VCDS Version: 19.6.0.6 (x64)  HEX-NET CB: 0.4505.4
VIN: 1V2NR2CA0KC531985   License Plate:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 2B 36 3C 42 44 47 4B 52
          5F 69 6C 6D 75 A5 CA D6 D7
VIN: 1V2NR2CA0KC531985   Mileage: 118km-73miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (0-32-CDVC)       Labels: None
   Part No SW: 03H 906 026 AA    HW: 03H 907 309 K
   Component: VR6 3.6l FSI  H21 6694
   Revision: 52H21000
   Coding: 012A003244740108B0000000000000000000000000000000
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_ECM36FSI01103H906026AA 001005
   ROD: EV_ECM36FSI01103H906026AA.rod
   VCID: E484E126EFDD226F91-80B0
   CAN Converter 01:
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [036] - -
                    Mileage: 16 km
                    Date: 2019.04.27
                    Time: 13:17:24
                    Engine speed: 3618.50 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 65 km/h
                    Coolant temperature: 59 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 14.460 V
                    Unlearning counter according OBD: 42
                    Long-term fuel trim bank 1 at idle: -0.14 %
                    Oxygen control: adaptation value at partial load: bank 1: 0.98779
                    Short term adaptation of mixture formation bank 1: 9.4 %
                    Outside air temperature: 21 °C
                    Oxy sensor 1 bank 1 char curve offset: -0.00031
                    Fuel: tank fill level: 3.0 l
10594 - Cylinder 4
          P0304 00 [036] - Misfire Detected
                    Mileage: 16 km
                    Date: 2019.04.27
                    Time: 13:17:24
                    Air mass: actual value:: 131.36 g/s
                    Engine torque: 413.8 Nm
                    Oxygen sensor bank 1 sensor 1: specified value: 0.8582
                    Intake camshaft bank1 active operating mode-Bits 0-7: 1
                    Intake camshaft bank1 active operating mode-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
Readiness: 0000 0100
   Part No SW: 09G 927 158 DR    HW: 09G 927 158
   Component: AISIN AQ8     206 3536
   Coding: 0000000100000000000000000000000000000000
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 8640DBAE39A1B07F2F-80D2
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 53468000000088
   Coding: 44FC6B8D84231A6DC5800308A2C86922D62158A3C045967E38415058C2AA420B0023641C12141A1D8DDB45506CC8CF
   ROD: EV_Brake1UDSContiMK100IPB_037_VW41.rod
   VCID: F7BEA66A4E4BD9F724-80A2
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0497749917
   Coding: 1F20000723
   VCID: C3C602BA4A13455748-8096
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11363946
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 3CN 907 044 M    HW: 3CN 907 044 M
   Component: Climatronic   H05 2009
   Revision: 00001K03
   Coding: 1602002620001C001104210C5210152C
   ASAM Dataset: EV_ACClimaBHBVW416 002012
   ROD: EV_ACClimaBHBVW416.rod
   VCID: C9DA1092683F9F0782-809C
   Fresh Air Blower Back:
   Part No SW: 5Q0 937 085 BT    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H38 0273
   Serial number: 8326000302ÿÿÿÿ
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 8C54E98627CDCA2F79-80D8
   Subsystem 1 - Part No SW: 5Q0 955 555     HW: 5Q0 955 555
   Component: RLHSS  052 0122
   Serial number: S7Y18M10D23H08M44S45
   Coding: 00382D
   Subsystem 2 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H08 0050
   Serial number: 0000009600363Z01M402
   Coding: 150000
   Subsystem 3 - Part No SW: 3CN 959 719     HW: 3CN 959 719
   Component: GTO BF  H06 0007
   Serial number: 8MW00103101800011054
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 R    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23 0170
   Serial number: 0300091220180C206242
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE1161534
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1161415
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1163033
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1164820
197904 - Central Locking
          B140A 4B [008] - Over temperature
                    Reset counter: 42
                    Mileage: 15 km
                    Date: 2019.04.20
                    Time: 10:47:51
204293 - Remote key 1
          B1479 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 43
                    Mileage: 15 km
                    Date: 2019.04.16
                    Time: 09:51:11
204549 - Remote key 2
          B147A 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 43
                    Mileage: 18 km
                    Date: 2019.05.06
                    Time: 17:34:16
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000137089R18319
   Coding: 0271267951
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: D1EA38F2806FA7C7CA-8084
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 320007C959FFC728949C810530401600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: C4C401A64F1D426F71-8090
   Part No SW: 3Q0 959 655 BN    HW: 3Q0 959 655 BN
   Component: Airbag VW21   006 0713
   Revision: --------    Serial number: 003SUMKTQTAP
   Coding: 8CCCDC00000000005000001A420800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 8B56EA9A22C3CD1770-80DE
   Occupant Detection:
   Component: Occ.Detection  H13 0022
   Serial number: IBH0000J18000ARL7B0L
   Coding: 303030
   Subsystem 2 - Part No SW: -----------    HW: 454 002 810 18
   Serial number: 3570000000076784E13M
   Subsystem 3 - Part No SW: -----------    HW: 454 001 310 18
   Serial number: 3580000000066655D13I
   Subsystem 4 - Part No SW: -----------    HW: 454 801 212 18
   Serial number: 35100CAAC3F17000000-
   Subsystem 5 - Part No SW: -----------    HW: 454 802 711 18
   Serial number: 3520017F71F17000000L
   Subsystem 6 - Part No SW: -----------    HW: 454 802 111 18
   Serial number: 35500B165EC16000000Q
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 454 802 111 18
   Component: FrontSensor_P  304 0149
   Serial number: 35600B36DEC16000000.
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 3CN 920 891 B    HW: 3CN 920 891 B
   Component: KOMBI         403 4191
   Coding: 0BA40F1DEF88CF0502886B0B50010000A0000000
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 26111800841855
   Coding: 0B0500347F087300FB0322581E0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: BD3274422CF733A73E-80E8
   Component: 1-01-0e-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 33180001731780091439
   Coding: 2EFFFF
   Serial number: 9617136200
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 3CN 907 155     HW: 3CN 907 155
   Component: U13DCAC  H23 0890
   Serial number: B008238
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00011.10.18
   Coding: 0301
   VCID: CCD42986674D8A2FB9-8098
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 18000349867003
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: B326527A1AB3F5D7D8-80E6
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RJG33210
   Coding: 0010000000000500018280808080000000008100000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   Component: HRE_Master    H12 0081
   Serial number: 0500310623
   Coding: 02012103
   ROD: EV_HREntryHella_VW27.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0501534397
   Coding: 020121
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YA008RKL00L92
   Coding: 003F1B205200020000000000
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000001319251
   Coding: 011000
   Part No SW: 3QF 909 144 B    HW: 3QF 909 144 A
   Component: EPS_MQB_ZFLS  570 1582
   Coding: 9B1F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: C7DE16AA7E2B697794-8092
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1JMD03LYHD
   Coding: 2214060002AAAFAA000000000000
   ASAM Dataset: EV_AMPMst12C3Gen2ALPI 001001
   ROD: EV_AMPMst12C3Gen2ALPI.rod
   VCID: AE10430EF191D83FB7-80FA
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 03121800841039
   Coding: 000000070900135200010000000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: B5226C6214C7EBE7F6-80E0
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YA008RKM00C38
   Coding: 003F13205E00020000000000
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000001320934
   Coding: 091000
   Part No SW: 3QF 035 876 A    HW: 3QF 035 876 A
   Component: MU-S-NS-US    853 0890
   Coding: 021406020000000051220002001808001F0500E401200405CE
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: C8DC15967335660F9D-809C
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJV2910418
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0497744968
   Coding: 0200000200000000
   VCID: C0CC0DB65B055E4F55-8094
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG040522
   Coding: 01140604A30F20003000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   VCID: B93A605238DF0F8712-80EC
   Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0266
   Revision: --------    Serial number: A2-C758-8680-2
   Coding: 0988
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: C5C21CA244277B6766-8090
   Component: OCULowMQBUS   009 0570
   Coding: 02140602C2823A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 1272
   Serial number: 14081841P11760
   Coding: 000401060001020100221355C150490084000E200120
   ROD: EV_MFKBoschMQBB_001_VW27.rod
   VCID: 885CD59633B5A60F5D-80DC
   Coding: 00804074160C
   Part No SW: 7P5 941 591 AA    HW: 7P5 941 591 A
   Component: LED1L         H06 0003
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: FBB6BA5A7263FD9740-80AE
0800 - Bulb for Low-Beam Headlamp
          C1198 F6 [040] - Over-Temp Protection Active
                    Reset counter: 0
                    Mileage: 116 km
                    Date: 2019.06.01
                    Time: 16:12:18
   Component: LED1R         H06 0003
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
                    Reset counter: 0
                    Mileage: 114 km
                    Date: 2019.06.01
                    Time: 16:10:01
End----------(Elapsed Time: 02:10, VBatt start/end: 14.4V/14.4V)-----------
Engine @ idle, cold start:
;SW:03H-906-026-AA   HW:03H-907-309-K ---  Engine
;Component:VR6 3.6l FSI  H21 6694, Coding:012A003244740108B0000000000000000000000000000000
;EV_ECM36FSI01103H906026AA,001005,EV_ECM36FSI01103H906026AA.rod
;Monday,17,June,2019,10:50:58:34333
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: E484E126EFDD226F91-80B0
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),1V2NR2CA0KC531985,
IDE00019,Voltage terminal 30,14.200, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,1189, /min
IDE00025,Coolant temperature,27, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,14, s
IDE00083,Throttle valve position (absolute),17.3, %
IDE00084,Absolute load value,42, %
IDE00085,Normed load value,47.8, %
IDE00086,Accelerator position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,60.0, Nm
IDE00148,Median injection timing,1.940, ms
IDE00150,Pressure in brake booster,72.77, hPa
IDE00151,Oil fill level,59.904, mm
IDE00152,Oil warning threshold,28.000, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00159,Timing angle retardation cylinder 5,0.0, °
IDE00160,Timing angle retardation cylinder 6,0.0, °
IDE00167,Exhaust temperature 1 bank 1,408.7, °C
IDE00168,Exhaust temperature 1 bank 2,403.9, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00173,Cruise Control System: specified speed,0,
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-5.063, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-6.086, °
IDE00178,Camshaft adjustment intake bank 1: specified value,15.078, °
IDE00179,Camshaft adjustment intake bank 1: actual value,15.133, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.00, °
IDE00186,Fuel low pressure: actual value,553.8, kPa
IDE00187,Coolant temperature at engine start,24.8, °C
IDE00188,Fuel high pressure: actual value,6.9395, MPa
IDE00192,Coolant temperature at radiator outlet: actual value,27.6, °C
IDE00194,Coolant temperature at radiator output: specified value,95.0, °C
IDE00196,Engine oil temperature,25.8, °C
IDE00201,High fuel pressure: specified value,6.9840, MPa
IDE00202,Low fuel pressure: specified value,550.0, kPa
IDE00304,Fuel level,11.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00347,Air mass: actual value:,17.77, g/s
IDE00348,Intake air temperature,30, °C
IDE00349,Throttle valve position: normed,7, %
IDE00350,Air mass: specified value,63.6, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00357,Fuel temperature,25.5, °C
IDE00358,Limitation: torque,469.8, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,984.84, hPa
IDE00371,Fuel consumption,6.42, l/h
IDE00375,Generator: load signal,29.01, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,737.4, mV
IDE00393,Accelerator pedal: sensor voltage 2,371.0, mV
IDE00405,Crankshaft speed (RPM),1203.0, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,1,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,9,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,0,
IDE00474,Ambient air pressure,98, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,14.9, Nm
IDE00496-ENG57549,Activation of oil pressure switch valve-Bits 0-7,0,
IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,5,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,29, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.987 Lambda / -0.043 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.635, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00565,Current of oxygen sensor bank 2 sensor 1 (broadband sensor),0.977 Lambda / -0.063 mA,
IDE00566-MAS04121,Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage,0.595, V
IDE00566-MAS04122,Oxygen sensor bank 2 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,0.990, Lambda
IDE00583,Throttle valve specified value,7, %
IDE00584,Distance driven since erasing DTC memory,111, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,15.3, %
IDE00592,Oxygen sensor control status,Closed loop,  / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,-13.0, Degrees
IDE00595,Allocation of oxygen sensors,B1S1 B1S2   / B2S1 B2S2  ,
IDE00597,Long term adaptation of mixture formation bank 1,-1.6, %
IDE00598,Long term adaptation of mixture formation bank 2,3.1, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,9,
IDE00604,Short term adaptation of mixture formation bank 1,-1.6, %
IDE00605,Short term adaptation of mixture formation bank 2,-4.7, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00699,ESI: minimum oil level in service interval,32.000, mm
IDE00700,ESI: maximum oil level in service interval,-32.000, mm
IDE00727,Test steps still to be performed,0,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,0.00000,
IDE00739,Test of oxygen sensors bank 2: Delta-Lambda,0.00000,
IDE00752,Test of oxygen sensor control.,Test off,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00787,Cause for cancellation,0,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,29.2, °C
IDE01076,Time since ignition off,65535, s
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,1.0000,
IDE01236-ENG57549,Coolant recirculation pump-Bits 0-7,0,
IDE01260,Generator power,1149.82, W
IDE01266-ENG57549,Coolant shut-off valve-Bits 0-7,3,
IDE01267,Height correction,0.97205,
IDE01378,High fuel pressure: control deviation,0.0715, MPa
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01405-ENG57549,Status of starter activation-Bits 0-7,2,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test off,
IDE01638-ENG127368,Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951,235,
IDE01639,Dynamic factor O2 sensors bank 2 or bank 4 before cat. conv.,1.0000,
IDE01641-ENG57549,Result of oxygen sensor test bank 1 after catalytic converter-Bits 0-7,160,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.695, V
IDE01645,Oxygen sensor voltage bank 2 after catalytic converter,0.670, V
IDE01647,Result of O2 sensor aging test bank 2 after cat. conv.,Test off,
IDE01647-ENG129417,Result of O2 sensor aging test bank 2 after cat. conv.-Test_Program_Channel 379,235,
IDE01649,Throttle valve position 1,4.30, %
IDE01650,Throttle valve position 2,13, %
IDE01652,Opening degree Evap. Emission (EVAP) Canister Purge Reg. Valve,0.0, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test off,
IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,235,
IDE01678,Result of O2 sensor test ready bank 2 after cat. conv.,B2-S2 OK,
IDE01678-ENG129413,Result of O2 sensor test ready bank 2 after cat. conv.-Test_Program_Channel 114,213,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01834,Battery voltage,14300, mV
IDE01869,Long-term fuel trim bank 1 at idle,0.23, %
IDE01870,Oxygen sensor after catalytic converter: operating status,B1-S2 OK,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,209,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,8.0000,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,-0.470, %
IDE01876,Adaptation of loss torque,3.3, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,5,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000100 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,40.302, %
IDE01885,Shut off of oxygen sensor control,l-Reg.ON,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01887,Adaptation of Fuel Pump (FP),-43.8, kPa
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,50.751, %
IDE01899,Load value: corrected specified value,79.17, %
IDE01901,Lost torque adaptation: idle,1.4, Nm
IDE01902,Lost torque adaptation A/C compressor,3.3, Nm
IDE01903,Lost torque adaptation driving mode,-0.2, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,5.1, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.01910,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,0.95355,
IDE01911,Leakage air,0.2, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,0.9902,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,170,
IDE01916,Leakage recognition from oxygen sensor control,0.9561,
IDE01917,Leakage after throttle valve,-1.000,
IDE01918,Leakage before throttle valve,-1.000,
IDE01919-ENG57549,Leakage recognition: status-Bits 0-7,221,
IDE01920,Oxygen sensor: mixture correction with active diagnosis,0.0000,
IDE01922,Vehicle distance driven,118, km
IDE01923,Control module distance driven,118122, m
IDE01928,Close cam shaft angle at quantity control valve,46.7, °
IDE01929,Open cam shaft angle at quantity control valve,-23.2, °
IDE01930,High pressure regulation: adaptation value,0.0000, MPa
IDE01932,High pressure pump injection volume,-13.14, mm³
IDE01975,Numb.of misfir.: cylinder 1,15,
IDE01976,Numb.of misfir.: cylinder 2,25,
IDE01977,Numb.of misfir.: cylinder 3,9,
IDE01978,Numb.of misfir.: cylinder 4,18,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,30,
IDE02116,Exhaust gas temperature before catalytic converter,417.86, °C
IDE02117,Relative load value,22.41, %
IDE02118,Oxygen sensor bank 1 sensor 1: voltage,0.000, V
IDE02119,Long term adaptation of oxygen sensor control: bank 1,-0.8, %
IDE02211,Brake pressure,4.29, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02756,Number of manual engine starts,85,
IDE02757,Number of automatic engine starts,3,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,13,
IDE03010-MAS01627,Number of prevented stop processes-Steering,42,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,76,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,8,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,58,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,81,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,7,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,12,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.505, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.496, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.759, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.243, V
IDE03362,Requested transmission torque,1000.0, Nm
IDE03363,Numb.of misfir.: cylinder 5,9,
IDE03364,Numb.of misfir.: cylinder 6,18,
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,0.000, m/s²
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,202,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,165,
IDE03694-ENG57549,Result of test of fuel supply system partial throttle-Bits 0-7,0,
IDE03696-ENG57549,Result test of oxygen sensor heater after catalytic converter-Bits 0-7,145,
IDE03697-ENG57549,Result test of oxygen sensor heater before catalytic converter-Bits 0-7,5,
IDE03698-ENG57549,Result of dynamic test of oxygen sensor before cat. converter-Bits 0-7,1,
IDE03699-ENG57549,Result of test of oxygen sensor before catalytic converter-Bits 0-7,229,
IDE03700,Status adaptation dew point end,ADP is OK,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,2,
IDE03703-ENG57549,Result catalytic converter diagnosis test-Bits 0-7,1,
IDE03707-ENG57549,Result of NPulse test-Bits 0-7,170,
IDE03708-ENG57549,Result of test 2 of oxygen sensor before catalytic converter-Bits 0-7,1,
IDE03709,Angle difference actual-specified camshaft adjuster,0.156, °
IDE03710-ENG57549,Result of camshaft diagnostic test-Bits 0-7,1,
IDE03711,Mass flow through throttle valve,26.6, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03794,Long-term fuel trim bank 2 at idle,0.75, %
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,38.373, %
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,3,
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,6,
IDE03808-ENG57549,Oxygen sensor bank 2 sensor 1: status-Bits 0-7,3,
IDE03809-ENG57549,Oxygen sensor bank 2 sensor 2: status-Bits 0-7,6,
IDE03810,Oxygen sensor bank 2 sensor 1: specified value,0.9976,
IDE03811,Test of oxygen sensors bank 2: Delta-Lambda: result,Test off,
IDE03811-ENG129422,Test of oxygen sensors bank 2: Delta-Lambda: result-Test_Program_Channel 977,235,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,356.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.ON,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,216,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,147.07, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,30.746, %
IDE03822-ENG101533,Heated oxygen sensor bank 2: sensor 2: resistance-R uw q2 UWORD Chann 121,564.000, Ohm
IDE03822-ENG127296,Heated oxygen sensor bank 2: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03823,Heated oxygen sensor bank 2: sensor 2: activation,Unknown (0),
IDE03823-ENG129414,Heated oxygen sensor bank 2: sensor 2: activation-Test_Program_Channel 125,0,
IDE03824,Heated oxygen sensor bank 2: sensor 1: resistance,147.07, Ohm
IDE03825,Heated oxygen sensor bank 2: sensor 1: activation,31.131, %
IDE03827,Conversion test Bank 2: result,Test off,
IDE03827-ENG129418,Conversion test Bank 2: result-Test_Program_Channel 487,235,
IDE03830,Status of adaptation of on-demand fuel pump,Test off,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,235,
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,B1-S2 OK,
IDE03836-ENG129323,Result of O2 sensor aging test bank 1 after cat. conv.-Test_Program_Channel 2114,209,
IDE03837,Result of O2 sensor aging test bank 2 after cat. conv.,B2-S2 OK,
IDE03837-ENG129416,Result of O2 sensor aging test bank 2 after cat. conv.-Test_Program_Channel 2115,213,
IDE03876,Misfires per 1000 revolutions of cylinder 5,0,
IDE03877,Misfires per 1000 revolutions of cylinder 6,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.98102,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03968-ENG57549,Camshaft adaptation results-Bits 0-7,1,
IDE04010,Engine torque: normalized,17, %
IDE04011,Nominal torque,470, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:4420/--- kPa,
IDE04083,Coolant temperatures,ECT 1:27 °C / ECT 2:30 °C,
IDE04110,Additional inputs and outputs,N/D_STAT:DRIVE,
IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,1310.711431, kJ
IDE04235,Heat quantity f dew pt end before cat conv bank 2: modeled,1171.134583, kJ
IDE04236,Heat quantity f dew pt end behind fr cat conv bank 1: modeled,217.157472, kJ
IDE04237,Heat quantity f dew pt end behind fr cat conv bank 2: modeled,216.286931, kJ
IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,133.551333, kJ
IDE04239,Heat quantity f dew pt end behind main cat conv bank 2: modeled,133.500125, kJ
IDE04240,Counter start bef dew pt end f O2 sensor bef cat conv bank1,0,
IDE04241,Counter start bef dew pt end f O2 sensor bef cat conv bank2,0,
IDE04242,Counter start bef dew pt end f O2 sensor beh fr cat conv bank1,0,
IDE04243,Counter start bef dew pt end f O2 sensor beh fr cat conv bank2,0,
IDE04244,Count start bef dew pt end f O2 sensor beh main cat conv bank1,0,
IDE04245,Count start bef dew pt end f O2 sensor beh main cat conv bank2,0,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,0,
IDE04324,Long term adaptation of oxygen sensor control: bank 2,0.0, %
IDE04410,Intake manifold pressure: target value,397.73, hPa
IDE04414,Cat conv temp: modeled,235, °C
IDE04604,Accelerator pedal travel,0.00, %
IDE04638,Transmission coolant valve,False result,
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
IDE04651,Torque request: A/C compressor,12.1, Nm
IDE04654-ENG57549,CAN status - engine control module-Bits 0-7,0,
IDE04655-ENG57549,CAN status - transmission control module-Bits 0-7,0,
IDE04656-ENG57549,CAN status - brake control module 1-Bits 0-7,0,
IDE04657-ENG57549,CAN status - brake control module 2-Bits 0-7,0,
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,7,
IDE04685,Setpoint generation interior torque,81.9, Nm
IDE04689,Starter control: Start interruption status,Correct result,
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,1,
IDE04691,Calculated reducing transmission intervention torque,1000.0, Nm
IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-50000.0, Nm
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04814,Transmission oil cooler valve,False result,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04858,Brake booster low pressure actual value,935.98, hPa
IDE04887,Powertrain target torque,-1382.1, Nm
IDE04889,Target torque for combustion engine crankshaft level,-52.8, Nm
IDE04933,Number of fill level decreases,0,
IDE04934,Last odometer reading since fill level decrease,0, km
IDE04935,Next to last odometer reading since fill level decrease,0, km
IDE04936,3. Last odometer reading since fill level decrease,0, km
IDE04937,Sensor for engine block temperature: raw value,27.0, °C
IDE05128,Intake air temperature in intake manifold bank 1,30.0, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,156149, s
IDE05140,Intake manifold pressure raw value,0.00, hPa
IDE05228,Operating hour counter,174, min
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05436,Engine operating condition,Idling,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,29.3, °C
IDE05438,Rear cat conv temp main cat conv model value,255.53, °C
IDE05439,Rear cat conv temp main cat conv bank 2 model value,246.51, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,22.73, %
IDE05445,Pressure before throttle valve of pressure sensor,984.38, hPa
IDE05447,Leak recog from oxygen sensor control bank 2,0.9761,
IDE05448,Long term adaptation of mixture form bank 2 at partial load,1.02066,
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,16000, Ohm
IDE05450,Oxygen sensor 2 bank 2 internal resistance limit value,16000, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,-0.00024,
IDE05463,Oxy sensor 1 bank 2 char curve offset,0.00314,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,719.99, °C
IDE05469,Oxygen sensor 1 bank 2 ceramic temp,719.55, °C
IDE05470,Cat converter oxygen storage capacity,446.1, mg
IDE05472,Cat converter oxygen storage capacity ref standardized,0.0000,
IDE05473,Cat converter oxygen storage capacity ref standardized bank 2,0.0000,
IDE05474,Main cat converter OSC age correction factor,1.008,
IDE05475,Main cat converter OSC age correction factor bank 2,0.938,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,14.1, kg/h
IDE05479,Misfire recognition reference moment,17.630, %
IDE05480-ENG57549,Evap. emiss. can. purge reg. valve short trip result-Bits 0-7,0,
IDE05482,Tank venting adaptation factor,0.000,
IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05487,Coolant temperature linearized value,26.959, °C
IDE05488,Coolant temperature modeled value,26.3, °C
IDE05508,Adaptation val cyl 1 with slow diagnosis,1.00000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,1.00000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,1.00000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,1.00000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,1.00000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,1.00000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,1.00000,
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,34,
IDE05797,Throttle valve adapter: specified value,4.826, %
IDE05928,Fuel consumption since DTC memory last erased,21.767, l/100km
IDE06006,Idle speed specified value,890, /min
IDE06017,Camshaft position deviation from reference position,0.00, °
IDE06020,Intake air temperature in intake manifold bank raw value,30.6, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,890.0, /min
IDE06040,High fuel pressure: regulator output value,-0.0915, MPa
IDE06041-ENG57549,PDTC drive cycle conditions status-Bits 0-7,36,
IDE06043,Cylinder head temperature: actual value,32.6, °C
IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,23, s
IDE06049,Pressure in brake booster: raw value,44.65, hPa
IDE06053-ENG57549,Test of mixture adaptation bank 1: status-Bits 0-7,1,
IDE06054-ENG57549,Test of mixture adaptation bank 2: status-Bits 0-7,1,
IDE06098,Sensor control factor: output value,0.98441,
IDE06192,Knock sensor: cylinder 2: voltage,0.283, V
IDE06193,Knock sensor: cylinder 3: voltage,0.400, V
IDE06194,Knock sensor: cylinder 4: voltage,0.820, V
IDE06195,Knock sensor: cylinder 1: voltage,0.269, V
IDE06255,Vehicle lateral acceleration,0.01, g
IDE06256,Vehicle lateral acceleration: raw value,0.00, g
IDE06257,Vehicle inclination acceleration angle: raw value,-12.557, m/s²
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,6,
IDE06307-MAS00108,Stop prevention history data-Day,8,
IDE06307-MAS00109,Stop prevention history data-Hours,15,
IDE06307-MAS00110,Stop prevention history data-Minutes,42,
IDE06307-MAS00111,Stop prevention history data-Seconds,50,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Engine temperature,
IDE06307,Stop prevention history data,Driving situation,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,Cat. heater,
IDE06308,Start request history data,Restriction in the start system,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Motor protection active,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Engine hood open,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Brake under pressure too low,
IDE06386,Oil level: static measurement,1.320, mm
IDE06387,Oil level: last valid dynamic value,0.000, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06393,Oil level: dynamic average value,131.068, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,1,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,0.000, m/s²
IDE06446-ENG57549,Status: incline angle-Bits 0-7,1,
IDE06495,Results of testing of crankcase ventilation successful,3,
IDE06496,Results of testing of crankcase ventilation unsuccessful,0,
IDE06567,Start-stop function deactivation frequency counter,13,
IDE06568,Stop prevention by driver frequency counter,98,
IDE06569,Vehicle stopped frequency counter,225,
IDE06610,Vehicle standstill with stop frequency counter,4,
IDE06647-ENG57549,Start-stop switch status-Bits 0-7,1,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,2,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,8,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06706-ENG57549,ACC variants-Bits 0-7,2,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,1,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,3,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06758,Air mass since engine start,0.64, kg
IDE06759,Cam shaft adaptation inlet: counter,5,
IDE06760,Camshaft adaptation: exhaust: counter,5,
IDE06761,Adaptation val cyl 5 with slow diagnosis,1.00000,
IDE06762,Adaptation val cyl 5 with fast diagnosis,1.00000,
IDE06763,Adaptation val cyl 6 with slow diagnosis,1.00000,
IDE06764,Adaptation val cyl 6 with fast diagnosis,1.00000,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG57549,Brake actuated status-Bits 0-7,3,
IDE06956-ENG57549,Driver-side belt buckle status-Bits 0-7,2,
IDE06957,Unfiltered clutch input rpm,895.0, /min
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,12,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,98,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,255,
IDE07164,Number injections,2794,
IDE07170,Clutch K0: torque,0.0, Nm
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,66,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07234,Status bid for valid static oil level,1,
IDE07235,Status bid for dynamic oil level,0,
IDE07238,Status of power transfer,0.00,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07475,Throttle valve position 2,4.71, %
IDE07573,Throttle valve adapter: actual value,4.81, %
IDE07840-ENG57549,Status plausibility accelerator pedal to brake pedal-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,1,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,1,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE08071-ENG57549,Remote start cancellation reason store 1-Bits 0-7,0,
IDE08072-ENG57549,Remote start cancellation reason store 2-Bits 0-7,0,
IDE08073-ENG57549,Remote start cancellation reason store 3-Bits 0-7,0,
IDE08074-ENG57549,Remote start cancellation reason store 4-Bits 0-7,0,
IDE08075-ENG57549,Remote start cancellation reason store 5-Bits 0-7,0,
IDE08562,Basic correction factor: Injector cyl. 1: filtered,1.0045,
IDE08564,Basic correction factor: Injector cyl. 3: filtered,0.9829,
IDE08566,Basic correction factor: Injector cyl. 5: filtered,1.0021,
IDE08567,Basic correction factor: Injector cyl. 6: filtered,0.9905,
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
IDE09573,O2 sens. dwnstrm. of cat. bank 2: gradient transf. lean -> rich,0.00, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09575,O2 sens. dwnstrm. of cat. bank 2: gradient transf. rich -> lean,0.00, s
IDE09693-ENG57549,Charisma driving program: system status-Bits 0-7,0,
IDE09695-ENG57549,Charisma driving program: target value from coordinator-Bits 0-7,2,
IDE09696-ENG57549,Charisma driving program: CAN output value-Bits 0-7,2,
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG57549,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE10041-ENG57549,Intake camshaft bank1 active operating mode-Bits 0-7,0,
IDE10041-ENG57549,Intake camshaft bank1 active operating mode-Bits 0-7,32,
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10302,Time since engine start,58.4, s
IDE10303,Integrated air masse at first engine start,0.6748, kg
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10631,O2 sens.upstrm. of cat. bank 2: delay time transf.rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,0.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.02, s
IDE10671,O2 sens.upstrm. of cat. B. 2: filter const.transf. rich -> lean,0.06, s
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11293,Fuel consumption difference: injectors/sensors,0.176, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,0.219, l
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,3.00, %
IDE12198,High-pressure fuel injection valve adapted value: cylinder 6,-9.86, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,16.88, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,-21.44, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,14.68, %
IDE12202,High-pressure fuel injection valve adapted value: cylinder 5,-13.02, %
IDE12355,ESI: consumption equivalent of the engine control module,0.00000076,
IDE12915,Throttle 1: bank 1: position sensor 1: raw voltage,0.687, V
IDE12923,Lambda regulation: bank 1: output value,1.00323,
IDE12924,Lambda regulation: bank 2: output value,1.00726,
IDE12927,Lambda regulation: bank 2: filtered average output value,1.00775,
IDE12928,Lambda regulation: bank 1: filtered average output value,1.00452,
IDE12935,Ignition angle: bank 2 raw value,14.3, °
IDE12936,Ignition angle: bank 1 raw value,16.5, °
MAS15845,Fuel: tank fill level,11.0, l
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,1,
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,0.62, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,11.92, kg
ENG101413,Calibration Identification,03H026AA6694FVAA,
ENG99697,Calibration Verification Number,34 DA 89 4C,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG111031-ENG57549,DFC_status_error_debounced_counter-Bits 0-7,0,
ENG111031-ENG57549,DFC_status_error_debounced_counter-Bits 0-7,1,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,3,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,103,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,199,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG115973,Engine Exhaust Flow Rate,28.0, kg/h
ENG20102,Engine Friction - Percent Torque,10.0, %
ENG111034,Engine_temperature_modelbased_substitute_value,32.3, °C
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.56, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.56, g/s
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,26.1, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,00 06 00 54 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00 01 00 09 00 06 00 00 00 00 00 01 00 02 00 00 00 01 00 00 00 01 00 00 00 06 00 00 00 00 00 00 00 00 00 00 00 00,
ENG107236,Knock_sensor_cylinder_5_voltage,0.791, V
ENG107237,Knock_sensor_cylinder_6_voltage,0.454, V
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,0.9951,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2127,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,15,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,31,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,63,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127734,Life_cycle_data_start_requirement_development,12 V electrical system,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor system for driver assistance systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel electronics,
ENG127734,Life_cycle_data_start_requirement_development,Engine,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Front axis lift system,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2019,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,6,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,1,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,15,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,1,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,21,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127735,Life_cycle_data_stop_prohibition_development,A/C,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2019,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,4,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,27,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,13,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,36,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,14,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG127733,Life_cycle_data_system_failure,not active,
ENG107964,Oxygen_sensor_bank_2_sensor_1_voltage,0.000, V
ENG109006,Spark_efficiency_deviation_at_idle_maximum,8.6, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,26.6, %
ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG115976,Vehicle Odometer,118.5, km
Elapsed Time: 00:49
Engine @ idle, +80C:
;Monday,17,June,2019,10:57:49:34333
IDE00019,Voltage terminal 30,14.400, V
IDE00021,Engine speed,892, /min
IDE00025,Coolant temperature,83, °C
IDE00078,Time since engine start,425, s
IDE00083,Throttle valve position (absolute),13.3, %
IDE00084,Absolute load value,22, %
IDE00085,Normed load value,29.4, %
IDE00100,Engine torque,73.5, Nm
IDE00148,Median injection timing,0.838, ms
IDE00150,Pressure in brake booster,52.66, hPa
IDE00151,Oil fill level,54.840, mm
IDE00152,Oil warning threshold,30.736, mm
IDE00167,Exhaust temperature 1 bank 1,534.2, °C
IDE00168,Exhaust temperature 1 bank 2,512.5, °C
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-15.000, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-14.914, °
IDE00178,Camshaft adjustment intake bank 1: specified value,19.594, °
IDE00179,Camshaft adjustment intake bank 1: actual value,19.656, °
IDE00182,Camshaft adaptation intake bank 1: phase position,-0.66, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,5.58, °
IDE00186,Fuel low pressure: actual value,488.9, kPa
IDE00188,Fuel high pressure: actual value,3.4805, MPa
IDE00192,Coolant temperature at radiator outlet: actual value,37.2, °C
IDE00196,Engine oil temperature,74.0, °C
IDE00201,High fuel pressure: specified value,3.4685, MPa
IDE00202,Low fuel pressure: specified value,490.0, kPa
IDE00347,Air mass: actual value:,6.36, g/s
IDE00348,Intake air temperature,36, °C
IDE00349,Throttle valve position: normed,3, %
IDE00350,Air mass: specified value,23.7, kg/h
IDE00357,Fuel temperature,61.5, °C
IDE00361,Ambient air pressure,984.65, hPa
IDE00371,Fuel consumption,2.40, l/h
IDE00375,Generator: load signal,32.23, %
IDE00380,Coolant fan 1: activation,50.00, %
IDE00392,Accelerator pedal: sensor voltage 1,741.0, mV
IDE00393,Accelerator pedal: sensor voltage 2,373.4, mV
IDE00405,Crankshaft speed (RPM),890.0, /min
IDE00477,Torque request: sum of auxiliary aggregate,20.8, Nm
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.995 Lambda / -0.031 mA,
IDE00565,Current of oxygen sensor bank 2 sensor 1 (broadband sensor),0.995 Lambda / -0.031 mA,
IDE00566-MAS04121,Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage,0.830, V
IDE00582,Equivalence ratio target value,1.000, Lambda
IDE00583,Throttle valve specified value,4, %
IDE00584,Distance driven since erasing DTC memory,0, km
IDE00593,Ignition timing adjustment cylinder 1,3.0, Degrees
IDE00597,Long term adaptation of mixture formation bank 1,-0.8, %
IDE00598,Long term adaptation of mixture formation bank 2,1.6, %
IDE00603,Number of driving cycles since erasing DTC memory,0,
IDE00604,Short term adaptation of mixture formation bank 1,0.8, %
IDE00605,Short term adaptation of mixture formation bank 2,-0.8, %
IDE00612,Target position of EVAP canister valve,21.2, %
IDE01260,Generator power,791.681, W
IDE01266-ENG57549,Coolant shut-off valve-Bits 0-7,2,
IDE01267,Height correction,0.97192,
IDE01378,High fuel pressure: control deviation,-0.0225, MPa
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.659, V
IDE01645,Oxygen sensor voltage bank 2 after catalytic converter,0.826, V
IDE01649,Throttle valve position 1,4.52, %
IDE01652,Opening degree Evap. Emission (EVAP) Canister Purge Reg. Valve,30.5, %
IDE01834,Battery voltage,14420, mV
IDE01869,Long-term fuel trim bank 1 at idle,-0.23, %
IDE01873,Test of catalytic converter: measured value,5.0000,
IDE01875,Required torque adjustment by idling regulator,0.891, %
IDE01876,Adaptation of loss torque,11.1, Nm
IDE01884,Camshaft adjustment intake bank 1: activation,46.094, %
IDE01887,Adaptation of Fuel Pump (FP),-41.2, kPa
IDE01893,Fuel pump: specified value,47.765, %
IDE01899,Load value: corrected specified value,76.29, %
IDE01901,Lost torque adaptation: idle,1.5, Nm
IDE01902,Lost torque adaptation A/C compressor,11.2, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.99933,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,0.94623,
IDE01911,Leakage air,0.5, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
IDE01916,Leakage recognition from oxygen sensor control,1.0042,
IDE01919-ENG57549,Leakage recognition: status-Bits 0-7,20,
IDE01928,Close cam shaft angle at quantity control valve,40.2, °
IDE01929,Open cam shaft angle at quantity control valve,-14.4, °
IDE01932,High pressure pump injection volume,-4.37, mm³
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,223,
IDE02116,Exhaust gas temperature before catalytic converter,441.58, °C
IDE02117,Relative load value,19.66, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,0.00, MPa
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03660,Longitudinal acceleration,0.004, m/s²
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,161,
IDE03696-ENG57549,Result test of oxygen sensor heater after catalytic converter-Bits 0-7,144,
IDE03697-ENG57549,Result test of oxygen sensor heater before catalytic converter-Bits 0-7,4,
IDE03698-ENG57549,Result of dynamic test of oxygen sensor before cat. converter-Bits 0-7,0,
IDE03699-ENG57549,Result of test of oxygen sensor before catalytic converter-Bits 0-7,228,
IDE03703-ENG57549,Result catalytic converter diagnosis test-Bits 0-7,0,
IDE03708-ENG57549,Result of test 2 of oxygen sensor before catalytic converter-Bits 0-7,0,
IDE03709,Angle difference actual-specified camshaft adjuster,-0.172, °
IDE03710-ENG57549,Result of camshaft diagnostic test-Bits 0-7,0,
IDE03711,Mass flow through throttle valve,22.9, kg/h
IDE03794,Long-term fuel trim bank 2 at idle,0.47, %
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,6.252, %
IDE03809-ENG57549,Oxygen sensor bank 2 sensor 2: status-Bits 0-7,2,
IDE03810,Oxygen sensor bank 2 sensor 1: specified value,1.0000,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,440.000, Ohm
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,146.56, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,24.640, %
IDE03822-ENG101533,Heated oxygen sensor bank 2: sensor 2: resistance-R uw q2 UWORD Chann 121,366.000, Ohm
IDE03824,Heated oxygen sensor bank 2: sensor 1: resistance,146.99, Ohm
IDE03825,Heated oxygen sensor bank 2: sensor 1: activation,25.375, %
IDE03830,Status of adaptation of on-demand fuel pump,ADP is OK,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,2,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,1.00000,
IDE03968-ENG57549,Camshaft adaptation results-Bits 0-7,4,
IDE04010,Engine torque: normalized,15, %
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:2940/--- kPa,
IDE04083,Coolant temperatures,ECT 1:88 °C / ECT 2:87 °C,
IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,3049.763500, kJ
IDE04235,Heat quantity f dew pt end before cat conv bank 2: modeled,2839.758125, kJ
IDE04236,Heat quantity f dew pt end behind fr cat conv bank 1: modeled,1387.967736, kJ
IDE04237,Heat quantity f dew pt end behind fr cat conv bank 2: modeled,1362.380639, kJ
IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,1381.652042, kJ
IDE04239,Heat quantity f dew pt end behind main cat conv bank 2: modeled,1357.106181, kJ
IDE04410,Intake manifold pressure: target value,381.80, hPa
IDE04414,Cat conv temp: modeled,505, °C
IDE04651,Torque request: A/C compressor,12.6, Nm
IDE04685,Setpoint generation interior torque,69.7, Nm
IDE04858,Brake booster low pressure actual value,931.99, hPa
IDE04887,Powertrain target torque,-1181.5, Nm
IDE04889,Target torque for combustion engine crankshaft level,-44.4, Nm
IDE04937,Sensor for engine block temperature: raw value,88.9, °C
IDE05128,Intake air temperature in intake manifold bank 1,36.8, °C
IDE05228,Operating hour counter,180, min
IDE05437,Outside air temperature via CAN,28.5, °C
IDE05438,Rear cat conv temp main cat conv model value,505.47, °C
IDE05439,Rear cat conv temp main cat conv bank 2 model value,476.83, °C
IDE05444,Air filling: specified value,19.71, %
IDE05445,Pressure before throttle valve of pressure sensor,984.45, hPa
IDE05447,Leak recog from oxygen sensor control bank 2,0.9919,
IDE05448,Long term adaptation of mixture form bank 2 at partial load,1.00000,
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,8998, Ohm
IDE05450,Oxygen sensor 2 bank 2 internal resistance limit value,9014, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00000,
IDE05463,Oxy sensor 1 bank 2 char curve offset,0.00000,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,720.30, °C
IDE05469,Oxygen sensor 1 bank 2 ceramic temp,719.73, °C
IDE05470,Cat converter oxygen storage capacity,1000.0, mg
IDE05474,Main cat converter OSC age correction factor,1.000,
IDE05475,Main cat converter OSC age correction factor bank 2,1.000,
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,12.7, kg/h
IDE05479,Misfire recognition reference moment,15.163, %
IDE05482,Tank venting adaptation factor,7.402,
IDE05487,Coolant temperature linearized value,89.458, °C
IDE05488,Coolant temperature modeled value,33.0, °C
IDE05797,Throttle valve adapter: specified value,4.416, %
IDE05928,Fuel consumption since DTC memory last erased,99.998, l/100km
IDE06017,Camshaft position deviation from reference position,0.04, °
IDE06020,Intake air temperature in intake manifold bank raw value,36.9, °C
IDE06040,High fuel pressure: regulator output value,-0.0265, MPa
IDE06043,Cylinder head temperature: actual value,85.9, °C
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,52.66, hPa
IDE06053-ENG57549,Test of mixture adaptation bank 1: status-Bits 0-7,128,
IDE06054-ENG57549,Test of mixture adaptation bank 2: status-Bits 0-7,128,
IDE06098,Sensor control factor: output value,1.01208,
IDE06192,Knock sensor: cylinder 2: voltage,0.342, V
IDE06193,Knock sensor: cylinder 3: voltage,0.518, V
IDE06194,Knock sensor: cylinder 4: voltage,0.493, V
IDE06195,Knock sensor: cylinder 1: voltage,0.376, V
IDE06495,Results of testing of crankcase ventilation successful,1,
IDE06758,Air mass since engine start,3.64, kg
IDE06759,Cam shaft adaptation inlet: counter,3,
IDE06760,Camshaft adaptation: exhaust: counter,4,
IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
IDE06957,Unfiltered clutch input rpm,895.5, /min
IDE07164,Number injections,23001,
IDE07475,Throttle valve position 2,4.30, %
IDE07573,Throttle valve adapter: actual value,4.37, %
IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
IDE10041-ENG57549,Intake camshaft bank1 active operating mode-Bits 0-7,1,
IDE10302,Time since engine start,469.1, s
IDE10303,Integrated air masse at first engine start,3.7077, kg
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.00, s
IDE10671,O2 sens.upstrm. of cat. B. 2: filter const.transf. rich -> lean,0.00, s
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,0.176, l
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,0.00, %
