Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 2016 audi q5 3.0 tdi dpf fault limp mode
    Apr 2019
    had a dpf filter closed fault then a bought a new filter cleared the codes then less than 100 miles later has a soot fault code help me please
    Monday,17,June,2019,14:42:29:54993
    Dealer/Shop Name: wagner
    VIN: WA1DVAFP7GA039342   License Plate:
    Mileage: 73680km-45782mi   Repair Order:
    Chassis Type: FP-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
              62 6C 6D 72 AC
    VIN: WA1DVAFP7GA039342   Mileage: 73680km-45782miles
    Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
       Part No SW: 8K5 907 401 AC    HW: 4G0 907 401 E
       Component: 3.0TDI EDC17  H14 0002
       Revision: 58H14---
       Coding: 2A2A4012052603050000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30TDI0118K5907401AC 001003
       ROD: EV_ECM30TDI0118K5907401AC_001.rod
       VCID: 71BFD4BC0124779F613-8024
    5188 - Diesel Particle Filter
              P2463 00 [175] - Excessive Soot Accumulation
                        Mileage: 73636 km
                        Date: 2019.06.17
                        Time: 12:05:06
                        Engine speed: 698.00 /min
                        Normed load value: 22.7 %
                        Coolant temperature: 50 °C
                        Intake air temperature: 31 °C
                        Voltage terminal 30: 14.240 V
                        P Flt Ld fac Ash Cor: 1.0000
                        Particul.filter diff.pressure: 8 hPa
                        Exh t Adap T Oxi Cat Ds: 113.6 °C
                        Exh t Adap TP Flt Ds: 98.8 °C
                        Current operating mode_2-Bits 0-7: 0
                        Current operating mode_2-Bits 0-7: 16
    9574 - NOx Sensor 1 Bank 1
              P2200 00 [096] - Electrical Malfunction
                        Mileage: 73636 km
                        Date: 2019.06.17
                        Time: 12:11:20
                        Engine speed: 699.50 /min
                        Normed load value: 23.5 %
                        Coolant temperature: 60 °C
                        Intake air temperature: 33 °C
                        Voltage terminal 30: 14.200 V
                        NOx sensor 1: NOx concentration: 1650 ppm
                        Com r Lam Lin Rec Ds: 0.2170
                        NOx sensor 1: feed voltage: 13760 mV
                        Target value of heating temperature of NOx sensor 1-Bits 0-7: 1
                        Com st N Ox Vld Ds-Bits 0-7: 0
                        Exh st Lam Stat NSC Ds-Bits 0-7: 1
                        Exh.gas temp.sen 1: 137.5 °C
    4456 - No Communication with NOx Sensor 1 Bank 1
              U1006 00 [032] - -
              [NOX Sensor 1 Bank 1No communication]
                        Mileage: 73636 km
                        Date: 2019.06.17
                        Time: 12:10:29
                        Engine speed: 700.00 /min
                        Normed load value: 24.3 %
                        Coolant temperature: 59 °C
                        Voltage terminal 30: 14.220 V
                        Cruise Control System (CCS): status-Bits 0-7: 44
                        selected gear-Bits 0-7: 0
    5189 - Particulate Trap Bank 1
              P2002 00 [047] - Efficiency Below Threshold
                        Mileage: 73636 km
                        Date: 2019.06.17
                        Time: 12:05:06
                        Ambient temperature: 16.0 °C
                        Particle filter: offset for differential press.: 1 hPa
                        Particle filter: soot mass measured: 0.60 g
                        Particle filter: soot mass calculated: 51.71 g
                        Particle filter: kilometers since last regeneration: 964495 m
                        Particle filter field regeneration: cancel conditions-Bits 0-7: 0
    Readiness: 1 1 0 0 1
       Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
       Component: 0BK 30 TDIUSA H19 1003
       Revision: --H19---
       Coding: 000001
       VCID: 4BC3665443487D4F3BF-801E
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
       Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
       Component: ESP8 quattro  H09 0020
       Coding: 231D1C03
       Shop #: WSC 06335 000 00000
       VCID: 117FB43C6164179F013-8044
       Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
       Component: BCM2 2.0      H15 0711
       Coding: 0DA54040000000000000
       VCID: 08499958123E5657D6D-805C
       Serial number: 3215000123160002
       Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
       Component: KLIMA 3 ZONEN H04 0122
       Revision: C1000000    Serial number: 01300720152180
       Coding: 3621228080
       VCID: 77ABEAA46FC029AFAF7-8022
       Revision: 08016001    Serial number: 00001138036501
       Coding: 26000091863CAFE00100488300003D0D0F9CC708A6090221000008004000030100000034000000
       VCID: 78A9E99862DE26D7A6D-802C
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 150721  H12 0050
       Serial number: 90243014150715125857
       Coding: 01DD13
       Serial number: 20473013
       Coding: 02005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001407151791
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z01FE2311
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 59E8CDB7000000000001
       Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
       Component: AirbagVW-AU10 H53 0812
       Serial number: 003NED156C7+
       Coding: 303635313832383132304A55304C38523053
       ASAM Dataset: EV_AirbaECUVWAUDI010 003114
