Audi Q7 Seat memory basic settings
Donibcsi
Hungary
C?ID=28126
Good morning,
I have an Q7 and the seat memory function does not working. All the another function are working fine.....seat, steering, mirrors adjustment, but I have one fault code and the controller does not accept the basic settings because the button is grey.
What is the right way to finish basic settings?
Thank you for all.
Tuesday,18,June,2019,09:49:14:34036
VCDS Version: 19.6.0.6  HEX-V2 CB: 0.4505.4
Dealer/Shop Name: Doni Motors
Workshop Code: 141 04653 000001
VIN: WAUZZZ4LXED017035   License Plate:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 20 28 36 3C 42 46 47 4C
          4F 52 55 56 5F 62 6C 6D 6F 72
VIN: WAUZZZ4LXED017035   Mileage: 112370km-69823miles
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401 B    HW: 4L0 907 401 C
   Component: 3.0TDI EDC17  H41 0003
   Revision: 53H41---    Serial number:
   Coding: 2A2A4012A52601020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114L2910401B 001003
   ROD: EV_ECM30TDI0114L1910401H.rod
   VCID: 2310E7114B5DB75FF77-8076
   Part No SW: 0C8 927 750 AL    HW: 0C8 927 750 AL
   Component: AL1000 AISIN  001 2096
   Coding: 001578
   Shop #: WSC 46954 001 1048576
   ROD: EV_TCMAL991031_002.rod
   VCID: 76B6EE45A84F72F7E09-8022
   Revision: 00H02001
   Coding: 2196593
   VCID: 3432144DF23320E71ED-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0200
   Revision: 00H08000    Serial number: 10603702091659
   Coding: 0000135
   VCID: 2514F90949E9496F993-8070
   Subsystem 1 - Part No: 4F0 910 132 G
   Component: FBSAUDIC6 EZS   H04 0020
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
   Revision: 00---031    Serial number: 00000000398139
   Coding: 01049016
   VCID: 2514F90945E9496F993-8070
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0133221
   VCID: 6E86C625DC9F4A37289-803A
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55931327100352
   Coding: 28031F
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 3432144DFEB320E71ED-8060
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 71 AIRBAG AUDI8RH44 0230
   Revision: 05H44000    Serial number: 00399D0D1TTK
   Coding: 0014129
   VCID: 2E0606251C1F0A37689-807A
   Subsystem 1 - Serial number: 6332QSME3B410766D
   Subsystem 2 - Serial number: 6342QSME3F413C7EZ
   Subsystem 3 - Serial number: 6352QSME3B413376F
   Subsystem 4 - Serial number: 6362QSME1E39125ER
   Subsystem 5 - Serial number: 63734SME1935115E/
   Subsystem 6 - Serial number: 63834SME533A057A2
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H09000    Serial number: 90026132150184
   Coding: 0012042
   VCID: 280AF03D3EFB5407A25-807C
   Component: E0221           H03 0040
   Part No SW: 4L0 920 933 H    HW: 4L0 920 933 H
   Component: KOMBIINSTR.   H35 0332
   Revision: 00000000    Serial number: X2M22P9AE
   Coding: 1356630401000008000004
   VCID: 323E125504272ED70C1-8066
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 815 071 H
   Component: Heizgeraet      H10 0140
   Revision: 0000000A    Serial number: 00000009024928
   Coding: 0000101
   VCID: 609AA81D164BEC47AA5-8034
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB700037    Serial number: 3700M13915060F
   Coding: 00CF07
   VCID: 3FD84B61C775F3BFF3F-806A
   Component: J367-BDM  H07 0125
   Serial number: 30280548424121214548
   Serial number: 13270000861011200181
   Part No SW: 4F0 857 511 K    HW: 4F0 857 511 K
   Revision: AA001002
   Coding: 02019064747464545425363E
   VCID: 303A185D0A2B1CC77A5-8064
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
   Revision: 00---011    Serial number: 00000000397617
   Coding: 0000006
   VCID: 688AB03DFE7B9407625-803C
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00000075525802
   Coding: 00581B00000011110000
   VCID: 313C1D59012115CF75B-8064
03333 - Motor for Cushion Angle Adjustment
                    Fault Status: 01100101
                    Reset counter: 34
                    Mileage: 112377 km
                    Date: 2019.06.18
                    Time: 08:37:22
   Component: J0769_SWA_MasterH02 0050
   Revision: 00H02000    Serial number: 6PZ 009 014-10
   Coding: 0000101
   Component: J0770_SWA_Slave_H02 0050
   Subsystem 3 - Serial number: 5F26.09.1300H02000AMS15228˙
   Subsystem 4 - Serial number: S15228˙
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000077998371
   Coding: 011F52205E40440004
   VCID: 48CA50BD92BBB407425-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 01938349530000
   Coding: 3547525
   VCID: 382A207DEE5BC487325-806C
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004001    Serial number: 00000000019822
   Coding: 030000
   VCID: 290CF53929F16D0FBDB-807C
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005191030888
   Coding: 0758473
   VCID: 2310E71147DDB75FF77-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000708553
   Coding: 0011001
   VCID: 5EE696E52C3FDAB7989-800A
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000077999242
   VCID: 47C853819FA5BB7F4BF-8012
                    Reset counter: 34