IDE12198,High-pressure fuel injection valve adapted value: cylinder 6,0.00, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,0.00, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,0.00, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,0.00, %
IDE12202,High-pressure fuel injection valve adapted value: cylinder 5,0.00, %
IDE12355,ESI: consumption equivalent of the engine control module,0.00000040,
IDE12915,Throttle 1: bank 1: position sensor 1: raw voltage,0.673, V
IDE12923,Lambda regulation: bank 1: output value,1.00504,
IDE12924,Lambda regulation: bank 2: output value,0.99567,
IDE12927,Lambda regulation: bank 2: filtered average output value,0.99619,
IDE12928,Lambda regulation: bank 1: filtered average output value,1.00659,
IDE12935,Ignition angle: bank 2 raw value,3.0, °
IDE12936,Ignition angle: bank 1 raw value,9.8, °
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,3.62, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,15.32, kg
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,106,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,196,
ENG115973,Engine Exhaust Flow Rate,25.6, kg/h
ENG20102,Engine Friction - Percent Torque,9.0, %
ENG111034,Engine_temperature_modelbased_substitute_value,92.3, °C
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.44, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.44, g/s
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,24.3, kg/h
ENG107236,Knock_sensor_cylinder_5_voltage,0.640, V
ENG107237,Knock_sensor_cylinder_6_voltage,0.444, V
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
Elapsed Time: 00:49
02:
;SW:09G-927-158-DR   HW:09G-927-158 ---  Auto Trans
;Component:AISIN AQ8     206 3536, Coding:0000000100000000000000000000000000000000
;EV_TCMAQ450031,001001,EV_TCMAQ450031_VW37.rod
;Monday,17,June,2019,10:58:40:34333
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: 8640DBAE39A1B07F2F-80D2
Group,Description,Actual
IDE00008-ENG103646,Softwareversion-VW Application Software Version Number,3536,
IDE00018,Voltage terminal 15,14.3, V
IDE00019,Voltage terminal 30,14.4, V
IDE00021-ENG99543,Engine speed-Engine RPM,883, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,835, /min
IDE00023,Transmission output speed,0, /min
IDE00024,Transmission fluid temperature,35, °C
IDE00025-ENG101037,Coolant temperature-Engine coolant temperature,85.50, °C
IDE00026,Vehicle speed from transmission,0.00, km/h
IDE00031-ENG101217,Torque transmitting function-Transmission function,0.0,
IDE00037-MAS02112,Programmability status-Programmability,programmable,
IDE00037-MAS02113,Programmability status-Program consistency,Program present,
IDE00072,ASAM/ODX file identification,EV_TCMAQ450031,
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0, km/h
IDE00086-ENG98363,Accelerator position-Accelerator pedal position,0.0, %
IDE00087-ENG102622,Tiptronic status-Tiptroni Minus,not active,
IDE00087-ENG98977,Tiptronic status-Tiptronic gate,not active,
IDE00087-ENG100388,Tiptronic status-Tiptronic Lenkrad Minus,not active,
IDE00087-ENG103352,Tiptronic status-Tiptronic Lenkrad Plus,not active,
IDE00087-ENG102721,Tiptronic status-Tiptronik Plus,not active,
IDE00089-ENG101851,Driving position-Automatic Transmission shift position,P,
IDE00090,selected gear,PN range,
IDE00094,Kick-down status,OFF,
IDE00095,Status of selector lever lock,active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00098-ENG103732,Transmission position-POS_INFO Signal,P,
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00358-ENG101555,Limitation: torque-Engine torque limitation,271, Nm
IDE00544,Factor torque,Factor 0.5,
IDE00548-ENG101198,Converter clutch slip-Slip Speed LU,53, /min
IDE00609-ENG110904,Communication status of data bus 1-ACC ECU support/not support,Not supported,
IDE00609-ENG110905,Communication status of data bus 1-ACC Status active/not active,not active,
IDE00609-ENG110906,Communication status of data bus 1-Airbag ECU support/not support,Not supported,
IDE00609-ENG110907,Communication status of data bus 1-Airbag Status active/not active,not active,
IDE00609-ENG110902,Communication status of data bus 1-Aircon ECU support/not support,Not supported,
IDE00609-ENG110903,Communication status of data bus 1-Aircon Status active/not active,not active,
IDE00609-ENG30405,Communication status of data bus 1-BCM ECU support/not support,supported,
IDE00609-ENG30406,Communication status of data bus 1-BCM Status active/not active,active,
IDE00609-ENG110900,Communication status of data bus 1-Brake ECU support/not support,supported,
IDE00609-ENG110901,Communication status of data bus 1-Brake Status active/not active,active,
IDE00609-ENG130510,Communication status of data bus 1-Column Lock ECU support/not support,supported,
IDE00609-ENG130511,Communication status of data bus 1-Column Lock Status active/not active,active,
IDE00609-ENG110898,Communication status of data bus 1-Engine ECU support/not support,supported,
IDE00609-ENG110899,Communication status of data bus 1-Engine Status active/not active,active,
IDE00609-ENG110916,Communication status of data bus 1-EPB ECU support/not support,supported,
IDE00609-ENG110917,Communication status of data bus 1-EPB Status active/not active,active,
IDE00609-ENG110912,Communication status of data bus 1-Gateway ECU support/not support,supported,
IDE00609-ENG110913,Communication status of data bus 1-Gateway Status active/not active,active,
IDE00609-ENG130512,Communication status of data bus 1-Hybrid Charge Battery Manager ECU support/not support,Not supported,
IDE00609-ENG130513,Communication status of data bus 1-Hybrid Charge Battery Manager Status active/not active,not active,
IDE00609-ENG110910,Communication status of data bus 1-Kombi ECU support/not support,supported,
IDE00609-ENG110911,Communication status of data bus 1-Kombi Status active/not active,active,
IDE00609-ENG110918,Communication status of data bus 1-Shifter ECU support/not support,Not supported,
IDE00609-ENG110919,Communication status of data bus 1-Shifter Status active/not active,not active,
IDE00609-ENG110908,Communication status of data bus 1-Steering Wheel ECU support/not support,Not supported,
IDE00609-ENG110909,Communication status of data bus 1-Steering Wheel Status active/not active,not active,
IDE00609-ENG110914,Communication status of data bus 1-Transfercase ECU support/not support,Not supported,
IDE00609-ENG110915,Communication status of data bus 1-Transfercase Status active/not active,not active,
IDE00798-ENG28485,Number of possible access authorizations-Number of Logins,01,
IDE00820-ENG114742,Activating and deactivating all development messages-Activation of Development Messages,00,
IDE00972,Idle speed increase,OFF,
IDE02211,Brake pressure,-0.00, bar
IDE02220-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,valid value,
IDE02713,Brake Light Switch,OFF,
IDE02714,Brake test switch,OFF,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,wire,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,1,
IDE02820,Transmission mileage,118.0, km
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03008-ENG28321,Stop process prevented-Start_/_Stop_prohibition,not condition,
IDE03010-ENG31515,Number of prevented stop processes-Frequency_counter_Start_/_Stop_ prohibition,0,
IDE03127-ENG101616,Prevented stop processes (ring memory)-Frequency_counter_Start_/_Stop_prohibition_ring_buffer,2000,
IDE03152-ENG100761,Neutral due to driver registr. proced. cond.: cause-cause: when it happened last time,N after R,
IDE03152-ENG102840,Neutral due to driver registr. proced. cond.: cause-distance [ s ] = km: last time it occurred,0, km
IDE03152-ENG100645,Neutral due to driver registr. proced. cond.: cause-how often over life time,0, counts
IDE03171-ENG103012,Driving strategy transmission mileage-Total Driving Time2,N/A---,
IDE03172-ENG103276,Driving strategy driving portions in D or S w/ CCS-Driving Time Ecological,0, %
IDE03173-ENG103020,Driving strategy driving portions in S w/o CCS-Driving Time Sporty,0, %
IDE03174-ENG100072,Driving strategy driving portions in Tiptronic-Driving Time Manual,0, %
IDE03180-ENG103176,Number of standard trips-General Denominator,9,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,84,
IDE03212-ENG100620,Start-stop conditions-Start_/_Stop_conditions,Stop release,
IDE03361-ENG130487,Driver request torque-Driver Requested Torque,12, Nm
IDE03404-ENG130574,AUTOSAR Standard application software identification-software ID,20 00,
IDE03404-ENG104191,AUTOSAR Standard application software identification-Vendor ID,00 01,
IDE03404-ENG99019,AUTOSAR Standard application software identification-Version number,01 01 00,
IDE05398-ENG130490,Transmission output speed: uncond voltage-Automatic transmission output speed raw voltage,1.4, V
IDE05400-ENG102986,Hill factor driving strategy-DSP Mountain Index,0.0, %
IDE05401-ENG130491,Transmission input speed: uncond voltage-Automatic transmission input speed raw voltage,1.4, V
IDE05403-ENG130492,Accelerator pedal idling-Accelerator Idle signal,Not operated,
IDE05668-ENG101751,Transmission control module torque request-TCM Requested Torque,initialized,
IDE06323-ENG102229,Status: switch valve S1/S2-S1,closed,
IDE06323-ENG102841,Status: switch valve S1/S2-S2,Open,
IDE06658-ENG99605,Pressure control valve 2: act. current-Actual current SLB1,0.09, A
IDE06659-ENG101258,Pressure control valve 3: act. current-Actual current SLC1,0.10, A
IDE06660-ENG101181,Pressure control valve 3: spec. current-Order current SLC1,0.10, A
IDE06661-ENG100294,Pressure control valve 2: spec. current-Order current SLB1,0.10, A
IDE06662-ENG100356,Pressure control valve 4: spec. current-Order current SLC2,0.10, A
IDE06663-ENG99880,Pressure control valve 4: act. current-Actual current SLC2,0.10, A
IDE06664-ENG99347,Pressure control valve 5: act. current-Actual current SLC3,0.34, A
IDE06665-ENG101266,Pressure control valve 5: spec. current-Order current SLC3,0.34, A
IDE06666-ENG101252,Pressure control valve 6: act. current-Actual current SLC4,0.10, A
IDE06667-ENG103324,Pressure control valve 6: spec. current-Order current SLC4,0.10, A
IDE06668-ENG103285,Pressure control valve 1: act. current-Actual current SLT,0.99, A
IDE06669-ENG103245,Pressure control valve 1: spec. current-Order current SLT,1.00, A
IDE06670-ENG102978,Pressure control valve 7: act. current-Actual current SLU,0.10, A
IDE06671-ENG101564,Pressure control valve 7: spec. current-Order current SLU,0.10, A
IDE06672-ENG130501,Current gear/clutch status-Actual Gear And LU Mode,0 ,
IDE06674-ENG102023,Driving strategy: rolling resistance-DSP Road Resistance,-0.3, %
IDE06675-ENG100839,Driving strategy: Sport Index-DSP Sport Index,0, %
IDE06676-ENG130488,Driving strategy: driving mode-DSP Driving Mode,DS,
IDE06677-ENG100939,Driving strategy: Sport Index Hybrid-DSP Sport Index Hybrid,Not supported,
IDE06875-ENG101762,Height-Altitude,0.96844, mbar
IDE06879-ENG103976,Software level supplier-ATCU software level,3,
IDE06880-ENG06100,Calc. transmission fluid temp.-Temp TC Lifetime Max Value,102, °C
IDE06881-ENG130493,Max. transmission fluid temperature over lifetime-ATF Temperature Lifetime Max Value,96, °C
IDE06882-ENG102253,Trans. fluid temp. model value-Transmission fluid temperature (Model),42, °C
IDE06883-ENG130500,Max. transmission fluid temp. model value over lifetime-ATF Temperature Model Lifetime Max Value,100, °C
IDE06884-ENG99385,Trans. fluid temp. sensor: voltage-ATF-Temperature Voltage,2.3, V
IDE06885-ENG102696,Torque converter: torque loss-Converter Loss Torque,0, Nm
IDE06887-ENG130498,Driver for electric oil pump: max. temperature-DrivingRecorder - highest temperature of the choke coil estimate temperature,-55, °C
IDE06888-ENG130499,battery voltage: distribution-DrivingRecorder - distribution of Battery voltage,N/A---,
IDE06889-ENG130497,Driver for electric oil pump: temperature distribution-DrivingRecorder - distribution of choke coil estimate temperature,N/A---,
IDE06893-ENG130489,Trans. thermal management request-DSP Fan control,heating,
IDE06894-ENG130495,Hot running progr. status-DSP Hotmode Status,normal,
IDE06895-ENG130502,Level/hill recognition-DSP Plain/Mountains,Ebene (Plain),
IDE06896-ENG103489,Driving strategy: software version-DSP software level,3,
IDE06897-ENG99419,Engine torque loss-Engine Loss Torque,Not supported,
IDE06898-ENG101044,Engine torque with external intervention-Engine Torque With External Engagement,3, Nm
IDE06899-ENG99632,Engine torque without external intervention-Engine Torque Without External Engagement,13, Nm
IDE06912-ENG125777,DTC for primary and secondary processor-Error Code Sub And Main CPU,N/A---,
IDE06913-ENG102247,Trans. pilot control torque-Idle Speed Loss Torque,4, Nm
IDE06914-ENG99114,Unfiltered transmission input speed-Turbine Speed Signal Current Value,810, /min
IDE06915-ENG98331,Trans. position switch: raw signal-a,closed,
IDE06915-ENG98436,Trans. position switch: raw signal-B,Open,
IDE06915-ENG98435,Trans. position switch: raw signal-C,Open,
IDE06915-ENG98824,Trans. position switch: raw signal-Pa,closed,
IDE06916-ENG101593,Software_ID-Mot-File,H8400G43.MOT ,
IDE06917-ENG100970,Software enable status-Software Level,3,
IDE06918-ENG99734,Software enable status 2-Software Version of Sub-CPU,02 00,
IDE06919-ENG102285,Torque converter clutch: status-Lock Up Clutch Status,Open,
IDE06920-MAS00115,Tiptronic: raw signal-Tiptronic gate,OFF,
IDE06920-MAS00116,Tiptronic: raw signal-Tiptronic +,OFF,
IDE06920-MAS00117,Tiptronic: raw signal-Tiptronic -,OFF,
IDE06920-MAS00118,Tiptronic: raw signal-Tiptronic steering wheel +,OFF,
IDE06920-MAS00119,Tiptronic: raw signal-Tiptronic steering wheel -,OFF,
IDE06921-ENG100848,Calculated vehicle speed-Vehicle Speed Sensor (Dev),0.0, km/h
IDE07159-ENG28759,Control module switch-off: counter-Knockout_counter,0,
IDE80020,Analysis 20,0,
IDE80021,Analysis 21,0,
IDE80022,Analysis 22,100,
IDE80023,Analysis 23,100,
IDE80024,Analysis 24,100,
IDE80025,Analysis 25,100,
IDE80026,Analysis 26,88,
IDE80027,Analysis 27,88,
IDE80028,Analysis 28,100,
IDE80029,Analysis 29,77,
IDE80030,Analysis 30,100,
IDE80031,Analysis 31,100,
IDE80032,Analysis 32,100,
IDE80033,Analysis 33,88,
IDE80034,Analysis 34,100,
IDE80035,Analysis 35,360,
IDE80036,Analysis 36,150,
IDE80039,Analysis 39,23668,
IDE80040,Analysis 40,N/A---,
IDE80041,Analysis 41,N/A---,
IDE80042,Analysis 42,N/A---,
IDE80043,Analysis 43,N/A---,
IDE80046,Analysis 46,N/A---,
ENG114439-ENG98401,Analysis 48-Block 1,62,
ENG114439-ENG98452,Analysis 48-Block 2,0.0,
ENG114439-ENG98408,Analysis 48-Block 3,0,
ENG114440,Analysis 49,100,
ENG125778,EMOP Demand Duty %,0, %
ENG125927-ENG125781,EMOP_Feedback_ON OFF-EMOP Feedback ON/OFF,OFF,
ENG02239,The counter and interval timer for Race up shifting,Not supported,
Elapsed Time: 00:15
03:
;SW:5Q0-614-517-DE   HW:5Q0-614-517-AD ---  ABS Brakes
;Component:ESC           H25 0524, Coding:44FC6B8D84231A6DC5800308A2C86922D62158A3C045967E38415058C2AA420B0023641C12141A1D8DDB45506CC8CF
;EV_Brake1UDSContiMK100IPB,037009,EV_Brake1UDSContiMK100IPB_037_VW41.rod
;Monday,17,June,2019,10:58:58:34333
;VCID: F7BEA66A4E4BD9F724-80A2
IDE00609-MAS01155,Communication status of data bus 1-Control module,Engine Control Module 1,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,active,
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,No,
IDE02270-IDE02713,CAN input signal(s) status-Brake Light Switch,not activated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,Open,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up light,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,CA31985,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency brake display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.00000, m/s²
IDE02486,Data logger triggering,not active,
IDE02492,Start-stop function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,indicator lights-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,indicator lights-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,indicator lights--AUTO HOLD- Indicator Lamp,Not available due to specific system,
IDE02986-IDE04771,indicator lights-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,indicator lights-ABS indicator lamp,OFF,
IDE02986-MAS00556,indicator lights-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,indicator lights-Hill descent control indicator lamp,OFF,
IDE02986-MAS02925,indicator lights-Brake system indicator lamp,OFF,
IDE02986-MAS03234,indicator lights-ESP_off indicator lamp,OFF,
IDE03008-IDE04446,Stop process prevented-Hill descent control,not active,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-IDE06139,Stop process prevented-AUTO HOLD slippage recognition,not active,
IDE03008-MAS04485,Stop process prevented-ESP function deactivation,not active,
IDE03008-MAS04513,Stop process prevented-Brake control module pump operation,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03008-MAS07931,Stop process prevented-Retaining function unavailable,not active,
IDE03008-MAS07932,Stop process prevented-Inclination limit,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,6,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-Brake control module pump operation,11,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,0,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,12,
IDE03011-IDE04446,Number of requested start processes-Hill descent control,0,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04485,Number of requested start processes-ESP function deactivation,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2126,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2000,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,0,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,14,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,30,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,0,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,0,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,62,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,0,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,62,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2126,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,0,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,14,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,30,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,62,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,0,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,0,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,62,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Freescale,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,3,
IDE03527-IDE02445,CAN signals-Transmission type,17,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.005, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,14.391, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-935, mbar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.20, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake Light Switch,not activated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,65535, mm
IDE04425-IDE04436,Left front ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04425-IDE04437,Left front ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04425-IDE04438,Left front ABS wheel speed sensor-Average division value,Condition not met,
IDE04425-IDE04440,Left front ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04425-IDE04441,Left front ABS wheel speed sensor-Validity of gap information,invalid,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Front right wheel speed,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,65535, mm
IDE04426-IDE04436,Right front ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04426-IDE04437,Right front ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04426-IDE04438,Right front ABS wheel speed sensor-Average division value,Condition not met,
IDE04426-IDE04440,Right front ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04426-IDE04441,Right front ABS wheel speed sensor-Validity of gap information,invalid,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,65535, mm
IDE04427-IDE04436,Left rear ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04427-IDE04437,Left rear ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04427-IDE04438,Left rear ABS wheel speed sensor-Average division value,Condition not met,
IDE04427-IDE04440,Left rear ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04427-IDE04441,Left rear ABS wheel speed sensor-Validity of gap information,invalid,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forwards,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,65535, mm
IDE04428-IDE04436,Right rear ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04428-IDE04437,Right rear ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04428-IDE04438,Right rear ABS wheel speed sensor-Average division value,Condition not met,
IDE04428-IDE04440,Right rear ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04428-IDE04441,Right rear ABS wheel speed sensor-Validity of gap information,invalid,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forwards,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,KW 30 2018,
IDE04442-IDE00010,Vacuum sensor-Serial number,04 DD C5 8D 09,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,Available,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,0,
IDE04442,Vacuum sensor,-935, mbar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,2,
IDE04443-IDE02241,Traction control system sensor-Lateral acceleration sensor 1,0.08829, m/s²
IDE04443-IDE02538,Traction control system sensor-Longitudinal acceleration sensor,0.12753, m/s²
IDE04443-IDE04429,Traction control system sensor-Lateral acceleration sensor 1: offset,0.09810, m/s²
IDE04443-IDE04430,Traction control system sensor-Longitudinal acceleration sensor: offset,0.00000, m/s²
IDE04443-IDE04449,Traction control system sensor-Rotation rate sensor 1: Z-axis,-0.875, °/s
IDE04443-IDE04460,Traction control system sensor-Steering angle sensor: offset straight line running,-1.969, °
IDE04443-MAS00815,Traction control system sensor-Steering angle sensor,-1.969, °
IDE04446-IDE01599,Hill descent control-Slope,0, %
IDE04446-IDE02955,Hill descent control-System status,Available,
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,not activated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not available due to specific system,
IDE04452-IDE03664,Brake system button-Button for driving program,not activated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,not activated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,not activated,
IDE04456-IDE02955,Brake disk drying-System status,Available,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,0, km
IDE04456-MAS01282,Brake disk drying-Wiper,not active,
IDE04456-MAS03095,Brake disk drying-Function status,not active,
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MYERAD00038,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,not completed successfully,
IDE04461-IDE03659,Internal measured values-Roller test bench mode,not active,
IDE04461-MAS01481,Internal measured values-Temperature in control module,31, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAB00008,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not recognized,
IDE04508-IDE02955,Hydraulic brake booster-System status,Available,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,-935, mbar
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.20, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,972, mbar
IDE04644-IDE02955,Roll-over protection-System status,Available,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04644-MAS03095,Roll-over protection-Function status,not active,
IDE04645-IDE00003,Electromechanical parking brake-Coding,performed,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,Enabled,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,Enabled,
IDE04645-IDE02955,Electromechanical parking brake-System status,Available,
IDE04645-IDE03493,Electromechanical parking brake-Driver door status,Enabled,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,Enabled,
IDE04645-IDE04941,Electromechanical parking brake-Clearance calibration,calibrated,
IDE04645-IDE04942,Electromechanical parking brake-Main examination mode,not active,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,Enabled,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,Enabled,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,Enabled,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04645-IDE02657,Electromechanical parking brake-Cut-off current: left: reached,0.00, A
IDE04645-IDE02658,Electromechanical parking brake-Cut-off current: right: reached,0.00, A
IDE04645-IDE04496,Electromechanical parking brake-Left parking brake motor: status,closed,
IDE04645-IDE04497,Electromechanical parking brake-Right parking brake motor: status,closed,
IDE04645-IDE04506,Electromechanical parking brake-Calculated left rear brake temperature,29.0, °C
IDE04645-IDE04507,Electromechanical parking brake-Calculated right rear brake temperature,29.0, °C
IDE04645-IDE04647,Electromechanical parking brake-Left parking brake motor: current,0.00, A
IDE04645-IDE04648,Electromechanical parking brake-Right parking brake motor: current,0.00, A
IDE04645-IDE05048,Electromechanical parking brake-Left parking brake motor: actuation counter,31,
IDE04645-IDE05049,Electromechanical parking brake-Right parking brake motor: actuation counter,31,
IDE04765-IDE02955,Counter steer support-System status,Available,
IDE04765-IDE03735,Counter steer support-Steering torque,0, Nm
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,0, km
IDE04765-MAS03095,Counter steer support-Function status,not active,
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,On,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04774-MAS03095,Vehicle and trailer stabilization-Function status,not active,
IDE04871-IDE01599,Dynamic starting assist-Slope,0, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Act.val.,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),-7, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire pressure monitoring display-System status,Available,
IDE04939-IDE04248,Tire pressure monitoring display-Left front tire pressure diffusion indicator,248,
IDE04939-IDE04249,Tire pressure monitoring display-Right front tire pressure diffusion indicator,248,
IDE04939-IDE04250,Tire pressure monitoring display-Left rear tire pressure diffusion indicator,248,
IDE04939-IDE04251,Tire pressure monitoring display-Right rear tire pressure diffusion indicator,248,
IDE04939-IDE04432,Tire pressure monitoring display-Tire Pressure Monitoring Display Button,not activated,
IDE04939-IDE04946,Tire pressure monitoring display-Odometer reading at last adaptation,6, km
IDE04939-IDE04947,Tire pressure monitoring display-Odometer reading of last warning,0, km
IDE04939-MAS04538,Tire pressure monitoring display-Odometer reading two adaptations ago,0, km
IDE04939-MAS04539,Tire pressure monitoring display-Odometer reading three adaptations ago,0, km
IDE04939-MAS04540,Tire pressure monitoring display-Odometer reading four adaptations ago,0, km
IDE04939-MAS04541,Tire pressure monitoring display-Odometer reading of next-to-last warning,0, km
IDE04939-MAS04542,Tire pressure monitoring display-Odometer reading of third-to-last warning,0, km
IDE04939-MAS04543,Tire pressure monitoring display-Odometer reading of fourth-to-last warning,0, km
IDE04939-MAS04544,Tire pressure monitoring display-Left front flat tire indicator,254,
IDE04939-MAS04545,Tire pressure monitoring display-Right front flat tire indicator,255,
IDE04939-MAS04546,Tire pressure monitoring display-Left rear flat tire indicator,254,
IDE04939-MAS04547,Tire pressure monitoring display-Right rear flat tire indicator,255,
IDE05712-IDE02955,AUTO HOLD-System status,Not available due to specific system,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,valid,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,OFF,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,1524,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,42508,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,601,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,81,
IDE07280-IDE04775,Multikollisionsbremse-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multikollisionsbremse-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multikollisionsbremse-Year,2126,
IDE07280-MAS00107,Multikollisionsbremse-Month,14,
IDE07280-MAS00108,Multikollisionsbremse-Day,0,
IDE07280-MAS00109,Multikollisionsbremse-Hours,30,
IDE07280-MAS00110,Multikollisionsbremse-Minutes,62,
IDE07280-MAS00111,Multikollisionsbremse-Seconds,62,
IDE07280-MAS07659,Multikollisionsbremse-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multikollisionsbremse-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multikollisionsbremse-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multikollisionsbremse-Mileage reading of the last deactivation by driver,0, km
IDE80101,Analysis 101,A3 32 38 35 31 35 37 38 38 34 32 33 30 30 30 30 35 31 38 43 31 32 30 30 30 35 38 2F 02 1C 1E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,97.2594, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,98.0406, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,97.65, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,7,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,99.2124, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,23,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,98.4312, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,6,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,98.8218, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,13,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,Available,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,29.0, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,29.0, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,29.0, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,29.0, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake Light Switch,not activated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,Available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Available,
MAS00121-MAS03095,Electronic Differential Lock-Function status,not active,
MAS00210-IDE80007,Parking Brake-Analysis 7,0, km
MAS00210-IDE80008,Parking Brake-Analysis 8,118, km
MAS00210-IDE80009,Parking Brake-Analysis 9,0, km
MAS00210-IDE80010,Parking Brake-Analysis 10,0, km
MAS00210-IDE80011,Parking Brake-Analysis 11,118, km
MAS00210-IDE80012,Parking Brake-Analysis 12,8F 0A 11 10 02 0C,
MAS00210-ENG36680,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG36681,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG36682,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG36683,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG36684,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG36685,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Available,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS01464,All Wheel Drive (AWD)-Emergency running mode,not active,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, %
MAS02138-IDE02955,Hill-start assistant-System status,Available,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,Open,
MAS02138-MAS00988,Hill-start assistant-Reverse gear,not selected,
MAS02138-MAS03095,Hill-start assistant-Function status,Condition not met,
MAS02426-MAS00580,Text display in instrument panel insert-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument panel insert-Text,0,
MAS02672-IDE02955,Start-stop-System status,Available,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,2,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,2,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,2,
MAS08072-MAS13688,Driving profile selection-ESC actual value,2,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,2,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,2,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,2,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,2,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,Available,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Available,
MAS08072-MAS13700,Driving profile selection-ESC system status,Available,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG26281-IDE01011,HBV_Event_Counter-Data record,0,
Elapsed Time: 00:14
05:
;SW:3Q0-959-435-L   HW:3Q0-959-435-L ---  Acc/Start Auth.
;Component:VWKESSYMQB    037 1204, Coding:1F20000723
;EV_KessyHellaMQBAB,004046,EV_KessyHellaMQBAB_004_VW37.rod
;Monday,17,June,2019,10:59:15:34333
;VCID: C3C602BA4A13455748-8096
IDE00019,Voltage terminal 30,14.385, V
IDE00021,Engine speed,898.0, /min
IDE00021-MAS02248,Engine speed-Signal state,valid,
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.0, km/h
IDE00075-MAS02248,Vehicle speed-Signal state,valid,
IDE00096-MAS02248,Selector lever position-Signal state,Current,
IDE00096,Selector lever position,OK,
IDE00322,Status of basic setting,Basic setting ended,
IDE02406,Key number of last identified ID sensor,ID sensor 1,
IDE02407,Status of vehicle locking,Vehicle unlocked at single door,
IDE02408-MAS00218,Individual door locking: status-Driver door,Open,
IDE02408-MAS00219,Individual door locking: status-Front Passenger Door,closed,
IDE02408-MAS00220,Individual door locking: status-Left rear door,closed,
IDE02408-MAS00221,Individual door locking: status-Right rear door,closed,
IDE02409,ID sensor 1 authentication: status,No response,
IDE02410,ID sensor 2 authentication: status,No response,
IDE02411,ID sensor 3 authentication: status,No response,
IDE02412,ID sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear exterior door handle touch sensor-Coding information,coded,
IDE02416-MAS02176,Left rear exterior door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear exterior door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear exterior door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear exterior door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear exterior door handle touch sensor-Coding information,coded,
IDE02417-MAS02176,Right rear exterior door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear exterior door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear exterior door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear exterior door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,11,
IDE02419,Proximity sensor frt.pass. door: number of triggers,123,
IDE02420,Proximity sensor left rear door: number of triggers,111,
IDE02421,Proximity sensor right rear door: number of triggers,118,
IDE02422-MAS01482,Driver door handle: version information-Hardwareversion,31,
IDE02422-MAS01483,Driver door handle: version information-Softwareversion,17,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,AA,
IDE02423-MAS01482,ass. door handle: version information-Hardwareversion,31,
IDE02423-MAS01483,ass. door handle: version information-Softwareversion,17,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,AA,
IDE02424-MAS01482,Left rear door handle: version information-Hardwareversion,31,
IDE02424-MAS01483,Left rear door handle: version information-Softwareversion,17,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,AA,
IDE02425-MAS01482,Right rear door handle: version information-Hardwareversion,31,
IDE02425-MAS01483,Right rear door handle: version information-Softwareversion,17,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,AA,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,Yes,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,No,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,Yes,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,Yes,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,Yes,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,No,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,No,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,No,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,No,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,No,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72-hour signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02484,72-hr signaling counter left rear door,0,
IDE02485,72-hr signaling counter right rear door,0,
IDE02495,Service key: number of activations,35,
IDE02496,Service key: number of timeouts,0,
IDE02497,Service key: number of incomplete messages,0,
IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
IDE02572-MAS02350,Starter button: status-Switch contact 1,not activated,
IDE02572-MAS02351,Starter button: status-Switch contact 2,not activated,
IDE02579,Park selector lever position,Engaged and locked,
IDE02581,Drive train uncoupling,decoupled,
IDE02582-MAS00179,Brake activation: switch status-Brake Light Switch,OFF,
IDE02582-MAS02248,Brake activation: switch status-Signal state,valid,
IDE02582-MAS02253,Brake activation: switch status-Brake test switch,OFF,
IDE02589,Rotary latch status,Open,
IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
IDE03008-MAS05971,Stop process prevented-Missing message from Engine Control Module,not active,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,not active,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,not active,
IDE03008-MAS06119,Stop process prevented-CAN signal: operation reader coil is set,not active,
IDE03009-MAS12704,Start process requested-System error if motor stops,not active,
IDE03010-MAS05971,Number of prevented stop processes-Missing message from Engine Control Module,0,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,0,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,0,
IDE03010-MAS06119,Number of prevented stop processes-CAN signal: operation reader coil is set,1,
IDE03011-MAS12704,Number of requested start processes-System error if motor stops,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2011,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,1,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,1,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,39,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,25,
IDE03127-MAS02886,Prevented stop processes (ring memory)-Last prohibited stop,CAN signal: operation reader coil is set,
IDE03127-MAS02888,Prevented stop processes (ring memory)-Penultimate prohibited stop,Empty,
IDE03127-MAS02890,Prevented stop processes (ring memory)-Third-last prohibited stop,Empty,
IDE03127-MAS02892,Prevented stop processes (ring memory)-Fourth last prohibited stop,Empty,
IDE03127-MAS02894,Prevented stop processes (ring memory)-Fifth-last prohibited stop,Empty,
IDE03128,Requested start processes (ring memory),Empty,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
IDE03527-MAS08112,CAN signals-Drive readiness,not active,
IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
IDE03527-MAS10894,CAN signals-Hybrid error,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04042-ENG123041,ID sensor history data-Scan 1: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123040,ID sensor history data-Scan 1: Scan_trigger_en,GO_AUTHENTIFICATION_REQUEST,
IDE04042-ENG123042,ID sensor history data-Scan 1: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,62,
IDE04042-ENG123045,ID sensor history data-Scan 2: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123044,ID sensor history data-Scan 2: Scan_trigger_en,GO_ID_REQUEST,
IDE04042-ENG123046,ID sensor history data-Scan 2: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,52,
IDE04042-ENG123049,ID sensor history data-Scan 3: Scan_origin_en,KEY_MINDER,
IDE04042-ENG123048,ID sensor history data-Scan 3: Scan_trigger_en,ENTRY_WITHOUT_PROXIMITY,
IDE04042-ENG123050,ID sensor history data-Scan 3: Single_scan_en,DRIVER_FRONT,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,A4,
IDE05204,Manufacturing dates for driver door handle,1F 07 21 9A 51,
IDE05205,Manufacturing dates for frt.pass. door handle,1F 07 21 9A 51,
IDE05206,Manufacturing dates for left rear door handle,1F 07 21 9A 51,
IDE05207,Manufacturing dates for right rear door handle,1F 07 21 9A 51,
IDE07028,Time until shut-off terminal S,1800, s
IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE07290-MAS08119,Conditions for turning on the ignition-Request active,Condition not met,
IDE07290-MAS08136,Conditions for turning on the ignition-Enabling Steering Column Lock,Condition not met,
IDE07290-MAS08137,Conditions for turning on the ignition-Enabling immobilizer,Condition not met,
IDE07290-MAS08138,Conditions for turning on the ignition-No active error mode,Condition met,
IDE07290-MAS08139,Conditions for turning on the ignition-Key signature validity,Condition met,
IDE07359,Dimming of starter button lighting,90,
IDE08440,Recommendation energy management,no restriction,
IDE09840-MAS06517,CU for tailgate opener: counter readings-Rear spoiler counter,0,
IDE09840-MAS12705,CU for tailgate opener: counter readings-Number of detected proximities,19,
IDE09840-MAS12706,CU for tailgate opener: counter readings-Number of detected kick movements,19,
IDE09840-MAS12707,CU for tailgate opener: counter readings-Number of transmitter activations,364,
IDE09841-MAS04394,CU for tailgate opener: sensor status-Connection status,No,
IDE09841-MAS09384,CU for tailgate opener: sensor status-Proximity detected: sensor 1,No,
IDE09841-MAS09385,CU for tailgate opener: sensor status-Proximity detected: sensor 2,No,
IDE80258,Immobilizer status,Electronic steering locking device installed,
IDE80258-MAS00106,Immobilizer status-Year,2011,
IDE80258-MAS00107,Immobilizer status-Month,1,
IDE80258-MAS00108,Immobilizer status-Day,1,
IDE80258-MAS00109,Immobilizer status-Hours,0,
IDE80258-MAS00110,Immobilizer status-Minutes,39,
IDE80258-MAS00111,Immobilizer status-Seconds,43,
IDE80258-MAS02349,Immobilizer status-Learn mode,Adapted,
IDE80258-MAS06793,Immobilizer status-Number of adapted keys,02,
MAS00025,Driver seat belt switch,not connected,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,17,
MAS00464-MAS00109,Standard - ambient data 1-Hours,9,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,58,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,34,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,11,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,118, km
MAS01493,Engine running,active,
MAS03554,Clutch pedal operation,No,
MAS03607,Engine stop in start-stop mode active,active,
MAS04004,Transmission code,OK,
MAS05104,Driver request: start engine,not active,
MAS08076,Exiting the vehicle,Condition not met,
MAS08788,Driving Cycle,Condition not met,
MAS08790,Driver absence,Condition met,
MAS09771,Driver information comfort switching,No switch-off,
ENG125217,Active_requirement_light_lag,not activated,
ENG129039-ENG129149,Car_keys_RSSI_measurements-Abort_counter,0,
ENG129039-ENG129148,Car_keys_RSSI_measurements-Easy_close_function_counter,0,
ENG129039-ENG129150,Car_keys_RSSI_measurements-Last_abort_reason,none,
ENG129039-ENG29819,Car_keys_RSSI_measurements-RSSI_Value_1,0,
ENG129039-ENG29818,Car_keys_RSSI_measurements-RSSI_Value_2,0,
ENG129039-ENG29817,Car_keys_RSSI_measurements-RSSI_Value_3,0,
ENG129039-ENG29816,Car_keys_RSSI_measurements-RSSI_Value_4,0,
ENG102274,Control Module Voltage,14.374, V
ENG08690,Easy_open_unavailable_reason,Kl15_is_active,
ENG129032,ELV_Status,ELV_nicht_entriegelt,
ENG114479,Enginestart_variant_coded,--no display--,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2000,
ENG125220-MAS00107,History last automatic terminal switch off-Month,0,
ENG125220-MAS00108,History last automatic terminal switch off-Day,0,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,0,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,0,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,0,
ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,0, km
ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,0, km
ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,0, km
ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,0, km
ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,0, km
ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Leaving the car,
ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Leaving the car,
ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,SBC_UNDERVOLTAGE_RESET,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG121906,Last_LIN_Message_Kessy,00 00 00 00 2D 00 00 00,
ENG121907,Last_LIN_Message_LIN,00 00 00 00 80 FF FF FF,
ENG26926-MAS00106,lf_shutdowns-Year,2000,
ENG26926-MAS00107,lf_shutdowns-Month,0,
ENG26926-MAS00108,lf_shutdowns-Day,0,
ENG26926-MAS00109,lf_shutdowns-Hours,0,
ENG26926-MAS00110,lf_shutdowns-Minutes,0,
ENG26926-MAS00111,lf_shutdowns-Seconds,0,
ENG26926-ENG32070,lf_shutdowns-Mileage_lf_shutdown_n,0, km
ENG26926-ENG32071,lf_shutdowns-Mileage_lf_shutdown_n-1,0, km
ENG26926-ENG32072,lf_shutdowns-Mileage_lf_shutdown_n-2,0, km
ENG26926-ENG32073,lf_shutdowns-Mileage_lf_shutdown_n-3,0, km
ENG120048,Overtemperaturecounter for ADRIMA,0,
ENG129034-ENG129128,power_state_door_handle-power_state_bt,active,
ENG129034-ENG129127,power_state_door_handle-power_state_ft,active,
ENG129034-ENG129129,power_state_door_handle-power_state_hl,active,
ENG129034-ENG129130,power_state_door_handle-power_state_hr,active,
ENG121948-ENG121879,Rear_Lid_Opening_Sender_Cycle_Data-trace_1,10,
ENG121948-ENG121888,Rear_Lid_Opening_Sender_Cycle_Data-trace_10,01,
ENG121948-ENG121889,Rear_Lid_Opening_Sender_Cycle_Data-trace_11,01,
ENG121948-ENG121890,Rear_Lid_Opening_Sender_Cycle_Data-trace_12,01,
ENG121948-ENG121891,Rear_Lid_Opening_Sender_Cycle_Data-trace_13,10,
ENG121948-ENG121892,Rear_Lid_Opening_Sender_Cycle_Data-trace_14,70,
ENG121948-ENG121893,Rear_Lid_Opening_Sender_Cycle_Data-trace_15,10,
ENG121948-ENG121894,Rear_Lid_Opening_Sender_Cycle_Data-trace_16,70,
ENG121948-ENG121895,Rear_Lid_Opening_Sender_Cycle_Data-trace_17,70,
ENG121948-ENG121896,Rear_Lid_Opening_Sender_Cycle_Data-trace_18,70,
ENG121948-ENG121897,Rear_Lid_Opening_Sender_Cycle_Data-trace_19,70,
ENG121948-ENG121880,Rear_Lid_Opening_Sender_Cycle_Data-trace_2,70,
ENG121948-ENG121898,Rear_Lid_Opening_Sender_Cycle_Data-trace_20,70,
ENG121948-ENG121881,Rear_Lid_Opening_Sender_Cycle_Data-trace_3,70,
ENG121948-ENG121882,Rear_Lid_Opening_Sender_Cycle_Data-trace_4,70,
ENG121948-ENG121883,Rear_Lid_Opening_Sender_Cycle_Data-trace_5,70,
ENG121948-ENG121884,Rear_Lid_Opening_Sender_Cycle_Data-trace_6,70,
ENG121948-ENG121885,Rear_Lid_Opening_Sender_Cycle_Data-trace_7,70,
ENG121948-ENG121886,Rear_Lid_Opening_Sender_Cycle_Data-trace_8,70,
ENG121948-ENG121887,Rear_Lid_Opening_Sender_Cycle_Data-trace_9,70,
ENG121949,Rear_Lid_Opening_Sender_ROM-Parameter_Version,2320,
ENG129030,Request_steering_column_lock_terminal_approval,not requested,
ENG108452,Reset_counter,15,
ENG129033,s_anf_klemmenfreigabe_wfs,not requested,
ENG126972,s_klemmenfreigabe_wfs,No enabling,
ENG26348-ENG129140,Scan_cycle_data-Car_key_1,1,
ENG26348-ENG129140,Scan_cycle_data-Car_key_1,0,
ENG26348-ENG129141,Scan_cycle_data-Car_key_2,0,
ENG26348-ENG129142,Scan_cycle_data-Car_key_3,0,
ENG26348-ENG129143,Scan_cycle_data-Car_key_4,0,
ENG26348-ENG30036,Scan_cycle_data-Mileage_n,117, km
ENG26348-ENG30037,Scan_cycle_data-Mileage_n-1,117, km
ENG26348-ENG30038,Scan_cycle_data-Mileage_n-10,0, km
ENG26348-ENG30039,Scan_cycle_data-Mileage_n-11,0, km
ENG26348-ENG30040,Scan_cycle_data-Mileage_n-12,0, km
ENG26348-ENG30041,Scan_cycle_data-Mileage_n-13,0, km
ENG26348-ENG30042,Scan_cycle_data-Mileage_n-14,0, km
ENG26348-ENG30043,Scan_cycle_data-Mileage_n-15,0, km
ENG26348-ENG30044,Scan_cycle_data-Mileage_n-16,0, km
ENG26348-ENG30045,Scan_cycle_data-Mileage_n-17,0, km
ENG26348-ENG30046,Scan_cycle_data-Mileage_n-18,0, km
ENG26348-ENG30047,Scan_cycle_data-Mileage_n-19,0, km
ENG26348-ENG30048,Scan_cycle_data-Mileage_n-2,55, km
ENG26348-ENG30049,Scan_cycle_data-Mileage_n-3,55, km
ENG26348-ENG30050,Scan_cycle_data-Mileage_n-4,18, km
ENG26348-ENG30051,Scan_cycle_data-Mileage_n-5,18, km
ENG26348-ENG30052,Scan_cycle_data-Mileage_n-6,0, km
ENG26348-ENG30053,Scan_cycle_data-Mileage_n-7,0, km
ENG26348-ENG30054,Scan_cycle_data-Mileage_n-8,0, km
ENG26348-ENG30055,Scan_cycle_data-Mileage_n-9,0, km
ENG26348-ENG30076,Scan_cycle_data-Retry_count_n,63,
ENG26348-ENG30077,Scan_cycle_data-Retry_count_n -6,0,
ENG26348-ENG30078,Scan_cycle_data-Retry_count_n-1,9,
ENG26348-ENG30079,Scan_cycle_data-Retry_count_n-10,0,
ENG26348-ENG30080,Scan_cycle_data-Retry_count_n-11,0,
ENG26348-ENG30081,Scan_cycle_data-Retry_count_n-12,0,
ENG26348-ENG30082,Scan_cycle_data-Retry_count_n-13,0,
ENG26348-ENG30083,Scan_cycle_data-Retry_count_n-14,0,
ENG26348-ENG30084,Scan_cycle_data-Retry_count_n-15,0,
ENG26348-ENG30085,Scan_cycle_data-Retry_count_n-16,0,
ENG26348-ENG30086,Scan_cycle_data-Retry_count_n-17,0,
ENG26348-ENG30087,Scan_cycle_data-Retry_count_n-18,0,
ENG26348-ENG30088,Scan_cycle_data-Retry_count_n-19,0,
ENG26348-ENG30089,Scan_cycle_data-Retry_count_n-2,10,
ENG26348-ENG30090,Scan_cycle_data-Retry_count_n-3,9,
ENG26348-ENG30091,Scan_cycle_data-Retry_count_n-4,19,
ENG26348-ENG30092,Scan_cycle_data-Retry_count_n-5,9,
ENG26348-ENG30093,Scan_cycle_data-Retry_count_n-7,0,
ENG26348-ENG30094,Scan_cycle_data-Retry_count_n-8,0,
ENG26348-ENG30095,Scan_cycle_data-Retry_count_n-9,0,
ENG26348-ENG30114,Scan_cycle_data-Scan_reason_n,Driver_door,
ENG26348-ENG30115,Scan_cycle_data-Scan_reason_n-1,Driver_door,
ENG26348-ENG30116,Scan_cycle_data-Scan_reason_n-10,Initial,
ENG26348-ENG30117,Scan_cycle_data-Scan_reason_n-11,Initial,
ENG26348-ENG30118,Scan_cycle_data-Scan_reason_n-12,Initial,
ENG26348-ENG30119,Scan_cycle_data-Scan_reason_n-13,Initial,
ENG26348-ENG30120,Scan_cycle_data-Scan_reason_n-14,Initial,
ENG26348-ENG30121,Scan_cycle_data-Scan_reason_n-15,Initial,
ENG26348-ENG30122,Scan_cycle_data-Scan_reason_n-16,Initial,
ENG26348-ENG30123,Scan_cycle_data-Scan_reason_n-17,Initial,
ENG26348-ENG30124,Scan_cycle_data-Scan_reason_n-18,Initial,
ENG26348-ENG30125,Scan_cycle_data-Scan_reason_n-19,Initial,
ENG26348-ENG30126,Scan_cycle_data-Scan_reason_n-2,Driver_door,
ENG26348-ENG30127,Scan_cycle_data-Scan_reason_n-3,Driver_door,
ENG26348-ENG30128,Scan_cycle_data-Scan_reason_n-4,Passenger_door,
ENG26348-ENG30129,Scan_cycle_data-Scan_reason_n-5,Passenger_door,
ENG26348-ENG30130,Scan_cycle_data-Scan_reason_n-6,Initial,
ENG26348-ENG30131,Scan_cycle_data-Scan_reason_n-7,Initial,
ENG26348-ENG30132,Scan_cycle_data-Scan_reason_n-8,Initial,
ENG26348-ENG30133,Scan_cycle_data-Scan_reason_n-9,Initial,
ENG26348-ENG30134,Scan_cycle_data-Scan_trigger_n,Reset_stop_car,
ENG26348-ENG30135,Scan_cycle_data-Scan_trigger_n-1,Set_stop_car,
