Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: ACC not available / RS3 2018
  1. #21
    Jun 2019
    Hi.
    Thank you. Yes, I will when I get home this evening.
    I forgot to save it last night.
  2. #22
    Jun 2019
    Hi.
    Here is my autoscan. I hope you can help me to access reset misalighnment angle for ACC in Module 13.
    Thank you
    Friday,05,July,2019,20:08:36:19515
    VIN: WVGZZZ1TZGW559272   License Plate:
    Chassis Type: 1T-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F BB BC CA
    VIN: WVGZZZ1TZGW559272   Mileage: 58384km-36278miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CRKB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 C    HW: 04L 907 309 M
       Component: R4 1,6L EDC   H23 1760
       Revision: B4H23---
       Coding: 0125001203651D092000
       ASAM Dataset: EV_ECM16TDI01104L906026C 001003
       ROD: EV_ECM16TDI01104L906026C_001.rod
       VCID: 2A0D03B6CC7BEAE7B4D-807E
    17156 - Databus
              U1123 00 [047] - Received Error Message
                        Mileage: 58380 km
                        Date: 2019.07.04
                        Time: 20:20:23
                        Engine speed: 838.00 /min
                        Normed load value: 29.4 %
                        Coolant temperature: 46 °C
                        Intake air temperature: 31 °C
                        Voltage terminal 30: 14.400 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 0
                        Drivetrain coordinator: brake function status-Bits 0-7: 0
                        Drivetrain coordinator: brake function status-Bits 0-7: 4
                        Acceleration: 0.000 m/s²
       Part No SW: 0CW 300 048 N    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 0610
       Revision: 00005005    Serial number: CU501511295022
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 47CB5A027F29378F4B3-8012
       Revision: 00000000    Serial number: 60336000000873
       Coding: 0CEA92A034258B750779060741C52930492CD1E0608294F51842F078C202
       VCID: 7AADF3F67C5B9A6784D-802E
       Part No SW: 5G0 907 426 AF    HW: 5G0 907 426 AF
       Component: AC Manuell    H03 1202
       Revision: 00001K06
       Coding: 08120104203100001000000000000002
       ASAM Dataset: EV_ACManueBHBVW37X 003129
       VCID: 6FBBD2A23719CFCF233-803A
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Component: BCM PQ37BOSCH 028 0163
       Revision: --------    Serial number: 86581002160001
       Coding: 03D01842C24102730F844090B10403281080000000000000000000000000
       ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
       ROD: EV_BCMBOSCH_015.rod
       VCID: 03538E120B91DBAFD7B-8056
       Subsystem 1 - Part No SW: 5TC 955 119 A    HW: 5TB 955 119
       Component: WWS    150921  042 0608
       Serial number:         151026132257
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S3Y16M02D08H18M27S49
       Coding: 90A8DD
       Serial number: 000000000ZY1600702Q7
       Serial number: 00000000000034541609
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 39391601508330
       Coding: 0071051811
       VCID: 44D14D0E4E1F1C97AE1-8010
       Component: ACC BOSCH MQB H04 0192
       Coding: 3200078255FFC428949C8055
       ASAM Dataset: EV_ACCBOSCHVW48X 001008
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 34311DCE1EBFAC171E1-8060
    0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] - -
              [FAULT_ALIGNMENT_NOT_OK]
                        Reset counter: 146
                        Mileage: 58380 km
                        Date: 2019.07.04
                        Time: 20:20:22
                        Control Module temperature: 39 °C
                        Voltage terminal 15: 14.1 V
                        Status_ACC_System: ACC_irreversible error
    0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] - -
              [FAULT_MISALIGNMENT_VERTICAL]
                        Reset counter: 146
                        Mileage: 58380 km
                        Date: 2019.07.04
                        Time: 20:20:22
    0836 - Databus
              [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                        Reset counter: 186
                        Mileage: 58382 km
                        Date: 2019.07.04
                        Time: 22:09:04
                        Control Module temperature: 32 °C
                        Voltage terminal 15: 14.2 V
                        Velocity_vehicle_reference: 4.31 m/s
                        Longitudinal_acceleration_vehicle_reference: 1.09 m/s²
    1233 - Databus
              [FAULT_TIMEOUT_HCA_01]
                        Reset counter: 146
                        Mileage: 58380 km
                        Date: 2019.07.04
                        Time: 20:20:22
       Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
       Component: AirbagVW21    005 0130
       Serial number: 003NSR1F710J
       Coding: 98CCC0C00C0000005C5450CF00C800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
       ROD: EV_AirbaVW20SMEVW37X.rod
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 5TC857705E0035Q00772
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 5TC857706E0035Q00089
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 001 102 16
       Serial number: 357000000002D36C191J
       Subsystem 4 - Part No SW: -----------    HW: 480 001 102 16
       Serial number: 358000000008446C191I
       Subsystem 5 - Part No SW: -----------    HW: 480 410 802 16
       Component: SideSensor_Dr  003 0189
       Serial number: 351001A011BBE2936CDH
       Subsystem 6 - Part No SW: -----------    HW: 480 411 302 16
       Component: SideSensor_Pr  003 0189
       Serial number: 352001A011B42AB22C7+
