Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: ACC not available / RS3 2018
  1. #31
    That simple!
  2. #32
    Jun 2019
    How come you want to enable "reset misalignment" menu ?
    Have you read that in some explanation for another radar, on the internet ?
    For your Radar it is not available/used (as you already have seen).
    There are different Actuator test and Basic Setting procedure used, together with the calibration plates.
    Hi Thank you for your reply again.
    This thread is started by someone who wants to enable it, first of all. I just wonder if the alignment was really all right, it could clear the fault (I still believe so, but it may be not).
    As far as I understand, the fault should come back straightaway when the alignment is not correct. Hence, I just wanted to try.
    NE tech - Would be able to tell me why this menu is not available for the radar I use while it is possible/available for other Bosch (almost identical looking) radars.
    Is it Ross-tech that wouldn't give this particular radar module the option? Or is that Bosch or VAG's decision?
    I gave the part number earlier before sending the full scan. You could have told me that it is not available for the radar I used then...?
    I agree other guy's comments and am aware of the safety issues, so the radar will be calibrated by a specialist (not VW dealer, but a reputable garage) in two weeks time.
    Wished I could have sorted it today as I will have a long trip to north next weekend.
    I really like ACC when driving on motor way, usually just stick to a slow lane and relax(!) unless I am in a hurry.
  3. #33
  4. #34
    Quote Originally Posted by tetskoma View Post
    You have the menus that are needed to do a calibration with VCDS.
    "reset misalignment" is not used for your system.
    Before we got the Autoscan, you showed the hardware number of the Radar and hardware number of the Controller, not the software number of the Controller.
    But the important information that is needed is ASAM ID.
    There are different procedures, depending of different ASAM data.
    And, I have used the hole day yesterday to find out how the procedures is for your system, after we got the Autoscan.
    So it is first now, that I know "reset misalignment" is not used for your system.
  5. Likes PetrolDave, Uwe liked this post
  6. #35
    Jun 2019
    Thank you very much for your time and efforts to find this out, NE Tech.
    So SW number/ASAM ID determine how to process the calibration and if the procedure includes 'reset misalignment', the option may be available!
  7. #36
    May 2016
    NETech, you are a nice guy.
    Hope what goes around comes around.
    LARIMORE
  8. #37
    Jun 2019
    Just a little update. ACC calibration has been done this morning. I had nearly 200 miles trip after that, using ACC most of time on motorways.
    It worked actually better than before (normal cruising, 50mph average zone, slow/congestion all fine!).
    Last time my radar was calibrated by VW dealer in London, but used to throw lots of warning suddenly (by front assist) when nothing was in front of me.
    But now it happens only when I brake the car very late (another car in front of me, of course). Also, ACC responds better, I felt (like when another car cut in or slowed down etc).
    I am not sure if I should write this here, but I was surprised that this specialist did the calibration like DIY (it was my choice to proceed it without wheel alignment as I believe it is fine).
    He used a mini white board with something like a flip chart stands to hold the board in front of the radar, but with 3 measurement tools (laser distance and angles with leveller).
    He had an official ODIS from his shop to do the job, so he even registered this work to German(?) data centre. This calibration is actually recorded in my official service history!
    I went through the calibration process with him. It requires lots of perseverance and patience when you do it home.
    Struggled a little bit first to align the board as it was not really on a flat surface (we did this in a car park by his flat).
    After we moved the car to a better surface, it was like 5 mins job - just several step,s mirror position 1, 2, 3, and screw adjustments, then repeat 1,2 3 done! (well, after failed 3 times...).
    He said, for a newer laser, even it doesn’t use a board as it only requires 1 step calibration.
    In fact, he thought my radar was a newer type, so he just tried it on a brick wall in the car park before bringing this magical white board.
    It seems that just the distance between the radar and the wall is crucial/critical but it doesn't have to be perfectly level or parallel as the newer radar correct/calibrate itself after that, according to him (I don't know if this is right or not, though).
    My radar need three step calibration, so the board must be parallel to the car.
    He could have flashed a rom on my radar and loaded a different SW into it, which may give me an option to do 'reset ACC misalignment angle'.
    But it would cost some extra money and not sure which SW is available/stable for my car, so he told me not to bother doing it. Maybe next time we will do it if I manage to find the right SW with the option available for my car....
    Anyway, this confirms what NEtech said above, I think. Thank you.
  9. Likes Uwe, jyoung8607 liked this post
  10. #38
    Post a new auto-scan to see if firmware or any changes happened please!
  11. #39
    Jun 2019
    Well, we didn't change SW/firmware so it should be same, I think....?
    Coding is different, I don't know how/why.
    If my ACC needs a calibration again, I think I will try another radar with a different SW no.