ENG26348-ENG30136,Scan_cycle_data-Scan_trigger_n-10,Set_stop_car,
ENG26348-ENG30137,Scan_cycle_data-Scan_trigger_n-11,Set_stop_car,
ENG26348-ENG30138,Scan_cycle_data-Scan_trigger_n-12,Set_stop_car,
ENG26348-ENG30139,Scan_cycle_data-Scan_trigger_n-13,Set_stop_car,
ENG26348-ENG30140,Scan_cycle_data-Scan_trigger_n-14,Set_stop_car,
ENG26348-ENG30141,Scan_cycle_data-Scan_trigger_n-15,Set_stop_car,
ENG26348-ENG30142,Scan_cycle_data-Scan_trigger_n-16,Set_stop_car,
ENG26348-ENG30143,Scan_cycle_data-Scan_trigger_n-17,Set_stop_car,
ENG26348-ENG30144,Scan_cycle_data-Scan_trigger_n-18,Set_stop_car,
ENG26348-ENG30145,Scan_cycle_data-Scan_trigger_n-19,Set_stop_car,
ENG26348-ENG30146,Scan_cycle_data-Scan_trigger_n-2,Reset_stop_car,
ENG26348-ENG30147,Scan_cycle_data-Scan_trigger_n-3,Set_stop_car,
ENG26348-ENG30148,Scan_cycle_data-Scan_trigger_n-4,Reset_stop_car,
ENG26348-ENG30149,Scan_cycle_data-Scan_trigger_n-5,Set_stop_car,
ENG26348-ENG30150,Scan_cycle_data-Scan_trigger_n-6,Set_stop_car,
ENG26348-ENG30151,Scan_cycle_data-Scan_trigger_n-7,Set_stop_car,
ENG26348-ENG30152,Scan_cycle_data-Scan_trigger_n-8,Set_stop_car,
ENG26348-ENG30153,Scan_cycle_data-Scan_trigger_n-9,Set_stop_car,
ENG125222-ENG129124,Selective_catalytic_reduction-Possible_Engine_Start,OK,
ENG125222-ENG129123,Selective_catalytic_reduction-SCR_install_state,not installed,
ENG129035-MAS00106,service_key_internal_status-Year,2019,
ENG129035-MAS00106,service_key_internal_status-Year,2000,
ENG129035-MAS00107,service_key_internal_status-Month,6,
ENG129035-MAS00107,service_key_internal_status-Month,0,
ENG129035-MAS00108,service_key_internal_status-Day,0,
ENG129035-MAS00108,service_key_internal_status-Day,8,
ENG129035-MAS00109,service_key_internal_status-Hours,15,
ENG129035-MAS00109,service_key_internal_status-Hours,0,
ENG129035-MAS00110,service_key_internal_status-Minutes,42,
ENG129035-MAS00110,service_key_internal_status-Minutes,0,
ENG129035-MAS00111,service_key_internal_status-Seconds,22,
ENG129035-MAS00111,service_key_internal_status-Seconds,0,
ENG129035-ENG129135,service_key_internal_status-checksum_comparison_service_key1,OK,
ENG129035-ENG129136,service_key_internal_status-checksum_comparison_service_key2,not OK,
ENG129031,Steering_column_lock_terminal_approval,No enabling,
ENG125218,Suppression_ignition_message,not activated,
ENG129036,To_block_terminal_upshift,not active,
ENG129037,Trigger_terminal_deactivation_central_locking,not activated,
ENG129038,Valid_time_control_section_diagnostics,0, s
ENG08630-ENG09181,WFS_key_signature-clap_15_activateing_signature,01,
ENG08630-ENG09176,WFS_key_signature-signature_key_1,07 11,
ENG08630-ENG09177,WFS_key_signature-signature_key_2,07 25,
ENG08630-ENG09178,WFS_key_signature-signature_key_3,00 00,
ENG08630-ENG09179,WFS_key_signature-signature_key_4,00 00,
ENG08630-ENG09180,WFS_key_signature-signature_key_5,00 00,
Elapsed Time: 00:21
08:
;SW:3CN-907-044-M   HW:3CN-907-044-M ---  Auto HVAC
;Component:Climatronic   H05 2009, Coding:1602002620001C001104210C5210152C
;EV_ACClimaBHBVW416,002012,EV_ACClimaBHBVW416.rod
;Monday,17,June,2019,10:59:39:34333
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: C9DA1092683F9F0782-809C
Group,Description,Actual
IDE00019,Voltage terminal 30,14.3, V
IDE00021,Engine speed,800, /min
IDE00025,Coolant temperature,85, °C
IDE00075,Vehicle speed,0, km/h
IDE00198,Refrigerant pressure,13.0, bar
IDE00322,Status of basic setting,was not yet started,
IDE00767,No. of unscheduled ECU resets,14,
IDE00965,Compressor shut-off requirement,Compressor active: no shut-off condition is present,
IDE00966,Compressor current: actual value,0.650, A
IDE00967,Compressor current: specified value,0.650, A
IDE00968,Compressor speed,900, /min
IDE00969,Compressor load,11.8, Nm
IDE00970,Coolant fan activation: actual value,50.0, %
IDE00971,Coolant fan activation: specified value,50.4, %
IDE00973,Outside air temperature,30.0, °C
IDE00974,Outside air temperature internally calculated,29.0, °C
IDE00976,Left front vent temperature,12.0, °C
IDE00977,Right front vent temperature,10.0, °C
IDE00981,Footwell vent temperature,21.0, °C
IDE00982,Temperature after evaporator,4.0, °C
IDE00983,Interior temperature,31.0, °C
IDE00984,Sun intensity left,580, W/m²
IDE00985,Sun intensity right,560, W/m²
IDE00987,Blower voltage: specified value,4.9, V
IDE00989,Blower status,active,
IDE00994,Actual value for fresh air/recirculation air flow flap,174,
IDE00994,Actual value for fresh air/recirculation air flow flap,100.0, %
IDE00995,Specified value for fresh air/recirc air flow flap,175,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,170,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,77,
IDE00998,Left temperature flap - actual value,23,
IDE00998,Left temperature flap - actual value,0.0, %
IDE00999,Left temperature flap - specified value,22,
IDE01040,Left temperature flap: cold stop,27,
IDE01041,Left temperature flap: warm stop,232,
IDE01042,Right temperature flap: actual value,0.0, %
IDE01042,Right temperature flap: actual value,26,
IDE01043,Right temperature flap: specified value,25,
IDE01044,Right temperature flap: cold stop,30,
IDE01045,Right temperature flap: warm stop,231,
IDE01050,Front air distribution flap: actual value,0.0, %
IDE01050,Front air distribution flap: actual value,22,
IDE01051,Front air distribution flap: specified value,18,
IDE01052,Front air distribution flap: air outlet stop,236,
IDE01053,Front air distribution flap: footwell air outlet stop,23,
IDE01054,Defroster flap: actual value,100.0, %
IDE01054,Defroster flap: actual value,238,
IDE01055,Defroster flap: specified value,240,
IDE01056,Defroster flap: stop open,235,
IDE01057,Defroster flap: stop closed,17,
IDE01061,Rear air distribution flap: actual value,16,
IDE01061,Rear air distribution flap: actual value,0.0, %
IDE01062,Rear air distribution flap: specified value,15,
IDE01063,Status of recirculation air,Manual recirc. active,
IDE01065,Rear vent temperature,9.0, °C
IDE01066,Convertible top status,closed,
IDE01068,Rear blower voltage: actual value,9.0, V
IDE01069,Rear blower voltage: specified value,9.0, V
IDE01076,Time since ignition off,240, min
IDE01088,Rear temperature flap: actual value,0.0, %
IDE01088,Rear temperature flap: actual value,22,
IDE01089,Rear temperature flap: specified value,19,
IDE01090,Rear temperature flap: cold stop,24,
IDE01091,Rear temperature flap: warm stop,231,
IDE01092,Rear air distribution flap: vent stop,20,
IDE01093,Rear air distribution flap: footwell stop,245,
IDE01217-MAS01447,Left heated seat stage-Act.val.,0,
IDE01217-MAS01448,Left heated seat stage-Specified value,0,
IDE01218-MAS01447,Right heated seat stage-Act.val.,0,
IDE01218-MAS01448,Right heated seat stage-Specified value,0,
IDE01226,Blower voltage: actual value,4.8, V
IDE01227,Blower current,2.00, A
IDE01229,Blower current for rear fresh air blower,5.25, A
IDE01232,Supply voltage for external components,5.0, V
IDE01264,Remaining time of parking heater/ventilation operation,0, min
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,47,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,0,
IDE01419,Compressor shut-off condition: last,Low pressure event,
IDE01420,Compressor shut-off requirement: penultimate,Low pressure event,
IDE01421,Compressor shut-off requirement: antepenultimate,Low pressure event,
IDE01433,Air quality status,not installed,
IDE01442-MAS01533,Pressing a button-Defrost,not activated,
IDE01442-MAS01534,Pressing a button-Recirculating air,not activated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,not activated,
IDE01442-MAS01550,Pressing a button-AC,not activated,
IDE01442-MAS01554,Pressing a button-Left heated seat,not activated,
IDE01442-MAS01556,Pressing a button-Right heated seat,not activated,
IDE01442-MAS01560,Pressing a button-OFF,not activated,
IDE01442-MAS01577,Pressing a button-Parking heater,not activated,
IDE01442-MAS02015,Pressing a button-AUTO,not activated,
IDE01442-MAS02192,Pressing a button-SYNC,not activated,
IDE01442-MAS03196,Pressing a button-Menu,not activated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,not activated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,not activated,
IDE01442-MAS03832,Pressing a button-Air distribution up,not activated,
IDE01442-MAS04605,Pressing a button-AC MAX,not activated,
IDE01443,Left push-and-rotary knob counter,0,
IDE01444,Right push-and-rotary knob counter,0,
IDE01694-MAS01767,Left rear seat heater-Left rear seat heater stage,0,
IDE01695-MAS01771,Right rear seat heater-Right rear seat heater stage,0,
IDE02270-IDE00002,CAN input signal(s) status-Transport mode,OFF,
IDE02270-IDE01211,CAN input signal(s) status-Static current measuring mode,OFF,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01269,CAN input signal(s) status-Wipe wash,OFF,
IDE02270-MAS01277,CAN input signal(s) status-Rear window heater actual value,OFF,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,On,
IDE03008-MAS01517,Stop process prevented-Defrost active,not active,
IDE03008-MAS01564,Stop process prevented-Windshield defogger,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to setting,active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS04353,Stop process prevented-Fogging hazard (humidity sensor),not active,
IDE03008-MAS04354,Stop process prevented-Interior comfort humidity too high (humidity sensor),active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxil. heat mode,not active,
IDE03008-MAS05047,Stop process prevented-Maximum cooling and heating set,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03009-MAS01517,Start process requested-Defrost active,not active,
IDE03009-MAS01564,Start process requested-Windshield defogger,not active,
IDE03009-MAS02802,Start process requested-Interior temperature difference to setting,not active,
IDE03009-MAS02803,Start process requested-Interior vent difference to setting,not active,
IDE03009-MAS02804,Start process requested-Manual fan speed increase,not active,
IDE03009-MAS04353,Start process requested-Fogging hazard (humidity sensor),not active,
IDE03009-MAS04354,Start process requested-Interior comfort humidity too high (humidity sensor),not active,
IDE03009-MAS05009,Start process requested-A/C request: auxil. heat mode,not active,
IDE03009-MAS05047,Start process requested-Maximum cooling and heating set,not active,
IDE03009-MAS06551,Start process requested-Seat ventilation,not active,
IDE03009-MAS09538,Start process requested-max A/C,not active,
IDE03010-MAS00478,Number of prevented stop processes-Reserved,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Windshield defogger,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to setting,3,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,2,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxil. heat mode,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,15,
IDE03011-MAS00478,Number of requested start processes-Reserved,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Windshield defogger,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to setting,0,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,0,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxil. heat mode,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2019,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,6,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,15,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,1,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,21,
IDE03127,Prevented stop processes (ring memory),max A/C,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128,Requested start processes (ring memory),Measured value not available,
IDE03212,Start-stop conditions,Stop prohibition: no start request,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,255, s
IDE04312-MAS00084,System run time-Terminal 15 on,255, s
IDE04797,Center push-and-rotary knob counter,6,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,232,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,54.5, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,54.5, °C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,9.5, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,12.8, °C
IDE06201,Blower reduction,No switch-off: no reduction,
IDE06235,Potentiometer for rear vent temperature,13,
IDE07991-MAS04446,A/C clutch-Relay activation status,active,
IDE11430,Rear blower reduction,No switch-off: no reduction,
IDE11431,Rear blower status,active,
IDE12141-MAS00106,History memory: parking heater-Year,2127,
IDE12141-MAS00107,History memory: parking heater-Month,15,
IDE12141-MAS00108,History memory: parking heater-Day,31,
IDE12141-MAS00109,History memory: parking heater-Hours,31,
IDE12141-MAS00110,History memory: parking heater-Minutes,63,
IDE12141-MAS00111,History memory: parking heater-Seconds,63,
IDE12141-MAS02526,History memory: parking heater-Activation,Measured value not available,
IDE12141-MAS04390,History memory: parking heater-Active source,Measured value not available,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load mgmnt.,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside air temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,59,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,0,
Elapsed Time: 00:14
09:
;SW:5Q0-937-085-BT   HW:5Q0-937-085-BG ---  Cent. Elect.
;Component:BCM MQBAB HNA H38 0273, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,019001,EV_BCMBOSCH_019_VW37.rod
;Monday,17,June,2019,10:59:56:34333
;VCID: 8C54E98627CDCA2F79-80D8
IDE00075,Vehicle speed,0.00, km/h
IDE00323,Security Access: Number of invalid keys,0,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No communication,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,No communication,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,No communication,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,No communication,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,No communication,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,No communication,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,No communication,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,No communication,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,No communication,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,No communication,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,Measured value not available,
IDE00973,Outside air temperature,30.00, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01285,Counter of component protection malfunctions,0,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,not activated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01464-MAS01580,Rear window defogger-Activation,not active,
IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Windshield defogger-Activation,not coded/not installed,
IDE01943-MAS01737,Turn signal-Diagnosis,normal,
IDE01943-MAS02248,Turn signal-Signal state,not active,
IDE01943-MAS03873,Turn signal-Duty cycle,0.0, %
IDE01943-MAS04351,Turn signal-Connector terminal number,60,
IDE01943-MAS04352,Turn signal-Connector number,Plug A,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not activated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,closed,
IDE02092-MAS02447,Tailgate condition-Release,not enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,not activated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,closed,
IDE02486,Data logger triggering,not active,
IDE02488-MAS01632,DWA Interior monitoring-Status,not coded/not installed,
IDE02488-MAS04508,DWA Interior monitoring-Alarm detected,not coded/not installed,
IDE02515-MAS01737,Low beam-Diagnosis,normal,
IDE02515-MAS02248,Low beam-Signal state,not active,
IDE02515-MAS03873,Low beam-Duty cycle,0.0, %
IDE02515-MAS04351,Low beam-Connector terminal number,5,
IDE02515-MAS04352,Low beam-Connector number,Plug C,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not coded/not installed,
IDE02711,Rear Window Wiper,not active,
IDE02743-MAS01737,High Beam-Diagnosis,not coded/not installed,
IDE02743-MAS02248,High Beam-Signal state,not active,
IDE02743-MAS03873,High Beam-Duty cycle,0.0, %
IDE02743-MAS04351,High Beam-Connector terminal number,0,
IDE02743-MAS04352,High Beam-Connector number,Plug A,
IDE02744-MAS01632,Steering wheel heater-Status,switched off,
IDE02744-MAS02311,Steering wheel heater-Steering wheel heating button,not activated,
IDE02744-MAS09758,Steering wheel heater-Temperature sensor,85,
IDE02857-IDE03111,Activation current-Interior light,16, mA
IDE02857-IDE05533,Activation current-Spray nozzle heater,0, mA
IDE02857-IDE06012,Activation current-Search lights,0, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-MAS05942,Activation current-Windshield and rear window washer pump,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,no error,
IDE02857-ENG128455,Activation current-Cockpittaster_2,no error,
IDE02857-ENG128456,Activation current-Cockpittaster_3,no error,
IDE02857-ENG128457,Activation current-Cockpittaster_4,no error,
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,0, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957-MAS01737,Ambient lighting-Diagnosis,not coded/not installed,
IDE02957-MAS02248,Ambient lighting-Signal state,not active,
IDE02957-MAS03873,Ambient lighting-Duty cycle,0.00, %
IDE02957-MAS04351,Ambient lighting-Connector terminal number,0,
IDE02957-MAS04352,Ambient lighting-Connector number,not coded/not installed,
IDE02957-MAS06670,Ambient lighting-Channel,Chan. A,
IDE03111-MAS01737,Interior light-Diagnosis,not coded/not installed,
IDE03111-MAS02248,Interior light-Signal state,not active,
IDE03111-MAS03873,Interior light-Duty cycle,0.00, %
IDE03111-MAS04351,Interior light-Connector terminal number,0,
IDE03111-MAS04352,Interior light-Connector number,Plug A,
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,18.4, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,127.5,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,14.4, V
IDE03310-MAS01737,Brake light-Diagnosis,normal,
IDE03310-MAS02248,Brake light-Signal state,not active,
IDE03310-MAS03873,Brake light-Duty cycle,0.0, %
IDE03310-MAS04351,Brake light-Connector terminal number,35,
IDE03310-MAS04352,Brake light-Connector number,Plug B,
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,38.50, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,41.50, °C
IDE03504-IDE02022,Personalized settings-Comfort opening,OFF,
IDE03504-IDE03679,Personalized settings-Adaptive light functions,active,
IDE03504-IDE04036,Personalized settings-High beam assistant: status,active,
IDE03504-MAS01597,Personalized settings-Sunroof,not active,
IDE03504-MAS04322,Personalized settings-Masked continuous high beam,active,
IDE03504-MAS06456,Personalized settings-Autolock,active,
IDE03504-MAS06457,Personalized settings-autounlock,active,
IDE03504-MAS06911,Personalized settings-Status Coming Home,active,
IDE03504-MAS06912,Personalized settings-Status Leaving Home,active,
IDE03504-MAS07014,Personalized settings-Tourist light,not active,
IDE03504-MAS07967,Personalized settings-profile,1,
IDE03504-MAS07971,Personalized settings-Electrical rear lid,not active,
IDE03504-MAS07972,Personalized settings-Manual door unlock,Unlock. indiv. doors,
IDE03504-MAS07973,Personalized settings-Rain closure,not active,
IDE03504-MAS07978,Personalized settings-Mirror adjustment,INDIVIDUAL,
IDE03504-MAS07980,Personalized settings-Mirror lowering,active,
IDE03504-MAS07981,Personalized settings-Automatic mirror fold-in,active,
IDE03504-MAS07982,Personalized settings-Activation sound: theft warning system,active,
IDE03504-MAS07983,Personalized settings-Virtual pedal,active,
IDE03504-MAS07984,Personalized settings-Automatic rear window wiper,active,
IDE03504-MAS07985,Personalized settings-Coming Home set point,10, s
IDE03504-MAS07986,Personalized settings-Leaving Home set point,10, s
IDE03504-MAS07987,Personalized settings-Light intensity,normal,
IDE03504-MAS07990,Personalized settings-Comfort flasher,active,
IDE03504-MAS07991,Personalized settings-Comfort flasher set point,3,
IDE03504-MAS07992,Personalized settings-Sliding beam range,not active,
IDE03504-MAS07993,Personalized settings-Rain light,active,
IDE03504-ENG29901,Personalized settings-Touristenlicht Einstellwert,not active,
IDE03638-MAS01737,static AFS light-Diagnosis,normal,
IDE03638-MAS02248,static AFS light-Signal state,not active,
IDE03638-MAS03873,static AFS light-Duty cycle,0.0, %
IDE03638-MAS04351,static AFS light-Connector terminal number,45,
IDE03638-MAS04352,static AFS light-Connector number,Plug B,
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator light for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00104,Expanded environmental conditions-DTC,03 1F 05,
IDE04347-IDE07836,Expanded environmental conditions-Log data,00 00 00 02 0D 1A 0D 00 63 00 00 03 00 FF 00 00 00 00 00 00 00 00 00 00 00 01 00 02 00 04 D8 D2 00 00 07 15 00 00 0C 13 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 08 00 00 00 02 00 20 00 00 22 00 0B 00 00 00 00 00 00 07 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C 00 01 00 00 01 00 4B 64 06 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 08 00 00 01 00 01 04 81 04 20 00 00 00 00 04 4C 20 34 00 20 00 00 40 08 00 02 6B 1F 00 00 00 96 FF 93 00 3B 00 00 00 00 00 00 00 00 00 00 01 00 02 01 00 00 00 00 00 00 00 00 00 00 00 00 00 8F 00 00 00 00 00 00,
IDE04925-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
IDE04925-MAS02248,Daytime running lights-Signal state,not active,
IDE04925-MAS03873,Daytime running lights-Duty cycle,0.0, %
IDE04925-MAS04351,Daytime running lights-Connector terminal number,0,
IDE04925-MAS04352,Daytime running lights-Connector number,Plug A,
IDE05042-IDE05043,Emergency flasher button-Emergency flasher indicator lamp,On,
IDE05042-MAS02158,Emergency flasher button-Actuation condition,Not operated,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,22.50, %
IDE05045-IDE05183,Front windshield wiper module-Malfunction left,not coded/not installed,
IDE05045-IDE05184,Front windshield wiper module-Malfunction right,not coded/not installed,
IDE05045-MAS01632,Front windshield wiper module-Status,not active,
IDE05045-MAS02282,Front windshield wiper module-Position,park position,
IDE05045-MAS03638,Front windshield wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front windshield wiper module-Number of wiper cycles,0,
IDE05045-MAS05878,Front windshield wiper module-Stage,Stage 1,
IDE05323-MAS01737,Fog light-Diagnosis,normal,
IDE05323-MAS02248,Fog light-Signal state,not active,
IDE05323-MAS03873,Fog light-Duty cycle,0.0, %
IDE05323-MAS04351,Fog light-Connector terminal number,45,
IDE05323-MAS04352,Fog light-Connector number,Plug B,
IDE05434-MAS01737,Rear entry light-Diagnosis,not coded/not installed,
IDE05434-MAS02248,Rear entry light-Signal state,not active,
IDE05434-MAS03873,Rear entry light-Duty cycle,0.00, %
IDE05434-MAS04150,Rear entry light-Side,NOT-DEFINED,
IDE05434-MAS04351,Rear entry light-Connector terminal number,0,
IDE05434-MAS04352,Rear entry light-Connector number,Plug A,
IDE05533,Spray nozzle heater,not active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02339,Window washer system-Windshield washer system,not active,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,Not operated,
IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not coded/not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: engaged,
IDE05727-IDE02589,Front passenger side door status-Rotary latch status,closed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: engaged,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not coded/not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: engaged,
IDE05730-MAS01737,Luggage compartment light-Diagnosis,not coded/not installed,
IDE05730-MAS02248,Luggage compartment light-Signal state,not active,
IDE05730-MAS03873,Luggage compartment light-Duty cycle,0.00, %
IDE05730-MAS04351,Luggage compartment light-Connector terminal number,0,
IDE05730-MAS04352,Luggage compartment light-Connector number,Plug A,
IDE05739-MAS01737,Footwell light-Diagnosis,normal,
IDE05739-MAS02248,Footwell light-Signal state,active,
IDE05739-MAS03873,Footwell light-Duty cycle,62.0, %
IDE05739-MAS04351,Footwell light-Connector terminal number,72,
IDE05739-MAS04352,Footwell light-Connector number,Plug C,
IDE05742-IDE02515,Light switch position-Low beam,not activated,
IDE05742-IDE05323,Light switch position-Fog light,not activated,
IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
IDE05742-MAS00063,Light switch position-OFF,not activated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,operated,
IDE05742-MAS03835,Light switch position-Parking light,not activated,
IDE05742-MAS03836,Light switch position-Rear fog light,not coded/not installed,
IDE05822-MAS01632,DWA Vehicle inclination sensor-Status,not coded/not installed,
IDE05822-MAS04508,DWA Vehicle inclination sensor-Alarm detected,not coded/not installed,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded/not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Alarm horn for anti-theft warning system,not activated,
IDE05829-ENG28562,Rear spoiler history data-Spoiler_Activation_Trigger,NoEntry,
IDE05829-ENG28563,Rear spoiler history data-Spoiler_Activation_Trigger_Date,335544320,
IDE05829-ENG28565,Rear spoiler history data-Spoiler_Activation_Trigger_Milage,0, km
IDE05829-ENG28564,Rear spoiler history data-Spoiler_Activation_Trigger_Time,0,
IDE05830-MAS02282,Rear Spoiler-Position,not coded/not installed,
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05833-MAS00106,Anti-theft warning system: history data-Year,2019,
IDE05833-MAS00107,Anti-theft warning system: history data-Month,1,
IDE05833-MAS00108,Anti-theft warning system: history data-Day,9,
IDE05833-MAS00109,Anti-theft warning system: history data-Hours,13,
IDE05833-MAS00110,Anti-theft warning system: history data-Minutes,17,
IDE05833-MAS00111,Anti-theft warning system: history data-Seconds,58,
IDE05833-MAS00711,Anti-theft warning system: history data-Odometer reading,2, km
IDE05833-MAS04478,Anti-theft warning system: history data-Cause for alarm activation,Door contact passenger door,
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00211,Driver info-Insufficient brake fluid,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00213,Driver info-Insufficient coolant,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded/not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05836-MAS03638,Rain recognition sensor-Wipe speed,0,
IDE05836-MAS04806,Rain recognition sensor-Splash,not active,
IDE05836-MAS04807,Rain recognition sensor-park position,active,
IDE05837,Activation for signal horn,not active,
IDE05838-MAS01794,Light recognition sensor-Freeway,OFF,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,100000, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,6126, lx
IDE05838-MAS04808,Light recognition sensor-Rain,OFF,
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE05839-MAS01737,Parking light-Diagnosis,normal,
IDE05839-MAS02248,Parking light-Signal state,active,
IDE05839-MAS03873,Parking light-Duty cycle,100.0, %
IDE05839-MAS04351,Parking light-Connector terminal number,39,
IDE05839-MAS04352,Parking light-Connector number,Plug B,
IDE05841-MAS06441,Central locking history data-Control-section / cause,Remote control,
IDE05841-MAS07519,Central locking history data-Command,Unlock. indiv. doors,
IDE05841-MAS07942,Central locking history data-Additional information,Rem. ctrl. no. 1,
IDE05841-ENG29969,Central locking history data-command_direction_locking,No_locking,
IDE05841-ENG29970,Central locking history data-command_direction_unlocking,Door unlock,
IDE05842-MAS00218,Comfort function history data-Driver door,not active,
IDE05842-MAS00219,Comfort function history data-Front Passenger Door,not active,
IDE05842-MAS00220,Comfort function history data-Left rear door,not active,
IDE05842-MAS00221,Comfort function history data-Right rear door,not active,
IDE05842-MAS06441,Comfort function history data-Control-section / cause,KESSY: driver door,
IDE05842-MAS07560,Comfort function history data-Top,not active,
IDE05842-MAS07561,Comfort function history data-Sun roof/tilt roof,active,
IDE05842-MAS07941,Comfort function history data-Operating command,Close,
IDE06012-MAS01737,Search lights-Diagnosis,not coded/not installed,
IDE06012-MAS02248,Search lights-Signal state,not active,
IDE06012-MAS03873,Search lights-Duty cycle,0.0, %
IDE06012-MAS04351,Search lights-Connector terminal number,0,
IDE06012-MAS04352,Search lights-Connector number,Plug A,
IDE06012-MAS15156,Search lights-terminal,NOT-DEFINED,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,-38.2, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,55.0, °C
IDE06091-MAS04647,Humidity sensor: internal-Dew point,-38.8, °C
IDE06096-IDE03111,Interior lighting-Interior light,100, %
IDE06096-IDE05724,Interior lighting-Terminal 58xt dimmer,89.0, %
IDE06096-IDE05725,Interior lighting-Terminal 58xs dimmer,0.0, %
IDE06096-IDE05726,Interior lighting-Terminal 58xd dimmer,104.0, %
IDE06096-MAS01634,Interior lighting-Supply voltage,89.0, %
IDE06096-MAS04528,Interior lighting-Instrument panel and switch illumination dimmer switch,50, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06470-MAS01737,Ambience lighting-Diagnosis,not coded/not installed,
IDE06470-MAS02248,Ambience lighting-Signal state,not active,
IDE06470-MAS03873,Ambience lighting-Duty cycle,0.0, %
IDE06470-MAS04351,Ambience lighting-Connector terminal number,0,
IDE06470-MAS04352,Ambience lighting-Connector number,Plug A,
IDE06507-MAS13127,Button in center console-Status of button 1,not activated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,OFF,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded/not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded/not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,OFF,
IDE06507-MAS13137,Button in center console-Status of button 4,not activated,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lights,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Signal horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Parking light,not coded/not installed,
IDE06649-MAS05016,Radio-frequency transmitter-Receiver status,not installed,
IDE06649-MAS05048,Radio-frequency transmitter-Number of transmitters adapted,0,
IDE06649-ENG116085,Radio-frequency transmitter-Kom.Schlüssel eFFB Handsender 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06649-ENG116115,Radio-frequency transmitter-Kom.Schlüssel eFFB Handsender 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06695-IDE01459,Energy management: last critical state-Energy management heat output control status,0,
IDE06695-MAS00107,Energy management: last critical state-Month,0,
IDE06695-MAS00108,Energy management: last critical state-Day,0,
IDE06695-MAS06555,Energy management: last critical state-Maximum switch-off priority while driving,0,
IDE06695-MAS06570,Energy management: last critical state-Number of critical operation cycles,0,
IDE06695-ENG28924,Energy management: last critical state-Anz_erreichte_Max_Freigaben,0,
IDE06695-ENG28921,Energy management: last critical state-Anz_krit_Betriebszyklen,0,
IDE06695-ENG28922,Energy management: last critical state-Bedingung_Tab_NQ,0,
IDE06695-ENG28920,Energy management: last critical state-min_prio_Tab_K,0,
IDE06695-ENG28919,Energy management: last critical state-min_prio_Tab_M,0,
IDE06695-ENG28923,Energy management: last critical state-min_prio_Tab_NQ,0,
IDE06695-ENG99063,Energy management: last critical state-Year,2000,
IDE06864-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
IDE06864-MAS02248,Daytime running lights-Signal state,not active,
IDE06864-MAS03873,Daytime running lights-Duty cycle,0.0, %
IDE06864-MAS04351,Daytime running lights-Connector terminal number,0,
IDE06864-MAS04352,Daytime running lights-Connector number,Plug A,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,04,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,Not Used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,not administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,stored,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,6553.5, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,5.000, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,126, %
IDE07344-MAS02447,Sunroof shade-Release,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,not activated,
IDE07345,Sunroof front closed position switch,not activated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,closed,
IDE07346,Sunroof shade switches,not activated,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left cabin heater-PTC heater element: current consumption,not coded/not installed,
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right cabin heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08177-MAS06456,Central locking-Autolock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,Open,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Vehicle unlocked at single door,
IDE08177-ENG09185,Central locking-Load_compartment_closing,not coded/not installed,
IDE08211-MAS00106,History data control module reset-Year,2011,
IDE08211-MAS00107,History data control module reset-Month,1,
IDE08211-MAS00108,History data control module reset-Day,1,
IDE08211-MAS00109,History data control module reset-Hours,0,
IDE08211-MAS00110,History data control module reset-Minutes,0,
IDE08211-MAS03129,History data control module reset-Reset counter,8,
IDE08211-MAS06734,History data control module reset-last cause of reset,Analysis 1,
IDE08343,Immobilizer Challenge,87 EB 3E A1,
IDE08356-IDE00102,Left seat backrest fan 1-Control Module temperature,34, °C
IDE08356-MAS01447,Left seat backrest fan 1-Act.val.,3582, /min
IDE08356-MAS01634,Left seat backrest fan 1-Supply voltage,14, V
IDE08356-MAS09948,Left seat backrest fan 1-Pin coding. spec. value,7,
IDE08356-MAS09949,Left seat backrest fan 1-Pin coding. act. value,7,
IDE08356-MAS10342,Left seat backrest fan 1-No. of start-up attempts after blocking error,0,
IDE08358-IDE00102,Left seat cushion fan 1-Control Module temperature,31, °C
IDE08358-MAS01447,Left seat cushion fan 1-Act.val.,3552, /min
IDE08358-MAS01634,Left seat cushion fan 1-Supply voltage,14, V
IDE08358-MAS09948,Left seat cushion fan 1-Pin coding. spec. value,6,
IDE08358-MAS09949,Left seat cushion fan 1-Pin coding. act. value,6,
IDE08358-MAS10342,Left seat cushion fan 1-No. of start-up attempts after blocking error,0,
IDE08360-IDE00102,Right seat backrest fan 1-Control Module temperature,33, °C
IDE08360-MAS01447,Right seat backrest fan 1-Act.val.,0, /min
IDE08360-MAS01634,Right seat backrest fan 1-Supply voltage,15, V
IDE08360-MAS09948,Right seat backrest fan 1-Pin coding. spec. value,3,
IDE08360-MAS09949,Right seat backrest fan 1-Pin coding. act. value,3,
IDE08360-MAS10342,Right seat backrest fan 1-No. of start-up attempts after blocking error,0,
IDE08362-IDE00102,Right seat cushion fan 1-Control Module temperature,31, °C
IDE08362-MAS01447,Right seat cushion fan 1-Act.val.,0, /min
IDE08362-MAS01634,Right seat cushion fan 1-Supply voltage,14, V
IDE08362-MAS09948,Right seat cushion fan 1-Pin coding. spec. value,2,
IDE08362-MAS09949,Right seat cushion fan 1-Pin coding. act. value,2,
IDE08362-MAS10342,Right seat cushion fan 1-No. of start-up attempts after blocking error,0,
IDE08949-MAS07867,Operating current: light driver-Conn. pin 0,0, mA
IDE08949-MAS07868,Operating current: light driver-Conn. pin 1,0, mA
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,400, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,416, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07881,Operating current: light driver-Conn. pin 14,0, mA
IDE08949-MAS07882,Operating current: light driver-Conn. pin 15,0, mA
IDE08949-MAS07883,Operating current: light driver-Conn. pin 16,0, mA
IDE08949-MAS07884,Operating current: light driver-Conn. pin 17,0, mA
IDE08949-MAS07885,Operating current: light driver-Conn. pin 18,6, mA
IDE08949-MAS07886,Operating current: light driver-Conn. pin 19,0, mA
IDE08949-MAS07887,Operating current: light driver-Conn. pin 20,0, mA
IDE08949-MAS07888,Operating current: light driver-Conn. pin 21,0, mA
IDE08949-MAS07889,Operating current: light driver-Conn. pin 22,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07893,Operating current: light driver-Conn. pin 26,0, mA
IDE08949-MAS07894,Operating current: light driver-Conn. pin 27,0, mA
IDE08949-MAS07895,Operating current: light driver-Conn. pin 28,0, mA
IDE08949-MAS07896,Operating current: light driver-Conn. pin 29,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,582, mA
IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,19, mA
IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,13, mA
IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,14, mA
IDE08949-MAS07901,Operating current: light driver-Conn. pin 34,19, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,2,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,Not operated,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,Not operated,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,Not operated,
IDE11134-IDE01943,Light sequence HU test result-Turn signal,not installed / not active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,not installed / not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,not installed / not active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,not installed / not active,
IDE11134-IDE03310,Light sequence HU test result-Brake light,not installed / not active,
IDE11134-IDE03638,Light sequence HU test result-static AFS light,not installed / not active,
IDE11134-IDE05323,Light sequence HU test result-Fog light,not installed / not active,
IDE11134-IDE05839,Light sequence HU test result-Parking light,not installed / not active,
IDE11134-IDE06470,Light sequence HU test result-Ambience lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,not installed / not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,not installed / not active,
IDE11134-MAS03835,Light sequence HU test result-Parking light,not installed / not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog light,not installed / not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,760, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,735, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded/not installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,Steering wheel heater,
IDE11943-MAS01737,Signature light-Diagnosis,not coded/not installed,
IDE11943-MAS02248,Signature light-Signal state,not active,
IDE11943-MAS03873,Signature light-Duty cycle,0.0, %
IDE11943-MAS04351,Signature light-Connector terminal number,0,
IDE11943-MAS04352,Signature light-Connector number,Plug A,
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,Not Present,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,not activated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,not activated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear Window Wiper,not activated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,not activated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,not activated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,not activated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,not activated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Signal horn,not activated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 4,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,not activated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,not activated,
IDE12940,Lever functions of the steering column electronics,not activated,
IDE14095-MAS17564,Wiper park position heater-Relay actuation,not coded/not installed,
IDE14110-MAS17842,Digital Key-NFC control section,Not operated,
IDE14110-MAS17843,Digital Key-Bluetooth control section,Not operated,
IDE14172-MAS03692,Remote key movement information-Key 1,not inoperative,
IDE14172-MAS03693,Remote key movement information-Key 2,not inoperative,
IDE14172-MAS03694,Remote key movement information-Key 3,not inoperative,
IDE14172-MAS03695,Remote key movement information-Key 4,not inoperative,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Supply voltage: Terminal 30-Voltage terminal 30,14.30, V
MAS00043-IDE05835,Supply voltage: Terminal 30-Supply voltage for central locking,14.35, V
MAS00043-IDE05967,Supply voltage: Terminal 30-Voltage terminal 30 left,14.35, V
MAS00043-IDE05968,Supply voltage: Terminal 30-Voltage terminal 30 right,14.35, V
MAS00043-IDE08734,Supply voltage: Terminal 30-Supply voltage for anti-theft alarm system,14.35, V
MAS00043-IDE08735,Supply voltage: Terminal 30-Supply voltage for seat heater,14.35, V
MAS00043-MAS00362,Supply voltage: Terminal 30-Battery voltage,5.00, V
MAS00043-MAS07472,Supply voltage: Terminal 30-Battery voltage BEM,14.40, V
MAS00043-MAS07473,Supply voltage: Terminal 30-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Supply voltage: Terminal 30-Test voltage windshield defogger,0.00, V
MAS00179-MAS04422,Brake Light Switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake Light Switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,17,
MAS00464-MAS00109,Standard - ambient data 1-Hours,9,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,59,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,11,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,118, km
MAS00829-MAS00244,Access and start authorization-Awakening wire,operated,
MAS00829-MAS01763,Access and start authorization-Signal Strength,-50,
MAS00829-MAS07866,Access and start authorization-Duration: last awakening wire actua.,4, ms
MAS01281-MAS01737,Back-up light-Diagnosis,normal,
MAS01281-MAS02248,Back-up light-Signal state,not active,
MAS01281-MAS03873,Back-up light-Duty cycle,0.0, %
MAS01281-MAS04351,Back-up light-Connector terminal number,11,
MAS01281-MAS04352,Back-up light-Connector number,Plug C,
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,not activated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge condition,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in detection area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heater,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,Enabling stage 3,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,Enabling stage 3,
MAS01490-MAS01564,Energy management-Windshield defogger,Enabled,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,0,
MAS01490-MAS05795,Energy management-Rear seat heater,Enabled,
MAS01490-MAS05796,Energy management-Emergency shut-down,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,Enabled,
MAS01490-MAS06552,Energy management-Seat heater front,Enabling stage 3,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,0,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance drive,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Not adapted,
MAS01597-MAS02282,Sunroof-Position,126, %
MAS01597-MAS02447,Sunroof-Release,not active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,not normed,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835-MAS01737,Parking light-Diagnosis,normal,
MAS03835-MAS02248,Parking light-Signal state,active,
MAS03835-MAS03873,Parking light-Duty cycle,100.0, %
MAS03835-MAS04351,Parking light-Connector terminal number,39,
MAS03835-MAS04352,Parking light-Connector number,Plug B,
MAS03836-MAS01737,Rear fog light-Diagnosis,not coded/not installed,
MAS03836-MAS02248,Rear fog light-Signal state,not active,
MAS03836-MAS03873,Rear fog light-Duty cycle,0.0, %
MAS03836-MAS04351,Rear fog light-Connector terminal number,0,
MAS03836-MAS04352,Rear fog light-Connector number,Plug A,
MAS07959-IDE00787,Remote start history data-Cause for cancellation,No release from the engine control module,
MAS07959-MAS00107,Remote start history data-Month,6,
MAS07959-MAS00108,Remote start history data-Day,7,
MAS07959-MAS00109,Remote start history data-Hours,15,
MAS07959-MAS00110,Remote start history data-Minutes,11,
MAS07959-MAS07960,Remote start history data-Stop or cancel cause,No reason for prevention,
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,22860, lx
MAS08228-MAS04121,Light sensor-Voltage,25.4, V
MAS13141,Test voltage,0, V
ENG116910,Control unit internal measured value (supplier),00 00 00 02 0D 1A 0D 1A 63 00 00 03 5E FF 00 00 00 00 00 00 00 00 00 00 00 02 00 04 00 06 15 C4 00 00 07 15 00 00 07 15 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 08 00 00 00 02 00 20 00 00 10 00 0B 00 00 00 00 00 00 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 0E 00 01 00 00 00 00 53 64 08 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 01 08 00 0C 81 14 5B 00 00 10 00 04 4C 20 34 00 20 00 00 40 08 00 02 6B 1F 00 00 00 CC BB 63 00 3B 00 00 00 00 00 00 00 00 00 00 01 00 06 02 00 00 00 00 00 00 00 00 00 00 00 00 00 81 00 00 00 00 00 00,
ENG117285-ENG115839,Cycle_Protection_Counter-central_locking_cycle_protection_counter,0,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,gueltiges Funktelegramm,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,0,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG116813-ENG28575,Entwicklermesswerte_CONTI-KurzSchlussZaehler,0,
ENG116008-IDE10662,light_swich_module-Light switch (button module),not coded/not installed,
ENG116008-MAS17838,light_swich_module-Exterior lighting: global shutoff,not coded/not installed,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,not coded/not installed,
ENG116909-ENG114948,LIN activity-LIN 3,active,
ENG116909-ENG114949,LIN activity-LIN 4,active,
ENG116909-ENG114950,LIN activity-LIN 5,active,
ENG116909-ENG114951,LIN activity-LIN 6,active,
ENG116793,Monitor 1,00 00 00 00 00 00 00 00,
ENG116802,Monitor 10,00 00 00 00 00 00 00 00,
ENG116794,Monitor 2,00 00 00 00 00 00 00 00,
ENG116795,Monitor 3,00 00 00 00 00 00 00 00,
ENG116796,Monitor 4,00 00 00 00 00 00 00 00,
ENG116797,Monitor 5,00 00 00 00 00 00 00 00,
ENG116798,Monitor 6,00 00 00 00 00 00 00 00,
ENG116799,Monitor 7,00 00 00 00 00 00 00 00,
ENG116800,Monitor 8,00 00 00 00 00 00 00 00,
ENG116801,Monitor 9,00 00 00 00 00 00 00 00,
ENG128380,Parametermonitor_0,82 14 64 64 A0 78 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 32 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 0A 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 05 00 00 00 00 00 00 14 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 28 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 05 10 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 19 0A 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 14 14 C8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 FF 02 05 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 32 0A 34 0B 01 64 64 03 0A 05 01 0A 46 00 1E 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 1E 03 B4 00 0A 05 05 0A 4B 00 32 0A 00 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653-MAS00107,Personalized_Account_Key_History-Month,6,
ENG126653-MAS00108,Personalized_Account_Key_History-Day,10,
ENG126653-MAS00109,Personalized_Account_Key_History-Hours,11,
ENG126653-MAS00110,Personalized_Account_Key_History-Minutes,35,
ENG126653-MAS01551,Personalized_Account_Key_History-Key number,1,
ENG126653-ENG28771,Personalized_Account_Key_History-Account,1,
ENG126652-MAS03692,Personalized_key__Setting-Key 1,1,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,1,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654-MAS00107,Personalized_Signals-Month,6,
ENG126654-MAS00108,Personalized_Signals-Day,17,
ENG126654-MAS00109,Personalized_Signals-Hours,9,
ENG126654-MAS00110,Personalized_Signals-Minutes,49,
ENG126654-ENG30061,Personalized_Signals-Perso_Aktiv,1,
ENG126654-ENG28925,Personalized_Signals-Perso_Bedienstelle,0,
ENG126654-ENG28926,Personalized_Signals-Perso_Freigabe_Verstellung,0,
ENG126654-ENG28772,Personalized_Signals-Perso_Konto,1,
ENG126654-ENG28775,Personalized_Signals-Perso_Status,1,
ENG126654-ENG28773,Personalized_Signals-Perso_Steuerung,0,
ENG126654-ENG28774,Personalized_Signals-Perso_Steuerungs_parameter,0,
ENG116792-ENG115817,Power up history-Funktionsanforderung,10,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,16,
ENG116790-MAS00711,Supply voltage history-Odometer reading,3, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,14.9, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.4, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,14.3, V
ENG116791,Temperatures,29.50, °C
ENG127111-ENG127149,Valeo_Entwickler_MWB-Batterie_Spannung_KL_15,0.0, V
ENG127111-ENG127148,Valeo_Entwickler_MWB-Batterie_Spannung_KL_30,0.0, V
ENG127111-ENG127156,Valeo_Entwickler_MWB-GRA leitung,0,
ENG127111-ENG30013,Valeo_Entwickler_MWB-Historienspeicher im Fehlerfall,00 00 00 00 8F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127111-ENG98652,Valeo_Entwickler_MWB-Horn,OFF,
ENG127111-ENG30027,Valeo_Entwickler_MWB-Lenkrad Heizung,0,
ENG127111-ENG30075,Valeo_Entwickler_MWB-Resetmonitor,0,
ENG127111-ENG127158,Valeo_Entwickler_MWB-U12V_SW2,0,
ENG127111-ENG30182,Valeo_Entwickler_MWB-WakeUp2,OFF,
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,not activated,
ENG116907-IDE04639,Zusaetzliche Umgebungsdaten-Last wake-up cause,Radio telegram: valid,
ENG116907-IDE07956,Zusaetzliche Umgebungsdaten-redundant signal line,infinite,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside air temperature,29.5, °C
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,operated,
ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Parking light,not activated,
ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,14.3, V
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,not activated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,not activated,
ENG116907-MAS14232,Zusaetzliche Umgebungsdaten-Light switch: zero setting,not activated,
ENG116907-MAS19766,Zusaetzliche Umgebungsdaten-Status of brake lamp switch: discrete,OFF,
ENG116907-MAS19768,Zusaetzliche Umgebungsdaten-Brake lamp switch via CAN: status,OFF,
Elapsed Time: 01:24
10:
;SW:5QA-919-298-D   HW:5QA-919-298-A ---  Park/Steer Assist
;Component:PLA 3.0 12KH07 0050, Coding:0271267951
;EV_EPHVA2CAU3700000,009041,EV_EPHVA2CAU3700000.rod
;Monday,17,June,2019,11:01:23:34333
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: D1EA38F2806FA7C7CA-8084
Group,Description,Actual
IDE00018,Voltage terminal 15,13.9, V
IDE00030,Status of actuator test,not active,
IDE00322,Status of basic setting,not active,
IDE00325,Diagnostic mode,OBD-diagnostic mode,