                    Mileage: 112379 km
                    Date: 2019.06.18
                    Time: 09:13:44
   Serial number: 130927-0004-005
   Coding: 1147A71010020500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 42DE4295B4079E579C1-8016
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227J30D7863282
   Coding: 010003010000000000
   VCID: 2616FE0538EF4277909-8072
   Part No SW: 4L2 035 670 N    HW: 4L2 035 670 D
   Component: H-BNT-EU      H46 1036
   Revision: --------    Serial number: 220JW0D7516811
   Coding: 180100060004E3EF510003556F632003040000000100000000
   VCID: 35342949F54939EF293-8060
   Subsystem 1 - Part No: 8R0 060 884 BC
   Component: EUR 2013/2014  1603
   Component: DU7 High  H42 0104
   Serial number: A130JZ0D2845652
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002140894
   Component: CD-Database  5298
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000078014963
   Coding: 010E50204040230004
   VCID: 46D65E8598AFA277B09-8012
   Part No SW: 4L0 907 428     HW: 7P6 907 441 D
   Component: TopView       H05 0293
   Revision: 11001001    Serial number: 82330JF0109452
   Coding: 020C010001000100000102000000
   ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
   ROD: EV_CamSysteCorneViewAUDI.rod
   VCID: 6E86C625D01F4A37289-803A
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H57 0500
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C82CC2DEA83B82706D-8038
   Subsystem 2 - Serial number: 7
ó
   Subsystem 3 - Serial number: RD05.10.13--H57001002E0201˙
   Subsystem 4 - Serial number: 2E0201˙
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 0077014388----
   Coding: 0003587
   VCID: 2616FE0534EF4277909-8072
   Component: J_245_EE16_SKB10H14 0220
   Component: J_394_EE16_SKB10H14 0220
   Component: J_392_EE16_SKB10H14 0220
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000078014962
                    Reset counter: 32
                    Mileage: 111412 km
                    Date: 2019.06.04
                    Time: 14:57:33
End----------(Elapsed Time: 03:12, VBatt start/end: 12.2V/12.2V)-----------
I think "Basic Settings" on those are done like on windows... Just run it through the full range of adjustments manually, using the controls on the seat itself. When it hits an end-stop, keep holding the control in that direction for a second or two, release and then press and hold in the same direction again for a second or two.
It is indeed!
Sometimes twice too.........
Donibcsi
Hungary
C?ID=28126
I tried but does not work. Is it a backrest? Did I understand well?
MasterTommy
Amsterdam
C?ID=295586
Adjust the seat in a single direction until it stops by itself. Then hold the button again in the same direction for about 5-10 seconds. This way the end stops are relearned. Repeat this for every direction of every possible adjustment. Then cycle ignition and rescan.
Donibcsi
Hungary
C?ID=28126
I found something. This lift motor of the front side of the seat. If I operate by button up and down about on the 1/3 and 2/3 way the seat stop moving. If I repush the button, the seat will move again. I thought maybe is stucked and I tried to help the seat with my hand but same result. I touched the mootor, is not hot. There is a grease on the screw.
Dana
Western PA, USA
Hi guys,
Because the learning process is a matter of hitting the mechanical limits I don't believe VCDS measuring block data is going to shed much light on this however group 050 may apply:
050,1,Standardization Status (0 = NOT Standardized / 1 = Standardized)
x-xxx? = Longitudinal Adjustment
x-xx?x = Backrest Adjustment
x-x?xx = Height Adjustment
x-?xxx = Rake Adjustment
?-xxxx = Head Restraint Adjustment (ignore for S/RS-Models)
I believe you'll have a 0 in the Height Adjustment position because the system is not calibrated. The Seat Height adjustment switch input appears to be in MVB 003,1 (Not Oper. and Operated) so you could check it to see it the switch is dropping off when it stops moving during the calibration attempt.
I have confidence OP will finally prevail & make sure nothing stops end limits like a golf ball or a dog/kids toy!
Donibcsi
Hungary
C?ID=28126
I removed the motor and it's full with rust inside. Thanks for all.
darkchina811
ITALY
C?ID=333184
cool, but you'll still need to run the basic settings after you put it back :D
dgp
Australia
C?ID=380715
Hey, thanks guys for the info in this thread about the seat learning procedure taking the seat to its end stops via the buttons on the seat itself. This solved the issue I was having in my MY19.5 Tiguan Allspace Highline, whereby the seat would move into its position once the car was started, but if I adjusted the seat forward manually, it would stop after moving about 10mm.
EuroX
Northern NJ USA
C?ID=208579
You need to run the basic setting manually from the seat switch. The tilt for the seat bottom. The long horizontal button you can use it for seat height and also adjust angle of seat bottom. Run basic setting for seat bottom and then all should be good. Report back.