    Saturday,13,July,2019,21:17:47:19515
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    VIN: WVGZZZ1TZGW559272   License Plate:
    Chassis Type: 1T-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F BB BC CA
    VIN: WVGZZZ1TZGW559272   Mileage: 59359km-36883miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CRKB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 C    HW: 04L 907 309 M
       Component: R4 1,6L EDC   H23 1760
       Revision: B4H23---
       Coding: 0125001203651D092000
       ASAM Dataset: EV_ECM16TDI01104L906026C 001003
       ROD: EV_ECM16TDI01104L906026C_001.rod
       VCID: 2A0D03B6CC7BEAE7B4D-807E
       Part No SW: 0CW 300 048 N    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 0610
       Revision: 00005005    Serial number: CU501511295022
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 47CB5A027F29378F4B3-8012
       Revision: 00000000    Serial number: 60336000000873
       Coding: 0CEA92A034258B750779060741C52930492CD1E0608294F51842F078C202
       VCID: 7AADF3F67C5B9A6784D-802E
       Part No SW: 5G0 907 426 AF    HW: 5G0 907 426 AF
       Component: AC Manuell    H03 1202
       Revision: 00001K06
       Coding: 08120104203100001000000000000002
       ASAM Dataset: EV_ACManueBHBVW37X 003129
       VCID: 6FBBD2A23719CFCF233-803A
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Component: BCM PQ37BOSCH 028 0163
       Revision: --------    Serial number: 86581002160001
       Coding: 03D01842C24102730F844090B10403281080000000000000000000000000
       ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
       ROD: EV_BCMBOSCH_015.rod
       VCID: 03538E120B91DBAFD7B-8056
       Subsystem 1 - Part No SW: 5TC 955 119 A    HW: 5TB 955 119
       Component: WWS    150921  042 0608
       Serial number:         151026132257
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S3Y16M02D08H18M27S49
       Coding: 90A8DD
       Serial number: 000000000ZY1600702Q7
       Serial number: 00000000000034541609
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 39391601508330
       Coding: 0071051811
       VCID: 44D14D0E4E1F1C97AE1-8010
       Component: ACC BOSCH MQB H04 0192
       Coding: 3200678251FFC428949C804D
       Shop #: WSC 43723 003 1048576
       ASAM Dataset: EV_ACCBOSCHVW48X 001008
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 34311DCE1EBFAC171E1-8060
       Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
       Component: AirbagVW21    005 0130
       Serial number: 003NSR1F710J
       Coding: 98CCC0C00C0000005C5450CF00C800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
       ROD: EV_AirbaVW20SMEVW37X.rod
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 5TC857705E0035Q00772
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 5TC857706E0035Q00089
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 001 102 16
       Serial number: 357000000002D36C191J
       Subsystem 4 - Part No SW: -----------    HW: 480 001 102 16
       Serial number: 358000000008446C191I
       Subsystem 5 - Part No SW: -----------    HW: 480 410 802 16
       Component: SideSensor_Dr  003 0189
       Serial number: 351001A011BBE2936CDH
       Subsystem 6 - Part No SW: -----------    HW: 480 411 302 16
       Component: SideSensor_Pr  003 0189
       Serial number: 352001A011B42AB22C7+
       Subsystem 7 - Part No SW: -----------    HW: 480 400 602 16
       Serial number: 3550001AB1EED224527D
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 401 302 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001A31EED235B29E
       Subsystem 9 - Part No SW: -----------    HW: 480 401 310 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001B5231F2B4B272
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 402 809 16
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001AB2303C94A1A
       Subsystem 11 - Part No SW: -----------    HW: 480 000 502 16
       Serial number: I0M00000000E7B501912
       Subsystem 12 - Part No SW: -----------    HW: 480 000 502 16
       Serial number: I0N0000000053829F816
       Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 09021604401283
       Coding: 0410
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 025D8B16148BD2A7DCD-8056
       Part No SW: 5TA 920 941     HW: 5TA 920 941
       Component: KOMBI         208 6421
       Coding: 27A401082780260001886B011400000000000000
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1244
       Revision: --------    Serial number: 0004427959
       Coding: 0301000417087300FB00005C1C0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 79AFECFA795D917F8D7-802C
       Serial number: 29160001423310106295
       Coding: 2CFFFF
       Subsystem 3 - Part No SW: 5QA 915 181 B    HW: 5QA 915 181 B
       Component: J367-BDMHella  H10 9052
       Serial number: 5388259103
       Serial number: 161215ELF03529
       Coding: 003082208001048000001000
       VCID: 43D34E124B111BAF97B-8016
       Component: EPS_MQB_ZFLS  125 1063
       Coding: 8103
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 151115BKE12567
       Coding: 003080208001048000801000
       VCID: 40D9411E5A0700B78A9-8014
       Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
       Component: MU-S-ND-ER    820 0627
       Coding: 02730801FF00000051111101008808001F0100C601200100CF
       Shop #: WSC 46292 001 1048576
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 303911DEEAA790377A9-8064
       Component: ABT_Std-2_Nav  H43 4064
       Serial number: VWZ6Z9S0371001
       Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
       Serial number: 200116BAI08565
       Coding: 002080200001048000001000
       VCID: 45D7500A4525259FB9F-8010
       Serial number: 200116BAI08407
       Part No SW: 4M0 907 594 D    HW: 4M0 907 594
       Component: SAD_STG_1     011 0003
       Coding: 708040737802
       ASAM Dataset: EV_SunRoofCONTIAU736 004008
       ROD: EV_SunRoofCONTIAU736_004.rod
       VCID: 372B2AC20FC9470F3B3-8062
    End----------(Elapsed Time: 01:47, VBatt start/end: 12.3V/12.3V)-----------
  12. Likes Uwe liked this post
  13. #40
    It is indeed unchanged.
    32 00 07 82 55 FF C4 28 94 9C 80 55 <- Before
    32 00 67 82 51 FF C4 28 94 9C 80 4D <- After
    The coding changes are interesting.
    Looks like the following "features" were turned on:
    Overtaking Right Prevention active
    Overtaking Assistance active
    And this was turned off:
    Emergency Assist installed
    Stopping Distance Reduction (AWV) Adjustability
  14. Likes jyoung8607 liked this post