IDE00957-MAS01632,Resulting distance of front sensors-Status,72, cm
IDE00958-MAS01632,Resulting distance of rear sensors-Status,infinite,
IDE00973,Outside air temperature,29.50, °
IDE00974,Outside air temperature internally calculated,29.00, °
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,No,
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,infinite,
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,infinite,
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,infinite,
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,73, cm
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,73, cm
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,1.184, ms
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,1.184, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,1.152, ms
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,1.168, ms
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,1.088, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,1.056, ms
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,1.056, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,1.152, ms
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Speaker volume for rear park assist,Stage 6,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 4,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Speaker volume for front park assist,Stage 4,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 6,
IDE01163,Sound output for park assist in selector lever position P,OFF,
IDE01164,Park assist button,not activated,
IDE01165,Park assist activation tone,On,
IDE01166,Supply voltage for park assist sensor,13.9, V
IDE01167,Convertible offset for volume level 1,not installed,
IDE01168,Increment for convertible volume levels,not installed,
IDE01169,Audio reduction request,Yes,
IDE01171,Convertible factory setting offset for volume level 1,not installed,
IDE01172,Factory setting for increment for convertible volume levels,not installed,
IDE01173,Audio reduction factory setting,Yes,
IDE01175-MAS01632,Distance of side left rear parking aid sensors-Status,infinite,
IDE01176-MAS01632,Distance of side right rear parking aid sensors-Status,infinite,
IDE01177-MAS01632,Oscillating time of side left rear parking aid sensors-Status,1.136, ms
IDE01178-MAS01632,Oscillating time of side right rear parking aid sensors-Status,1.104, ms
IDE01185-MAS01632,Distance sensor for left front parking aid-Status,infinite,
IDE01186-MAS01632,Distance sensor for right front parking aid-Status,infinite,
IDE01187-MAS01632,Decay time for side left front parking aid sensor-Status,1.056, ms
IDE01188-MAS01632,Decay time for right side front parking aid sensor-Status,0.944, ms
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,activated,
IDE01411-MAS01426,Personalization 1 for park assist-Speaker volume for rear park assist,Stage 6,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01411-MAS01428,Personalization 1 for park assist-Speaker volume for front park assist,Stage 4,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,Parking aid active,
IDE01411-MAS12843,Personalization 1 for park assist-Maneuvering brake function,activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Speaker volume for rear park assist,Stage 6,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01412-MAS01428,Personalization 2 for park assist-Speaker volume for front park assist,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,not active,
IDE01412-MAS12843,Personalization 2 for park assist-Maneuvering brake function,activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Speaker volume for rear park assist,Stage 6,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01413-MAS01428,Personalization 3 for park assist-Speaker volume for front park assist,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12843,Personalization 3 for park assist-Maneuvering brake function,activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Speaker volume for rear park assist,Stage 6,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01414-MAS01428,Personalization 4 for park assist-Speaker volume for front park assist,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12843,Personalization 4 for park assist-Maneuvering brake function,activated,
IDE01588,Driving direction,forwards,
IDE01632,System condition of park assist,not active,
IDE01633,Cause of park assist switching off,No shut-off requirement,
IDE01943,Turn signal,not activated,
IDE01965,Parallel parking assistance button,not activated,
IDE01966,Cause of parallel park assist switching off,No shut-off requirement,
IDE01967,Parking side,Right,
IDE02486,Data logger triggering,not active,
IDE03008-IDE03726,Stop process prevented-Parallel Parking Assistance,passive,
IDE03008-MAS00825,Stop process prevented-Parking Aid Control Module,passive,
IDE03010-IDE03726,Number of prevented stop processes-Parallel Parking Assistance,0,
IDE03010-MAS00825,Number of prevented stop processes-Parking Aid Control Module,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2000,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,0,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03127-MAS02886,Prevented stop processes (ring memory)-Last prohibited stop,none,
IDE03127-MAS02888,Prevented stop processes (ring memory)-Penultimate prohibited stop,none,
IDE03127-MAS02890,Prevented stop processes (ring memory)-Third-last prohibited stop,none,
IDE03127-MAS02892,Prevented stop processes (ring memory)-Fourth last prohibited stop,none,
IDE03127-MAS02894,Prevented stop processes (ring memory)-Fifth-last prohibited stop,none,
IDE03212,Start-stop conditions,Stop release,
IDE03683,Request power steering boost,No,
IDE03684,Vehicle stopped,Yes,
IDE03782,Switch-off speed for parking assist,15, km/h
IDE03783,Switch-on speed for parallel parking assist,37, km/h
IDE03784,Temporary function limitation due to environmental influences,No,
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator position,255, %/s
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,255, bar
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2127,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,15,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,31,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,31,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,63,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,63,
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,0.0, km/h
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,Parking aid active,
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,0.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,0.0, m
MAS00464-MAS00109,Standard - ambient data 1-Hours,10,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,43,
MAS01426,Speaker volume for rear park assist,Stage 6,
MAS01427,Speaker frequency for rear park assist,Stage 4,
MAS01428,Speaker volume for front park assist,Stage 4,
MAS01429,Speaker frequency for front park assist,Stage 6,
MAS10122,ARA operating condition,Initializing,
MAS10122-MAS11700,ARA operating condition-ARA function request door control module,no request,
ENG113995,Dimming_Signal_Terminal_58xd_pdc_pla,87, %
ENG113996-ENG113979,Function_PLA-BS_alignement_BF,Yes,
ENG113996-ENG113982,Function_PLA-BS_alignement_driver,Yes,
ENG113996-ENG113978,Function_PLA-BS_identified_BF,Yes,
ENG113996-ENG113980,Function_PLA-BS_identified_BF_old,Yes,
ENG113996-ENG113981,Function_PLA-BS_identified_Driver,Yes,
ENG113996-ENG113983,Function_PLA-BS_identified_Driver_old,Yes,
ENG113996-ENG106720,Function_PLA-Fzgx_Max,6533.0, cm
ENG113996-ENG106721,Function_PLA-Fzgy_Max,1280.1, cm
ENG113996-ENG113974,Function_PLA-L_Rangier_Min,6553.5, cm
ENG113996-ENG107571,Function_PLA-Manual_Steering_Moment,0.0, Nm
ENG113996-ENG108155,Function_PLA-Parking_Aid_Senders_Cutoff_Time,0, s
ENG113996-ENG113977,Function_PLA-PL_Depth_BF,6553.5, cm
ENG113996-ENG113986,Function_PLA-PL_depth_BF_old,50, cm
ENG113996-ENG113988,Function_PLA-PL_Depth_Driver,6553.5, cm
ENG113996-ENG113990,Function_PLA-PL_Depth_Driver_Old,0.0, cm
ENG113996-ENG113976,Function_PLA-PL_Length_BF,6553.5, cm
ENG113996-ENG113985,Function_PLA-PL_Length_BF_old,537.5, cm
ENG113996-ENG113987,Function_PLA-PL_Length_Driver,1280.1, cm
ENG113996-ENG113989,Function_PLA-PL_Length_Driver_Old,6553.5, cm
ENG113996-ENG108329,Function_PLA-Psi0_BF,70.31, °
ENG113996-ENG108330,Function_PLA-Psi0_BF_Alt,359.99, °
ENG113996-ENG108331,Function_PLA-Psi0_Fahrer,359.99, °
ENG113996-ENG108332,Function_PLA-Psi0_Fahrer_Alt,70.59, °
ENG113996-ENG109009,Function_PLA-Speed_Limit_Power_Steering,255, km/h
ENG113996-ENG109117,Function_PLA-Steering_Angle_Actual_Value,0.0, °
ENG113996-ENG109118,Function_PLA-Steering_Angle_Nominal_Value,0.0, °
ENG113996-ENG113975,Function_PLA-T_Rangier_Min,6530.0, cm
ENG113996-ENG113984,Function_PLA-Visual_Indication,Yes,
ENG113996-ENG110295,Function_PLA-X0_BF,2227.2, cm
ENG113996-ENG110296,Function_PLA-X0_BF_Alt,1987.4, cm
ENG113996-ENG110297,Function_PLA-X0_Fahrer,1280.1, cm
ENG113996-ENG110298,Function_PLA-X0_Fahrer_Alt,-0.1, cm
ENG113996-ENG110299,Function_PLA-Xa_BF_Alt,-23.6, cm
ENG113996-ENG110300,Function_PLA-Xa_Fahrer_Alt,51.1, cm
ENG113996-ENG110301,Function_PLA-Y0_BF,11.8, cm
ENG113996-ENG110302,Function_PLA-Y0_BF_Alt,-2453.3, cm
ENG113996-ENG110303,Function_PLA-Y0_Fahrer,-0.1, cm
ENG113996-ENG110304,Function_PLA-Y0_Fahrer_Alt,537.5, cm
ENG113996-ENG113973,Function_PLA-Ya_Alt,-20.6, cm
ENG113996-ENG110306,Function_PLA-Ya_Fahrer_Alt,-0.1, cm
Elapsed Time: 00:14
13:
;SW:5Q0-907-572-P   HW:3QF-907-572-A ---  Auto Dist. Reg
;Component:ACC BOSCH MQB H11 0682, Coding:320007C959FFC728949C810530401600000000000000000004
;EV_ACCBOSCHVW416,002008,EV_ACCBOSCHVW416_002_VW37.rod
;Monday,17,June,2019,11:01:40:34333
;VCID: C4C401A64F1D426F71-8090
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,14.1, V
IDE00102,Control Module temperature,53, °C
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE01285,Counter of component protection malfunctions,00 00,
IDE01788,Heated lens control signal,0.00, %
IDE01794,ACC operating lever signal,00000000 10101000 ,
IDE01985-MAS06854,FAZIT identification test sum-Version,81,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,AE C5 BA 4C,
IDE03008-MAS12557,Stop process prevented-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,not active,
IDE03008-MAS12559,Stop process prevented-Driving ahead Vehicles start moving: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Driving ahead Vehicles are starting: ACC off,not active,
IDE03008-MAS16236,Stop process prevented-Vehicle ahead approaching: ECC not coded,not active,
IDE03010-MAS12557,Number of prevented stop processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
IDE03010-MAS12559,Number of prevented stop processes-Driving ahead Vehicles start moving: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Driving ahead Vehicles are starting: ACC off,0,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
IDE03011-MAS12558,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting possible,0,
IDE03011-MAS12559,Number of requested start processes-Driving ahead Vehicles start moving: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Driving ahead Vehicles are starting: ACC off,0,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03203,Alignment instructions,Set mirror in posit 1 and start measurement,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 90 03,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C2 F7 2F 35 53 5E E2 17 A5 77 DB 79 FD 19 AF 44 A3 60 AB 15 CA A5 5E F9 45 CD 6F 1E F6 A2 BE 4E 8D 28 64 CF 1C 34 C7 C9 16 DE DE 67 B5 57 39 00 C2 53 57 B6 FB 19 A1 41 40 A0 F5 B2 60 C0 18 01 6D C7 8E B5 02 83 63 E2 BA D4 28 DD 96 22 FD D1 F4 87 8B 5F EC EC 1D 9D 62 41 0B 2B 9F 3C 6B 2B AE 87 95 D3 A9 B9 72 54 56 6C 80 1C 53 40 5F 4E CE C1 CD 32 AD 83 5B 53 DE BA EF E3 D0 D0 B8 A7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,3,
IDE04805-MAS01448,Driving profile selection-Specified value,3,
IDE05814,Individualization characteristic,C4 94 DF C3 D6,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307-MAS16236,Stop prevention history data-Vehicle ahead approaching: ECC not coded,not active,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308-MAS16236,Start request history data-Vehicle ahead approaching: ECC not coded,not active,
IDE06308,Start request history data,not active,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,01,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08768,Mirror deviation: horizontal,24.464, °
IDE08769,Mirror deviation: vertical,-24.464, °
IDE08770-MAS01466,Adjustment of screw top left-Direction of rotation,none,
IDE08770-MAS02559,Adjustment of screw top left-Rotations,0.00,
IDE08771-MAS01466,Adjustment of screw top right-Direction of rotation,none,
IDE08771-MAS02559,Adjustment of screw top right-Rotations,0.00,
IDE08772-MAS01466,Adjustment of screw bottom left-Direction of rotation,none,
IDE08772-MAS02559,Adjustment of screw bottom left-Rotations,0.00,
IDE08773-MAS01466,Adjustment of screw bottom right-Direction of rotation,none,
IDE08773-MAS02559,Adjustment of screw bottom right-Rotations,0.00,
IDE08936,Misalignment angle: horiz,-0.116, °
IDE08937,Misalignment angle: horiz: fast algorithm,0.183, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,0.00, °
IDE09380-MAS00106,Performed adjustment-Year,19,
IDE09380-MAS00107,Performed adjustment-Month,01,
IDE09380-MAS00108,Performed adjustment-Day,09,
IDE09380-MAS05610,Performed adjustment-Calibration,static,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,-0.29, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,2.90, °
IDE09906,Vertical deadjustment,1.923, °
IDE11924-MAS13427,Correction angle-Horizontal correction angle: dynamic,0.000, °
IDE11924-MAS13428,Correction angle-Vertical correction angle: dynamic,0.000, °
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,0.180, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,1.920, °
IDE11924-MAS13887,Correction angle-Horizontal correction angle static,-0.290, °
IDE11924-MAS13888,Correction angle-Vertical correction angle static,2.890, °
ENG107409,Longitudinal_acceleration_vehicle_reference,0.00, m/s²
ENG107860,Number_of_ANB_partial_bracings,0,
ENG107861,Number_of_ANB_target_bracings,0,
ENG107862,Number_of_ANB-CM,0,
ENG00926,Number_of_boost_function_active,0,
ENG00927,Number_of_deactivation_ASR_active,0,
ENG00928,Number_of_deactivation_ESC_active,0,
ENG00913,Number_of_Emergency_steer_assist,0,
ENG00915,Number_of_fully_developed_deceleration_1,0,
ENG00916,Number_of_fully_developed_deceleration_2,0,
ENG06681,Number_of_mainwarnings,0,
ENG03998,number_of_prewarnings,0,
ENG00914,Number_of_Turn_off_assistant_intervention,0,
ENG107928,Operating_time_ACC,1, min
ENG00919,Operating_time_ACC_active_driving_programm_auto,0, min
ENG00918,Operating_time_ACC_active_driving_programm_comfort,0, min
ENG00917,Operating_time_ACC_active_driving_programm_dynamic,0, min
ENG00920,Operating_time_ACC_active_driving_programm_efficiency,1, min
ENG00921,Operating_time_ACC_active_timegap_1,0, min
ENG00922,Operating_time_ACC_active_timegap_2,0, min
ENG00923,Operating_time_ACC_active_timegap_3,1, min
ENG00924,Operating_time_ACC_active_timegap_4,0, min
ENG00925,Operating_time_ACC_active_timegap_5,0, min
ENG00929,Operating_time_ACC_active_v-delta_0,1, min
ENG00932,Operating_time_ACC_active_v-delta_large,0, min
ENG00931,Operating_time_ACC_active_v-delta_medium,0, min
ENG00930,Operating_time_ACC_active_v-delta_small,0, min
ENG00933,Operating_time_STA_active,0, min
ENG00934,Operating_time_STA_off_activation_possible,0, min
ENG00935,Status_ACC_System,ACC_StandBy,
ENG08760,Sw_version_supplier,1037604546;PF_R28.9.0_VW.MQB_371_JETTA.0682_I1.0;0;Compiled by bor7htv on Wed Nov 29 18:39:27 2017$!,
ENG109878,Velocity_vehicle_reference,0.00, m/s
Elapsed Time: 00:14
15:
;SW:3Q0-959-655-BN   HW:3Q0-959-655-BN ---  Airbags
;Component:Airbag VW21   006 0713, Coding:8CCCDC00000000005000001A420800000065
;EV_AirbaVW21TS6VW48X,001014,EV_AirbaVW21TS6VW48X.rod
;Monday,17,June,2019,11:01:57:34333
;VCID: 8B56EA9A22C3CD1770-80DE
IDE00821,Safety belt switch 2nd row driver side,not installed,
IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
IDE00823,Safety belt switch 2nd row center,not installed,
IDE00824,Driver side 3rd row seat belt switch,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,2.8, Ohm
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01100,Passenger side airbag igniter ohm value,2.2, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,2.1, Ohm
IDE01102,Driver's side airbag igniter ohm value,2.3, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.3, Ohm
IDE01104,driver side rear airbag igniter ohm value,no measured value present,
IDE01105,Ft. pass.side rear airbag igniter ohm value,no measured value present,
IDE01106,Driver side head curtain airbag igniter ohm value,2.4, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.3, Ohm
IDE01108,Driver side knee airbag igniter ohm value,no measured value present,
IDE01109,Frt.pass. side knee airbag igniter ohm value,no measured value present,
IDE01110,Driver side belt tensioner igniter ohm value,2.3, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.3, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,2.0, Ohm
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,2.0, Ohm
IDE01114,Driver side belt force limiter igniter ohm value,no measured value present,
IDE01115,side belt force limiter igniter ohm value,2.4, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,no measured value present,
IDE01117,Passenger side rear belt tensioner igniter ohm value,no measured value present,
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,too Low,
IDE01194,Frt.pass. belt tensioner ohm value,too Low,
IDE01197,Key switch contact 1 ohm value,no measured value present,
IDE01198,Key switch contact 2 ohm value,no measured value present,
IDE01200,Driver seat position sensor current value,no measured value present,
IDE01201,Frt.pass. seat position sensor current value,5.8, mA
IDE01205,Safety belt switch 2nd row driver side ohm value,no measured value present,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,no measured value present,
IDE01207,Safety belt switch center 2nd row ohm value,no measured value present,
IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01285,Counter of component protection malfunctions,0,
IDE01357,Pedestrian protection trigger: driver side,not installed,
IDE01358,Pedestrian protection trigger: frt.pass. side,not installed,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,0,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,0,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,0,
IDE01555,Number of frontal crashes,0,
IDE01556,Number of side crashes driver side,0,
IDE01557,Number of side crashes frt.pass. side,0,
IDE01558,Number of rear crashes,0,
IDE01559,Number of rollover crashes,0,
IDE01634,Pedestrian protection trigger: driver side ohmic value,no measured value present,
IDE01635,Pedestrian protection trigger: frt.pass. side ohmic value,no measured value present,
IDE02246,Number of activations of pedestrian protection,0,
IDE02852,Igniter for battery interrupt: high voltage battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,no measured value present,
IDE03730,Igniter for driver side air bag release valve: ohm value,no measured value present,
IDE03731,Igniter for frt.pass. side air bag release valve: ohm value,no measured value present,
IDE03800,Driver airbag release valve igniter,not installed,
IDE03801,Frt.pass. airbag release valve igniter,not installed,
IDE03870,Seat occupied recognition malfunction status,00,
IDE03870,Seat occupied recognition malfunction status,0,
IDE06034,Rollover protection trigger: driver side,not installed,
IDE06035,Rollover protection trigger: frt.pass. side,not installed,
IDE06036,Rollover protection trigger: driver side ohm value,no measured value present,
IDE06038,Rollover protection trigger: frt.pass. side ohm value,no measured value present,
IDE06959,Seat occupant detection: diagnosis signal,33.5, %
IDE06960,Seat occupant detection: msmt. signal,0.0, %
IDE06961,Seat occupant detection: ref. signal,1.0, %
IDE10187,Supply voltage [V],14.2, V
MAS00001,Driver airbag igniter,correct,
MAS00003,Passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,not installed,
MAS00008,Passenger side rear thorax airbag igniter,not installed,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,not installed,
MAS00012,Front passenger knee airbag igniter,not installed,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver seat belt tensioner igniter 2,correct,
MAS00016,Front passenger side seat belt tensioner igniter 2,correct,
MAS00017,Driver side belt force limiter igniter,not installed,
MAS00018,Front passenger side belt force limiter igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,not installed,
MAS00020,Passenger side rear safety belt tension igniter,not installed,
MAS00022,Igniter for battery interrupt,not installed,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00031,Airbag deactivation status,On,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,not installed,
MAS00036,Seat position sensor: front passenger side,Rear,
MAS00037,Calibration status,0,
MAS01634,Supply voltage,correct,
Elapsed Time: 00:13
17:
;SW:3CN-920-891-B   HW:3CN-920-891-B ---  Instruments
;Component:KOMBI         403 4191, Coding:0BA40F1DEF88CF0502886B0B50010000A0000000
;EV_DashBoardVDDMQBAB,009058,EV_DashBoardVDDMQBAB_009_VW37.rod
;Monday,17,June,2019,10:56:38:34333
;VCID: C3C602BA4A13455748-8096
IDE00019,Voltage terminal 30,14.3, V
IDE00021,Engine speed,915.00, /min
IDE00025,Coolant temperature,90.00, °C
IDE00075,Vehicle speed,0, km/h
IDE00196,Engine oil temperature,46, °C
IDE00301,Distance,118, km
IDE00310,Outside air temperature,29.5, °C
IDE00316-IDE00500,Time-Hour,9, H
IDE00316-IDE00501,Time-Minute,55, min
IDE00316-MAS00111,Time-Seconds,46, s
IDE00317-IDE00502,Date-Year,2019, yr
IDE00317-IDE00503,Date-Month,6, mon
IDE00317-IDE00504,Date-Day,17, d
IDE00510,ESI: distance driven from inspection,118, km
IDE00511,ESI: time from inspection,159, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,400, km
IDE00520,Phototransistor,252,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,15990, km
IDE00698,ESI: remaining running time,206, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,158, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,2323, mm
IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2323, mm
IDE00935,ESI: Theoretical service interval,15000, km
IDE01076,Time since ignition off,131068, s
IDE01153,SIA: maximum value of distance to service,16100, km
IDE01154,SIA: maximum value of time to service,365, d
IDE01985-MAS06854,FAZIT identification test sum-Version,02,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,17 41 AA C9,
IDE02307,Parking brake status,not activated,
IDE02642,Outside temp.: displayed value,29.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,E7,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,196,
IDE03349,FIX: Max. distance until next mileage-related inspection,32200, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,100, km
IDE03352,FIX: Time since last time-dependent inspection,159, d
IDE03471-IDE03640,Vehicle configuration-Dynamic AFS light,Correct coding,
IDE03471-IDE03726,Vehicle configuration-Parallel Parking Assistance,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
IDE03471-MAS00809,Vehicle configuration-Electro-Mechanical Parking Brake Control Module,Correct coding,
IDE03471-MAS00811,Vehicle configuration-Active steering control module,Correct coding,
IDE03471-MAS00911,Vehicle configuration-All Wheel Drive (AWD),Correct coding,
IDE03471-MAS01091,Vehicle configuration-Automated manual transmission,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
IDE03471-MAS03385,Vehicle configuration-Lane change assistance,Correct coding,
IDE03471-MAS04384,Vehicle configuration-Electrical steering column lock control module,Correct coding,
IDE03471-MAS05723,Vehicle configuration-Adaptive cruise control or reducing stopping distance,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,2.8, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,35.8, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,33.0, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,0.0, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,0.0, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,9.9, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,9.9, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,0.0, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,0.0, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,0.0, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,0.0, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,0.0, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,0.0, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,0.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,0.0, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,0.0, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,0,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,0,
IDE03472-MAS06155,Volume after refueling-Third to last distance,0,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,0,
IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,243, Ohm
IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,Fuel tank sens-Fuel level sensor 1 soiling resistance,2, Ohm
IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,-32768, Ohm
IDE03473-IDE03494,Fuel tank sens-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,Fuel tank sens-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,Fuel tank sens-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,Fuel tank sens-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,2254,
IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,1371,
IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,Fuel tank sens-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,Fuel tank sens-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,Fuel tank sens-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,Fuel tank sens-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,11.4, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,241, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,14.1, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03826,Calculated volume-Quality sensor 1,10,
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS03828,Calculated volume-Quality sensor 3,not installed,
IDE03474-MAS03829,Calculated volume-Quality sensor 4,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,14.1, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-32768.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,14.1, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,14.1, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,14.1, l
IDE03474-ENG99553,Calculated volume-linking,0.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.00000, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.00,
IDE03474-ENG101623,Calculated volume-reference_volume,15.2, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,54,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0000000,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,15, H
IDE03477-IDE00501,GPS time-Minute,50, min
IDE03477-IDE00501,GPS time-Minute,56, min
IDE03477-IDE00502,GPS time-Year,2019, yr
IDE03477-IDE00503,GPS time-Month,6, mon
IDE03477-IDE00504,GPS time-Day,17, d
IDE03477-MAS00111,GPS time-Seconds,37, s
IDE03477-MAS00111,GPS time-Seconds,48, s
IDE03477-MAS03493,GPS time-last synchronization year,2019, yr
IDE03506,Distance: high resolution,00 01 CE FD,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,17,
IDE03880-MAS03425,MOST address-Physical address,04 02,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,FF FF FF FF,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,FF FF FF FF,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,FF FF FF FF,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,FF FF FF FF,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,FF FF FF FF,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,FF FF FF FF,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,FF FF FF FF,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01393,Service -interval- display: history 3-Block 4,FF FF FF FF,
IDE03913-MAS01394,Service -interval- display: history 3-Block 5,FF FF FF FF,
IDE03913-MAS01395,Service -interval- display: history 3-Block 6,FF FF FF FF,
IDE03913-MAS01396,Service -interval- display: history 3-Block 7,FF FF FF FF,
IDE03913-MAS01397,Service -interval- display: history 3-Block 8,FF FF FF FF,
IDE03913-MAS01398,Service -interval- display: history 3-Block 9,FF FF FF FF,
IDE03913-MAS01399,Service -interval- display: history 3-Block 10,FF FF FF FF,
IDE03913-MAS01400,Service -interval- display: history 3-Block 11,FF FF FF FF,
IDE03913-MAS01401,Service -interval- display: history 3-Block 12,FF FF FF FF,
IDE03913-MAS01402,Service -interval- display: history 3-Block 13,FF FF FF FF,
IDE03913-MAS01403,Service -interval- display: history 3-Block 14,FF FF FF FF,
IDE03913-MAS01404,Service -interval- display: history 3-Block 15,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01390,Service -interval- display: history 4-Block 1,FF FF FF FF,
IDE03914-MAS01391,Service -interval- display: history 4-Block 2,FF FF FF FF,
IDE03914-MAS01392,Service -interval- display: history 4-Block 3,FF FF FF FF,
IDE03914-MAS01393,Service -interval- display: history 4-Block 4,FF FF FF FF,
IDE03914-MAS01394,Service -interval- display: history 4-Block 5,FF FF FF FF,
IDE03914-MAS01395,Service -interval- display: history 4-Block 6,FF FF FF FF,
IDE03914-MAS01396,Service -interval- display: history 4-Block 7,FF FF FF FF,
IDE03914-MAS01397,Service -interval- display: history 4-Block 8,FF FF FF FF,
IDE03914-MAS01398,Service -interval- display: history 4-Block 9,FF FF FF FF,
IDE03914-MAS01399,Service -interval- display: history 4-Block 10,FF FF FF FF,
IDE03914-MAS01400,Service -interval- display: history 4-Block 11,FF FF FF FF,
IDE03914-MAS01401,Service -interval- display: history 4-Block 12,FF FF FF FF,
IDE03914-MAS01402,Service -interval- display: history 4-Block 13,FF FF FF FF,
IDE03914-MAS01403,Service -interval- display: history 4-Block 14,FF FF FF FF,
IDE03914-MAS01404,Service -interval- display: history 4-Block 15,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,30000, km
IDE05932,FIX: Reset value for next time-dependent inspections,1095, d
IDE09552-IDE07944,Vehicle configuration 2-electronic brake booster,Correct coding,
IDE09552-MAS06008,Vehicle configuration 2-Internal noise sound actuator,Correct coding,
IDE09552-MAS08940,Vehicle configuration 2-Collision warning,Correct coding,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG124477-MAS06854,Adapted_transponders_checksum-Version,01,
ENG124477-MAS06855,Adapted_transponders_checksum-Test sum,2F F2 79 5E,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,0, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,0, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,0, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,68, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,76, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,100, km
ENG106922,Immobilizer - Challenge,31 59 9A 95,
ENG99439,Instrument_recorder,03 04 91 00 4D 51 42 56 57 31 38 53 31 46 41 43 00 00 00 00 01 00 5D 00 1C 00 00 02 01 00 00 00 00 80 00 00 10 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AB 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 0A FF FF FF FF FF FF FF FF FF 00 00 1C 00 5D 00 01 02 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 11 01,
ENG128745,Instrument_recorder_graphic,02 04 92 00 4D 51 42 56 57 31 38 53 31 46 47 43 00 00 00 00 01 00 00 00 04 07 00 00 00 CD 00 00 00 24 00 00 02 01 00 00 00 00 00 00 00 00 00 00 00 E2 00 00 00 28 00 00 05 BD 00 00 C3 02 00 00 00 00 00 00 01 00 00 00 00 2D 00 00 00 00 00 00 C1 03 00 00 00 01 00 00 01 00 00 00 00 2D 00 00 00 00 00 00 C2 03 80 00 00 01 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 32 00 00 00 4A 00 00 00 00 00 00 00 00 00 00 00 00 0A FF FF FF FF FF FF FF FF FF,
ENG107920-ENG100914,onboard_computer-current_consumption,300.0,
ENG107920-ENG119788,onboard_computer-range_average_consumption,12.3, l/100km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,11.1, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,13.8, l/100km
ENG107920-ENG119791,onboard_computer-range_display_value,56, km
ENG107920-ENG119792,onboard_computer-range_R,58,
ENG107920-ENG112418,onboard_computer-total_range_gas,56, km
ENG107953-ENG100938,outside_temp_algorithm_group-coolant_temperature_outdated_bit,not active,
ENG107953-ENG101136,outside_temp_algorithm_group-distance_threshold_not_yet_reached,active,
ENG107953-ENG99778,outside_temp_algorithm_group-downward_tendency,not active,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG102352,outside_temp_algorithm_group-ice_warning_symbol,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,158,
ENG107953-ENG99258,outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit,not active,
ENG107953-ENG102589,outside_temp_algorithm_group-outside_temperature_old,not active,
ENG107953-ENG102387,outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit,not active,
ENG103405,read_out_measured_value_block,0,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,35,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,1,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Wait_SpeedlimitExceed,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG119808,Service_Key_Pointer-Write_Pointer_Adr_159,0,
ENG108929-ENG119809,Service_Key_Pointer-Write_Pointer_Adr_191,0,
ENG108929-ENG119810,Service_Key_Pointer-Write_Pointer_Adr_223,0,
ENG100879-ENG118224,State Blocking Time-blocking_time,00 00 00 00 00 00,
ENG103899-ENG99298,State of Immobilizer-State,02 01 03 B6 02 00 00 00 01 00,
ENG103284-ENG118223,State of Immobilizer Slaves-ELV_State,F8,
ENG103284-ENG118222,State of Immobilizer Slaves-GSG_State,00,
ENG103284-ENG118217,State of Immobilizer Slaves-Immobilizer_State,00,
ENG103284-ENG118216,State of Immobilizer Slaves-key_state,1C,
ENG103284-ENG118218,State of Immobilizer Slaves-MSG_1_State,F8,
ENG103284-ENG118219,State of Immobilizer Slaves-MSG_2_State,00,
ENG103284-ENG118220,State of Immobilizer Slaves-MSG_3_State,00,
ENG103284-ENG118221,State of Immobilizer Slaves-MSG_4_State,00,
ENG103284-ENG20775,State of Immobilizer Slaves-OCU_state,00,
ENG103284-ENG20776,State of Immobilizer Slaves-VTS_state,00,
ENG109576,Transponder ID Key 1,00 44 8F 55,
ENG109577,Transponder ID Key 2,00 44 7F 61,
Elapsed Time: 00:13
19:
;SW:3Q0-907-530-Q   HW:3Q0-907-530-C ---  CAN Gateway
;Component:GW MQB High   518 5344, Coding:0B0500347F087300FB0322581E0F00010001070000000000000000000000
;EV_GatewNF,013023,EV_GatewNF.rod
;Monday,17,June,2019,10:56:55:34333
;VCID: BD3274422CF733A73E-80E8
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00056-ENG20489,History data 1-Life Cycle Data String,2019-06-17-09:49*17.2*01*02151***
2019-06-16-16:56*24.0*01**
2019-06-15-16:27*00.0*01**
2019-05-07-06:52*00.0*01*00000***
2019-05-07-06:38*00.0*01**
2019-04-27-09:00*00.0*01**
IDE00057-ENG20489,History data 2-Life Cycle Data String,-------------:--*---*---*--.---*-------------*-*--*-----**
IDE00058-ENG20489,History data 3-Life Cycle Data String,2019-02-21-09:02*T*0*079*072*0-0-0-0-0-0-0*0*0*00.0*00.0**
2019-02-18-16:46*T*0*075*068*0-0-0-0-0-0-0*0*0*00.0*00.0**
2019-02-18-13:19*T*0*078*069*0-0-0-0-0-0-0*0*0*00.0*00.0**
2019-02-18-13:09*T*0*081*073*1-0-0-0-0-0-0*0*0*00.0*00.0**
2019-02-16-11:51*T*0*074*068*0-0-0-0-0-0-0*0*0*00.0*00.0**
2019-02-16-11:46*T*0*074*068*0-0-0-0-0-0-0*0*0*00.0*00.0**
2019-02-16-11:42*T*0*074*067*0-0-0-0-0-0-0*0*0*00.0*00.0**
2019-02-16-11:39*T*0*074*068*0-0-0-0-0-0-0*0*0*00.0*00.0**
2019-02-16-11:31*T*0*077*048*0-0-0-0-0-0-0*0*0*00.0*00.0**
2019-02-16-11:30*T*0*077*048*0-0-0-0-0-0-0*0*0*00.0*00.0**,
IDE00059-ENG20489,History data 4-Life Cycle Data String,       0000000km*01*070*MLA*1111111111*09997*00074*000.0*000.0*000.0**
IDE00060-ENG20489,History data 5-Life Cycle Data String,-------------:--*-*--.---*--.--*---*--*---.-*-----*-----*------*-------------*-*-*-*--.-*--.-*---.-*--*--*--*--*--**
IDE00061-ENG20489,History data 6-Life Cycle Data String,2019-06-15-13:54*066*+24*+000.7*00.00*0.00*000**
2019-06-10-11:01*070*+23*+001.0*00.20*0.00*000**
2019-06-08-15:41*069*+24*+000.3*00.00*0.00*000**
2019-06-07-15:55*068*+24*+000.5*00.00*0.00*000**
2019-06-07-15:46*068*+24*+000.2*00.00*0.00*000**
2019-06-07-14:50*073*+24*+000.2*00.00*0.00*000**
2019-06-07-08:36*077*+21*+000.1*00.00*0.00*000**
2019-06-03-11:49*083*+24*+000.2*00.00*0.00*000**
2019-06-03-11:44*085*+24*+000.1*00.00*0.00*000**
2019-06-01-16:18*073*+40*+000.5*00.00*0.00*000**,
IDE00062-ENG20489,History data 7-Life Cycle Data String,2019-06-15-13:57*065*+001.5*043.4*00.0*00.0**
2019-06-10-11:16*066*+002.3*122.8*00.0*00.0**
2019-06-08-15:42*070*+001.2*043.3*00.0*00.0**
2019-06-07-16:00*070*+000.4*023.7*00.0*00.0**
2019-06-07-15:47*068*+000.1*000.1*00.0*00.0**
2019-06-07-15:11*069*+000.0*000.5*00.0*00.0**
2019-06-07-14:51*070*+000.2*000.2*00.0*00.0**
2019-06-07-08:38*074*+000.3*006.1*00.0*00.0**
2019-06-03-11:50*077*+001.2*092.7*00.0*00.0**
2019-06-03-11:46*083*+000.2*000.0*00.0*00.0**,
IDE00063-ENG20489,History data 8-Life Cycle Data String,       0000006km*1*02*00*00*01*-------------:--*01**
2019-01-09-11:35*4*01*00*00*01*2011-01-01-00:43*01**
       0000000km*1*01*00*00*00*-------------:--*01**,
IDE00064-ENG20489,History data 9-Life Cycle Data String,       0000000km*000*000*000*000*00000*09.00*+00*00*01*00.00*00000*00000**
IDE00065-ENG20489,History data 10-Life Cycle Data String,-------------:--*-*---.-*----.-*-*---.-*----.-*--.--*-------**
IDE00066-ENG20489,History data 11-Life Cycle Data String,2019-06-10-11:01*000*000*000*015*0000*015*00.0*01.0*073*070*074*070*01*00002*00002*00002*00015*00028**
2019-06-08-15:41*000*000*000*001*0000*001*00.0*00.3*073*070*073*069*01**
2019-06-07-15:55*000*000*000*005*0000*005*00.0*00.5*071*067*072*068*01**
2019-06-07-15:46*000*000*000*001*0000*001*00.0*00.2*071*069*071*068*01**
2019-06-07-14:50*000*000*000*001*0000*001*00.0*00.3*075*073*075*073*01**,
IDE00067-ENG20489,History data 12-Life Cycle Data String,2019-05-07-13:48*0-0-0-1-0-0-1-0**
2019-05-07-13:47*0-0-0-1-0-0-1-0**
00000*00000*00000*00002*00000*00000*00002*00000**
IDE00068-ENG20489,History data 13-Life Cycle Data String,-------------:--*---------*---.-*-----**
IDE00069-ENG20489,History data 14-Life Cycle Data String,2019-06-17-09:51*1*00001*0000*0000*00.10*020001*+26*0002.1*0000.0*0000.0**
2019-06-17-09:49*3*00068*0000*0002*00.00*020001*+26**
2019-06-15-13:54*3*00163*0000*0002*00.00*020001*+24**
2019-06-10-11:01*3*00915*0000*0002*00.20*020001*+23**
2019-06-08-15:41*3*00084*0000*0003*00.00*020001*+24**
00152*00008*00017*00000*00000**
IDE00071-ENG20489,History data 16-Life Cycle Data String,       0000118km**
00010*00017*00059*00011*00000**
00060*00005*00002*00000**
00578*00006*00000*00000**
00075*00015*00003*00003**
00088*00007*00001**
00000*00000*00000*00000**
00012*00001*00000**
00001*00000*00000**
00002*00000*00000**
00001*00000*00001*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No malfunction detected,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not activated,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,Engaged ON,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not activated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Accelerate tap,not activated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not activated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not activated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not activated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,5,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,not activated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Delay tip level 2,not activated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,5,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,45,
IDE00767-ENG123029,No. of unscheduled ECU resets-Counter_Watchdog_Resets,0,
IDE00773,Terminal 15 status via CAN,On,
IDE01459,Energy management heat output control status,Stage 1,
IDE01805-ENG20489,History data 19-Life Cycle Data String,-------------:--*-----*---*---*---**
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.0, H
IDE01807-MAS00106,History data 21-Year,2000,
IDE01807-MAS00107,History data 21-Month,1,
IDE01807-MAS00108,History data 21-Day,1,
IDE01807-MAS00109,History data 21-Hours,0, H
IDE01807-MAS00110,History data 21-Minutes,0, min
IDE01807-MAS14375,History data 21-Cycle counter,0,
IDE01807-MAS14376,History data 21-ECU 1,Node_0x-- $-- (empty entry),
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.0, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,Node_0x-- $-- (empty entry),
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,Node_0x-- $-- (empty entry),
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01808-MAS03173,History data 22-Databus drivetrain,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.1, H
IDE01808-MAS03175,History data 22-Databus extended,0.1, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03177,History data 22-Databus Infotainment,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.1, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,Node_0x-- $-- (empty entry),
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,Node_0x-- $-- (empty entry),
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,Node_0x-- $-- (empty entry),
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,Node_0x-- $-- (empty entry),
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,Node_0x-- $-- (empty entry),
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,2.9, H
IDE01810-MAS00106,History data 24-Year,2019,
IDE01810-MAS00107,History data 24-Month,6,
IDE01810-MAS00108,History data 24-Day,15,
IDE01810-MAS00109,History data 24-Hours,16, H
IDE01810-MAS00110,History data 24-Minutes,54, min
IDE01810-MAS14375,History data 24-Cycle counter,104,
IDE01810-MAS14399,History data 24-CarWakeUp bit 1,0,
IDE01810-MAS14402,History data 24-CarWakeUp bit 2,0,
IDE01810-MAS14405,History data 24-CarWakeUp bit 3,0,
IDE01810-MAS14408,History data 24-CarWakeUp bit 4,0,
IDE01810-MAS14411,History data 24-CarWakeUp bit 5,0,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,49,
IDE01810-MAS14414,History data 24-ID of the alerting message 1,00 00 06 A6,
IDE01810-MAS14415,History data 24-Counter of the alerting message 1,3,
IDE01810-MAS14416,History data 24-Bus of the alerting message 1,Comfort data bus,
IDE01810-MAS14417,History data 24-ID of the alerting message 2,17 F0 00 09,
IDE01810-MAS14418,History data 24-Counter of the alerting message 2,2,
IDE01810-MAS14419,History data 24-Bus of the alerting message 2,Databus extended,
IDE01810-MAS14420,History data 24-ID of the alerting message 3,00 00 05 92,
IDE01810-MAS14421,History data 24-Counter of the alerting message 3,1,
IDE01810-MAS14422,History data 24-Bus of the alerting message 3,Comfort data bus,
IDE01810-MAS14423,History data 24-ID of the alerting message 4,00 00 00 00,
IDE01810-MAS14424,History data 24-Counter of the alerting message 4,0,
IDE01810-MAS14425,History data 24-Bus of the alerting message 4,Unknown,
IDE01810-MAS14426,History data 24-ID of the alerting message 5,00 00 00 00,
IDE01810-MAS14427,History data 24-Counter of the alerting message 5,0,
IDE01810-MAS14428,History data 24-Bus of the alerting message 5,Unknown,
IDE01812-MAS01468,History data 26-Terminal 15,103,
IDE01812-MAS03173,History data 26-Databus drivetrain,14,
IDE01812-MAS03174,History data 26-Comfort data bus,504,
IDE01812-MAS03175,History data 26-Databus extended,464,
IDE01812-MAS03177,History data 26-Databus Infotainment,0,
IDE01812-MAS03178,History data 26-Suspension data bus,8,
IDE01812-MAS03180,History data 26-Local data bus,1,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS14374,History data 26-Totals,991,
IDE01813-MAS03173,History data 27-Databus drivetrain,174,
IDE01813-MAS03174,History data 27-Comfort data bus,823,
IDE01813-MAS03175,History data 27-Databus extended,137,
IDE01813-MAS03177,History data 27-Databus Infotainment,24,
IDE01813-MAS03178,History data 27-Suspension data bus,98,
IDE01813-MAS14374,History data 27-Totals,1256,
IDE01814-MAS03173,History data 28-Databus drivetrain,0,
IDE01814-MAS03174,History data 28-Comfort data bus,984,
IDE01814-MAS03175,History data 28-Databus extended,0,
IDE01814-MAS03177,History data 28-Databus Infotainment,0,
IDE01814-MAS03178,History data 28-Suspension data bus,1,
IDE01814-MAS14374,History data 28-Totals,985,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.6, H
IDE01816-MAS00106,History data 30-Year,2011,
IDE01816-MAS00107,History data 30-Month,1,
IDE01816-MAS00108,History data 30-Day,1,
IDE01816-MAS00109,History data 30-Hours,0, H
IDE01816-MAS00110,History data 30-Minutes,38, min
IDE01816-MAS14375,History data 30-Cycle counter,10,
IDE01816-ENG20570,History data 30-Bus_1,Databus extended,
IDE01816-ENG20572,History data 30-Bus_2,Suspension data bus,
IDE01816-ENG20574,History data 30-Bus_3,Comfort data bus,
IDE01816-ENG20576,History data 30-Bus_4,Unknown,
IDE01816-ENG20578,History data 30-Bus_5,Unknown,
IDE01816-ENG20571,History data 30-Bus_Active_Time_1,0.2, H
IDE01816-ENG20573,History data 30-Bus_Active_Time_2,0.1, H
IDE01816-ENG20575,History data 30-Bus_Active_Time_3,0.1, H
IDE01816-ENG20577,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG20579,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.0, H
IDE01817-MAS00106,History data 31-Year,2000,
IDE01817-MAS00107,History data 31-Month,1,
IDE01817-MAS00108,History data 31-Day,1,
IDE01817-MAS00109,History data 31-Hours,0, H
IDE01817-MAS00110,History data 31-Minutes,0, min
IDE01817-MAS14375,History data 31-Cycle counter,0,
IDE01817-MAS14376,History data 31-ECU 1,Node_0x-- $-- (empty entry),
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.0, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,Node_0x-- $-- (empty entry),
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,Node_0x-- $-- (empty entry),
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,Node_0x-- $-- (empty entry),
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,Node_0x-- $-- (empty entry),
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,Node_0x-- $-- (empty entry),
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,2.9, H
IDE01819-MAS00106,History data 33-Year,2019,
IDE01819-MAS00107,History data 33-Month,6,
IDE01819-MAS00108,History data 33-Day,15,
IDE01819-MAS00109,History data 33-Hours,16, H
IDE01819-MAS00110,History data 33-Minutes,54, min
IDE01819-MAS14375,History data 33-Cycle counter,104,
IDE01819-MAS14393,History data 33-ID of the alerting message,00 00 06 A6,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,43.8, H
IDE01820-MAS00106,History data 34-Year,2019,
IDE01820-MAS00107,History data 34-Month,6,
IDE01820-MAS00108,History data 34-Day,17,
IDE01820-MAS00109,History data 34-Hours,9, H
IDE01820-MAS00110,History data 34-Minutes,49, min
IDE01820-MAS14375,History data 34-Cycle counter,104,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 32,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,0, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,105,
IDE01823-MAS14429,History data 37-Time in current cycle,0.1, H
IDE01827,Generator specified voltage value,14.6, V
IDE01828,Generator DF Signal,32.275, %
IDE01829,Generator exciter current,1.875, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,Electrical OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Valeo GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,120A - 180A MOSFET,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,1,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01834,Battery voltage,14.423, V
IDE01836,Battery current,8.624, A
IDE01837,Temperature of battery sensor,34, °C
IDE01838,Battery temperature,26, °C
IDE01839,Battery charge condition,71, %
IDE01841,Battery internal resistance,4.0, mOhm
IDE01842,Usable battery charge,66, Ah
IDE01843,Battery voltage at rest,12.4, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shutdown level,Deactivation stage 0,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Previous journey energy summary,1.3, Ah
IDE01849,Previous journey duration,0.1, H
IDE01852,Static current measurement: result,Initializing,
IDE01853,Static current measurement: status,Cancel,
IDE01854,Energy reclamation request,not active,
IDE01855,Generator current,43.4, A
IDE01948,Battery internal resistance not normed,4.2, mOhm
IDE01985-ENG101043,FAZIT identification test sum-Checksum,F3 17 0A 74,
IDE01985-ENG99027,FAZIT identification test sum-Version,129,
IDE02578-ENG06041,Play protection status-fiddle_proofing_1,not active,
IDE02578-ENG06043,Play protection status-fiddle_proofing_2,not active,
IDE02578-ENG06044,Play protection status-fiddle_proofing_3,not active,
IDE02578-ENG06045,Play protection status-fiddle_proofing_4,not active,
IDE02578-ENG06046,Play protection status-fiddle_proofing_5,not active,
IDE02578-ENG06047,Play protection status-fiddle_proofing_6,not active,
IDE02578-ENG06048,Play protection status-fiddle_proofing_7,not active,
IDE02578-ENG06049,Play protection status-fiddle_proofing_8,not active,
IDE02578-ENG06042,Play protection status-function_calls_counter_1,0,
IDE02578-ENG06050,Play protection status-function_calls_counter_2,0,
IDE02578-ENG06051,Play protection status-function_calls_counter_3,0,
IDE02578-ENG06052,Play protection status-function_calls_counter_4,0,
IDE02578-ENG06053,Play protection status-function_calls_counter_5,0,
IDE02578-ENG06054,Play protection status-function_calls_counter_6,0,
IDE02578-ENG06055,Play protection status-function_calls_counter_7,0,
IDE02578-ENG06056,Play protection status-function_calls_counter_8,0,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS02193,Stop process prevented-Outside air temperature,not active,
IDE03008-MAS04054,Stop process prevented-Consumer current too high,not active,
IDE03008-MAS04055,Stop process prevented-Usable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery charge condition too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible service life too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03009-MAS01478,Start process requested-Insuff. voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04054,Start process requested-Consumer current too high,not active,