       Subsystem 7 - Part No SW: -----------    HW: 480 400 602 16
       Serial number: 3550001AB1EED224527D
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 401 302 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001A31EED235B29E
       Subsystem 9 - Part No SW: -----------    HW: 480 401 310 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001B5231F2B4B272
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 402 809 16
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001AB2303C94A1A
       Subsystem 11 - Part No SW: -----------    HW: 480 000 502 16
       Serial number: I0M00000000E7B501912
       Subsystem 12 - Part No SW: -----------    HW: 480 000 502 16
       Serial number: I0N0000000053829F816
       Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 09021604401283
       Coding: 0410
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 025D8B16148BD2A7DCD-8056
       Part No SW: 5TA 920 941     HW: 5TA 920 941
       Component: KOMBI         208 6421
       Coding: 27A401082780260001886B011400000000000000
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1244
       Revision: --------    Serial number: 0004427959
       Coding: 0301000417087300FB00005C1C0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 79AFECFA795D917F8D7-802C
       Serial number: 29160001423310106295
       Coding: 2CFFFF
       Subsystem 3 - Part No SW: 5QA 915 181 B    HW: 5QA 915 181 B
       Component: J367-BDMHella  H10 9052
       Serial number: 5388259103
       Serial number: 161215ELF03529
       Coding: 003082208001048000001000
       VCID: 43D34E124B111BAF97B-8016
       Component: EPS_MQB_ZFLS  125 1063
       Coding: 8103
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 151115BKE12567
       Coding: 003080208001048000801000
       VCID: 40D9411E5A0700B78A9-8014
       Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
       Component: MU-S-ND-ER    820 0627
       Coding: 02730801FF00000051111101008808001F0100C601200100CF
       Shop #: WSC 46292 001 1048576
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 303911DEEAA790377A9-8064
       Component: ABT_Std-2_Nav  H43 4064
       Serial number: VWZ6Z9S0371001
       Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
       Serial number: 200116BAI08565
       Coding: 002080200001048000001000
       VCID: 45D7500A4525259FB9F-8010
       Serial number: 200116BAI08407
       Part No SW: 4M0 907 594 D    HW: 4M0 907 594
       Component: SAD_STG_1     011 0003
       Coding: 708040737802
       ASAM Dataset: EV_SunRoofCONTIAU736 004008
       ROD: EV_SunRoofCONTIAU736_004.rod
       VCID: 372B2AC20FC9470F3B3-8062
    End----------(Elapsed Time: 01:47, VBatt start/end: 12.1V/12.1V)-----------
  3. #23
    tetskoma is now verified. Moving to Car Repair Support.
  4. #24
    May 2016
    Olkor,, a whole new game and not just vw issue.
    Took 8 hrs of adas few month ago. The day of changing even a headlight, or just tweaking the hood may be total recalibration of addas.
    You removed intercooler so dicked with the front end, hey we all do it, seemed simple but maybe not, good luck. This is a young car? Was this a mod or should have been on warranty.
    Larimore
  5. #25
    OP
    Welcome to the VCDS forum.
    Time to RTFB.
    Like the fault says, sensor installed out of degree, so take out and reposition correctly and clear codes.
    When removing parts on any type of telemetry or in general always mark timing alignment of stuff with wax pencil or wipe able paint.
    This is induced FOD!
    A mirror can be used with adjustable laser pointers on levels tweaked to wheel offsets or request the rack at dealer
    JPPSG
    https://www.hella.com/techworld/us/T...Control-38634/
  6. #26
    Jun 2019
    Hi. Thank you for your reply.
    Yes, my ultimate objective is to reset the fault codes in module 13, but I clearly understand that it needs a proper calibration by a specialist.
    It was going to be done today, but due to my work, I re-scheduled it in 2 weeks times (or maybe next weekend if the garage is available then).
    Even if I manage to reset it myself somehow, I will go to the specialist this time although I still believe the alignment of the radar should be fine as I didn't touch the radar/bracket.
    Again, my question here is not clearing the fault code or making the radar adjustment, but would like to know how to enable 'reset misalignment' menu in Basic Option in Module 13.
    I entered the security access code (20103 - accepted), but the menus in Basic option stay the same (ie no 'reset misalignment' option available).
    Can anyone clarify if it is restricted by something else (a different security access code, firmware on the controller etc?) or simply is it available for my car?
    Thank you for your support.
  7. #27
    Often basic settings or adaption procedures are not permitted when a fault is present, no?
  8. #28
    Quote Originally Posted by tetskoma View Post
    How come you want to enable "reset misalignment" menu ?
    Have you read that in some explanation for another radar, on the internet ?
    For your Radar it is not available/used (as you already have seen).
    There are different Actuator test and Basic Setting procedure used, together with the calibration plates.
  9. Likes Jack@European_Parts, Uwe liked this post
  10. #29
    It's because OP is trying to circumvent the proper calibration tests while still stating the latter or see if one of us will open RT to a liability?
    Not going to happen now is it?
  11. #30
    May 2016
    Jack, totally correct.
    Many basic tasks without proper calibration opens a huge can of worms law suit wise, as stated a whole new game.
    Larimore