IDE03009-MAS04055,Start process requested-Usable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery charge condition too low,not active,
IDE03009-MAS04058,Start process requested-Service life expired,not active,
IDE03009-MAS06003,Start process requested-Charging contingent,not active,
IDE03009-MAS06004,Start process requested-Special start requirements,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,0,
IDE03010-IDE01844,Number of prevented stop processes-Increase idle speed request,0,
IDE03010-MAS02193,Number of prevented stop processes-Outside air temperature,0,
IDE03010-MAS04054,Number of prevented stop processes-Consumer current too high,0,
IDE03010-MAS04055,Number of prevented stop processes-Usable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery charge condition too low,2,
IDE03010-MAS04062,Number of prevented stop processes-Possible service life too short,2,
IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,0,
IDE03011-MAS01478,Number of requested start processes-Insuff. voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04054,Number of requested start processes-Consumer current too high,0,
IDE03011-MAS04055,Number of requested start processes-Usable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery charge condition too low,0,
IDE03011-MAS04058,Number of requested start processes-Service life expired,0,
IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,0,
IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2019,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,5,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,7,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,13,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,48,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,47,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,38,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,53,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,no measured value present,
IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,Battery charge condition too low,
IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,Possible service life too short,
IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,Battery charge condition too low,
IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,Possible service life too short,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,no measured value present,
IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,no measured value present,
IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,no measured value present,
IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,no measured value present,
IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,no measured value present,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03256-MAS06105,Battery adaptation-Rated battery capacity,70, Ah
IDE03256-MAS06106,Battery adaptation-Battery technology,EFB+,
IDE03256-MAS06107,Battery adaptation-Battery manufacturer,MLA,
IDE03256-MAS06108,Battery adaptation-Battery Serial Number,1111111111,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery malfunction,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04186,Battery terminal recognition,connected,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,present,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,Yes,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,invalid,
IDE04332,Release code for a SWaP function,2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,
IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04806-ENG06028,Driving profile selection button-Driving_Profile_Selection_Button_1,not activated,
IDE04806-ENG06029,Driving profile selection button-Driving_Profile_Selection_Button_2,not activated,
IDE04806-ENG06030,Driving profile selection button-Driving_Profile_Selection_Button_3,not activated,
IDE04806-ENG06031,Driving profile selection button-Driving_Profile_Selection_Button_4,not activated,
IDE04806-ENG06032,Driving profile selection button-Driving_Profile_Selection_Button_5,not activated,
IDE04806-ENG06033,Driving profile selection button-Driving_Profile_Selection_Button_6,not activated,
IDE04806-ENG06034,Driving profile selection button-Driving_Profile_Selection_Button_7,not activated,
IDE04806-ENG06035,Driving profile selection button-Driving_Profile_Selection_Button_8,not activated,
IDE05583-IDE02766,Pause recommendation-Malfunction status,not installed,
IDE05583-MAS03095,Pause recommendation-Function status,not installed,
IDE05583-MAS04622,Pause recommendation-Break recommend. message,No message,
IDE05583-MAS13162,Pause recommendation-Icon deactivated,No,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG05007,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG05008,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG05009,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG05010,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG05011,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG05012,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG05013,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG05014,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,97 5A 29 1B 5F,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,0,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,no entry,
IDE06007-MAS00106,Driving profile history data 1-Year,2000,
IDE06007-MAS00107,Driving profile history data 1-Month,0,
IDE06007-MAS00108,Driving profile history data 1-Day,0,
IDE06007-MAS00109,Driving profile history data 1-Hours,0,
IDE06007-MAS00110,Driving profile history data 1-Minutes,0,
IDE06007-MAS00111,Driving profile history data 1-Seconds,0,
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initializing,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,0,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,no entry,
IDE06008-MAS00106,Driving profile history data 2-Year,2000,
IDE06008-MAS00107,Driving profile history data 2-Month,0,
IDE06008-MAS00108,Driving profile history data 2-Day,0,
IDE06008-MAS00109,Driving profile history data 2-Hours,0,
IDE06008-MAS00110,Driving profile history data 2-Minutes,0,
IDE06008-MAS00111,Driving profile history data 2-Seconds,0,
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initializing,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,0,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,Transmission Control Module (TCM),
IDE06009-MAS00106,Driving profile history data 3-Year,2000,
IDE06009-MAS00107,Driving profile history data 3-Month,0,
IDE06009-MAS00108,Driving profile history data 3-Day,0,
IDE06009-MAS00109,Driving profile history data 3-Hours,0,
IDE06009-MAS00110,Driving profile history data 3-Minutes,0,
IDE06009-MAS00111,Driving profile history data 3-Seconds,0,
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initializing,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,0,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,Engine Control Module (ECM),
IDE06010-MAS00106,Driving profile history data 4-Year,2000,
IDE06010-MAS00107,Driving profile history data 4-Month,0,
IDE06010-MAS00108,Driving profile history data 4-Day,0,
IDE06010-MAS00109,Driving profile history data 4-Hours,0,
IDE06010-MAS00110,Driving profile history data 4-Minutes,0,
IDE06010-MAS00111,Driving profile history data 4-Seconds,0,
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initializing,
IDE06011-ENG04999,Selected driving profile-driving_profile_1,Dynamic,
IDE06011-ENG05000,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG05001,Selected driving profile-driving_profile_3,no function,
IDE06011-ENG05002,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG05003,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG05004,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG05005,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG05006,Selected driving profile-driving_profile_8,no function,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0,
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,25,
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,43,
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,2,
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,276,
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0,
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0,
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,1,
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0,
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0,
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0,
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0,
IDE06230-MAS00106,Break recommend.: last message-Year,2000,
IDE06230-MAS00107,Break recommend.: last message-Month,0,
IDE06230-MAS00108,Break recommend.: last message-Day,0,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initializing,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,not activated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,not engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,76,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,not engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,23,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,not engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,5,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,2,
IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
IDE07473-MAS06306,Generator limitation-Status generator release by engine,Request by Engine Control Module,
IDE07473-MAS06307,Generator limitation-Status of battery charging function,not active,
IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07616,Battery degradation for start/stop - operation,Phase 1,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stoppage time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,25, A
IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,14.4, V
IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,15.0, V
IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,Enabled,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,blocked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,Enabled,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in permissible range,
IDE07637,Current charge contingent for feedback,4680.0, As
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,8.90,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognized,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognized,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,3.30, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,3.35, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,976, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,968, A
IDE07681-MAS06086,Battery total charging throughput-Total re-charge,71.8, Ah
IDE07681-MAS06087,Battery total charging throughput-Total energy throughput,74.2, Ah
IDE07873-MAS06193,FPA enabled profiles-Profile 1,Not Used,
IDE07873-MAS06194,FPA enabled profiles-Profile 2,AUTO,
IDE07873-MAS06195,FPA enabled profiles-Profile 3,Dynamic,
IDE07873-MAS06196,FPA enabled profiles-Profile 4,Offroad,
IDE07873-MAS06197,FPA enabled profiles-Profile 5,Not Used,
IDE07873-MAS06198,FPA enabled profiles-Profile 6,Not Used,
IDE07873-MAS06199,FPA enabled profiles-Profile 7,Not Used,
IDE07873-MAS06200,FPA enabled profiles-Profile 8,Not Used,
IDE07873-MAS08875,FPA enabled profiles-Profile 9,Not Used,
IDE07873-MAS08876,FPA enabled profiles-Profile 10,Not Used,
IDE07873-MAS08877,FPA enabled profiles-Profile 11,Not Used,
IDE07873-MAS08878,FPA enabled profiles-Profile 12,Not Used,
IDE07907,Bus communication,active,
IDE08343,Immobilizer Challenge,80 71 12 53,
IDE08346-MAS06117,Generator Analysis-Rated voltage,14.6, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,14.6, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.2, V
IDE08346-MAS06866,Generator Analysis-Generator speed,564, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,68, °C
IDE08347,adapted battery capacity,117, Ah
IDE08680-MAS03173,Allocation data bus identifier-Databus drivetrain,11,
IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
IDE08680-MAS03175,Allocation data bus identifier-Databus extended,15,
IDE08680-MAS03177,Allocation data bus identifier-Databus Infotainment,13,
IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
IDE08681-MAS03173,Data bus defect error-Databus drivetrain,OK,
IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
IDE08681-MAS03175,Data bus defect error-Databus extended,OK,
IDE08681-MAS03177,Data bus defect error-Databus Infotainment,OK,
IDE08681-MAS03178,Data bus defect error-Suspension data bus,OK,
IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
IDE08682-MAS03173,Data bus single wire err.-Databus drivetrain,OK,
IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
IDE08682-MAS03175,Data bus single wire err.-Databus extended,OK,
IDE08682-MAS03177,Data bus single wire err.-Databus Infotainment,OK,
IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,OK,
IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
IDE08683-MAS03173,Data bus TimeOut error-Databus drivetrain,OK,
IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
IDE08683-MAS03175,Data bus TimeOut error-Databus extended,OK,
IDE08683-MAS03177,Data bus TimeOut error-Databus Infotainment,OK,
IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,OK,
IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
IDE08684-SFT09757,Allocation LIN system number-Alternator,00 1D,
IDE08684-SFT09777,Allocation LIN system number-Multi Function Steering Wheel Control Module,00 31,
IDE08684-SFT09783,Allocation LIN system number-Battery Monitoring Control Module,00 37,
IDE08684-SFT09833,Allocation LIN system number-Power Converter DC AC,00 69,
IDE08684-SFT09842,Allocation LIN system number-Analog clock,00 72,
IDE08684-SFT10031,Allocation LIN system number-Operating Unit Drive Mode Selection,01 2F,
IDE08684-SFT10046,Allocation LIN system number-Control module for steering wheel touch recognition,01 3E,
IDE08685-SFT09757,Status LIN user-Alternator,active,
IDE08685-SFT09777,Status LIN user-Multi Function Steering Wheel Control Module,active,
IDE08685-SFT09783,Status LIN user-Battery Monitoring Control Module,active,
IDE08685-SFT09833,Status LIN user-Power Converter DC AC,active,
IDE08685-SFT09842,Status LIN user-Analog clock,not active,
IDE08685-SFT10031,Status LIN user-Operating Unit Drive Mode Selection,active,
IDE08685-SFT10046,Status LIN user-Control module for steering wheel touch recognition,not active,
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initializing,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE09561,Closed-circuit current of last LIN sleep phase,-4.151, A
IDE09562,Range extension counter: stage 2,0,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,OK,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,8,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11573,Energy management in heating power allocation,1000, W
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initializing,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initializing,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initializing,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initializing,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery Energy Control Module 2,not active,
IDE11911-SFT00196,48V activation restriction-DC/DC Converter Control Module,not active,
IDE11911-SFT09769,48V activation restriction-Control module for auxiliary air heater,not active,
IDE11911-SFT09997,48V activation restriction-Electrical Charger,not active,
IDE12084,Status of component protection slaves,00 14 19 00 00 00 0E 13 00 00 00 57 13 00 00 00 15 11 00 00 00 6F 11 00 00 00 6D 20 00 00 00 73 11 00 00 00 4E 20 00 00 00 8A 20 00 00 00 2C 20 00 00 00 4F 20 00 00 00 7B 20 00 00,
IDE12133-MAS01896,Freewheel - energy-Free run,25, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,Maximum charge DC/DC converter,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Freewheel engine off block,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12135-MAS14363,Belt driven starter generator 12V-Specified voltage: lower limit,10.80, V
IDE12135-MAS14364,Belt driven starter generator 12V-Specified voltage limit,10.60, V
IDE12135-MAS14365,Belt driven starter generator 12V-Recommended specified voltage,10.6, V
IDE12135-MAS14366,Belt driven starter generator 12V-Maximum ramp time,0, s
IDE12135-MAS14367,Belt driven starter generator 12V-Minimum voltage for start,7.0, V
IDE12135-MAS14368,Belt driven starter generator 12V-Specified voltage of the belt driven starter generator,9.0, V
IDE12135-MAS14369,Belt driven starter generator 12V-Actual mode belt driven starter generator,Unknown (14),
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,254,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,254,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,254,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,Initializing,
IDE14424,Historical data info status,00000110 ,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,17,
MAS00464-MAS00109,Standard - ambient data 1-Hours,9,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,56,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,41,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,11,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,118, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,not activated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,not activated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,9,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Signal horn,not activated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,11,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,not activated,
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS01493,Engine running status-Engine running,Engine running,
MAS04447-MAS03023,Engine running status-Driving mode,Driving mode,
MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
SFT09757,Alternator,-,
SFT09757-ENG119789,Alternator-alternator_family,31,
SFT09757-ENG114913,Alternator-asic_manufacturer,30 31,
SFT09757-ENG119379,Alternator-asic_variant,30 34,
SFT09757-ENG40398,Alternator-Manufacturer,30 31,
SFT09757-ENG99001,Alternator-Variant,30 65,
ENG118785-ENG118741,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Error_Indication,0,
ENG118785-ENG118742,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Indication_State,0,
ENG118785-ENG118743,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State,0,
ENG118785-ENG118744,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State_Value,0,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG06039,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG06040,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG20970,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG06038,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,not active,
ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG06036,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG06057,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,2,
ENG118786-ENG06058,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,2,
ENG118786-ENG06061,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG06063,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG06062,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG06060,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG06059,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not recognized,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognized,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,active,
ENG06004-ENG118763,EM_battery_analog_monitoring-actual_difference_voltage,0.000, V
ENG06004-ENG118760,EM_battery_analog_monitoring-battery_analog_voltage,0.0, V
ENG06004-ENG118765,EM_battery_analog_monitoring-battery_off_counter,0,
ENG06004-ENG118764,EM_battery_analog_monitoring-battery_off_status_intern,connected,
ENG06004-ENG118761,EM_battery_analog_monitoring-battery_voltage_filtered,13.5, V
ENG06004-ENG118762,EM_battery_analog_monitoring-voltage_difference,0.00, V
ENG106123,EM_blAlternator On,On,
ENG106124,EM_blAlternator Valid,Yes,
ENG106140,EM_Current_Control_Recu,not active,
ENG20108,EM_electrical_system_current,39.493, A
ENG118437,EM_IAlternatorReserve,176.6, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,850, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,99, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,94, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG115189,EM_Recuperation_Precondition-48V_emergency_run,0,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,1,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,1,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,1,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,1,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,0,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,1,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,1,
ENG118780-ENG36229,EM_Recuperation_Precondition-climate_electronics_enable,1,
ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,1,
ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,1,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,1,
ENG118780-ENG36251,EM_Recuperation_Precondition-kfg_enable,1,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,1,
ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,1,
ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,0,
ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
ENG118781-ENG121521,EM_Recuperation_Restriction-limited_by_48V_consumer,0,
ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,0,
ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,0,
ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
ENG118781-ENG36309,EM_Recuperation_Restriction-voltage_requirement_bcm,0,
ENG118781-ENG36310,EM_Recuperation_Restriction-voltage_Requirement_kfg,0,
ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,1005,
ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,2015,
ENG118782-ENG06026,Gateway app. software identification-software_version_ehr,----,
ENG118782-ENG118454,Gateway app. software identification-software_version_em,2204,
ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,9060,
ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0700,
ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,----,
ENG118782-ENG118456,Gateway app. software identification-software_version_ks,----,
ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,0200,
ENG118782-ENG118463,Gateway app. software identification-software_version_mke,3148,
ENG118782-ENG32644,Gateway app. software identification-software_version_mv-em,0300,
ENG118782-ENG32645,Gateway app. software identification-software_version_rtm,----,
ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,----,
ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0630,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0100,
ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7190,
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60039,
ENG20113-ENG09375,MV-EM_48V_electrical_system_components-48V_Ptc_installed,not installed,
ENG20113-ENG09374,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG20113-ENG09370,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG20113-ENG09372,MV-EM_48V_electrical_system_components-eAbc_installed,not installed,
ENG20113-ENG09373,MV-EM_48V_electrical_system_components-eAv_installed,not installed,
ENG20113-ENG09371,MV-EM_48V_electrical_system_components-eAws_installed,not installed,
ENG20113-ENG09369,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG20113-ENG09368,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG20114-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK,
ENG20114-ENG09348,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG20114-ENG09349,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG20115-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK,
ENG20115-ENG09351,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG20115-ENG09344,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG20115-ENG09352,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,Initializing,
ENG20115-ENG09356,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_back_48V_actual_voltage,0.00, V
ENG20115-ENG09355,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_front_48V_actual_voltage,0.00, V
ENG20115-ENG09357,MV-EM_48V_electrical_system_diagnosis_typ_2-eAv_48V_actual_voltage,0.00, V
ENG20115-ENG09354,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_back_48V_actual_voltage,0.00, V
ENG20115-ENG09353,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_front_48V_actual_voltage,0.00, V
ENG20115-ENG09358,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltag,Initializing,
ENG20116-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK,
ENG20116-ENG09344,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG20116-ENG09345,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0.00, %
ENG20117-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initializing,
ENG20118-ENG09366,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG20118-ENG09367,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG20119,MV-EM_dc_current_Mv,-204.0, A
ENG20120,MV-EM_dc_power_desired,-6325, W
ENG20121,MV-EM_DC_voltage_desired,0.00, V
ENG20122,MV-EM_dc_voltage_Mv,0.00, V
ENG20123-ENG09198,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG20123-ENG09199,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG20123-ENG09200,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG20123-ENG09337,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG20124,MV-EM_EMG_level_of_capacity,0.025, %
ENG20125,MV-EM_Mv_current,-511, A
ENG20126-ENG09342,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG20126-ENG09343,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG20127-ENG09338,MV-EM_release-12V_coldstart_release,No enabling,
ENG20127-ENG09339,MV-EM_release-12V_warmstart_release,No enabling,
ENG20127-ENG09340,MV-EM_release-48V_coldstart_release,No enabling,
ENG20127-ENG09341,MV-EM_release-start_stopp_support_release,No enabling,
ENG20128,MV-EM_RSG_maximal_current,0, A
ENG20129,MV-EM_RSG_maximal_voltage,0.00, V
Elapsed Time: 00:48
22:
;SW:0CQ-907-554-J   HW:0CQ-525-130 ---  AWD
;Component:Haldex4Motion H55 7084, Coding:0301
;EV_AllWheelContrHA1VW37X,004013,EV_AllWheelContrHA1VW37X_004.rod
;Monday,17,June,2019,11:02:14:34333
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: CCD42986674D8A2FB9-8098
Group,Description,Actual
IDE00019,Voltage terminal 30,14.4, V
IDE00030,Status of actuator test,not active,
IDE00102,Control Module temperature,32, °C
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00920,Front left wheel speed,0.0, km/h
IDE00921,Front right wheel speed,0.0, km/h
IDE00922,Left rear wheel speed,0.0, km/h
IDE00923,Right rear wheel speed,0.0, km/h
IDE01617,Clutch temperature,32.40, °C
IDE02271-IDE02384,CAN output signal(s) status-Status of event memory,not active,
IDE02271-MAS01464,CAN output signal(s) status-Emergency running mode,not active,
IDE02271-MAS01480,CAN output signal(s) status-Excess temp.,not active,
IDE02404,Checksum calculation,DA BD 2A 9E,
IDE02486,Data logger triggering,not active,
IDE04502-MAS04730,Haldex clutch status-Degree of blockage,0.00, %
IDE05609,Cooling fin temperature,28.90, °C
IDE05610,Duration of overtemperature,0, min
IDE05707,Haldex clutch pump current,0.044, A
IDE05708,Haldex clutch pump PWM signal,0, %
IDE05710,Haldex clutch pump voltage,0.0, V
IDE06111,Axle speed deltas,0.0, km/h
IDE12115,Pumps diagnostic: number of tests during service life,0,
IDE12116,Pumps diagnostic: anomalies during service life,0,
IDE12117,Pump diagnostic: anomalies in current driving cycle,0,
IDE12118,Pump diagnostic: total of defined anomalies,0,
IDE80003-ENG119372,Analysis 3-Exeedance_Intergral_1_traction_slip_controller,0,
IDE80003-ENG119373,Analysis 3-Exeedance_Intergral_2_extreme_slip_event,0,
IDE80003-ENG119374,Analysis 3-Undercut_Integral_3_differential_lock_too_far_closed,0,
IDE80004-ENG119372,Analysis 4-Exeedance_Intergral_1_traction_slip_controller,0,
IDE80004-ENG119373,Analysis 4-Exeedance_Intergral_2_extreme_slip_event,0,
IDE80004-ENG119374,Analysis 4-Undercut_Integral_3_differential_lock_too_far_closed,0,
MAS00464-MAS00109,Standard - ambient data 1-Hours,10,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,1,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,23,
MAS03129,Reset counter,8,
ENG119394-ENG119379,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_EEPROM,1564,
ENG119394-ENG119380,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_Last_Measurement,0,
ENG119394-ENG119378,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Pressure_EEPROM,1,
ENG119394-ENG119381,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_EEPROM,2241,
ENG119394-ENG119382,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_Last_Measurement,0,
ENG119394-ENG119384,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_EEPROM,4689,
ENG119394-ENG119385,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_Interpolation,0,
ENG119394-ENG119383,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Pressure_EEPROM,14,
ENG119394-ENG119386,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_EEPROM,4958,
ENG119394-ENG119387,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_Interpolation,0,
ENG119394-ENG119389,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_EEPROM,9169,
ENG119394-ENG119390,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_Last_Measurement,0,
ENG119394-ENG119388,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Pressure_EEPROM,35,
ENG119394-ENG119391,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_EEPROM,7561,
ENG119394-ENG119392,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_Last_Measurement,0,
ENG119394-ENG119377,Pump_Calibration_Values-Series_Number_Pump,11116928,
ENG119394-ENG119376,Pump_Calibration_Values-Temperature_Value_at_Calibration,28, °C
ENG119375,Upper Limit of Temperature Duration,0, min
Elapsed Time: 00:04
2B:
;SW:3Q0-905-861-B   HW:3Q0-905-861-B ---  Steer. Col. Lock
;Component:ELV-MQBB      H05 0020, Coding:0800000000000000
;EV_ELVMarqMQBA0,002002,EV_ELVMarqMQBA0_VW41.rod
;Monday,17,June,2019,11:02:20:34333
;VCID: B326527A1AB3F5D7D8-80E6
IDE00019,Voltage terminal 30,14.3,
IDE00021,Engine speed,891.50, /min
IDE00021-MAS00058,Engine speed-Implausible,No,
IDE00021-MAS00103,Engine speed-invalid,No,
IDE00021-MAS02239,Engine speed-obsolete,No,
IDE00021-MAS02246,Engine speed-Timeout,No,
IDE00075,Vehicle speed,0.00, km/h
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-obsolete,No,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,OK,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,1,
IDE01766-MAS03715,Distance impulses-Right front wheel,0,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,not activated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,locked,
IDE02580,Number of unlocks,84,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,Open,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine speed,Condition not met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-MAS08251,Locking requirements-Communication status signal ESP_21,Condition met,
IDE06746-MAS08252,Locking requirements-Communication status signal Klemmenstatus_01,Condition not met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Cyclical Reception Signal ESP_21,Condition met,
IDE06746-MAS08792,Locking requirements-Cyclical Reception Signal ESP_10,Condition met,
IDE06746-MAS08794,Locking requirements-Cyclical Reception Signal Terminal Status_01,Condition met,
IDE06746-MAS11697,Locking requirements-Communication status signal ESP_10,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,31,
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG31613,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG31614,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128820,Free_Releases_Numbers,255,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Confirmed,
Elapsed Time: 00:04
36:
;SW:5Q0-959-760-C   HW:5Q0-959-760-C ---  Seat Mem. Drvr
;Component:Sitzmemory    H09 0024, Coding:0010000000000500018280808080000000008100000000F400
;EV_SeatMemorDriveSide,002022,EV_SeatMemorDriveSide.rod
;Monday,17,June,2019,11:02:27:34333
;VCID: BD3274422CF733A73E-80E8
IDE00019-MAS00043,Voltage terminal 30-Supply voltage: Terminal 30,14.4, V
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE03527-MAS03679,CAN signals-Terminal 15 status,On,
IDE03527-ENG123093,CAN signals-Memory_Adjustment,not active,
IDE03527-ENG123094,CAN signals-MemoryButton_Pressed,not active,
IDE03527-ENG123095,CAN signals-V_Signal_less_ 5kmh_more_5kmh,not active,
IDE06510-MAS01390,Backrest inclination adjustment-Block 1,22413,
IDE06510-MAS01391,Backrest inclination adjustment-Block 2,32645,
IDE06510-MAS02282,Backrest inclination adjustment-Position,29147,
IDE06510-MAS02955,Backrest inclination adjustment-Engine temperature,0, °C
IDE06510-MAS03129,Backrest inclination adjustment-Reset counter,41,
IDE06510-MAS04160,Backrest inclination adjustment-Load change,42,
IDE06510-MAS04337,Backrest inclination adjustment-Engine current,0, dez
IDE06510-MAS05370,Backrest inclination adjustment-Direction of movement,not activated,
IDE06510-MAS05563,Backrest inclination adjustment-Norming,normed,
IDE06510-MAS05719,Backrest inclination adjustment-Maximum travel,10232,
IDE06511-MAS01390,Seat height adjustment-Block 1,27864,
IDE06511-MAS01391,Seat height adjustment-Block 2,32537,
IDE06511-MAS02282,Seat height adjustment-Position,32406,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,0, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,49,
IDE06511-MAS04160,Seat height adjustment-Load change,50,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, dez
IDE06511-MAS05370,Seat height adjustment-Direction of movement,not activated,
IDE06511-MAS05563,Seat height adjustment-Norming,normed,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,4600,
IDE06512-MAS01390,Seat forward/back position adjustment-Block 1,27738,
IDE06512-MAS01391,Seat forward/back position adjustment-Block 2,36314,
IDE06512-MAS02282,Seat forward/back position adjustment-Position,30186,
IDE06512-MAS02955,Seat forward/back position adjustment-Engine temperature,0, °C
IDE06512-MAS03129,Seat forward/back position adjustment-Reset counter,76,
IDE06512-MAS04160,Seat forward/back position adjustment-Load change,79,
IDE06512-MAS04337,Seat forward/back position adjustment-Engine current,0, dez
IDE06512-MAS05370,Seat forward/back position adjustment-Direction of movement,not activated,
IDE06512-MAS05563,Seat forward/back position adjustment-Norming,normed,
IDE06512-MAS05719,Seat forward/back position adjustment-Maximum travel,8400,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS05766,Memory seat adjustment control head-Status of button for seat position storing,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,29992,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,31944,
IDE06683-MAS02282,Seat inclination adjustment-Position,30923,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,0, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,48,
IDE06683-MAS04160,Seat inclination adjustment-Load change,49,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, dez
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,not activated,
IDE06683-MAS05563,Seat inclination adjustment-Norming,normed,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,1960,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,65535,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,65535,
IDE06684-MAS02282,Lumbar support height adjustment-Position,30000,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,0, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,0,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,0,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, dez
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,not activated,
IDE06684-MAS05563,Lumbar support height adjustment-Norming,never normed,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,3200,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,29504,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,32704,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,30940,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,0, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,12,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,13,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, dez
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,not activated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Norming,normed,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,3200,
IDE06871-IDE06510,Seat adjustment control head-Backrest inclination adjustment,not activated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,not activated,
IDE06871-IDE06512,Seat adjustment control head-Seat forward/back position adjustment,not activated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,not activated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,not activated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,not activated,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Backrest inclination adjustment,30207,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,28682,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Seat forward/back position adjustment,30912,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,30063,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,30000,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,29600,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Backrest inclination adjustment,65535,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,65535,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Seat forward/back position adjustment,65535,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,65535,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,65535,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,65535,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Backrest inclination adjustment,65535,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,65535,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Seat forward/back position adjustment,65535,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,65535,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,65535,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,65535,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Backrest inclination adjustment,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Seat forward/back position adjustment,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Backrest inclination adjustment,29147,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,32399,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Seat forward/back position adjustment,30186,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,30923,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,30000,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,30940,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Backrest inclination adjustment,65535,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,65535,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Seat forward/back position adjustment,65535,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,65535,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,65535,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,65535,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Backrest inclination adjustment,65535,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,65535,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Seat forward/back position adjustment,65535,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,65535,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,65535,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,65535,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Backrest inclination adjustment,65535,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,65535,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Seat forward/back position adjustment,65535,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,65535,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,65535,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,65535,
IDE11195-IDE06510,Memory setting: user account 1 for seat adjustment-Backrest inclination adjustment,29147,
IDE11195-IDE06511,Memory setting: user account 1 for seat adjustment-Seat height adjustment,32399,
IDE11195-IDE06512,Memory setting: user account 1 for seat adjustment-Seat forward/back position adjustment,30186,
IDE11195-IDE06683,Memory setting: user account 1 for seat adjustment-Seat inclination adjustment,30923,
IDE11195-IDE06684,Memory setting: user account 1 for seat adjustment-Lumbar support height adjustment,30000,
IDE11195-IDE06685,Memory setting: user account 1 for seat adjustment-Lumbar support longitudinal position adjustment,30940,
IDE11196-IDE06510,Memory setting: user account 2 for seat adjustment-Backrest inclination adjustment,65535,
IDE11196-IDE06511,Memory setting: user account 2 for seat adjustment-Seat height adjustment,65535,
IDE11196-IDE06512,Memory setting: user account 2 for seat adjustment-Seat forward/back position adjustment,65535,
IDE11196-IDE06683,Memory setting: user account 2 for seat adjustment-Seat inclination adjustment,65535,
IDE11196-IDE06684,Memory setting: user account 2 for seat adjustment-Lumbar support height adjustment,65535,
IDE11196-IDE06685,Memory setting: user account 2 for seat adjustment-Lumbar support longitudinal position adjustment,65535,
IDE11197-IDE06510,Memory setting: user account 3 for seat adjustment-Backrest inclination adjustment,65535,
IDE11197-IDE06511,Memory setting: user account 3 for seat adjustment-Seat height adjustment,65535,
IDE11197-IDE06512,Memory setting: user account 3 for seat adjustment-Seat forward/back position adjustment,65535,
IDE11197-IDE06683,Memory setting: user account 3 for seat adjustment-Seat inclination adjustment,65535,
IDE11197-IDE06684,Memory setting: user account 3 for seat adjustment-Lumbar support height adjustment,65535,
IDE11197-IDE06685,Memory setting: user account 3 for seat adjustment-Lumbar support longitudinal position adjustment,65535,
IDE11198-IDE06510,Memory setting: user account 4 for seat adjustment-Backrest inclination adjustment,65535,
IDE11198-IDE06511,Memory setting: user account 4 for seat adjustment-Seat height adjustment,65535,
IDE11198-IDE06512,Memory setting: user account 4 for seat adjustment-Seat forward/back position adjustment,65535,
IDE11198-IDE06683,Memory setting: user account 4 for seat adjustment-Seat inclination adjustment,65535,
IDE11198-IDE06684,Memory setting: user account 4 for seat adjustment-Lumbar support height adjustment,65535,
IDE11198-IDE06685,Memory setting: user account 4 for seat adjustment-Lumbar support longitudinal position adjustment,65535,
IDE11199-IDE06510,Memory setting: user account 5 for seat adjustment-Backrest inclination adjustment,65535,
IDE11199-IDE06511,Memory setting: user account 5 for seat adjustment-Seat height adjustment,65535,
IDE11199-IDE06512,Memory setting: user account 5 for seat adjustment-Seat forward/back position adjustment,65535,
IDE11199-IDE06683,Memory setting: user account 5 for seat adjustment-Seat inclination adjustment,65535,
IDE11199-IDE06684,Memory setting: user account 5 for seat adjustment-Lumbar support height adjustment,65535,
IDE11199-IDE06685,Memory setting: user account 5 for seat adjustment-Lumbar support longitudinal position adjustment,65535,
IDE11200-IDE06510,Memory setting: user account 6 for seat adjustment-Backrest inclination adjustment,65535,
IDE11200-IDE06511,Memory setting: user account 6 for seat adjustment-Seat height adjustment,65535,
IDE11200-IDE06512,Memory setting: user account 6 for seat adjustment-Seat forward/back position adjustment,65535,
IDE11200-IDE06683,Memory setting: user account 6 for seat adjustment-Seat inclination adjustment,65535,
IDE11200-IDE06684,Memory setting: user account 6 for seat adjustment-Lumbar support height adjustment,65535,
IDE11200-IDE06685,Memory setting: user account 6 for seat adjustment-Lumbar support longitudinal position adjustment,65535,
IDE11201-IDE06510,Memory setting: user account 7 for seat adjustment-Backrest inclination adjustment,65535,
IDE11201-IDE06511,Memory setting: user account 7 for seat adjustment-Seat height adjustment,65535,
IDE11201-IDE06512,Memory setting: user account 7 for seat adjustment-Seat forward/back position adjustment,65535,
IDE11201-IDE06683,Memory setting: user account 7 for seat adjustment-Seat inclination adjustment,65535,
IDE11201-IDE06684,Memory setting: user account 7 for seat adjustment-Lumbar support height adjustment,65535,
IDE11201-IDE06685,Memory setting: user account 7 for seat adjustment-Lumbar support longitudinal position adjustment,65535,
IDE11202,Current seat position matches customer request position,active,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,40,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,Key 1,
ENG123055-ENG123091,Seat_Adjustment_Remote_Control_Locking_Info_CAN-DoorContact_more_than_10min_opened,active,
ENG123055-ENG123092,Seat_Adjustment_Remote_Control_Locking_Info_CAN-DoorContact_NotActive_Active,operated,
ENG123055-ENG123088,Seat_Adjustment_Remote_Control_Locking_Info_CAN-FFB_Close_Button,not active,
ENG123055-ENG123087,Seat_Adjustment_Remote_Control_Locking_Info_CAN-FFB_Open_Button,not active,
ENG123055-ENG123089,Seat_Adjustment_Remote_Control_Locking_Info_CAN-FT_lock,not active,
ENG123055-ENG123090,Seat_Adjustment_Remote_Control_Locking_Info_CAN-FT_locked,not locked,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,key_signal_1,
ENG123052-MAS01478,Seat_Adjustment_Reset_Status-Insuff. voltage,not active,
ENG123052-MAS03129,Seat_Adjustment_Reset_Status-Reset counter,0,
ENG123052-MAS03945,Seat_Adjustment_Reset_Status-Watchdog Reset,not active,
ENG123052-ENG123073,Seat_Adjustment_Reset_Status-Low_Voltage_At_Run_Up,not active,
ENG123052-ENG123072,Seat_Adjustment_Reset_Status-Power_On_Reset,not active,
ENG123052-ENG123071,Seat_Adjustment_Reset_Status-Software_Reset_by_diagnosis,not active,
ENG123052-ENG123074,Seat_Adjustment_Reset_Status-Watchdog_Reset_At_Run_Up,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG123056-ENG123096,systembasic_chip_overstrained-par_systembasic_chip_overstrained,not active,
Elapsed Time: 00:06
3C:
;SW:5Q0-907-686-C   HW:5Q0-907-686-C ---  Lane Change
;Component:HRE_Master    H12 0081, Coding:02012103
;EV_HREntryHella,001028,EV_HREntryHella_VW27.rod
;Monday,17,June,2019,11:02:35:34333
IDE00018,Voltage terminal 15,14.08, V
IDE00102,Control Module temperature,47.0, °C
IDE00925,Yaw rate,0.00, °/s
IDE01441,Back-up light,OFF,
IDE01766-MAS01853,Distance impulses-Left front,1,
IDE01766-MAS01854,Distance impulses-Right front,0,
IDE01766-MAS01855,Distance impulses-Left rear,0,
IDE01766-MAS01856,Distance impulses-Right rear,0,
IDE02049,Trailer detected,not recognized,
IDE02057-MAS10063,Dynamic calibration: status-Auto. calibration: percent. progress Master,30.00, km
IDE02057-MAS10064,Dynamic calibration: status-Auto. calibration: percent. progress Slave,100, %
IDE02057-MAS10065,Dynamic calibration: status-Distance of object 4,100, %
IDE02057,Dynamic calibration: status,is running,
IDE02219-MAS02471,Steering wheel angle: sign-Sign,Negative,
IDE02219,Steering wheel angle: sign,0.00,
IDE03619,System status,On,
IDE05064,lane change assist. 2: supply voltage,14.28, V
IDE05065,lane change assist. 2: temperature,45.0, °C
IDE05067-MAS08213,Functional status of lane change assist.-Blind spot detection,passive,
IDE05067-MAS10332,Functional status of lane change assist.-Parking assistant,On,
IDE05070,Curve radius,14976, m
IDE05072,Status of lane change assist. indicator lamp,active,
IDE05077-IDE02389,Rain/light recognition sensor via data bus-Ambient brightness,0,
IDE05077,Rain/light recognition sensor via data bus,not defined,
IDE05078-MAS04108,Distance of object 1-Distance in X-direction,-120.00, m
IDE05078-MAS04109,Distance of object 1-Distance in Y-direction,0.00, m
IDE05079-MAS02469,Relative speed of object 1-Speed in x-direction,0.00, m/s
IDE05080-MAS04108,Distance of object 2-Distance in X-direction,-120.00, m
IDE05080-MAS04109,Distance of object 2-Distance in Y-direction,0.00, m
IDE05081-MAS02469,Relative speed of object 2-Speed in x-direction,0.00, m/s
IDE05082-MAS04108,Distance of object 3-Distance in X-direction,-120.00, m
IDE05082-MAS04109,Distance of object 3-Distance in Y-direction,0.00, m
IDE05083-MAS02469,Relative speed of object 3-Speed in x-direction,0.00, m/s
IDE05084,Closest object left lane,No object recognized,
IDE05085,Closest object right lane,No object recognized,
IDE05086,Closest object lane used,No object recognized,
IDE05087,Dynamic angle offset lane change assist. 1,-2.07, °
IDE05088,Dynamic angle offset lane change assist. 2,2.31, °
IDE05090,Measured receiving power lane change assist. 1,0, %
IDE05091,Measured receiving power lane change assist. 2,0, %
IDE05092,Measured angle lane change assist. 1,20.32, °
IDE05093,Measured angle lane change assist. 2,20.32, °
IDE05094,Static angle offset lane change assist. 1,0.00, °
IDE05095,Static angle offset lane change assist. 2,0.00, °
IDE05100,Spray counter,0,
IDE10101,Dimming value of left warning light,0, %
IDE10102,Right warning light flashing cycle,OFF,
IDE10103,Left warning light flashing cycle,OFF,
IDE10104,Left warning light status,OFF,
IDE10105,Dimming value of right warning light,0, %
IDE10106,Right warning light status,OFF,
IDE10107,Dimming value of left warning light: warning algorithm,0, %
IDE10108,Status of left warning light: warning algorithm,0,
IDE10109,Dimming value of right warning light: warning algorithm,0, %
IDE10110,Status of right warning light: warning algorithm,0,
IDE10235-IDE10233,Status night design-Night design,not activated,
IDE10235-IDE10234,Status night design-Day design,activated,
IDE10235,Status night design,OFF,
IDE10236-MAS01487,Lane holding warn. syst.-LED,yellow,
IDE10236-MAS10041,Lane holding warn. syst.-Distance to lane,1.25, m
IDE10236-MAS10042,Lane holding warn. syst.-Time to lane crossing,3.0, s
IDE10236-MAS10043,Lane holding warn. syst.-Vehicle side,Right,
MAS05108-MAS10050,ESP-Delay regulation,Feedback: delay regulation is available,
MAS05108-MAS10059,ESP-Blind spot warning: message,consistent,
MAS05108-MAS10669,ESP-Delay regulation: brake jolt,Not available,
MAS08785-IDE02679,Parking aid-Tone sensor,Not available,
MAS08785-IDE03619,Parking aid-System status,System off,
MAS10065-MAS04108,Distance of object 4-Distance in X-direction,-120.00, m
MAS10065-MAS04109,Distance of object 4-Distance in Y-direction,0.00, m
MAS10066-MAS04108,Distance of object 5-Distance in X-direction,-120.00, m
MAS10066-MAS04109,Distance of object 5-Distance in Y-direction,0.00, m
MAS10067-MAS02469,Relative speed of object 4-Speed in x-direction,0.00, m/s
MAS10068-MAS02469,Relative speed of object 5-Speed in x-direction,0.00, m/s
Elapsed Time: 00:08
42:
;SW:5Q0-959-593-F   HW:5Q0-959-593-F ---  Door Elect, Driver
;Component:TSG FS001 0287, Coding:003F1B205200020000000000
;EV_DCU2DriveSideMAXHKLO,001010,EV_DCU2DriveSideMAXHCONT_VW37.rod
;Monday,17,June,2019,11:02:45:34333
;VCID: C4C401A64F1D426F71-8090
IDE00310,Outside air temperature,30.00, °C
IDE01766-MAS02248,Distance impulses-Signal state,Not available,
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,cannot be reached,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver side door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Not assigned,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,14.00, V
IDE02262,synchronous mirror adjustment,not installed,
IDE02267-IDE00773,Supply voltage for door control module: front: driver side-Terminal 15 status via CAN,active,
IDE02267-IDE01715,Supply voltage for door control module: front: driver side-Status terminal S,active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,14.10, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE02668,Central window regulator switch,not installed,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,Sleep mode,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,not activated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,not activated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,not activated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,not activated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,not activated,
IDE04220,Driver power window button,not activated,
IDE04343-MAS03180,Bus identification-Local data bus,Not assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Busmaster,
IDE04411,Child Safety Lock Switch,not activated,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,58, %
IDE04539-MAS02229,Mirror memory-Y coordinate,57, %
IDE04539-MAS02476,Mirror memory-install,installed,
IDE04540,Mirror adjustment (X/Y-direction),Position center,
IDE04580,Dimming of inside door handle lighting,100, %
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not active,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,Implausible,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,not activated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,not activated,
IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,100, %
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,No,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,active,
IDE06206-MAS02039,Front window regulator status: driver side-Force limitation,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Power window control standardized,Yes,
IDE06206-MAS03548,Front window regulator status: driver side-Motor current,0, A
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Power window control standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,Not available,
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06621,Driver side rear power window button,not activated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,4302,
IDE06933,Front window regulator relay: driver side,Open,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,14.00, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.50, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE07222,Window regulator child lock: driver side,Not available,
IDE07405-IDE03114,Enable driver front window regulator relay-Comfort function,No,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07409-MAS01632,Excessive temper. disconnect: front window regulator: driv.side-Status,not active,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,29, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,47, °C
IDE07413,Comfort function for front window regulator: driver side,not active,
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE08061,Child safety lock button 2,not installed,
IDE08205-MAS01453,Pull-shut asst.-Blocking detection,not active,
IDE08205-MAS02103,Pull-shut asst.-Signal from door lock: catch,Implausible,
IDE08205-MAS05370,Pull-shut asst.-Direction of movement,Not available,
IDE08205-MAS08613,Pull-shut asst.-Return contact,closed,
IDE08205-MAS08614,Pull-shut asst.-Closing assist motor current,Not available,
IDE08205-MAS09346,Pull-shut asst.-Door position,Open,
IDE08205-MAS09347,Pull-shut asst.-Redundant door contact,not installed,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE08697-MAS07303,Number of driving cycles without opening door-Actual number of driving cycles without opening door,0,
IDE08795,Button for rear window shade,not installed,
IDE09071-MAS00030,Belt feeder-Seat occupied recognition,not active,
IDE09071-MAS02666,Belt feeder-Seat belt buckle scan,Open,
IDE09071-MAS05370,Belt feeder-Direction of movement,Not available,
IDE09071-MAS08502,Belt feeder-Standardized belt feeder,No,
IDE09071-MAS08503,Belt feeder-End stop of Hall sensor,not recognized,
IDE09071-MAS08504,Belt feeder-Position of belt feeder,Not available,
IDE09071-MAS08505,Belt feeder-Motor current of belt feeder,Not available,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,automatic day/night exterior mirror-Status,not installed,
IDE10164-MAS03691,automatic day/night exterior mirror-Dimming,0, %
IDE12335-IDE12338,Door heating element 1-Sensor for door heating element 1,not installed,
IDE12335-MAS03095,Door heating element 1-Function status,not installed,
IDE12335-MAS04136,Door heating element 1-Current,not installed,
IDE12335-MAS09022,Door heating element 1-PWM value,not installed,
IDE12336-IDE12474,Door heating element 2-Sensor for door heating element 2,not installed,
IDE12336-MAS03095,Door heating element 2-Function status,not installed,
IDE12336-MAS04136,Door heating element 2-Current,not installed,
IDE12336-MAS09022,Door heating element 2-PWM value,not installed,
IDE12422-IDE02266,Driver side front door control head-Passenger side rear power window button,not activated,
IDE12422-IDE04220,Driver side front door control head-Driver power window button,not activated,
IDE12422-IDE04411,Driver side front door control head-Child Safety Lock Switch,not activated,
IDE12422-IDE04540,Driver side front door control head-Mirror adjustment (X/Y-direction),Position bottom,
IDE12422-IDE06621,Driver side front door control head-Driver side rear power window button,not activated,
IDE12422-IDE06872,Driver side front door control head-Front passenger power window button,not activated,
IDE12422-IDE10158,Driver side front door control head-Window lift: switch-over from front to rear,not installed,
IDE12422-IDE11140,Driver side front door control head-Mirror folding position,Driving setting,
IDE12422-MAS14179,Driver side front door control head-Child safety lock rear driver side: status,not active,
IDE12422-MAS14180,Driver side front door control head-Child safety lock rear passenger side: status,not active,
IDE12422-MAS15309,Driver side front door control head-Mirror selector switch: left,not activated,
IDE12422-MAS15310,Driver side front door control head-Mirror selection switch: right,not activated,
IDE12422-MAS15311,Driver side front door control head-Button: open rear lid,not activated,
IDE12422-MAS15312,Driver side front door control head-Close rear lid button,not installed,
IDE12422-MAS15313,Driver side front door control head-Bus signal: open rear lid,not activated,
IDE12422-MAS15314,Driver side front door control head-Close rear lid bus signal,not activated,
IDE13421-IDE06842,Memory seat adjustment control panel-Status - Button 1,not installed,
IDE13421-IDE06843,Memory seat adjustment control panel-Status - Button 2,not installed,
IDE13421-IDE06844,Memory seat adjustment control panel-Status - Button 3,not installed,
IDE13421-IDE06845,Memory seat adjustment control panel-Status - Button 4,not installed,
IDE13421-MAS05766,Memory seat adjustment control panel-Status of button for seat position storing,not installed,
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,Implausible,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,Implausible,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Unknown (6),
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Initializing,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
IDE14109-MAS14614,Excess temperature shutdown of close assist-Switch-on threshold,Not available,
IDE14109-MAS15599,Excess temperature shutdown of close assist-Counter reading,Not available,
IDE14109,Excess temperature shutdown of close assist,not active,
MAS01872,Rear lid remote release button,not activated,
MAS02099,Switch for inside door handle,not installed,
MAS02100,Switch for outside door handle,not installed,
MAS02101,Child safety,not active,
MAS06010,Ambient light,97, %
ENG117315-ENG32834,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J926 ,
Elapsed Time: 00:08
44:
;SW:3QF-909-144-B   HW:3QF-909-144-A ---  Steering Assist
;Component:EPS_MQB_ZFLS  570 1582, Coding:9B1F0000
;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
;Monday,17,June,2019,11:02:55:34333
;VCID: C7DE16AA7E2B697794-8092
IDE00018,Voltage terminal 15,14.39, V
IDE00019,Voltage terminal 30,14.26, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine speed,885, /min
IDE00102,Control Module temperature,43.0, °C
IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,09,
IDE00550-MAS01078,Identification of parameterization-Vehicle type,B6,
IDE00550-MAS05566,Identification of parameterization-Version of system parameters,71,
IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,24,
IDE00550-MAS05568,Identification of parameterization-Version of memory map,A1,
IDE02006-IDE02955,Lane assistant-System status,operational,
IDE02006-IDE04227,Lane assistant-Directional stab. asst w/ pwr steering asst: steering status,0.000, Nm
IDE02006-MAS03095,Lane assistant-Function status,activated,
IDE02006-MAS03368,Lane assistant-Steering wheel vibration,not active,
IDE02202,End stage temperature,35.0, °C
IDE02216-IDE05795,Steering angle sensor: basic setting-End basic setting,Not permitted,
IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
IDE02955,System status,Driving mode,
IDE03682-IDE04457,Sensor for motor position-Electric motor speed,-15, /min
IDE03682-MAS02961,Sensor for motor position-Engine angle,-31.8, °
IDE03682-MAS03083,Sensor for motor position-Cosine signal,1.420, V
IDE03682-MAS03211,Sensor for motor position-Sine signal,2.727, V
IDE03682-MAS05053,Sensor for motor position-Reference value,Condition met,
IDE03725-IDE03734,Steering Assistance-Support power,-100, %
IDE03725-MAS03001,Steering Assistance-Mode,automatic,
IDE03725-MAS03095,Steering Assistance-Function status,activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,operational,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,-2.5, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,0.0, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,activated,
IDE03735,Steering torque,-0.194, Nm
IDE03735-MAS01632,Steering torque-Status,OK,
IDE03736,Steering torque 2,-0.194, Nm
IDE03736-MAS01632,Steering torque 2-Status,OK,
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,0.4, °
IDE04118-MAS03095,Straight line running correction-Function status,activated,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,0.4, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03738,Active reset-Restoring force: setpoint,2, N
IDE04183,Steering assistance: target engine torque,-0.022, Nm
IDE04184,Steering assistance: engine output,100.000, %
IDE04185,Terminal 30 voltage filtered,14.36, V
IDE04186,Battery terminal recognition,connected,
IDE04187,Steering torque: raw value 1,-40.039, %
IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
IDE04188,Steering torque: raw value 2,-71.094, %
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04189,Steering torque: raw value 3,-40.039, %
IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
IDE04190,Steering torque: raw value 4,-71.094, %
IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.38, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.40, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.38, %
IDE04192-MAS03084,Steering assistance: motor current-Phase 1,-0.1, A
IDE04192-MAS03085,Steering assistance: motor current-Phase 2,0.1, A
IDE04192-MAS03086,Steering assistance: motor current-Phase 3,0.0, A
IDE04194,Steering assistance: electromotor power,-0.89, W
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,-2.0, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,-0.3, °
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,160.97, mm
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,Yes,
IDE04459,Steering angle sensor: offset index mark mechanical center,0.27, mm
IDE04460,Steering angle sensor: offset straight line running,-5.5, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not recognized,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not recognized,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not recognized,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not recognized,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,1,
IDE04511,Steering angle sensor external via CAN: angle,Measured value not available,
IDE04512,Steering angle sensor external via CAN: angular velocity,Measured value not available,
IDE04513,Steering angle sensor external via CAN: status,not active,
IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
IDE04765-IDE02955,Counter steer support-System status,operational,
IDE04765-MAS03095,Counter steer support-Function status,activated,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
IDE04766-MAS00371,Replacement values-Engine speed,No,
IDE04787,Hybrid status,not active,
IDE04805-IDE02955,Driving profile selection-System status,operational,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
IDE04805-MAS01447,Driving profile selection-Act.val.,3,
IDE04805-MAS01448,Driving profile selection-Specified value,3,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05155,Power steering current consumption,-0.06, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS01849,Software end stop-Left,80.76, mm
IDE05162-MAS01850,Software end stop-Right,-80.21, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Release,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,1611,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,1590,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,0,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,0,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,0,
IDE05994-ENG08146,Engine specified torque load-10_to_11_kilo_newton,0,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
IDE05994-ENG08147,Engine specified torque load--11_to_-10_kilo_newton,0,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,0,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
IDE05994-ENG30242,Engine specified torque load-above_11_kilo_newton,439,
IDE05994-ENG30407,Engine specified torque load-below_-11_kilo_newton,439,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,27804,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,0,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,0,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,0,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,7,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,4,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,8,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,547,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
IDE06678-MAS03000,Pull compensation-Adapt. value,0.120, Nm
IDE06678-MAS03095,Pull compensation-Function status,activated,
IDE07399,Engine type,2,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Regulation active,Condition met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,17,
MAS00464-MAS00109,Standard - ambient data 1-Hours,10,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,9,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,11,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,118, km
MAS00976-IDE80003,Counter-Analysis 3,2476265702,
MAS00976-IDE80004,Counter-Analysis 4,202132,
MAS01172-MAS01156,Development messages-Communication status,active,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
ENG37819-ENG37964,Strain_detection-Calculated_worm_gear_temperature,41.0, °C
ENG37819-ENG38046,Strain_detection-High_count_worm_gear_alt,202132,
ENG37819-ENG38061,Strain_detection-KlimaSensor02_alt,1,
ENG37819-ENG38097,Strain_detection-Low_count_worm_gear_alt,2476265702,
ENG37819-ENG38105,Strain_detection-Mileage_counter,0, km
ENG37819-ENG38117,Strain_detection-OBD_FStatus_ATemp,kein Fehler/Init/nicht verbaut,
ENG37819-ENG102605,Strain_detection-outside_temperature,30.0, °C
ENG37819-ENG37918,Strain_detection-revolutions_per_minute_electric_motor,-1, /min
ENG37819-ENG26208,Strain_detection-Steering_angle,-2.0, °
ENG37819-ENG37919,Strain_detection-steering_moment,-0.202, Nm
ENG37819-ENG37920,Strain_detection-Steering_Support_Engine_Commanded_Torque,-0.022, Nm
ENG37819-ENG38151,Strain_detection-Strain_detection_per_cent,0.0000015181, %
Elapsed Time: 00:07
47:
;SW:5Q0-035-456-A   HW:5Q0-035-456-A ---  Sound System
;Component:MIB2_lite_amp H40 0200, Coding:2214060002AAAFAA000000000000
;EV_AMPMst12C3Gen2ALPI,001001,EV_AMPMst12C3Gen2ALPI.rod
;Monday,17,June,2019,11:03:05:34333
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: AE10430EF191D83FB7-80FA
Group,Description,Actual
IDE00019,Voltage terminal 30,14.2, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,891.50, /min
IDE00075,Vehicle speed,0.00, km/h
IDE00323,Security Access: Number of invalid keys,0,
IDE00767,No. of unscheduled ECU resets,0, counts
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,On,
IDE01715,Status terminal S,On,
IDE01716,Terminal 50 status,OFF,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Databus Infotainment,No,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,Yes,
IDE02486,Data logger triggering,not active,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,47,
IDE03880-MAS03425,MOST address-Physical address,04 01,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,12, min
IDE04317-MAS00108,Total system run time-Day,0, d
IDE04317-MAS00109,Total system run time-Hours,5, H
IDE04317-MAS00110,Total system run time-Minutes,22, min
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,No,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,Yes,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.7, dB
IDE04649-MAS01968,Activation for housing fan-Fan,OFF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,Mute,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,Mute,
IDE05704-MAS02646,Digital Transmission Content Protection (DTCP) key-Key type,License key (DTLA),
IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,2,
IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,60,
IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE06055,Invalid authentication (DTCP),00,
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,46, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,-7, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Current,34, °C
IDE10545-IDE02129,Speaker status-Left rear speaker,Condition not met,
IDE10545-IDE02130,Speaker status-Right rear speaker,Condition not met,
IDE10545-MAS01190,Speaker status-Left front treble speaker,Condition not met,
IDE10545-MAS01193,Speaker status-Right front treble speaker,Condition not met,
IDE10545-MAS01198,Speaker status-Center speaker,Condition not met,
IDE10545-MAS01199,Speaker status-Left effect speaker,Condition not met,
IDE10545-MAS01200,Speaker status-Right effect speaker,Condition not met,
IDE10545-MAS01201,Speaker status-Subwoofer speaker,Condition not met,
IDE10545-MAS12334,Speaker status-Double bass speaker 1: left front,Condition not met,
IDE10545-MAS12335,Speaker status-Double bass speaker 1: right front,Condition not met,
IDE10545-MAS12336,Speaker status-Double bass speaker 2: left front,Condition not met,
IDE10545-MAS12337,Speaker status-Double bass speaker 2: right front,Condition not met,
IDE10545,Speaker status,Measured value not available,
IDE10657-MAS01424,Temperature switching power supply-max.value,205, °C
IDE10657-MAS01425,Temperature switching power supply-min.value,205, °C
IDE10657-MAS02238,Temperature switching power supply-Current,205, °C
IDE10659-MAS01424,Temperature switching power supply 2-max.value,48, °C
IDE10659-MAS01425,Temperature switching power supply 2-min.value,1, °C
IDE10659-MAS02238,Temperature switching power supply 2-Current,37, °C
MAS00464-MAS00111,Standard - ambient data 1-Seconds,15,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,dont care,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,dont care,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,3, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,19, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,6, mon
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,17, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,9, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,49, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,49, s
Elapsed Time: 00:04
4B:
;SW:3Q0-907-338-C   HW:3Q0-907-338-C ---  Multifunc. Module
;Component:FCM MQB Low   002 0345, Coding:000000070900135200010000000000000000000000000000000000000000
;EV_MultiModulContiVW48X,002006,EV_MultiModulContiVW48X_002_VW41.rod
;Monday,17,June,2019,11:03:12:34333
;VCID: B5226C6214C7EBE7F6-80E0
IDE00019,Voltage terminal 30,14.4, V
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.0, km/h
IDE00322,Status of basic setting,not active,
IDE00326,Steering wheel angle,-2.00, °
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE00773,Terminal 15 status via CAN,On,
IDE01714,Status reverse gear,OFF,
IDE01717-ENG30211,Processor load-Software_component_AFS_MXB,9, %
IDE01717-ENG30223,Processor load-Total_system_FCM,22, %
IDE01943,Turn signal,not activated,
IDE01946,ESP intervention,not active,
IDE02389,Ambient brightness,6126, lx
IDE02515,Low beam,OFF,
IDE02743,High Beam,OFF,
IDE03214,Engine stop using start-stop function,OFF,
IDE03215,Engine start using start-stop function,OFF,
IDE03602,Left front level control system sensor,-0.01, %
IDE03604,Left rear level control system sensor,50.00, %
IDE03616,Motor status,On,
IDE03620,Front jounce travel,0.0, mm
IDE03621,Rear jounce travel,0.0, mm
IDE03622,Left headlight beam adjusting motor: status,no error,
IDE03623,Right headlight beam adjusting motor: status,no error,
IDE03624,Left dynamic AFS light motor: specified value,32.000000, °
IDE03625,Right dynamic AFS light motor: specified value,32.000000, °
IDE03626,Left dynamic AFS light motor: status,no error,
IDE03627,Right dynamic AFS light motor: status,no error,
IDE03628,Adjusting motor for variable left front lighting: status,no error,
IDE03629,Adjusting motor for variable right front lighting: status,no error,
IDE03630,Left headlight beam adjusting motor: specified value,1024.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,1024.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638-IDE03717,static AFS light-Dim static left AFS light,102.0, %
IDE03638-IDE03718,static AFS light-Dim static right AFS light,102.0, %
IDE03640,Dynamic AFS light,On,
IDE03669,Light distribution status,not activated,
IDE03727,Variable left front lighting specified position,204.70, %
IDE03728,Variable right front lighting specified position,204.70, %
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),-0.01, %
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),-0.01, %
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE08447,Driving axis angle,-120.0, '
IDE08516-IDE02743,LED headlights: light distribution requirement-High Beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lights,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,both sides,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08706-MAS17323,Actual angle of ref. segments-Horizontal angle reference segment left: in angular minutes,-500.0, '
IDE08706-MAS17324,Actual angle of ref. segments-Horizontal angle reference segment left: in degrees,-10.00, °
IDE08706-MAS17325,Actual angle of ref. segments-Horizontal angle reference segment left: as a percentage,-15.00, %
IDE08706-MAS17326,Actual angle of ref. segments-Horizontal angle reference segment right: in angular minutes,-500.0, '
IDE08706-MAS17327,Actual angle of ref. segments-Horizontal angle reference segment right: in degrees,-10.00, °
IDE08706-MAS17328,Actual angle of ref. segments-Horizontal angle reference segment right: as a percentage,-15.00, %
IDE08706-MAS17329,Actual angle of ref. segments-Vertical angle reference segment left: in angular minutes,-120.0, '
IDE08706-MAS17330,Actual angle of ref. segments-Vertical angle reference segment left: in degrees,-10.00, °
IDE08706-MAS17331,Actual angle of ref. segments-Vertical angle reference segment left: as a percentage,-15.00, %
IDE08706-MAS17332,Actual angle of ref. segments-Vertical angle reference segment right: in angular minutes,-120.0, '
IDE08706-MAS17333,Actual angle of ref. segments-Vertical angle reference segment right: in degrees,-10.00, °
IDE08706-MAS17334,Actual angle of ref. segments-Vertical angle reference segment right: as a percentage,-15.00, %
IDE08713-MAS17335,Matrix light: calculated offset values-Horizontal offset: left headlight in angular minutes,-300.0, '
IDE08713-MAS17336,Matrix light: calculated offset values-Horizontal offset: left headlight in degrees,-5.00, °
IDE08713-MAS17337,Matrix light: calculated offset values-Horizontal: left headlight as a percentage,-9.00, %
IDE08713-MAS17338,Matrix light: calculated offset values-Horizontal offset: right headlight in angular minutes,-300.0, '
IDE08713-MAS17339,Matrix light: calculated offset values-Horizontal offset: right headlight in degrees,-5.00, °
IDE08713-MAS17340,Matrix light: calculated offset values-Horizontal offset: right headlight as a percentage,-9.00, %
IDE08713-MAS17341,Matrix light: calculated offset values-Vertical offset: left headlight in angular minutes,-300.0, '
IDE08713-MAS17342,Matrix light: calculated offset values-Vertical offset: left headlight in degrees,-5.00, °
IDE08713-MAS17343,Matrix light: calculated offset values-Vertical offset: left headlight as a percentage,-9.00, %
IDE08713-MAS17344,Matrix light: calculated offset values-Vertical offset: right headlight in angular minutes,-300.0, '
IDE08713-MAS17345,Matrix light: calculated offset values-Vertical offset: right headlight in degrees,-5.00, °
IDE08713-MAS17346,Matrix light: calculated offset values-Vertical offset: right headlight as a percentage,-9.00, %
IDE08714-MAS06929,Axle offsets-Axle offset front,-400.0, mm
IDE08714-MAS06930,Axle offsets-Axle offset rear,-400.0, mm
IDE08715,Func. status matrix high beam,not active,
MAS16427-MAS17003,Online data acquisition configuration-Locking time for change of condition,1.0, s
MAS16427-MAS19090,Online data acquisition configuration-Configuration version,FF FF FF FE,
MAS16428-MAS00106,Online data acquisition and analysis-Year,2000,
MAS16428-MAS00107,Online data acquisition and analysis-Month,0,
MAS16428-MAS00108,Online data acquisition and analysis-Day,0,
MAS16428-MAS00109,Online data acquisition and analysis-Hours,0,
MAS16428-MAS00110,Online data acquisition and analysis-Minutes,0,
MAS16428-MAS00111,Online data acquisition and analysis-Seconds,0,
MAS16428-MAS16995,Online data acquisition and analysis-Downloads data set number,0,
MAS16428-MAS19089,Online data acquisition and analysis-Emergency Call Module recognition and communication unit or navigation,Navigation,
MAS16431-MAS16982,Online data acquisition warning overview-Type of first warning,24,
MAS16431-MAS16983,Online data acquisition warning overview-Type of second warning,27,
MAS16431-MAS16984,Online data acquisition warning overview-Type of third warning,31,
MAS16431-MAS16985,Online data acquisition warning overview-Type of fourth WARNING,15,
MAS16431-MAS16986,Online data acquisition warning overview-Type of fifth WARNING,0,
MAS16431-MAS16987,Online data acquisition warning overview-Type of sixth WARNING,0,
MAS16431-MAS16988,Online data acquisition warning overview-Type of seventh WARNING,0,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2019,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2000,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,0,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,6,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,17,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,0,
MAS16432-MAS00109,Online data acquisition: warning 1-Hours,0,
MAS16432-MAS00109,Online data acquisition: warning 1-Hours,22,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,50,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,0,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,36,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,0,
MAS16432-MAS16989,Online data acquisition: warning 1-Index of the warning,2,
MAS16432-MAS16990,Online data acquisition: warning 1-Number of warnings,98,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2019,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2000,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,0,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,6,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,0,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,17,
MAS16433-MAS00109,Online data acquisition: warning 2-Hours,22,
MAS16433-MAS00109,Online data acquisition: warning 2-Hours,0,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,50,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,0,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,0,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,36,
MAS16433-MAS16989,Online data acquisition: warning 2-Index of the warning,2,
MAS16433-MAS16990,Online data acquisition: warning 2-Number of warnings,98,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2019,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2000,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,0,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,6,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,17,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,0,
MAS16434-MAS00109,Online data acquisition: warning 3-Hours,0,
MAS16434-MAS00109,Online data acquisition: warning 3-Hours,22,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,50,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,0,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,0,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,36,
MAS16434-MAS16989,Online data acquisition: warning 3-Index of the warning,2,
MAS16434-MAS16990,Online data acquisition: warning 3-Number of warnings,98,
MAS16435-MAS00106,Online data acquisition: warning 4-Year,2000,
MAS16435-MAS00107,Online data acquisition: warning 4-Month,0,
MAS16435-MAS00107,Online data acquisition: warning 4-Month,1,
MAS16435-MAS00108,Online data acquisition: warning 4-Day,6,
MAS16435-MAS00108,Online data acquisition: warning 4-Day,0,
MAS16435-MAS00109,Online data acquisition: warning 4-Hours,0,
MAS16435-MAS00109,Online data acquisition: warning 4-Hours,8,
MAS16435-MAS00110,Online data acquisition: warning 4-Minutes,0,
MAS16435-MAS00111,Online data acquisition: warning 4-Seconds,46,
MAS16435-MAS00111,Online data acquisition: warning 4-Seconds,0,
MAS16435-MAS16989,Online data acquisition: warning 4-Index of the warning,3,
MAS16435-MAS16990,Online data acquisition: warning 4-Number of warnings,1,
MAS16436-MAS00106,Online data acquisition: warning 5-Year,2000,
MAS16436-MAS00107,Online data acquisition: warning 5-Month,0,
MAS16436-MAS00108,Online data acquisition: warning 5-Day,0,
MAS16436-MAS00109,Online data acquisition: warning 5-Hours,0,
MAS16436-MAS00110,Online data acquisition: warning 5-Minutes,0,
MAS16436-MAS00111,Online data acquisition: warning 5-Seconds,0,
MAS16436-MAS16989,Online data acquisition: warning 5-Index of the warning,0,
MAS16436-MAS16990,Online data acquisition: warning 5-Number of warnings,0,
MAS16437-MAS00106,Online data acquisition: warning 6-Year,2000,
MAS16437-MAS00107,Online data acquisition: warning 6-Month,0,
MAS16437-MAS00108,Online data acquisition: warning 6-Day,0,
MAS16437-MAS00109,Online data acquisition: warning 6-Hours,0,
MAS16437-MAS00110,Online data acquisition: warning 6-Minutes,0,
MAS16437-MAS00111,Online data acquisition: warning 6-Seconds,0,
MAS16437-MAS16989,Online data acquisition: warning 6-Index of the warning,0,
MAS16437-MAS16990,Online data acquisition: warning 6-Number of warnings,0,
MAS16438-MAS00106,Online data acquisition: warning 7-Year,2000,
MAS16438-MAS00107,Online data acquisition: warning 7-Month,0,
MAS16438-MAS00108,Online data acquisition: warning 7-Day,0,
MAS16438-MAS00109,Online data acquisition: warning 7-Hours,0,
MAS16438-MAS00110,Online data acquisition: warning 7-Minutes,0,
MAS16438-MAS00111,Online data acquisition: warning 7-Seconds,0,
MAS16438-MAS16989,Online data acquisition: warning 7-Index of the warning,0,
MAS16438-MAS16990,Online data acquisition: warning 7-Number of warnings,0,
ENG101323,Headlight leveling control state,static,
ENG107365,Left dynamic cornering light value,9.000000, °
ENG26446-ENG30212,Multifunction_Module_Application_Software_Version-Software_Version_AFS/MXB,0162,
ENG26446-ENG30225,Multifunction_Module_Application_Software_Version-Version_Routing_FCM,7190,
ENG124613,Predictive_Route_Data_Intown_Flag,Not available,
ENG124610,Predictive_Route_Data_Number_Of_Lanes,Not available,
ENG124612,Predictive_Route_Data_Placename_Sign,Not available,
ENG124611,Predictive_Route_Data_Speed_Limit,Not available,
ENG124609,Predictive_Route_Data_Street_Class,Not available,
ENG108468,Right dynamic cornering light value,ERROR,
Elapsed Time: 00:09
52:
;SW:5Q0-959-592-F   HW:5Q0-959-592-F ---  Door Elect, Pass.
;Component:TSG BFS001 0287, Coding:003F13205E00020000000000
;EV_DCU2PasseSideMAXHKLO,001010,EV_DCU2PasseSideMAXHCONT_VW37.rod
;Monday,17,June,2019,11:03:24:34333
;VCID: C3C602BA4A13455748-8096
IDE00310,Outside air temperature,30.50, °C
IDE00322,Status of basic setting,was not yet started,
IDE01993-MAS12276,Control module reference number-Front door control module,Frt.pass. side door control module,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,14.00, V
IDE02266,Passenger side rear power window button,not activated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,14.10, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04539-MAS02228,Mirror memory-X coordinate,44, %
IDE04539-MAS02229,Mirror memory-Y coordinate,58, %
IDE04540,Mirror adjustment (X/Y-direction),not installed,
IDE05727-IDE02589,Front passenger side door status-Rotary latch status,closed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,not activated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: engaged,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,not active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,Not available,
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,not activated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,4302,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,29, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,47, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,13.50, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.50, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
IDE08205-MAS09346,Pull-shut asst.-Door position,closed,
ENG117316-ENG32834,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J927 ,
Elapsed Time: 00:07
5F:
;SW:3QF-035-876-A   HW:3QF-035-876-A ---  Information Electr.
;Component:MU-S-NS-US    853 0890, Coding:021406020000000051220002001808001F0500E401200405CE
;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
;Monday,17,June,2019,11:03:33:34333
;VCID: C8DC15967335660F9D-809C
IDE00021,Engine speed,894.00, /min
IDE00668-MAS03231,Microphone current consumption-Microphone 1,5.90, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,25.50, mA
IDE00916-IDE02127,Speaker status-Left front speaker,Measured value not available,
IDE00916-IDE02128,Speaker status-Right front speaker,Measured value not available,
IDE00916-IDE02129,Speaker status-Left rear speaker,Measured value not available,
IDE00916-IDE02130,Speaker status-Right rear speaker,Measured value not available,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measured value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measured value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measured value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measured value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measured value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measured value not available,
IDE00916-ENG117408,Speaker status-loudspeaker_channel_5,Measured value not available,
IDE00916-ENG117409,Speaker status-loudspeaker_channel_6,Measured value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measured value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measured value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measured value not available,
IDE01351,Terminal 75 status,OFF,
IDE01442-MAS06123,Pressing a button-Eject button,not activated,
IDE01698-MAS07206,Status audio signal outputs-Audio signal output channel 1,Measured value not available,
IDE01698-MAS07207,Status audio signal outputs-Audio signal output channel 2,Measured value not available,
IDE01698-MAS07208,Status audio signal outputs-Audio signal output channel 3,Measured value not available,
IDE01698-MAS07209,Status audio signal outputs-Audio signal output channel 4,Measured value not available,
IDE01712-MAS01779,GPS Position-Length,084°06'42.08"W,
IDE01712-MAS01780,GPS Position-Width,035°54'20.35"N,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,15,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,13,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,70, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,1, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,42, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,0, dBµV
IDE01770-MAS01632,Status of GPS antenna-Status,Electrical OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,25, mA
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,System OK,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE01992-ENG16230,Installation list: current installations-ECU present Bit 0,not installed,
IDE01992-ENG20557,Installation list: current installations-ECU present Bit 0 Main_Unit,installed,
IDE01992-ENG45410,Installation list: current installations-ECU present Bit 1,not installed,
IDE01992-ENG20556,Installation list: current installations-ECU present Bit 1 reserved,not installed,
IDE01992-ENG20933,Installation list: current installations-ECU present Bit 10 SmartControlCarrier2,not installed,
IDE01992-ENG20932,Installation list: current installations-ECU present Bit 11 WirelessCharger1,not installed,
IDE01992-ENG20931,Installation list: current installations-ECU present Bit 12 WirelessCharger2,not installed,
IDE01992-ENG20930,Installation list: current installations-ECU present Bit 13 Multimedia Operating Unit,not installed,
IDE01992-ENG20929,Installation list: current installations-ECU present Bit 14 Head-up Display,not installed,
IDE01992-ENG20950,Installation list: current installations-ECU present Bit 15,not installed,
IDE01992-ENG45396,Installation list: current installations-ECU present Bit 2,not installed,
IDE01992-ENG20555,Installation list: current installations-ECU present Bit 2 Sound_System,installed,
IDE01992-ENG45402,Installation list: current installations-ECU present Bit 3,not installed,
IDE01992-ENG20554,Installation list: current installations-ECU present Bit 3 TV_Tuner,not installed,
IDE01992-ENG45430,Installation list: current installations-ECU present Bit 4,not installed,
IDE01992-ENG20553,Installation list: current installations-ECU present Bit 4 DVD_Changer,not installed,
IDE01992-ENG45377,Installation list: current installations-ECU present Bit 5,not installed,
IDE01992-ENG20552,Installation list: current installations-ECU present Bit 5 RearSeatEntertainment,not installed,
IDE01992-ENG21674,Installation list: current installations-ECU present Bit 6,not installed,
IDE01992-ENG20919,Installation list: current installations-ECU present Bit 6 MOST Kombi-Display,installed,
IDE01992-ENG16217,Installation list: current installations-ECU present Bit 7,not installed,
IDE01992-ENG20918,Installation list: current installations-ECU present Bit 7 SmartDisplayCarrier1,not installed,
IDE01992-ENG20935,Installation list: current installations-ECU present Bit 8 SmartDisplayCarrier2,not installed,
IDE01992-ENG20934,Installation list: current installations-ECU present Bit 9 SmartControlCarrier1,not installed,
IDE01995-ENG16990,Control module protocol information-Ethernet,No,
IDE01995-ENG16987,Control module protocol information-ISO-TP,Yes,
IDE01995-ENG16989,Control module protocol information-K Line,No,
IDE01995-ENG16988,Control module protocol information-TP 1.6,No,
IDE01995-ENG16991,Control module protocol information-TP 2.0,No,
IDE02070-MAS03177,Wake-up cause-Databus Infotainment,Yes,
IDE02070-MAS03833,Wake-up cause-Optical data bus,No,
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,7,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,4,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,1,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,18,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,49, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,47, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,46, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,46, dBµV
IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG20563,Status of event memory-ECU Dtc Bit 0 Main_Unit,OK,
IDE02384-ENG45352,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG20562,Status of event memory-ECU Dtc Bit 1 reserved,OK,
IDE02384-ENG20924,Status of event memory-ECU Dtc Bit 10 SmartControlCarrier2,OK,
IDE02384-ENG20923,Status of event memory-ECU Dtc Bit 11 WirelessCharger1,OK,
IDE02384-ENG20922,Status of event memory-ECU Dtc Bit 12 WirelessCharger2,OK,
IDE02384-ENG20921,Status of event memory-ECU Dtc Bit 13 Multimedia Operating Unit,OK,
IDE02384-ENG20920,Status of event memory-ECU Dtc Bit 14 Head-up Display,OK,
IDE02384-ENG20949,Status of event memory-ECU Dtc Bit 15,OK,
IDE02384-ENG45386,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG20561,Status of event memory-ECU Dtc Bit 2 Sound_System,OK,
IDE02384-ENG45404,Status of event memory-ECU Dtc Bit 3,OK,
IDE02384-ENG20560,Status of event memory-ECU Dtc Bit 3 TV_Tuner,OK,
IDE02384-ENG45387,Status of event memory-ECU Dtc Bit 4,OK,
IDE02384-ENG20559,Status of event memory-ECU Dtc Bit 4 DVD_Changer,OK,
IDE02384-ENG45440,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG20558,Status of event memory-ECU Dtc Bit 5 Rear_Seat_Entertainment,OK,
IDE02384-ENG21671,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG20945,Status of event memory-ECU Dtc Bit 6 MOST Kombi-Display,OK,
IDE02384-ENG16227,Status of event memory-ECU Dtc Bit 7,OK,
IDE02384-ENG20944,Status of event memory-ECU Dtc Bit 7 SmartDisplayCarrier1,OK,
IDE02384-ENG20926,Status of event memory-ECU Dtc Bit 8 SmartDisplayCarrier2,OK,
IDE02384-ENG20925,Status of event memory-ECU Dtc Bit 9 SmartControlCarrier1,OK,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE02766,Malfunction status,FF FB,
IDE03150-ENG16256,Readiness for bus sleep mode-Sleep Bit 0,Sleep mode,
IDE03150-ENG20569,Readiness for bus sleep mode-Sleep Bit 0 Main_Unit,End busstat,
IDE03150-ENG45492,Readiness for bus sleep mode-Sleep Bit 1,Sleep mode,
IDE03150-ENG20568,Readiness for bus sleep mode-Sleep Bit 1 reserved,Sleep mode,
IDE03150-ENG20941,Readiness for bus sleep mode-Sleep Bit 10 SmartControlCarrier2,Sleep mode,
IDE03150-ENG20940,Readiness for bus sleep mode-Sleep Bit 11 WirelessCharger1,Sleep mode,
IDE03150-ENG20939,Readiness for bus sleep mode-Sleep Bit 12 WirelessCharger2,Sleep mode,
IDE03150-ENG20938,Readiness for bus sleep mode-Sleep Bit 13 Bedienteil vorne,Sleep mode,
IDE03150-ENG20937,Readiness for bus sleep mode-Sleep Bit 14 Head-up Display,Sleep mode,
IDE03150-ENG20936,Readiness for bus sleep mode-Sleep Bit 15,Sleep mode,
IDE03150-ENG45491,Readiness for bus sleep mode-Sleep Bit 2,Sleep mode,
IDE03150-ENG20567,Readiness for bus sleep mode-Sleep Bit 2 Sound_System,End busstat,
IDE03150-ENG45490,Readiness for bus sleep mode-Sleep Bit 3,Sleep mode,
IDE03150-ENG20566,Readiness for bus sleep mode-Sleep Bit 3 TV_Tuner,Sleep mode,
IDE03150-ENG45489,Readiness for bus sleep mode-Sleep Bit 4,Sleep mode,
IDE03150-ENG20565,Readiness for bus sleep mode-Sleep Bit 4 DVD_Changer,Sleep mode,
IDE03150-ENG45488,Readiness for bus sleep mode-Sleep Bit 5,Sleep mode,
IDE03150-ENG20564,Readiness for bus sleep mode-Sleep Bit 5 RearSeatEntertainment,Sleep mode,
IDE03150-ENG21675,Readiness for bus sleep mode-Sleep Bit 6,Sleep mode,
IDE03150-ENG20928,Readiness for bus sleep mode-Sleep Bit 6 MOST Kombi-Display,End busstat,
IDE03150-ENG16255,Readiness for bus sleep mode-Sleep Bit 7,Sleep mode,
IDE03150-ENG20927,Readiness for bus sleep mode-Sleep Bit 7 SmartDisplayCarrier1,Sleep mode,
IDE03150-ENG20943,Readiness for bus sleep mode-Sleep Bit 8 SmartDisplayCarrier2,Sleep mode,
IDE03150-ENG20942,Readiness for bus sleep mode-Sleep Bit 9 SmartControlCarrier1,Sleep mode,
IDE03151-ENG20551,TP CAN identifier-ECU TP-CAN-Identifier-Request Bit 0,1907,
IDE03151-ENG20550,TP CAN identifier-ECU TP-CAN-Identifier-Response Bit 0,2013,
IDE03477-MAS00106,GPS time-Year,2019,
IDE03477-MAS00107,GPS time-Month,6,
IDE03477-MAS00108,GPS time-Day,17,
IDE03477-MAS00109,GPS time-Hours,15,
IDE03477-MAS00110,GPS time-Minutes,3,
IDE03477-MAS00111,GPS time-Seconds,33,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,5F,
IDE03880-MAS03425,MOST address-Physical address,04 00,
IDE04312-MAS00110,System run time-Minutes,13, min
IDE04317-MAS00109,Total system run time-Hours,9, H
IDE04317-MAS00110,Total system run time-Minutes,11, min
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 03 00 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
IDE04332,Release code for a SWaP function,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C2 93 92 9A 21 E4 DC EB 18 D7 5C 0E 67 EF 75 08 4A CA 81 A8 8A A1 CD 26 08 6F 9F 96 D8 F8 FA 57 23 75 F8 CC AC 03 B4 32 29 83 5E E1 8C CD 2B D4 35 44 5F C3 B1 B5 E4 E7 66 80 2B 94 D4 EA 91 A0 D0 58 AD 49 5A 16 DA 8D 0F 9C 65 A1 83 35 8B 85 CC 77 97 7A DE 07 49 4C A7 F9 AB 60 20 54 F1 F2 8B 52 39 6F 6C 41 24 BF 24 89 4D E5 3F AA 8B 5B 5C 19 D2 F4 80 50 F8 3C 6B 82 87 B2 35 B9 4D 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-ENG20542,Bus identification-Bus Identifier,Busmaster,
IDE04344-ENG20451,Control module assignment-ECU ID,5F,
IDE04344-ENG20480,Control module assignment-ECU Name,Information Control Unit 1,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Not available,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04544,Media type in optical drive,Not available,
IDE04545-IDE01588,Vehicle state-Driving direction,Measured value not available,
IDE04545-IDE01714,Vehicle state-Status reverse gear,not selected,
IDE04545-IDE01766,Vehicle state-Distance impulses,0,
IDE04545-IDE03684,Vehicle state-Vehicle stopped,Yes,
IDE04546-IDE00301,Navigation calibration-Distance,0.540, mm
IDE04546-MAS03647,Navigation calibration-Calibration condition,Position finding possible even without GPS,
IDE04547,Traffic information,OFF,
IDE04605-MAS01779,Navigation: Corrected position-Length,084°06'40.75"W,
IDE04605-MAS01780,Navigation: Corrected position-Width,035°54'19.58"N,
IDE04607-IDE03661,Angle of turn sensor for navigation-Rotation rate,-19.6, °/s
IDE04607-ENG117452,Angle of turn sensor for navigation-gyro_sensor_x_acceleration,20.08, m/s²
IDE04607-ENG117453,Angle of turn sensor for navigation-gyro_sensor_y_acceleration,20.08, m/s²
IDE04607-ENG117454,Angle of turn sensor for navigation-gyro_sensor_z_acceleration,20.08, m/s²
IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,Yes,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,No,
IDE04641,Speed-dependent volume adjustment,0.0, dB
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 2,
IDE04649-MAS06857,Activation for housing fan-Speed,5220, /min
IDE04748,Microphone override meter,0,
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth device address,B4 EC 02 98 D3 5A,
IDE05040-MAS01632,Video input status-Status,valid,
IDE05040-MAS04390,Video input status-Active source,Rearview camera,
IDE05536-MAS01632,GPS almanac-Status,valid,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2019,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,6,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,17,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,14,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,52,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,24,
IDE05596-MAS00106,Last time GPS position outside map-Year,2000,
IDE05596-MAS00107,Last time GPS position outside map-Month,0,
IDE05596-MAS00108,Last time GPS position outside map-Day,0,
IDE05596-MAS00109,Last time GPS position outside map-Hours,0,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,0,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,0,
IDE05597-IDE03615,Bluetooth: Paired device 1-Version,<ÐStacy's iPhone
Apple Inc.
iPhone11,8Version 12.3.1 (Build 16F203)ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth device address,F4 06 16 02 3C D0,
IDE05597-MAS01483,Bluetooth: Paired device 1-Softwareversion,<ÐStacy's iPhone
Apple Inc.
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),F4 06,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),F4 06,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,<ÐStacy's iPhone
Apple Inc.
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,Stacy's iPhone
Apple Inc.
iPhone11,8
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,F4 06,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,F4 06,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,F4 06,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,F4 06,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,F4 06,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,F4 06,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,F4 06,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,F4 06,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,F4 06,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,F4 06,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,F4 06,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,F4 06,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,F4 06,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,F4 06,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,F4 06,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,F4 06,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,F4 06,
IDE05598-IDE03615,Bluetooth: Paired device 2-Version,--
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth device address,00 00 00 00 00 00,
IDE05598-MAS01483,Bluetooth: Paired device 2-Softwareversion,--
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),00 00,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),00 00,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,--
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,--
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,00 00,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,00 00,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,00 00,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,00 00,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,00 00,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,00 00,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,00 00,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,00 00,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,00 00,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,00 00,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,00 00,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,00 00,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,00 00,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,00 00,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,00 00,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,00 00,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,00 00,
IDE05599-IDE03615,Bluetooth: Paired device 3-Version,--
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth device address,00 00 00 00 00 00,
IDE05599-MAS01483,Bluetooth: Paired device 3-Softwareversion,--
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),00 00,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),00 00,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,--
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,--
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,00 00,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,00 00,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,00 00,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,00 00,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,00 00,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,00 00,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,00 00,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,00 00,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,00 00,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,00 00,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,00 00,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,00 00,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,00 00,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,00 00,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,00 00,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,00 00,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,00 00,
IDE05600-IDE03615,Bluetooth: Paired device 4-Version,--
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Softwareversion,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Version,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Softwareversion,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,0,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,OK,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,91.64, %
IDE05814,Individualization characteristic,97 26 FD 0C 3D,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,00,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,1,
IDE06028-MAS04414,Control head button operation-Volume control,1,
IDE06425,Roller test bench mode: functional,not activated,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,No object in sector,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10479-MAS01482,Interface for external media: identification-Hardwareversion,H08,
IDE10479-MAS01483,Interface for external media: identification-Softwareversion,0014,
IDE10479-MAS04970,Interface for external media: identification-Part Number,5G0035953D ,
IDE10843-MAS01482,Function module: identification-Hardwareversion,1,
IDE10843-MAS04326,Function module: identification-Device name,AP_FLASH,
IDE10843-MAS11354,Function module: identification-Bootloader version,100,
IDE10843-MAS11355,Function module: identification-Application version,0,
IDE10843-MAS11356,Function module: identification-Module Name,IPL,
IDE10857-MAS02476,Touchless loading of mobile phone: status-install,Not available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-charge,No,
IDE11034-MAS01482,Satellite radio: module information-Hardwareversion,01-00-01---,
IDE11034-MAS11961,Satellite radio: module information-Serial number,HZR0RA09,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,8E D0 08 00 48 5A 52 30 52 41 30 39 00 02 98 07 8A 38 64 68 F5 31 71 89 46 FF 18 07 54 D2 CD 37 24 3B 6C 6D BE 39 00 08 00 66 03 41 00 09 00 66 00 07,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,0b-26-00---,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,02-04-04---,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,03-05-00---,
IDE11034-MAS11966,Satellite radio: module information-Database Version,02-04-04--A,
IDE11504-ENG127677,Satellite radio tuner: pre-activated subscription-SDARS_preactivation_coding status,Yes,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,58,
MAS00481-ENG117777,BAP-BAP_Function_ID,FF,
MAS00778-IDE03619,Multimedia display unit 1-System status,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,5, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,13, min
MAS00778-MAS00362,Multimedia display unit 1-Battery voltage,14.4, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,67, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,47, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,100, %
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,1,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Mute,
MAS01760-MAS02949,Radio Tuner 1-Frequency,6553.5, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,0, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,255, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),1260, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,255,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,1,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,0, dBµV
MAS01991-IDE00010,Card reader-Serial number,19 B5 47 9D,
MAS01991-IDE01001,Card reader-Application,AP,
MAS01991-MAS01632,Card reader-Status,connected,
MAS01991-MAS03159,Card reader-Manufacturer,09,
MAS01991-MAS03375,Card reader-Major version,2,
MAS01991-MAS03376,Card reader-Minor version,0,
MAS01991-MAS03959,Card reader-Write-protection,activated,
MAS01991-MAS04388,Card reader-Card type,MIBST,
MAS01991-MAS13476,Card reader-Manufacturing date: month,8, mon
MAS01991-MAS13477,Card reader-Manufacturing date: year,2018, yr
MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
MAS03780-IDE01001,Card reader 2-Application,--,
MAS03780-MAS01632,Card reader 2-Status,not connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
MAS03780-MAS03375,Card reader 2-Major version,15,
MAS03780-MAS03376,Card reader 2-Minor version,15,
MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
MAS03780-MAS04388,Card reader 2-Card type,-----,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, mon
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
MAS03782-ENG117422,WLAN-IP_Address,,
MAS03782-ENG117423,WLAN-IP_Subnetmask,,
MAS03782-ENG117421,WLAN-MAC_Address,00 00 00 00 00 00,
MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,23490384696518515,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,SPP,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,11,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,13,
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,0, min
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,15, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,16, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,9, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,36, s
ENG117869-ENG117441,Nav._Calculated_Direction-driving direction corrected,60, °
ENG117869-ENG98933,Nav._Calculated_Direction-Status,OK,
ENG122217-ENG122284,SDARS_service-audio_service,subscribed,
ENG122217-ENG122285,SDARS_service-traffic_service,subscribed,
ENG122217-ENG122286,SDARS_service-travel_link_service,subscribed,
ENG122216-MAS00106,SDARS_subscription_status-Year,2034,
ENG122216-MAS00107,SDARS_subscription_status-Month,1,
ENG122216-MAS00108,SDARS_subscription_status-Day,1,
ENG122216-MAS00109,SDARS_subscription_status-Hours,31,
ENG122216-MAS00110,SDARS_subscription_status-Minutes,63,
ENG122216-MAS00111,SDARS_subscription_status-Seconds,63,
ENG122216-ENG122279,SDARS_subscription_status-SDARS_subscription,subscribed,
ENG122216-ENG125804,SDARS_subscription_status-SDARS_suspend_alert,0,
ENG122216-ENG122280,SDARS_subscription_status-SDARS_suspension,not_suspended,
ENG127487-IDE02451,SDARS_tuner_status_2-Satellite radio antenna status,Electrical OK,
ENG127487-IDE02453,SDARS_tuner_status_2-Channel selection for satellite radio,38,
ENG127487-MAS01765,SDARS_tuner_status_2-Audio Signal,Available,
ENG127487-MAS01808,SDARS_tuner_status_2-Antenna current,108, mA
ENG127487-MAS02573,SDARS_tuner_status_2-Reception quality,optimum_signal,
ENG127487-MAS13343,SDARS_tuner_status_2-Satellite radio tuner: pre-activation status,07,
ENG127487-MAS13344,SDARS_tuner_status_2-Satellite radio tuner: pre-activation value,07,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,not activated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,65535,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,65535,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,46592,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,65535,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,65535,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,47873,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,65535,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,65535,
ENG117858-MAS01424,System_Temperature_Sensor_2-max.value,61, °C
ENG117858-MAS01425,System_Temperature_Sensor_2-min.value,0, °C
ENG117858-MAS02238,System_Temperature_Sensor_2-Current,46, °C
ENG117860-MAS01424,System_Temperature_Sensor_4-max.value,50, °C
ENG117860-MAS01425,System_Temperature_Sensor_4-min.value,-3, °C
ENG117860-MAS02238,System_Temperature_Sensor_4-Current,34, °C
ENG117862-MAS01424,System_Temperature_Sensor_6-max.value,59, °C
ENG117862-MAS01425,System_Temperature_Sensor_6-min.value,0, °C
ENG117862-MAS02238,System_Temperature_Sensor_6-Current,44, °C
Elapsed Time: 00:22
69:
;SW:5Q0-907-383-L   HW:5Q0-907-383-L ---  Trailer
;Component:Anhaenger     H27 0260, Coding:0200000200000000
;EV_TrailFunctGener2Hella,001008,EV_TrailFunctGener2Hella_VW26.rod
;Monday,17,June,2019,11:03:57:34333
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: C0CC0DB65B055E4F55-8094
Group,Description,Actual
IDE00323,Security Access: Number of invalid keys,0,
IDE01441-IDE02270,Back-up light-CAN input signal(s) status,OFF,
IDE01441-IDE04759,Back-up light-Hardware output,OFF,
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE01943-IDE05405,Turn signal-Hardware output for left,OFF,
IDE01943-IDE05406,Turn signal-Hardware output for right,OFF,
IDE01943-IDE05407,Turn signal-Light source detection for left,Measured value not available,
IDE01943-IDE05408,Turn signal-Light source detection for right,Measured value not available,
IDE01943-MAS00525,Turn signal-Trailer turn signal indicator lamp,OFF,
IDE01943-MAS04425,Turn signal-Left turn signal via CAN,OFF,
IDE01943-MAS04426,Turn signal-Right turn signal via CAN,OFF,
IDE01943-MAS04427,Turn signal-Emergency flasher signal via CAN,Measured value not available,
IDE02486-MAS01632,Data logger triggering-Status,not activated,
IDE03310-IDE02271,Brake light-CAN output signal(s) status,OFF,
IDE03310-IDE04751,Brake light-Hardware input,OFF,
IDE03310-IDE04759,Brake light-Hardware output,OFF,
IDE03310-IDE04803,Brake light-Light source detection,Measured value not available,
IDE03310-MAS04422,Brake light-Brake light signal via CAN,OFF,
IDE03310-MAS04423,Brake light-Automatic braking signal via CAN,OFF,
IDE03310-MAS04424,Brake light-Driver brakes signal via CAN,OFF,
IDE03310-MAS09719,Brake light-Status of output signal 2 via CAN,OFF,
IDE03310-MAS09720,Brake light-Signal 2 automatic braking via CAN,OFF,
IDE03527-IDE00075,CAN signals-Vehicle speed,0.00, km/h
IDE03527-IDE01211,CAN signals-Static current measuring mode,not active,
IDE03527-IDE02049,CAN signals-Trailer detected,not recognized,
IDE03527-MAS00217,CAN signals-Rear window,OFF,
IDE03527-MAS02290,CAN signals-Rear lid,OFF,
IDE03680-IDE00020,Supply voltages-Terminal 15 status,On,
IDE03680-IDE00773,Supply voltages-Terminal 15 status via CAN,On,
IDE03680-IDE04760,Supply voltages-Terminal 30 status output (pin 9 power outlet),OFF,
IDE03680-IDE04761,Supply voltages-Terminal 30 status output controlled (pin 10 power outlet),not coded/not installed,
IDE03680-IDE05404,Supply voltages-Status terminal 75x via CAN,On,
IDE03680-IDE05967,Supply voltages-Voltage terminal 30 left,14.4, V
IDE03680-IDE05968,Supply voltages-Voltage terminal 30 right,14.4, V
IDE03680-IDE05969,Supply voltages-Voltage terminal 30 trailer supply,14.4, V
IDE03680-IDE05970,Supply voltages-Voltage terminal 30 engine supply,Measured value not available,
IDE03680-IDE10782,Supply voltages-Voltage terminal 30 charging output,Measured value not available,
IDE05413-IDE05405,Tail light-Hardware output for left,OFF,
IDE05413-IDE05406,Tail light-Hardware output for right,OFF,
IDE05413-IDE05407,Tail light-Light source detection for left,Measured value not available,
IDE05413-IDE05408,Tail light-Light source detection for right,Measured value not available,
IDE05413-MAS04428,Tail light-Tail light signal via CAN,OFF,
IDE05413-MAS04429,Tail light-Left parking light signal via CAN,OFF,
IDE05413-MAS04430,Tail light-Right parking light signal via CAN,OFF,
IDE05594-IDE04762,Trailer hitch motor management-Fully electrical trailer hitch,retracted,
IDE05594-IDE04802,Trailer hitch motor management-Trailer swing warning,no warning,
IDE05594-MAS02002,Trailer hitch motor management-Pivoting trailer hitch,OFF,
IDE05594-MAS04336,Trailer hitch motor management-Pivoting: status,locked,
IDE05594-MAS04337,Trailer hitch motor management-Engine current,0.0, A
IDE05594-MAS04338,Trailer hitch motor management-Hall sensor,0,
IDE05594-MAS04339,Trailer hitch motor management-Contact switch 1 on lock pin,closed,
IDE05594-MAS04340,Trailer hitch motor management-Contact switch 2 on lock pin,Open,
IDE05594-MAS04495,Trailer hitch motor management-Connector A diagnosis,detected,
IDE09591-ENG125418,Trailer hitch indicator light-Trailor_hitch_indicator_lamp,not coded/not installed,
IDE09592-ENG125418,Trailer hitch indicator light 2-Trailor_hitch_indicator_lamp,not coded/not installed,
IDE09593,Trailer brake activation,OFF,
IDE09594,Trailer brake activation: diagnosis,no error,
IDE12009-IDE09554,Trailer load and trailer nose recognition: values-Voltage supply,14.4, V
IDE12009-MAS01561,Trailer load and trailer nose recognition: values-Unit,not coded/not installed,
IDE12009-MAS13747,Trailer load and trailer nose recognition: values-Trailer nose,not coded/not installed,
IDE12009-MAS13748,Trailer load and trailer nose recognition: values-Trailer load,65534,
IDE12009-ENG98504,Trailer load and trailer nose recognition: values-Day,FF,
IDE12009-ENG98748,Trailer load and trailer nose recognition: values-Month,FF,
IDE12009-ENG99063,Trailer load and trailer nose recognition: values-Year,FF,
MAS03836-IDE02270,Rear fog light-CAN input signal(s) status,OFF,
MAS03836-IDE02271,Rear fog light-CAN output signal(s) status,not active,
MAS03836-IDE04759,Rear fog light-Hardware output,OFF,
MAS03836-IDE04803,Rear fog light-Light source detection,Measured value not available,
MAS04102-IDE04756,Controls-Button for trailer hitch: extend,not coded/not installed,
MAS04102-IDE04757,Controls-Button for trailer hitch: retract,not coded/not installed,
MAS04102-IDE04758,Controls-Button for trailer hitch: unlock,not coded/not installed,
MAS04102-IDE05792,Controls-Handwheel contact switch,not coded/not installed,
MAS04102-MAS04341,Controls-Function illumination supply voltage: status,not coded/not installed,
MAS04606-IDE03615,Parameter set-Version,Variant A,
MAS04606-MAS01159,Parameter set-Version number,1,
Elapsed Time: 00:09
6C:
;SW:5Q0-907-556-C   HW:5Q0-907-556 ---  Back-up Cam.
;Component:Areaview 2    H13 0608, Coding:01140604A30F20003000400C
;EV_CamSysRVAV2ARCE2MQBAB,006017,EV_CamSysRVAV2ARCE2MQBAB.rod
;Monday,17,June,2019,11:04:10:34333
;VCID: B93A605238DF0F8712-80EC
IDE00019,Voltage terminal 30,14.09870, V
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.00, km/h
IDE00303-MAS00218,Status of doors/lids 1-Driver door,Open,
IDE00303-MAS00219,Status of doors/lids 1-Front Passenger Door,closed,
IDE00303-MAS00220,Status of doors/lids 1-Left rear door,closed,
IDE00303-MAS00221,Status of doors/lids 1-Right rear door,closed,
IDE00303-MAS00222,Status of doors/lids 1-Rear lid,closed,
IDE00303-MAS00223,Status of doors/lids 1-Hood,closed,
IDE00303-MAS01374,Status of doors/lids 1-Trailer,not recognized,
IDE00773,Terminal 15 status via CAN,On,
IDE00924-IDE08941,Steering angle-Rack position,163.78, mm
IDE00924-MAS02471,Steering angle-Sign,Negative,
IDE00924-MAS02983,Steering angle-Steering wheel angle,2.0, °
IDE00924,Steering angle,0.0500, °
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,81.89, °
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Positive,
IDE01164,Park assist button,not activated,
IDE01632,System condition of park assist,not active,
IDE01714,Status reverse gear,not selected,
IDE02322,Parking aid indicator light,not active,
IDE02486,Data logger triggering,not active,
IDE04515-MAS10857,Supply voltage for camera-Camera front,12.0, V
IDE04515-MAS10858,Supply voltage for camera-Camera rear,12.0, V
IDE04515-MAS10859,Supply voltage for camera-Camera left,12.0, V
IDE04515-MAS10860,Supply voltage for camera-Camera right,12.0, V
IDE05418-MAS02209,Image adjustment-Image contrast,50, %
IDE05418-MAS02851,Image adjustment-Brightness,50, %
IDE05418-MAS04278,Image adjustment-Color intensity,50, %
IDE07159-MAS01155,Control module switch-off: counter-Control module,50,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,50,
IDE07402,External activation,not active,
IDE10548-MAS11001,Reasons for poor image quality-Reason,Environmental conditions,
IDE10548-MAS11002,Reasons for poor image quality-current likeliness,0.0000000,
IDE10589-MAS10857,Temperature of the camera-Camera front,57, °C
IDE10589-MAS10858,Temperature of the camera-Camera rear,58, °C
IDE10589-MAS10859,Temperature of the camera-Camera left,62, °C
IDE10589-MAS10860,Temperature of the camera-Camera right,62, °C
IDE10605-MAS01482,Camera front: version information-Hardwareversion,013,
IDE10605-MAS01483,Camera front: version information-Softwareversion,0107,
IDE10605-MAS04970,Camera front: version information-Part Number,5Q0980546A.,
IDE10606-MAS01482,Camera rear: version information-Hardwareversion,013,
IDE10606-MAS01483,Camera rear: version information-Softwareversion,0107,
IDE10606-MAS04970,Camera rear: version information-Part Number,5Q0980546A.,
IDE10607-MAS01482,Camera left: version information-Hardwareversion,013,
IDE10607-MAS01483,Camera left: version information-Softwareversion,0107,
IDE10607-MAS04970,Camera left: version information-Part Number,5Q0980546A.,
IDE10608-MAS01482,Camera right: version information-Hardwareversion,013,
IDE10608-MAS01483,Camera right: version information-Softwareversion,0107,
IDE10608-MAS04970,Camera right: version information-Part Number,5Q0980546A.,
IDE10648,Operation time of the ARA function,0.000, s
IDE10649,ARA Status of camera,Initializing,
IDE10650,ARA camera function: activation,not active,
IDE10666-MAS10857,Connection status camera-Camera front,Normal oper.,
IDE10666-MAS10858,Connection status camera-Camera rear,Normal oper.,
IDE10666-MAS10859,Connection status camera-Camera left,Normal oper.,
IDE10666-MAS10860,Connection status camera-Camera right,Normal oper.,
IDE10740-IDE01453,System state area view-MMI display request,not requested,
IDE10740-IDE01454,System state area view-MMI display feedback,No display,
IDE10740-IDE03619,System state area view-System status,System active,
IDE10740-MAS02224,System state area view-Display request,passive,
IDE11014-MAS10857,Calibration table status-Camera front,Not Present,
IDE11014-MAS10858,Calibration table status-Camera rear,Not Present,
IDE11014-MAS10859,Calibration table status-Camera left,Not Present,
IDE11014-MAS10860,Calibration table status-Camera right,Not Present,
IDE11016-MAS11931,Rear camera: quality-Connection quality,Good,
IDE11016-MAS11932,Rear camera: quality-Counter open circuit,0,
IDE11016-MAS11933,Rear camera: quality-Counter CRC error,0,
IDE11017-MAS11931,Front camera: quality-Connection quality,Good,
IDE11017-MAS11932,Front camera: quality-Counter open circuit,0,
IDE11017-MAS11933,Front camera: quality-Counter CRC error,0,
IDE11018-MAS11931,Left camera: quality-Connection quality,Good,
IDE11018-MAS11932,Left camera: quality-Counter open circuit,0,
IDE11018-MAS11933,Left camera: quality-Counter CRC error,0,
IDE11019-MAS11931,Right camera: quality-Connection quality,Good,
IDE11019-MAS11932,Right camera: quality-Counter open circuit,0,
IDE11019-MAS11933,Right camera: quality-Counter CRC error,0,
IDE11129-ENG01653,Line calibration status-Line_calibration_max_deviation_exceeded,not_set,
IDE11129-ENG01656,Line calibration status-Line_calibration_max_final_error_exceeded,not_set,
IDE11129-ENG01651,Line calibration status-Line_calibration_not_successful,not_set,
IDE11129-ENG01650,Line calibration status-Line_calibration_running,Not_running,
IDE11129-ENG01652,Line calibration status-Line_calibration_solver_error,not_set,
IDE11129-ENG01654,Line calibration status-Line_calibration_solver_max_iterations_reached,Not_reached,
IDE11129-ENG01649,Line calibration status-Line_calibration_successful,Set,
IDE11129-ENG01655,Line calibration status-Line_detection_failure,not_set,
IDE11130-MAS12219,Line calibration error-Left front Range,detected,
IDE11130-MAS12220,Line calibration error-Right front Range,detected,
IDE11130-MAS12221,Line calibration error-Left rear range,detected,
IDE11130-MAS12222,Line calibration error-Right rear range,detected,
IDE11130-MAS12223,Line calibration error-Left horizontal range,detected,
IDE11130-MAS12224,Line calibration error-Left vertical range,detected,
IDE11130-MAS12225,Line calibration error-Right horizontal range,detected,
IDE11130-MAS12226,Line calibration error-Right vertical range,detected,
IDE11137,Line calibration phases,Calibration ended,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,7,
MAS00464-MAS00108,Standard - ambient data 1-Day,17,
MAS00464-MAS00109,Standard - ambient data 1-Hours,10,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,21,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,26,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,11,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,118, km
ENG26246-ENG30009,Camera_calibration_values-Front_camera_H_position_deviation,1114837648,
ENG26246-ENG30010,Camera_calibration_values-Front_camera_X_rotation_deviation,3212445541,
ENG26246-ENG30011,Camera_calibration_values-Front_camera_Y_rotation_deviation,3230454568,
ENG26246-ENG30012,Camera_calibration_values-Front_camera_Z_rotation_deviation,3210211421,
ENG26246-ENG30023,Camera_calibration_values-Left_camera_H_position_deviation,1108468704,
ENG26246-ENG30024,Camera_calibration_values-Left_camera_X_rotation_deviation,3185540739,
ENG26246-ENG30025,Camera_calibration_values-Left_camera_Y_rotation_deviation,3209431275,
ENG26246-ENG30026,Camera_calibration_values-Left_camera_Z_rotation_deviation,3203468978,
ENG26246-ENG30071,Camera_calibration_values-Rear_camera_H_position_deviation,1105674784,
ENG26246-ENG30072,Camera_calibration_values-Rear_camera_X_rotation_deviation,3220542129,
ENG26246-ENG30073,Camera_calibration_values-Rear_camera_Y_rotation_deviation,1029086538,
ENG26246-ENG30074,Camera_calibration_values-Rear_camera_Z_rotation_deviation,1064802539,
ENG26246-ENG30096,Camera_calibration_values-Right_camera_H_position_deviation,1109980672,
ENG26246-ENG30097,Camera_calibration_values-Right_camera_X_rotation_deviation,1051337983,
ENG26246-ENG30098,Camera_calibration_values-Right_camera_Y_rotation_deviation,3213490837,
ENG26246-ENG30099,Camera_calibration_values-Right_camera_Z_rotation_deviation,1062314552,
Elapsed Time: 00:23
6D:
;SW:5Q0-959-107-P   HW:5Q0-959-107-J ---  Trunk Elect.
;Component:HDSG-Modul    H13 0266, Coding:0988
;EV_DeckLidCONTIAU736,001016,EV_DeckLidCONTIAU736_VW41.rod
;Monday,17,June,2019,11:04:36:34333
;VCID: C5C21CA244277B6766-8090
IDE00019,Voltage terminal 30,12.98, V
IDE00542,Excessive temperature protection,not active,
IDE02010,Motor 1 for rear lid: activation,0, %
IDE02011,Motor 1 for tailgate: current,0.00, A
IDE02013,Motor 2 for rear lid: activation,0, %
IDE02014,Motor 2 for tailgate: current,0.00, A
IDE02017,Rear lid position: relative,0, %
IDE02018,Rear lid position: absolute,0,
IDE02019-MAS08993,Position programmable opening stop-Upper end pos.: relative,99, %
IDE02019-MAS08994,Position programmable opening stop-Upper end pos.: absolute,1712,
IDE02049,Trailer detected,not recognized,
IDE02093-MAS09014,Status of rear lid lock-Safety catch,closed,
IDE02093-MAS09015,Status of rear lid lock-Main catch,closed,
IDE02093-MAS09016,Status of rear lid lock-Rear lid lock,closed,
IDE02094-MAS09057,Status of closing assist-Limit switch for pull-shut assist.,operated,
IDE02095-MAS01947,Status of pinch protection-Clamping strip 1,not activated,
IDE02095-MAS01948,Status of pinch protection-Clamping strip 2,not activated,
IDE02095-MAS01949,Status of pinch protection-Clamping strip 3,not activated,
IDE02095-MAS01950,Status of pinch protection-Clamping strip 4,not activated,
IDE02171-MAS01913,Terminals for closing assist-Pull-shut asst.,not locked,
IDE02171-MAS01943,Terminals for closing assist-Terminal 1,Open,
IDE02171-MAS01944,Terminals for closing assist-Terminal 2,Open,
IDE03427-MAS08995,Upper end stop: maximum value-Max. upper end position,1724,
IDE03615-MAS02672,Version-Start-stop,2,
IDE03906-MAS01947,Pinch protection voltage supply status-Clamping strip 1,OFF,
IDE03906-MAS01948,Pinch protection voltage supply status-Clamping strip 2,OFF,
IDE03906-MAS01949,Pinch protection voltage supply status-Clamping strip 3,OFF,
IDE03906-MAS01950,Pinch protection voltage supply status-Clamping strip 4,OFF,
IDE05229-MAS09002,Reason for cancellation of rear lid procedure-Last reason,Lock malfunction,
IDE05229-MAS09003,Reason for cancellation of rear lid procedure-second last reasons,END,
IDE05229-MAS09004,Reason for cancellation of rear lid procedure-third last reason,END,
IDE05229-MAS09005,Reason for cancellation of rear lid procedure-fourth last reason,Blocking detection,
IDE05229-MAS09006,Reason for cancellation of rear lid procedure-fifth last reason,END,
IDE05584,Rear lid basic setting status,Unknown (18),
IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE09491-IDE03434,Lock-in area-Detection area lower,100,
IDE09491-IDE03435,Lock-in area-Detection area upper,20,
IDE09492-MAS06165,Temperatures-Processor,41.00, °C
IDE09492-MAS08858,Temperatures-Outside air temperature on CAN,29.00, °C
IDE09492-MAS08996,Temperatures-Internal temp. on CAN,0.00, °C
IDE09492-MAS08997,Temperatures-Output stage for tailgate motor,38.00, °C
IDE09492-MAS08998,Temperatures-Tailgate motor left,29.00, °C
IDE09492-MAS08999,Temperatures-Tailgate motor right,29.00, °C
IDE09492-MAS09001,Temperatures-Closing Assist Motor,Not available,
IDE09492-MAS09051,Temperatures-Output stage for tailgate motor: calculated,38.00, °C
IDE09492-MAS09053,Temperatures-Output stage for pull-shut assist.: calc.,Not available,
IDE09492-MAS11205,Temperatures-Luggage compartment cover motor,0.00, °C
IDE09492-MAS11206,Temperatures-Output stage for luggage comp. cover: calc.,38.00, °C
IDE09493,Status of basic tailgate setting,Basic setting not active,
IDE09494-MAS09002,Cancellation reason of basic tailgate setting-Last reason,Cancel,
IDE09494-MAS09003,Cancellation reason of basic tailgate setting-second last reasons,Cancel,
IDE09494-MAS09004,Cancellation reason of basic tailgate setting-third last reason,Cancel,
IDE09494-MAS09005,Cancellation reason of basic tailgate setting-fourth last reason,Cancel,
IDE09494-MAS09006,Cancellation reason of basic tailgate setting-fifth last reason,Cancel,
IDE09495,Status of tailgate initialization,initialized,
IDE09496-MAS09002,Reason for loss of tailgate initialization-Last reason,Reset,
IDE09496-MAS09003,Reason for loss of tailgate initialization-second last reasons,Position overrun,
IDE09496-MAS09004,Reason for loss of tailgate initialization-third last reason,Position overrun,
IDE09496-MAS09005,Reason for loss of tailgate initialization-fourth last reason,Position overrun,
IDE09496-MAS09006,Reason for loss of tailgate initialization-fifth last reason,Position overrun,
IDE09498-MAS01871,Status of control points-Rear lid lock button in luggage compartment,not activated,
IDE09498-MAS01872,Status of control points-Rear lid remote release button,not activated,
IDE09498-MAS06265,Status of control points-Release button in rear lid handle,not activated,
IDE09498-MAS06446,Status of control points-Remote radio control: button for luggage compartment unlocking,not activated,
IDE09498-MAS09010,Status of control points-Sensor for rear lid opening,not activated,
IDE09498-MAS09072,Status of control points-Locking mechanism button in the rear lid,ERROR,
IDE09498-MAS13753,Status of control points-Button 2 for rear lid remote release,ERROR,
IDE09499-IDE01991,Motors for tailgate: activation-Motor 1 for tailgate: status,OFF,
IDE09499-IDE02012,Motors for tailgate: activation-Motor 2 for tailgate: status,OFF,
IDE09499-MAS09001,Motors for tailgate: activation-Closing Assist Motor,OFF,
IDE09499-MAS11205,Motors for tailgate: activation-Luggage compartment cover motor,OFF,
IDE09500-MAS09012,Motors for tailgate: RPM-Rear lid motor 1,0.00, Hz
IDE09500-MAS09013,Motors for tailgate: RPM-Rear lid motor 2,0.00, Hz
IDE09500-MAS11205,Motors for tailgate: RPM-Luggage compartment cover motor,0.00, Hz
IDE09501-MAS09001,Motors for tailgate: elec. current-Closing Assist Motor,0.00, A
IDE09501-MAS09012,Motors for tailgate: elec. current-Rear lid motor 1,0.00, A
IDE09501-MAS09013,Motors for tailgate: elec. current-Rear lid motor 2,0.00, A
IDE09501-MAS11205,Motors for tailgate: elec. current-Luggage compartment cover motor,0.50, A
IDE09502-IDE02097,Tailgate angle sensor: absolute value-Position Sensor 1,0,
IDE09502-IDE02098,Tailgate angle sensor: absolute value-Position sensor 2,0,
IDE09502-IDE10697,Tailgate angle sensor: absolute value-Luggage compartment cover: position,0,
IDE09503-IDE02017,Tailgate angle sensor: relative value-Rear lid position: relative,0, %
IDE09503-MAS11205,Tailgate angle sensor: relative value-Luggage compartment cover motor,0, %
IDE09504,Status of clutch test,not active,
IDE09505-IDE02078,Tailgate actuation counter-Activations of rear lid closing button,34,
IDE09505-IDE02079,Tailgate actuation counter-Activations of rear lid unlocking button,44,
IDE09505-IDE02080,Tailgate actuation counter-Activations of rear lid remote unlocking switch,8,
IDE09505-IDE02081,Tailgate actuation counter-Activation of remote key button rid lid opening,4,
IDE09505-IDE02082,Tailgate actuation counter-Opening cycle counter,25,
IDE09505-IDE02083,Tailgate actuation counter-Closing cycle counter,27,
IDE09505-IDE02084,Tailgate actuation counter-Counter obstruction detected,5,
IDE09505-IDE02085,Tailgate actuation counter-Counter of selectable opening stop adapted,0,
IDE09505-IDE02087,Tailgate actuation counter-Counter for function limitation due to insufficient voltage,0,
IDE09505-IDE02088,Tailgate actuation counter-Counter for function limitation due to excessive voltage,0,
IDE09505-IDE02090,Tailgate actuation counter-Counter for function limitation due to excessive temperature,0,
IDE09505-IDE02174,Tailgate actuation counter-Counter of flap opening angle basic settings,25,
IDE09505-IDE03774,Tailgate actuation counter-Counter for closing operations canceled by lock-up,5,
IDE09505-MAS08873,Tailgate actuation counter-Resets to hardware watchdog,0,
IDE09505-MAS08874,Tailgate actuation counter-Resets due to software watchdog,0,
IDE09505-MAS09017,Tailgate actuation counter-Counter tailgate lock: implausible,7,
IDE09505-MAS09018,Tailgate actuation counter-Counter pull-shut asst. implausible,0,
IDE09505-MAS09019,Tailgate actuation counter-Play protection counter active,0,
IDE09505-MAS09058,Tailgate actuation counter-Counter Hall sensor in motor 1 for tailgate implausible,0,
IDE09505-MAS09059,Tailgate actuation counter-Counter Hall sensor in motor 2 for tailgate implausible,0,
IDE09505-MAS09060,Tailgate actuation counter-Wake-up events button for closing rear lid in lugg.compartment,11,
IDE09505-MAS09061,Tailgate actuation counter-Wake-up events Hall sensor in motor for tailgate,6,
IDE09505-MAS09062,Tailgate actuation counter-Wake-up events in data bus,351,
IDE09505-MAS09076,Tailgate actuation counter-Activating tailgate button for locking,0,
IDE09505-MAS09077,Tailgate actuation counter-Activating sensor for tailgate opening,0,
IDE09505-MAS09078,Tailgate actuation counter-Wake-up events button for unlocking tailgate,0,
IDE09505-MAS09482,Tailgate actuation counter-Current limitation active,0,
IDE09505-MAS10783,Tailgate actuation counter-Closing assist.counter: aborted by operating unit,0,
IDE09505-MAS11977,Tailgate actuation counter-Emergency running counter after terminal 30 reset,12,
IDE09505-MAS11978,Tailgate actuation counter-Play protection counter for closing aid active,0,
IDE09505-MAS12517,Tailgate actuation counter-Reset via timeout monitoring watchdog,0,
IDE09505-MAS12518,Tailgate actuation counter-Reset via network management monitoring watchdog,0,
IDE09505-MAS13753,Tailgate actuation counter-Button 2 for rear lid remote release,0,
IDE09506,Tailgate play protection,not active,
IDE09519-MAS09054,Status of hall sensor in motor for tailgate-Motor 1 for tailgate: Hall sensor voltage supply,OFF,
IDE09519-MAS09055,Status of hall sensor in motor for tailgate-Motor 2 for tailgate: Hall sensor voltage supply,OFF,
IDE09519-MAS09066,Status of hall sensor in motor for tailgate-Motor 1: Sensor 1,00000000 ,
IDE09519-MAS09067,Status of hall sensor in motor for tailgate-Motor 1: Sensor 2,00000000 ,
IDE09519-MAS09068,Status of hall sensor in motor for tailgate-Motor 2: Sensor 1,00000000 ,
IDE09519-MAS09069,Status of hall sensor in motor for tailgate-Motor 2: Sensor 2,00000000 ,
IDE09519-MAS11207,Status of hall sensor in motor for tailgate-Motor for luggage comp. cover: sensor 1,00000000 ,
IDE09519-MAS11209,Status of hall sensor in motor for tailgate-Motor for luggage compartment cover: Hall sensor voltage supply,OFF,
IDE10697-MAS01471,Luggage compartment cover: position-lower stop,0,
IDE10697-MAS01472,Luggage compartment cover: position-upper stop,0,
IDE10697-MAS02282,Luggage compartment cover: position-Position,0,
IDE10698-IDE03774,Luggage compartment cover: counter-Counter for closing operations canceled by lock-up,0,
IDE10698-MAS09020,Luggage compartment cover: counter-Down adjustment,0,
IDE10698-MAS09021,Luggage compartment cover: counter-Up adjustment,0,
IDE10698-MAS09023,Luggage compartment cover: counter-Total number of adjustments,0,
IDE10698-MAS09024,Luggage compartment cover: counter-Shutdowns by excess force limiter,0,
IDE10698-MAS09025,Luggage compartment cover: counter-Blocking bottom mechan. stop,0,
IDE10698-MAS09026,Luggage compartment cover: counter-Blocking upper mechan. stop,0,
IDE10698-MAS09027,Luggage compartment cover: counter-Re-initializationn in bottom mechan. stop,0,
IDE10698-MAS09028,Luggage compartment cover: counter-Re-initialization in upper mechan. stop,0,
IDE10698-MAS09029,Luggage compartment cover: counter-Number of re-initializations,0,
IDE10699-MAS00342,Status of luggage compartment cover initialization-Initializing,not initialized,
IDE10700-MAS09002,Reason for loss of luggage compartment cover initialization-Last reason,Not yet initialized,
IDE10700-MAS09003,Reason for loss of luggage compartment cover initialization-second last reasons,Not yet initialized,
IDE10700-MAS09004,Reason for loss of luggage compartment cover initialization-third last reason,Not yet initialized,
IDE10700-MAS09005,Reason for loss of luggage compartment cover initialization-fourth last reason,Not yet initialized,
IDE10700-MAS09006,Reason for loss of luggage compartment cover initialization-fifth last reason,Not yet initialized,
IDE10804,Easing of rear lid,not active,
IDE11033,Motor for luggage compart. cover: excess. temp: protection,not active,
IDE11036,Pull-shut asst.: play protec.,not active,
IDE11868,Indicator lamp for delayed closing,not installed,
IDE13157,Partial network operation counter not available,0,
MAS00972,Decoration variant,6,
Elapsed Time: 00:06
75:
;SW:5QE-035-285-A   HW:5QE-035-285-A ---  Telematics
;Component:OCULowMQBUS   009 0570, Coding:02140602C2823A017F1E06020000
;EV_OCULowMQB,001006,EV_OCULowMQB.rod
;Monday,17,June,2019,11:04:45:34333
;VCID: C3C602BA4A13455748-8096
IDE00019,Voltage terminal 30,12.7, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,44, °C
IDE00608,Type of fuel,Petrol,
IDE00667,Microphone status,Electrical OK,
IDE00668,Microphone current consumption,5.0, mA
IDE00672,Roadside Assistance Button,not activated,
IDE00673,Information Service Button,not activated,
IDE00767,No. of unscheduled ECU resets,0,
IDE01215,Terminal 58d dimmer,94.88, %
IDE01625,Muting of radio/radio navigation system via control wire,Measured value not available,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,W84°6'42.044",
IDE01712-MAS01780,GPS Position-Width,N35°54'20.236",
IDE01712-MAS02230,GPS Position-Height,292, m
IDE01713-MAS01632,Status GPS reception-Status,No GPS reception,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,15,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,9,
IDE01715,Status terminal S,On,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,0, mA
IDE01971,Lowest recorded control module temperature,1, °C
IDE01972,Highest recorded control module temperature,64, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,Electrical OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,1, mA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,100.0, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,0,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,0,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,0,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,0,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,0, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE02486,Data logger triggering,Measured value not available,
IDE03348-MAS01586,Speed warning-Alarm,0,
IDE03348,Speed warning,655.33, km/h
IDE03348-MAS08775,Speed warning-Calculation frequency,5, s
IDE03348-MAS08776,Speed warning-tolerance,5, m
IDE03348-MAS08777,Speed warning-Contact bounce suppression,5, s
IDE03477-MAS00110,GPS time-Minutes,4,
IDE03477-MAS00111,GPS time-Seconds,42,
IDE04605-IDE01712,Navigation: Corrected position-GPS Position,Not available,
IDE04605-MAS01779,Navigation: Corrected position-Length,84111680,
IDE04605-MAS01780,Navigation: Corrected position-Width,35905623,
IDE04605-ENG123297,Navigation: Corrected position-error_value,0, m
IDE04750-MAS03876,SIM cards-active SIM card,internal,
IDE04750-MAS03877,SIM cards-SIM ID,89011702258201129919,
IDE04750-MAS03878,SIM cards-SIM IMSI,310170820112991,
IDE04750-MAS04226,SIM cards-Telephone number,                              ,
IDE04750-MAS08401,SIM cards-SIM intern,Available,
IDE04750-MAS08402,SIM cards-SIM extern,Not available,
IDE04790,Call for help button,not activated,
IDE05430,Telephone serial number,358895054954087,
IDE06644,Vehicle positioning system,Measured value not available,
IDE07007-IDE00983,A/C heater function via remote control-Interior temperature,255, °C
IDE07007-IDE04927,A/C heater function via remote control-Window heater,On,
IDE07007-MAS01118,A/C heater function via remote control-Climate control,Measured value not available,
IDE07007-MAS02289,A/C heater function via remote control-Outside air temperature,255, °C
IDE07007-MAS05945,A/C heater function via remote control-Specified temperature,25.7, °C
IDE07007-MAS08947,A/C heater function via remote control-After-run time for power supply,255, min
IDE07007-MAS08948,A/C heater function via remote control-After-run time for battery,255, min
IDE07007-MAS08949,A/C heater function via remote control-Climate control without power supply,On,
IDE07007-MAS08957,A/C heater function via remote control-A/C window heater,On,
IDE07007-MAS08958,A/C heater function via remote control-reason for last climate control,Measured value not available,
IDE07543,Vehicle speed,0.00, km/h
IDE07940-IDE07007,Status of enabling for online services-A/C heater function via remote control,not activated,
IDE07940-IDE07909,Status of enabling for online services-Remote control for vehicle locking,not activated,
IDE07940,Status of enabling for online services,activated,
IDE07940-IDE07974,Status of enabling for online services-Transmission of navigation targets,activated,
IDE07940-IDE07975,Status of enabling for online services-Remote control for charge function of H-V battery,not activated,
IDE07940-IDE07976,Status of enabling for online services-Info call,activated,
IDE07940-IDE08155,Status of enabling for online services-Vehicle state report,not activated,
IDE07940-IDE08158,Status of enabling for online services-Roadside assistance / schedule agreement for service,activated,
IDE07940-MAS08370,Status of enabling for online services-Position monitoring (Geofencing),not activated,
IDE07940-MAS08371,Status of enabling for online services-Remote control for speed warning,not activated,
IDE07940-MAS08372,Status of enabling for online services-Remote control for vehicle shutdown,not activated,
IDE07940-MAS08373,Status of enabling for online services-Remote control for vehicle location,activated,
IDE07940-MAS08374,Status of enabling for online services-Remote control for lights and horn,not activated,
IDE07940-MAS08375,Status of enabling for online services-Distance statistics display,not activated,
IDE07940-MAS08376,Status of enabling for online services-Display vehicle state,not activated,
IDE07940-MAS08377,Status of enabling for online services-Remote control for departure time programming,not activated,
IDE07940-MAS08448,Status of enabling for online services-Manual roadside assistance,activated,
IDE07940-MAS08449,Status of enabling for online services-Automatic roadside assistance,activated,
IDE07975-IDE00704,Remote control for charge function of H-V battery-Charge level,Measured value not available,
IDE07975-IDE01839,Remote control for charge function of H-V battery-Battery charge condition,255, %
IDE07975-IDE05431,Remote control for charge function of H-V battery-Locking for H-V charge plug,Measured value not available,
IDE07975-IDE06986,Remote control for charge function of H-V battery-H-V battery charge current: maximum value,63, A
IDE07975-MAS01002,Remote control for charge function of H-V battery-Remaining operating range,65535, km
IDE07975-MAS01118,Remote control for charge function of H-V battery-Climate control,Measured value not available,
IDE07975-MAS05682,Remote control for charge function of H-V battery-External Charging,Not available,
IDE07975-MAS08781,Remote control for charge function of H-V battery-Connection state of charging plug,Measured value not available,
IDE07975-MAS08782,Remote control for charge function of H-V battery-Remaining charge time,255, min
IDE07975-MAS08783,Remote control for charge function of H-V battery-Reason for last battery charge,Measured value not available,
IDE07975-MAS08784,Remote control for charge function of H-V battery-Charging current type,Measured value not available,
IDE08077-MAS01240,Timer 1 for programming of departure time-Programming status,Measured value not available,
IDE08077-MAS01635,Timer 1 for programming of departure time-Monday,not programmed,
IDE08077-MAS01636,Timer 1 for programming of departure time-Tuesday,not programmed,
IDE08077-MAS01637,Timer 1 for programming of departure time-Wednesday,not programmed,
IDE08077-MAS01638,Timer 1 for programming of departure time-Thursday,not programmed,
IDE08077-MAS01639,Timer 1 for programming of departure time-Friday,not programmed,
IDE08077-MAS01640,Timer 1 for programming of departure time-Saturday,not programmed,
IDE08077-MAS01641,Timer 1 for programming of departure time-Sunday,not programmed,
IDE08077-MAS08963,Timer 1 for programming of departure time-Condition of timer,Measured value not available,
IDE08077-ENG123310,Timer 1 for programming of departure time-Timer_Mode,Measured value not available,
IDE08077-ENG123309,Timer 1 for programming of departure time-Timer_Type,Measured value not available,
IDE08078-MAS01240,Timer 2 for programming of departure time-Programming status,Measured value not available,
IDE08078-MAS01635,Timer 2 for programming of departure time-Monday,not programmed,
IDE08078-MAS01636,Timer 2 for programming of departure time-Tuesday,not programmed,
IDE08078-MAS01637,Timer 2 for programming of departure time-Wednesday,not programmed,
IDE08078-MAS01638,Timer 2 for programming of departure time-Thursday,not programmed,
IDE08078-MAS01639,Timer 2 for programming of departure time-Friday,not programmed,
IDE08078-MAS01640,Timer 2 for programming of departure time-Saturday,not programmed,
IDE08078-MAS01641,Timer 2 for programming of departure time-Sunday,not programmed,
IDE08078-MAS08963,Timer 2 for programming of departure time-Condition of timer,Measured value not available,
IDE08078-ENG123310,Timer 2 for programming of departure time-Timer_Mode,Measured value not available,
IDE08078-ENG123309,Timer 2 for programming of departure time-Timer_Type,Measured value not available,
IDE08079-MAS01240,Timer 3 for programming of departure time-Programming status,Measured value not available,
IDE08079-MAS01635,Timer 3 for programming of departure time-Monday,not programmed,
IDE08079-MAS01636,Timer 3 for programming of departure time-Tuesday,not programmed,
IDE08079-MAS01637,Timer 3 for programming of departure time-Wednesday,not programmed,
IDE08079-MAS01638,Timer 3 for programming of departure time-Thursday,not programmed,
IDE08079-MAS01639,Timer 3 for programming of departure time-Friday,not programmed,
IDE08079-MAS01640,Timer 3 for programming of departure time-Saturday,not programmed,
IDE08079-MAS01641,Timer 3 for programming of departure time-Sunday,not programmed,
IDE08079-MAS08963,Timer 3 for programming of departure time-Condition of timer,Measured value not available,
IDE08079-ENG123310,Timer 3 for programming of departure time-Timer_Mode,Measured value not available,
IDE08079-ENG123309,Timer 3 for programming of departure time-Timer_Type,Measured value not available,
IDE08159-IDE07007,Status of online services-A/C heater function via remote control,not active,
IDE08159-IDE07975,Status of online services-Remote control for charge function of H-V battery,not active,
IDE08159-IDE08158,Status of online services-Roadside assistance / schedule agreement for service,not active,
IDE08159-MAS08370,Status of online services-Position monitoring (Geofencing),not active,
IDE08159-MAS08371,Status of online services-Remote control for speed warning,not active,
IDE08159-MAS08372,Status of online services-Remote control for vehicle shutdown,not active,
IDE08159-MAS08373,Status of online services-Remote control for vehicle location,not active,
IDE08159-MAS08374,Status of online services-Remote control for lights and horn,not active,
IDE08159-MAS08377,Status of online services-Remote control for departure time programming,not active,
IDE08159-MAS08448,Status of online services-Manual roadside assistance,not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,00,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,04,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status GSG,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ELV,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,4,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,0,
MAS01490-MAS08403,Energy management-Remaining short term energy budget,1000, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,3,
MAS04394-IDE03580,Connection status-Country code for mobile network,310,
MAS04394-IDE07699,Connection status-Mobile network operator,410,
MAS04394-MAS03991,Connection status-Reception level antenna 1,100.0, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,HSPA,
MAS04394-MAS08407,Connection status-Data connection,not active,
MAS04394-MAS08408,Connection status-Number of hours to next event,14,
MAS04394-MAS08409,Connection status-Number of minutes to next event,50,
MAS04394-MAS08410,Connection status-Number of seconds to next event,44,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,204679715,
MAS04394-ENG123308,Connection status-TCP_Connection_State,not active,
MAS06193-IDE06986,Profile 1-H-V battery charge current: maximum value,0, A
MAS06193-MAS04721,Profile 1-Minimum charge level,0, %
MAS06193-MAS04722,Profile 1-Maximum charge level,0, %
MAS06193-MAS08967,Profile 1-Start high voltage charging:Hour,0,
MAS06193-MAS08968,Profile 1-Start high voltage charging:Minute,0,
MAS06193-MAS08969,Profile 1-End of high voltage charging:Hour,0,
MAS06193-MAS08970,Profile 1-End of high voltage charging:Minute,0,
MAS06194-IDE06986,Profile 2-H-V battery charge current: maximum value,0, A
MAS06194-MAS04721,Profile 2-Minimum charge level,0, %
MAS06194-MAS04722,Profile 2-Maximum charge level,0, %
MAS06194-MAS08967,Profile 2-Start high voltage charging:Hour,0,
MAS06194-MAS08968,Profile 2-Start high voltage charging:Minute,0,
MAS06194-MAS08969,Profile 2-End of high voltage charging:Hour,0,
MAS06194-MAS08970,Profile 2-End of high voltage charging:Minute,0,
MAS06195-IDE06986,Profile 3-H-V battery charge current: maximum value,0, A
MAS06195-MAS04721,Profile 3-Minimum charge level,0, %
MAS06195-MAS04722,Profile 3-Maximum charge level,0, %
MAS06195-MAS08967,Profile 3-Start high voltage charging:Hour,0,
MAS06195-MAS08968,Profile 3-Start high voltage charging:Minute,0,
MAS06195-MAS08969,Profile 3-End of high voltage charging:Hour,0,
MAS06195-MAS08970,Profile 3-End of high voltage charging:Minute,0,
MAS06413,Audio signal output,Electrical OK,
MAS08178-IDE02493,Crash information-Automatic door unlocking,No,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08178-MAS08956,Crash information-Automatic emergency call activated:Fuel shut-off,No,
MAS08179,List of last telephone numbers,,
MAS08180,Remote-controlled horn and lights,0, s
MAS08181-MAS01779,Area restriction configuration-Length,0, m
MAS08181-MAS01780,Area restriction configuration-Width,0, m
MAS08181-MAS08775,Area restriction configuration-Calculation frequency,65535, s
MAS08181-MAS08776,Area restriction configuration-tolerance,65535, m
MAS08181-MAS08777,Area restriction configuration-Contact bounce suppression,65535, s
MAS08181-MAS08778,Area restriction configuration-Rotation angle,65535, °
MAS08181-MAS08779,Area restriction configuration-Zone type,Not available,
MAS08181-MAS08780,Area restriction configuration-Area type,rectangle,
MAS08183-IDE02068,Event list: horn and lights (ring memory)-Time stamp,Write only channel,
MAS08183-MAS08552,Event list: horn and lights (ring memory)-Event generated,Write only channel,
MAS08184-IDE02068,Event list: emergency call(ring memory)-Time stamp,Write only channel,
MAS08184-MAS08552,Event list: emergency call(ring memory)-Event generated,Write only channel,
MAS08185-IDE02068,Event list: vehicle shut-down (ring memory)-Time stamp,Write only channel,
MAS08185-MAS08552,Event list: vehicle shut-down (ring memory)-Event generated,Write only channel,
MAS08186-IDE02068,Event list: vehicle location (ring memory)-Time stamp,Write only channel,
MAS08186-MAS08552,Event list: vehicle location (ring memory)-Event generated,Write only channel,
MAS08187-IDE02068,Event list area restriction (ring memory)-Time stamp,Write only channel,
MAS08187-MAS08552,Event list area restriction (ring memory)-Event generated,Write only channel,
MAS08188-IDE02068,Event list: Mobile Online services (ring memory)-Time stamp,Write only channel,
MAS08188-MAS08552,Event list: Mobile Online services (ring memory)-Event generated,Write only channel,
MAS08189-IDE02068,Event list: speed warning (ring memory)-Time stamp,Write only channel,
MAS08189-MAS08552,Event list: speed warning (ring memory)-Event generated,Write only channel,
MAS08190-IDE02068,Event list: distance statistics (ring memory)-Time stamp,Write only channel,
MAS08190-MAS08552,Event list: distance statistics (ring memory)-Event generated,Write only channel,
MAS08191-IDE02068,Event list: vehicle state (ring memory)-Time stamp,Write only channel,
MAS08191-MAS08552,Event list: vehicle state (ring memory)-Event generated,Write only channel,
MAS08192-IDE02068,Event list: info call (ring memory)-Time stamp,Write only channel,
MAS08192-MAS08552,Event list: info call (ring memory)-Event generated,Write only channel,
MAS08193-IDE02068,Event list: battery charge management (ring memory)-Time stamp,Write only channel,
MAS08193-MAS08552,Event list: battery charge management (ring memory)-Event generated,Write only channel,
MAS08194-IDE02068,Event list: A/C (ring memory)-Time stamp,Write only channel,
MAS08194-MAS08552,Event list: A/C (ring memory)-Event generated,Write only channel,
MAS08195-IDE02068,Event list: departure time (ring memory)-Time stamp,Write only channel,
MAS08195-MAS08552,Event list: departure time (ring memory)-Event generated,Write only channel,
MAS08196-IDE02068,Event list: vehicle status report (ring memory)-Time stamp,Write only channel,
MAS08196-MAS08552,Event list: vehicle status report (ring memory)-Event generated,Write only channel,
MAS08197-IDE02068,Event list:roadside assist and maint. schedule(ring memory)-Time stamp,Write only channel,
MAS08197-MAS08552,Event list:roadside assist and maint. schedule(ring memory)-Event generated,Write only channel,
MAS08198-IDE02068,Event lists: imported navigation destinations (bring memory)-Time stamp,Write only channel,
MAS08198-MAS08552,Event lists: imported navigation destinations (bring memory)-Event generated,Write only channel,
MAS08199-IDE02068,Event list: vehicle locking (ring memory)-Time stamp,Write only channel,
MAS08199-MAS08552,Event list: vehicle locking (ring memory)-Event generated,Write only channel,
ENG123206-ENG123337,Antenna_Switch-GPS_Antenna_Switch,external,
ENG123206-ENG123336,Antenna_Switch-GSM_Antenna_Switch,external,
ENG123207-IDE01588,Calculated_Position_And_Direction_Areal_Update-Driving direction,0, °
ENG123207-MAS01632,Calculated_Position_And_Direction_Areal_Update-Status,Not available,
ENG123207-MAS01779,Calculated_Position_And_Direction_Areal_Update-Length,,
ENG123207-MAS01780,Calculated_Position_And_Direction_Areal_Update-Width,,
ENG123207-ENG123297,Calculated_Position_And_Direction_Areal_Update-error_value,0, m
ENG123208-MAS00106,Geofencing_schedule_start_time-Year,2000,
ENG123208-MAS00107,Geofencing_schedule_start_time-Month,0,
ENG123208-MAS00108,Geofencing_schedule_start_time-Day,0,
ENG123208-MAS00109,Geofencing_schedule_start_time-Hours,0,
ENG123208-MAS00110,Geofencing_schedule_start_time-Minutes,0,
ENG123208-MAS00111,Geofencing_schedule_start_time-Seconds,0,
ENG123209-MAS00106,Geofencing_schedule_stop_time-Year,2000,
ENG123209-MAS00107,Geofencing_schedule_stop_time-Month,0,
ENG123209-MAS00108,Geofencing_schedule_stop_time-Day,0,
ENG123209-MAS00109,Geofencing_schedule_stop_time-Hours,0,
ENG123209-MAS00110,Geofencing_schedule_stop_time-Minutes,0,
ENG123209-MAS00111,Geofencing_schedule_stop_time-Seconds,0,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,0,
ENG123212-ENG123347,GPS_Dilution_of_precision-geometric_dilution_of_precision,218,
ENG123212-ENG123346,GPS_Dilution_of_precision-horizontal_dilution_of_precision,67,
ENG123212-ENG123296,GPS_Dilution_of_precision-Initiation,initialized,
ENG123212-ENG123348,GPS_Dilution_of_precision-positional_dilution_of_precision,770,
ENG123212-ENG123345,GPS_Dilution_of_precision-time_dilution_of_precision,260,
ENG123212-ENG123344,GPS_Dilution_of_precision-vertical_dilution_of_precision,315,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,0,
ENG125913,Hybrid_Type,no_Hybrid_Car,
ENG117422,IP_Address,10.97.49.239,
ENG117869-IDE01588,Nav._Calculated_Direction-Driving direction,338, °
ENG117869-MAS01632,Nav._Calculated_Direction-Status,Available,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,0,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,77,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,no error,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,0, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,35,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,no error,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,0,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,no error,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,38,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,0,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,0,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,0,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,0,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,0,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,3,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,0,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,0,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,0,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,no error,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,0,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,1, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,no error,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,2910, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,0,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,209804, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,no error,
ENG123204,Outgoing_call_line_state,Idle,
ENG123202,Phone_Register_State,registerstate_registered,
ENG129162-ENG98933,Serial_Tracing-Status,not activated,
ENG123210-MAS00106,Speed_alert_schedule_start_time-Year,2000,
ENG123210-MAS00107,Speed_alert_schedule_start_time-Month,0,
ENG123210-MAS00108,Speed_alert_schedule_start_time-Day,0,
ENG123210-MAS00109,Speed_alert_schedule_start_time-Hours,0,
ENG123210-MAS00110,Speed_alert_schedule_start_time-Minutes,0,
ENG123210-MAS00111,Speed_alert_schedule_start_time-Seconds,0,
ENG123211-MAS00106,Speed_alert_schedule_stop_time-Year,2000,
ENG123211-MAS00107,Speed_alert_schedule_stop_time-Month,0,
ENG123211-MAS00108,Speed_alert_schedule_stop_time-Day,0,
ENG123211-MAS00109,Speed_alert_schedule_stop_time-Hours,0,
ENG123211-MAS00110,Speed_alert_schedule_stop_time-Minutes,0,
ENG123211-MAS00111,Speed_alert_schedule_stop_time-Seconds,0,
ENG123193-ENG123341,Vehicle_Health_Report-Collection_Period,Deactivated,
ENG123193-ENG123342,Vehicle_Health_Report-Day_at_month_for_report,0,
ENG123193-ENG123343,Vehicle_Health_Report-Day_at_week_for_report,Not available,
ENG123193-ENG123339,Vehicle_Health_Report-Distance_Based_Distance,0, km
ENG123193-ENG123338,Vehicle_Health_Report-Distance_Based_Start_Mileage,0, km
ENG123193-ENG123340,Vehicle_Health_Report-Maintenance_Based_Distance,0, km
Elapsed Time: 00:18
A5:
;SW:3QD-980-654   HW:3Q0-980-654-A ---  Frt Sens. Drv. Assist
;Component:MQB_B_MFK     H09 1272, Coding:000401060001020100221355C150490084000E200120
;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_001_VW27.rod
;Monday,17,June,2019,11:05:06:34333
;VCID: 885CD59633B5A60F5D-80DC
IDE00018,Voltage terminal 15,12.9, V
IDE00102,Control Module temperature,63, °C
IDE00322,Status of basic setting,not active,
IDE00326-MAS02471,Steering wheel angle-Sign,Negative,
IDE00326,Steering wheel angle,2, °
IDE00925-MAS02471,Yaw rate-Sign,Negative,
IDE00925,Yaw rate,1.03, °/s
IDE00973,Outside air temperature,29.0, °C
IDE01968,Dynamic calibration: yaw angle offset,0.105, °
IDE01969,Dynamic calibration: pitch angle offset,0.079, °
IDE01970,Dynamic calibration: roll angle offset,0.230, °
IDE01972,Highest recorded control module temperature,82, °C
IDE02057,Dynamic calibration: status,Passive values stored,
IDE03222-MAS02534,Blindness detection-Clear view,Yes,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS11936,Blindness detection-Causes of blindness,Clear view,
IDE03222-MAS11937,Blindness detection-Pixel failure,0, %
IDE03222-MAS11949,Blindness detection-Windshield heater blindness,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,8, km
IDE04036,High beam assistant: status,not active,
IDE04037,High beam recommendation,OFF,
IDE04123,High beam: reason for shut-off,20,
IDE04125,Visibility,Not Used,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07214,Dynamic calibration: camera height offset,0, mm
IDE09424,Number of recognized lane markings,0,
IDE09433-MAS01632,Perception module for light assistant-Status,passive,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,unknown Object_1_distance,
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,unknown Object_2_distance,
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,unknown Object_1_horizontal_angle,
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,unknown Object_2_horizontal_angle,
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,unknown Object_1_vertical_angle,
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,unknown Object_2_vertical_angle,
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,0, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,0, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,0,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,0,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,No,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,No,
IDE09433-MAS08897,Perception module for light assistant-Object 1 horizontal quality left,0, °
IDE09433-MAS08898,Perception module for light assistant-Object 2 horizontal quality left,0, °
IDE09433-MAS08899,Perception module for light assistant-Object 1 horizontal quality right,0, °
IDE09433-MAS08900,Perception module for light assistant-Object 2 horizontal quality right,0, °
IDE09433-MAS08901,Perception module for light assistant-Object 1 vertical quality,0, °
IDE09433-MAS08902,Perception module for light assistant-Object 2 vertical quality,0, °
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,No object,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,No object,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Ambient brightness too high,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Left hand driv.,
IDE10220,Initial online calibration active,not active,
IDE10398-MAS10691,Self-glare-Self-glare quality,0, %
IDE10398-MAS11502,Self-glare-Self-glare recognition,No,
IDE10398-MAS11503,Self-glare-Self-glare status,not active,
IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,1.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,1.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,1.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,1.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.049, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,1.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,-0.203, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,1.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,0.025, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,1.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1597, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,1.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0, m
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10995,Last initial calibrations: details-Penultimate initial calibration: error code,Calibration not yet performed,
IDE10406-MAS10996,Last initial calibrations: details-Third-to-last initial calibration: error code,Calibration not yet performed,
IDE10406-MAS10997,Last initial calibrations: details-Fourth-to-last initial calibration: error code,Calibration not yet performed,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2019,
IDE10664-MAS00107,Current initial calibration: details-Month,1,
IDE10664-MAS00108,Current initial calibration: details-Day,9,
IDE10664-MAS00109,Current initial calibration: details-Hours,12,
IDE10664-MAS00110,Current initial calibration: details-Minutes,49,
IDE10664-MAS00111,Current initial calibration: details-Seconds,39,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,0,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00110011 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,1V2NR2CA0KC531985,
IDE10664-MAS03010,Current initial calibration: details-Focal length,1381,
IDE10664-MAS03075,Current initial calibration: details-Calibration point X coordinates on imaging sensor,640,
IDE10664-MAS03076,Current initial calibration: details-Calibration point Y coordinates on imaging sensor,364,
IDE10664,Current initial calibration: details,00111111 ,
IDE10664,Current initial calibration: details,00110011 ,
IDE11956,Boot manager version,31 12 30 13,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,20,
ENG130818-MAS01505,Windscreen_heater_camera-Engine off,No,
ENG130818-MAS02374,Windscreen_heater_camera-System malfunction,no error,
ENG130818-MAS03849,Windscreen_heater_camera-Crash signal,not active,
ENG130818-ENG120256,Windscreen_heater_camera-par_Actuator_test,not active,
ENG130818-ENG120266,Windscreen_heater_camera-par_Ambient_temperature_too_low,No,
ENG130818-ENG120257,Windscreen_heater_camera-par_Blindness_activation,no request,
ENG130818-ENG120260,Windscreen_heater_camera-par_camera_temperature_too_high,No,
ENG130818-ENG120258,Windscreen_heater_camera-par_condensation_danger_activation,no request,
ENG130818-ENG120268,Windscreen_heater_camera-par_current_windscreen_heater,0.0, A
ENG130818-ENG120265,Windscreen_heater_camera-par_Heating_time_exceeded,No,
ENG130818-ENG120259,Windscreen_heater_camera-par_initial_heating,not active,
ENG130818-ENG130881,Windscreen_heater_camera-par_preventive_heating,not active,
ENG130818-ENG120264,Windscreen_heater_camera-par_Windscreenheater_error,not active,
ENG130818-ENG101577,Windscreen_heater_camera-Windscreen_heater_state_of_activation,not active,
Elapsed Time: 00:26
CA:
;SW:4M0-907-594-J   HW:4M0-907-594 ---  Sunroof
;Component:SAD_STG_1     014 0005, Coding:00804074160C
;EV_SunRoofCONTIAU736,006008,EV_SunRoofCONTIAU736_006.rod
;Monday,17,June,2019,11:05:34:34333
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: BD3274422CF733A73E-80E8
Group,Description,Actual
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE03114-MAS02447,Comfort function-Release,Not Present,
IDE03114-MAS08867,Comfort function-Request open sliding sunroof,not active,
IDE03114-MAS08868,Comfort function-Request close sliding sunroof,not active,
IDE03114-MAS08869,Comfort function-Request open sunroof shade,not active,
IDE03114-MAS08870,Comfort function-Request close sunroof shade,not active,
IDE03421-MAS09452,Hall sensors for position detection-Hall sensor for sunroof motor,operated,
IDE03421-MAS09453,Hall sensors for position detection-Sunroof motor Hall sensor 2,Not operated,
IDE03421-MAS09454,Hall sensors for position detection-Hall sensor for roof blind motor,Not operated,
IDE03421-MAS09455,Hall sensors for position detection-Hall sensor 2 for roof blind motor,Not operated,
IDE09422-MAS02282,Roof Blind-Position,0, %
IDE09422-MAS05370,Roof Blind-Direction of movement,Not moving,
IDE09422-MAS05563,Roof Blind-Norming,normed,
IDE09422-MAS08536,Roof Blind-Excessive temperature protection,not active,
IDE09422-MAS08862,Roof Blind-Reversing,not active,
IDE09422-MAS08866,Roof Blind-Adaption depth,89, %
IDE09423-MAS02282,Sunroof-Position,0, %
IDE09423-MAS05370,Sunroof-Direction of movement,Not moving,
IDE09423-MAS05563,Sunroof-Norming,normed,
IDE09423-MAS05737,Sunroof-Position,Tilt out posi.,
IDE09423-MAS08536,Sunroof-Excessive temperature protection,not active,
IDE09423-MAS08862,Sunroof-Reversing,not active,
IDE09423-MAS08866,Sunroof-Adaption depth,100, %
IDE09427-MAS08536,Control module counter readings-Excessive temperature protection,0,
IDE09427-MAS08872,Control module counter readings-Resets due to interruption of supply voltage,21,
IDE09427-MAS08873,Control module counter readings-Resets to hardware watchdog,1,
IDE09427-MAS08874,Control module counter readings-Resets due to software watchdog,0,
IDE09428-MAS05563,Sunroof counter readings-Norming,3,
IDE09428-MAS08536,Sunroof counter readings-Excessive temperature protection,0,
IDE09428-MAS08862,Sunroof counter readings-Reversing,2,
IDE09428-MAS10406,Sunroof counter readings-Opening runs: sliding pos.,14,
IDE09428-MAS10407,Sunroof counter readings-Opening runs: tilted pos.,3,
IDE09428-MAS10408,Sunroof counter readings-Closing runs,17,
IDE09429-MAS05563,Sunroof shade counter readings-Norming,2,
IDE09429-MAS08536,Sunroof shade counter readings-Excessive temperature protection,0,
IDE09429-MAS08862,Sunroof shade counter readings-Reversing,1,
IDE09429-MAS08871,Sunroof shade counter readings-Opening cycles,16,
IDE09430-MAS00106,History data sunroof reversing-Year,2127,
IDE09430-MAS00107,History data sunroof reversing-Month,15,
IDE09430-MAS00108,History data sunroof reversing-Day,31,
IDE09430-MAS00109,History data sunroof reversing-Hours,0,
IDE09430-MAS00110,History data sunroof reversing-Minutes,0,
IDE09430-MAS00111,History data sunroof reversing-Seconds,0,
IDE09430-MAS00370,History data sunroof reversing-Vehicle speed,0.00, km/h
IDE09430-MAS01453,History data sunroof reversing-Blocking detection,not active,
IDE09430-MAS01634,History data sunroof reversing-Supply voltage,13.00, V
IDE09430-MAS02282,History data sunroof reversing-Position,55, %
IDE09430-MAS02289,History data sunroof reversing-Outside air temperature,25.00, °C
IDE09430-MAS05622,History data sunroof reversing-Cold start,not active,
IDE09430-MAS05737,History data sunroof reversing-Position,Tilt out posi.,
IDE09430-MAS09456,History data sunroof reversing-Counter reading sunroof reversals,2,
IDE09430-MAS10923,History data sunroof reversing-Absolute Position,105,
IDE09430-MAS10991,History data sunroof reversing-Restart,not active,
IDE09430-MAS10992,History data sunroof reversing-Absolute start position,176,
IDE09431-MAS00106,History data sunroof shade reversing-Year,2127,
IDE09431-MAS00107,History data sunroof shade reversing-Month,15,
IDE09431-MAS00108,History data sunroof shade reversing-Day,31,
IDE09431-MAS00109,History data sunroof shade reversing-Hours,0,
IDE09431-MAS00110,History data sunroof shade reversing-Minutes,0,
IDE09431-MAS00111,History data sunroof shade reversing-Seconds,0,
IDE09431-MAS01453,History data sunroof shade reversing-Blocking detection,not active,
IDE09431-MAS01634,History data sunroof shade reversing-Supply voltage,13.20, V
IDE09431-MAS02282,History data sunroof shade reversing-Position,13, %
IDE09431-MAS02289,History data sunroof shade reversing-Outside air temperature,25.00, °C
IDE09431-MAS05622,History data sunroof shade reversing-Cold start,not active,
IDE09431-MAS09457,History data sunroof shade reversing-Counter readings roof blind reversals,1,
IDE09431-MAS10923,History data sunroof shade reversing-Absolute Position,447,
IDE09431-MAS10991,History data sunroof shade reversing-Restart,not active,
IDE09431-MAS10992,History data sunroof shade reversing-Absolute start position,3218,
IDE09492-MAS01155,Temperatures-Control module,38.00, °C
IDE09492-MAS06997,Temperatures-Outside temperature: filtered,29.00, °C
IDE09492-MAS09033,Temperatures-Motor for sunroof,38.00, °C
IDE09492-MAS09047,Temperatures-Roof shade motor,38.00, °C
IDE09515-MAS08884,Controls-Sunroof button,not activated,
IDE09515-MAS08932,Controls-Sunroof shade button,not activated,
IDE09515-MAS08992,Controls-Button for sliding roof,not activated,
IDE09515-MAS12701,Controls-Search lights,Current cannot be measured,
IDE09516-MAS04194,Status of child safety-Driver side,not active,
IDE09516-MAS04195,Status of child safety-Frt. pass. side,not active,
IDE09517-IDE00075,Control module-Vehicle speed,0.00, km/h
IDE09517-MAS02447,Control module-Release,present,
IDE09517-MAS07376,Control module-Terminal 58xd,232,
IDE09517-MAS07720,Control module-Terminal 15 via CAN,On,
IDE09517-MAS08536,Control module-Excessive temperature protection,not active,
IDE09517-MAS09820,Control module-Terminal 58xt,100, %
IDE09517-MAS11498,Control module-Panel lighting for controls,0, %
IDE09517-MAS11499,Control module-Rear indicator light for tilting sunroof,not installed,
IDE09518-MAS01634,Voltages and currents-Supply voltage,12.90, V
IDE09518-MAS09048,Voltages and currents-Motor current consumption for sun roof,0.00, A
IDE09518-MAS09049,Voltages and currents-Motor current consumption for roof blind,0.00, A
IDE09844-MAS00106,History data sunroof standardization-Year,2011,
IDE09844-MAS00107,History data sunroof standardization-Month,1,
IDE09844-MAS00108,History data sunroof standardization-Day,1,
IDE09844-MAS00109,History data sunroof standardization-Hours,0,
IDE09844-MAS00110,History data sunroof standardization-Minutes,43,
IDE09844-MAS00111,History data sunroof standardization-Seconds,44,
IDE09844-MAS00370,History data sunroof standardization-Vehicle speed,0.00, km/h
IDE09844-MAS01155,History data sunroof standardization-Control module,32.00, °C
IDE09844-MAS01634,History data sunroof standardization-Supply voltage,13.40, V
IDE09844-MAS02289,History data sunroof standardization-Outside air temperature,21.00, °C
IDE09844-MAS04447,History data sunroof standardization-Engine running status,Motor not running,
IDE09844-MAS09458,History data sunroof standardization-Counter reading sunroof calibrations,3,
IDE09845-MAS00106,History data roof blind standardization-Year,2019,
IDE09845-MAS00107,History data roof blind standardization-Month,1,
IDE09845-MAS00108,History data roof blind standardization-Day,9,
IDE09845-MAS00109,History data roof blind standardization-Hours,11,
IDE09845-MAS00110,History data roof blind standardization-Minutes,34,
IDE09845-MAS00111,History data roof blind standardization-Seconds,42,
IDE09845-MAS00370,History data roof blind standardization-Vehicle speed,0.00, km/h
IDE09845-MAS01155,History data roof blind standardization-Control module,31.00, °C
IDE09845-MAS01634,History data roof blind standardization-Supply voltage,13.70, V
IDE09845-MAS02289,History data roof blind standardization-Outside air temperature,22.00, °C
IDE09845-MAS04447,History data roof blind standardization-Engine running status,Motor not running,
IDE09845-MAS09459,History data roof blind standardization-Counter read. roof blind calibrations,2,
IDE09846-MAS00106,History data sunroof control point-Year,2019,
IDE09846-MAS00107,History data sunroof control point-Month,6,
IDE09846-MAS00108,History data sunroof control point-Day,1,
IDE09846-MAS00109,History data sunroof control point-Hours,15,
IDE09846-MAS00110,History data sunroof control point-Minutes,1,
IDE09846-MAS00111,History data sunroof control point-Seconds,34,
IDE09846-MAS02282,History data sunroof control point-Position,100, %
IDE09846-MAS05737,History data sunroof control point-Position,Tilt out posi.,
IDE09846-MAS09430,History data sunroof control point-Operating pts.,Button for sliding roof,
IDE09916-MAS09563,Data set names-Number of data set names,1,
IDE09916-MAS09564,Data set names-Data set ID,71 00,
IDE09916-MAS09565,Data set names-Data set name,74160CVW4160,
IDE11840-MAS13333,Operating signals for sunroof/tilt roof and roof blind-Operating signals of roof shade,Unknown (255),
IDE11840-MAS13334,Operating signals for sunroof/tilt roof and roof blind-Front operating signals: rear roof shade,Unknown (255),
IDE11840-MAS13335,Operating signals for sunroof/tilt roof and roof blind-Rear operating signals: rear roof shade,Unknown (255),
IDE11840-MAS13364,Operating signals for sunroof/tilt roof and roof blind-Operating signal sliding/tilting roof,Unknown (255),
Elapsed Time: 00:04
D6:
;SW:7P5-941-591-AA   HW:7P5-941-591-A ---  Light Ctrl Left 2
;Component:LED1L         H06 0003, Coding:
;EV_LED_PLUS_L_KEBODAVW416,001003,EV_LED_PLUS_L_KEBODAVW416_VW37.rod
;Monday,17,June,2019,11:05:41:34333
;VCID: FBB6BA5A7263FD9740-80AE
IDE00030-FSS01408,Status of actuator test-Status,not active,
IDE00325,Diagnostic mode,Extended Session,
IDE00767-ENG14124,No. of unscheduled ECU resets-Test_Program_Watchdog_reset,0,
IDE03680-MAS01468,Supply voltages-Terminal 15,12.8, V
IDE03680-MAS09374,Supply voltages-Terminal 56b,0.1, V
IDE03680-MAS09375,Supply voltages-Terminal 56a,0.0, V
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,0.0, V
IDE03680-MAS10129,Supply voltages-Daytime driving light supply,0.0, V
IDE03680-MAS12194,Supply voltages-Supply for logic,12.8, V
IDE03680-ENG35043,Supply voltages-Terminal_30g,12.9, V
IDE06926-ENG28625,History memory: reset counter-reset_reason,Watchdog Reset,
IDE06926-ENG08623,History memory: reset counter-Timestamp,13 06 11 0A 04,
IDE08742-IDE09773,Operating time-Side-marker light,0.42, H
IDE08742-MAS02923,Operating time-Highway light,0.00, H
IDE08742-MAS09325,Operating time-Daytime running lights,1.83, H
IDE08742-MAS13654,Operating time-Auxiliary high beam,0.00, H
IDE08742-ENG28624,Operating time-all_weather_light,0.00, H
IDE08742-ENG36151,Operating time-City_light 4,0.00, H
IDE08742-ENG28616,Operating time-Control_module,4.67, H
IDE08742-ENG120597,Operating time-High_beam,0.00, H
IDE08742-ENG120596,Operating time-Low_beam,0.42, H
IDE08742-ENG35039,Operating time-Position_light,0.42, H
IDE08742-ENG120595,Operating time-Static_Cornering_Light,0.00, H
IDE08742-ENG28679,Operating time-Tourist_light,0.00, H
IDE08742-ENG35044,Operating time-Turn_indicator,0.00, H
IDE09770-MAS02526,High side channel 1-Activation,Sidemarker,
IDE09770-MAS04136,High side channel 1-Current,outside permissible range,
IDE09770-MAS09022,High side channel 1-PWM value,0.0, %
IDE09771-MAS02526,High side channel 2-Activation,Turn_indicator,
IDE09771-MAS04136,High side channel 2-Current,outside permissible range,
IDE09771-MAS09022,High side channel 2-PWM value,0.0, %
IDE09772-MAS01340,High side channel 3-Functions,no function,
IDE09772-MAS09022,High side channel 3-PWM value,0.0, %
IDE09774-IDE09773,Number of activations-Side-marker light,13,
IDE09774-MAS02923,Number of activations-Highway light,0,
IDE09774-MAS09325,Number of activations-Daytime running lights,25,
IDE09774-MAS13654,Number of activations-Auxiliary high beam,0,
IDE09774-ENG28624,Number of activations-all_weather_light,0,
IDE09774-ENG36136,Number of activations-city_light,0,
IDE09774-ENG120597,Number of activations-High_beam,2,
IDE09774-ENG28914,Number of activations-High_beam_excess_temperature,0,
IDE09774-ENG28912,Number of activations-High_beam_excess_temperature_protection,0,
IDE09774-ENG120596,Number of activations-Low_beam,17,
IDE09774-ENG28913,Number of activations-Low_beam_excess_temperature,0,
IDE09774-ENG28911,Number of activations-Low_beam_excess_temperature_protection,0,
IDE09774-ENG35039,Number of activations-Position_light,14,
IDE09774-ENG120595,Number of activations-Static_Cornering_Light,0,
IDE09774-ENG28679,Number of activations-Tourist_light,0,
IDE09774-ENG35044,Number of activations-Turn_indicator,531,
IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,0.00, H
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,0.00, H
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-over 60%,4.50, H
IDE09828-MAS00890,Head lamp variant-via CAN,E0 41,
IDE09828-ENG28616,Head lamp variant-Control_module,E0 41,
IDE10048-IDE09768,Supply information-LED channel 1,Not Used,
IDE10048-IDE09769,Supply information-LED channel 2,Terminal_30g,
IDE10048-IDE09771,Supply information-High side channel 2,Terminal_30g,
IDE10048-IDE09772,Supply information-High side channel 3,Terminal 15,
IDE10048-IDE11123,Supply information-High side channel 4,Terminal 15,
IDE10048-MAS01968,Supply information-Fan,Not Used,
IDE10048-MAS09754,Supply information-LED channel 3,Terminal_30g,
IDE10048-MAS09755,Supply information-Matrixbeam channels,Not Used,
IDE10048-MAS16122,Supply information-LED channel 4,Terminal_30g,
IDE10048-ENG30205,Supply information-Highside_channel 1,Terminal_30g,
IDE10165-FSS01570,LED channel 1: Master 1-Temperature,40, °C
IDE10165-MAS01340,LED channel 1: Master 1-Functions,Low_beam,
IDE10165-MAS04136,LED channel 1: Master 1-Current,0, mA
IDE10165-MAS09022,LED channel 1: Master 1-PWM value,100.0, %
IDE10165-MAS09327,LED channel 1: Master 1-LED brightness class,1,
IDE10167-FSS01570,LED channel 1: Slave-Temperature,40, °C
IDE10167-MAS01340,LED channel 1: Slave-Functions,no function,
IDE10167-MAS04136,LED channel 1: Slave-Current,0, mA
IDE10167-MAS09022,LED channel 1: Slave-PWM value,100.0, %
IDE10167-MAS09327,LED channel 1: Slave-LED brightness class,2,
IDE10168-FSS01570,LED channel 2: Master-Temperature,36, °C
IDE10168-MAS01340,LED channel 2: Master-Functions,High_beam,
IDE10168-MAS04136,LED channel 2: Master-Current,0, mA
IDE10168-MAS09022,LED channel 2: Master-PWM value,100.0, %
IDE10168-MAS09327,LED channel 2: Master-LED brightness class,2,
IDE10169-FSS01570,LED channel 2: Slave-Temperature,36, °C
IDE10169-MAS01340,LED channel 2: Slave-Functions,no function,
IDE10169-MAS04136,LED channel 2: Slave-Current,0, mA
IDE10169-MAS09022,LED channel 2: Slave-PWM value,100.0, %
IDE10169-MAS09327,LED channel 2: Slave-LED brightness class,2,
IDE10170-FSS01570,LED channel 3: Master-Temperature,56, °C
IDE10170-MAS01340,LED channel 3: Master-Functions,Position_light / Daytime_running_light,
IDE10170-MAS04136,LED channel 3: Master-Current,138, mA
IDE10170-MAS09022,LED channel 3: Master-PWM value,100.0, %
IDE10170-MAS09327,LED channel 3: Master-LED brightness class,2,
IDE10173-MAS09336,Operating times in temperature ranges-°C,0.00, H
IDE10173-MAS09337,Operating times in temperature ranges-between 105°C and 115°C,0.00, H
IDE10173-MAS09338,Operating times in temperature ranges-over 115°C,0.00, H
IDE10173-MAS09378,Operating times in temperature ranges-between -40°C and 95°C,2.67, H
IDE10205,Control module version,plus,
IDE10206-MAS09945,Fan for headlight-Fan 1: current,not installed,
IDE10206-MAS09946,Fan for headlight-Fan 2: current,not installed,
IDE10206-MAS11628,Fan for headlight-Fan 1: activation,not installed,
IDE10206-MAS11629,Fan for headlight-Fan 2: activation,not installed,
IDE10282-IDE10165,LED channels: voltages-LED channel 1: Master 1,0.00, V
IDE10282-IDE10168,LED channels: voltages-LED channel 2: Master,0.00, V
IDE10282-IDE10170,LED channels: voltages-LED channel 3: Master,34.67, V
IDE10282-IDE13678,LED channels: voltages-LED channel 4: Master,5.33, V
IDE10282-ENG36145,LED channels: voltages-Channel _1_Slave,0.00, V
IDE10282-ENG36146,LED channels: voltages-Channel _2_Slave,0.00, V
IDE10864-MAS11561,Control mod. temperatures-Power output stage for LED,43, °C
IDE10864-MAS11562,Control mod. temperatures-Matrix light power output stage,0, °C
IDE11123-MAS02526,High side channel 4-Activation,Channel not used,
IDE11123-MAS04136,High side channel 4-Current,Channel not used,
IDE11123-MAS09022,High side channel 4-PWM value,0.0, %
IDE11124-IDE10205,Headlight beam adjusting motor-Control module version,not defined,
IDE11124-ENG14129,Headlight beam adjusting motor-Test_Program_Inclination_of_low_beam,1024.00, mm
IDE11124-ENG14128,Headlight beam adjusting motor-Test_Program_Motor_position_percentage_of_maximum_adjustment_travel,101.60, %
IDE13678-FSS01570,LED channel 4: Master-Temperature,56, °C
IDE13678-MAS01340,LED channel 4: Master-Functions,Position_light / Daytime_running_light,
IDE13678-MAS04136,LED channel 4: Master-Current,114, mA
IDE13678-MAS09022,LED channel 4: Master-PWM value,100.0, %
IDE13678-MAS09327,LED channel 4: Master-LED brightness class,2,
MAS00468,Unlearning counter,11,
Elapsed Time: 00:04
D7:
;SW:7P5-941-591-AA   HW:7P5-941-591-A ---  Light Ctrl Right 2
;Component:LED1R         H06 0003, Coding:
;EV_LED_PLUS_R_KEBODAVW416,001003,EV_LED_PLUS_R_KEBODAVW416_VW41.rod
;Monday,17,June,2019,11:05:47:34333
IDE03680-MAS01468,Supply voltages-Terminal 15,12.9, V
IDE03680-MAS12194,Supply voltages-Supply for logic,12.9, V
IDE09770-IDE10205,High side channel 1-Control module version,Min LIN,
IDE09772-MAS02526,High side channel 3-Activation,Channel not used,
IDE09772-MAS04136,High side channel 3-Current,Channel not used,
IDE09774-IDE09773,Number of activations-Side-marker light,12,
IDE09774-MAS09325,Number of activations-Daytime running lights,24,
IDE09774-ENG120597,Number of activations-High_beam,1,
IDE09774-ENG120596,Number of activations-Low_beam,15,
IDE09774-ENG35039,Number of activations-Position_light,12,
IDE09774-ENG35044,Number of activations-Turn_indicator,773,
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-over 60%,4.67, H
IDE10048-ENG30206,Supply information-Highside_channel 2,Terminal_30g,
IDE10048-ENG30207,Supply information-Highside_channel 3,Terminal 15,
IDE10165-FSS01570,LED channel 1: Master 1-Temperature,43, °C
IDE10167-FSS01570,LED channel 1: Slave-Temperature,43, °C
IDE10168-FSS01570,LED channel 2: Master-Temperature,41, °C
IDE10169-FSS01570,LED channel 2: Slave-Temperature,41, °C
IDE10170-FSS01570,LED channel 3: Master-Temperature,62, °C
IDE10206-MAS02526,Fan for headlight-Activation,Highbeam_shutter,
IDE10206-MAS04136,Fan for headlight-Current,in permissible range,
IDE10282-ENG36150,LED channels: voltages-Channel_4_Master,5.33, V
IDE10864-MAS11561,Control mod. temperatures-Power output stage for LED,48, °C
IDE11124-MAS12195,Headlight beam adjusting motor-Reference run status,not performed,
IDE11124-MAS12196,Headlight beam adjusting motor-Fault position,not approached,
IDE11124-MAS12199,Headlight beam adjusting motor-Adjustment speed,normal,
IDE13678-FSS01570,LED channel 4: Master-Temperature,62, °C
Elapsed Time: 00:04
OBDII:
;33-OBD2
;Monday,17,June,2019,11:05:54:34333
03,Fuel system 1/2 status,Closed loop,,using O2 sensors,Engine off
04,Calculated load value,27.5 %,27.5 %
05,Engine coolant temperature,87 °C,87 °C
06,Short Term Trim - Bank 1,-1.6 %
07,Long Term Trim - Bank 1,-0.8 %
08,Short Term Trim - Bank 2,-0.8 %
09,Long Term Trim - Bank 2,1.6 %
0C,Engine RPM,881 /min,885 /min
0D,Vehicle speed,0 km/h,0 km/h
0E,Ignition timing advance for cyl #1,3.0 Degrees
0F,Intake air temperature,49 °C
10,Mass Air Flow,5.58 g/s
11,Throttle position sensor,12.9 %,12.9 %
13,Location of O2 sensors,B1S1 B1S2 ,B2S1 B2S2
15,Bank 1 Sensor 2 Status,0.820 V
19,Bank 2 Sensor 2 Status,0.815 V
1C,OBD Requirements Met,OBD + OBD II
1F,Time since engine start,911 s
21,Distance travelled with MIL on,0 km
2E,Commanded Evaporative Purge,41.2 %
2F,Fuel Level Input,15.3 %
30,Warm-ups since DTC cleared,0
31,Distance since DTC cleared,0 km
33,Barometric pressure,98 kPa abs
34,Bank 1 Sensor 1 Status,1.012 Lambda,-0.004 mA
38,Bank 2 Sensor 1 Status,1.008 Lambda,-0.012 mA
3C,B1S1 Cat. Temp.,547.6 °C
3D,B2S1 Cat. Temp.,518.4 °C
42,Control module voltage,13.020 V,13.014 V
43,Absolute Load Value,20 %,20 %
44,Commanded Equivalence Ratio,1.000 Lambda
45,Relative Throttle Position,3 %
46,Ambient Air Temp,30 °C
47,Absolute Throttle Position B,13 %
49,Accelerator Pedal Position D,15 %,15 %
4A,Accelerator Pedal Position E,15 %
4C,Commanded Throttle Actuator Control,4 %
51,Fuel type,Gasoline
56,Long term sec. O2 trim bank 1/3,0.0 %
58,Long term sec. O2 trim bank 2/4,0.0 %
62,Torque actual,13 %
63,Torque Reference,470 Nm
65,Auxiliary Input/Output,N/D_STAT:DRIVE
67,Engine Coolant Temp,ECT 1:91 °C,ECT 2:87 °C
6D,Fuel Press. Control A/B,FRP CMD:---/--- kPa,FRP ACT:2920/--- kPa,FRTemp:---/--- °C
Mode 9 : Calibration Identification
Type 02 - VIN : 1V2NR2CA0KC531985 (Address E8)
Type 04 - Calibration ID : 03H026AA6694FVAA (Address E8)
Type 04 - Calibration ID : 09G927158DR 3536 (Address E9)
Type 06 - Calibration Verification Number : 34DA894C (Address E8)
Type 06 - Calibration Verification Number : 0571F45B (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 6
    Ignition cycle count : 84
    Conditions completion count / Specified conditions encountered count
         Catalyst monitor bank 1 : 0 / 1
         Catalyst monitor bank 2 : 0 / 1
         O2 Sensor monitor bank 1 : 0 / 1
         O2 Sensor monitor bank 2 : 0 / 1
         EGR-VVT monitor : 9 / 6
         AIR monitor : 0 / 0
         EVAP monitor : 1 / 2
Type 0A - Controller Name : ECM-EngineControl (Address E8)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