       VCID: 4CC1654846467A77325-8018
       Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
       Serial number: 5810000R150000R2RB
       Serial number: 6334MSME533A2669H
       Serial number: 6344MSME530950501
       Serial number: 6352QSME2F562C74U
       Serial number: 6362QSME3357354EM
       Serial number: 63732SME79521046X
       Serial number: 63832SME7852104E+
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862OH1001E0
       Coding: 000037
       VCID: 48C9595852BE965716D-801C
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 982 A    HW: 8R0 920 982 A
       Component: KOMBIINSTR.   H35 0567
       Revision: 00200000    Serial number: 03K230W7G
       Coding: 8BB622000301D705020000
       VCID: 392F2C9C1954FFDF993-806C
       Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
       Component: GW-BEM 5CAN-M H11 0070
       Revision: 1Z130032    Serial number: 3241Z157080AED
       Coding: 80CF07FF00
       VCID: 7EA5FF8040FA18E7EC1-802A
       Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
       Component: J367-BDMHella  H07 8043
       Serial number: 0217847303
       Serial number: 15204000685011200410
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0077
       Revision: AA000000    Serial number: 00000158128178
       Coding: 01581B00000000000000
       VCID: 42DD4B707482BC07C89-8016
       Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
       Component: SWA Master    H05 0071
       Serial number: 0375155372
       Coding: 010211
       Shop #: WSC 06334 000 00000
       VCID: 3FDB428407F0D1EFA77-806A
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0071
       Serial number: 0375370424
       Coding: 010211
       Component: TSG FA        H02 0511
       Revision:             Serial number: 0000159663695
       Coding: 011D13215E00440004
       VCID: 4FFB7244B7D0416F577-801A
       Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
       Component: RCEPS         H43 0510
       Revision: 00001000    Serial number: 0016039765
       Coding: 100000010001
       ASAM Dataset: EV_RCEPSAU48X 008018
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 45D7506C652C8B3FEDB-8010
       Revision: 00002001    Serial number: 0375355434
       Coding: 0126023A20FA709584A0053600040047
       Component: GTO BF  H01 0080
       Serial number: 00000000000001032905
       Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J245EE04SKB03  H04 0090
       Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J394EE04SKB03  H04 0090
    01512 - Control Module for Sliding Roof
                        Fault Status: 01100101
                        Reset counter: 86
                        Mileage: 73636 km
                        Date: 2019.06.17
                        Time: 12:05:03
    02907 - Control Module for Roof Shade (J394)
                        Reset counter: 86
                        Mileage: 73636 km
                        Date: 2019.06.17
                        Time: 12:05:03
       Revision: 00005001    Serial number: 94813047152207
       VCID: 2D0708CCDD1C537F05B-8078
       Component: TSG BF        H02 0511
       Revision:             Serial number: 0000159868190
       VCID: 4EC56F40B0DA48675C1-801A
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 30000000407811
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A2D33901CD2F4C7909-806E
       Component: Radio U SIRIU H66 0133
       Revision: AB001007    Serial number: 156G80F8299931
       Coding: 020007010000000001
       VCID: 2411EDE88ED69237DA5-8070
       Part No SW: 8R1 035 746 H    HW: 8R1 035 746 G
       Component: H-BNT-NA      H43 0937
       Revision: --------    Serial number: 523G30F7580387
       Coding: 160200060005A1EF55028B5E00000403140000000000000000
       VCID: 3C2135881666CAF7825-8068
       Subsystem 1 - Part No: 8R0 060 884 CS
       Component: NAR 2015  1201
       Component: DU7 High  H42 0104
       Serial number: A130GT0F3426570
       Serial number: 00000002323299
       Component: CD-Database  6208
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000160143523
       Coding: 010C13204000240004
       VCID: 46D5576058AA8027E41-8012
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H09---    Serial number: 525PA8-JA5A47W
       Coding: 1020010
       VCID: 34311DA8323602B74A5-8060
       Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
       Component: J605  Master  H56 0330
       Revision: --------    Serial number: 8R0827851D
       VCID: 3D27388C0D7CC3FFB5B-8068
       Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
       Component: J756  Slave  H56 0330
       Serial number: 8R0827852D
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000160144521
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 151881126
       ROD: EV_RDCMA00100_008.rod
       VCID: 2F3B12C4D790216F377-807A
    End----(Elapsed Time: 02:13, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
    Apr 2019
    dpf filter clogged fault and now soot fault
    Less than 50,000 miles, and less than 4 years old. This vehicle should still be under Audi's bumper-bumper warranty, no?
    Apr 2019
    it is not under warranty front fender crash audi says no. just need to get the light out so I can smog it. I need help
    LOL it's spreading!
    Yeah did they put that bullshit in writing and explain how a damaged fender took out the DPF to void such an AECD warranty?
    Please oh please lets document this one OP, Okay?
    Did you JPPSG here yet OP?
    https://forums.ross-tech.com/showthr...l=1#post156577
    Would suck if it was found that all you needed was a PSI sensor huh?
    Got any pictures for extensiveness of the damage?
    Vehicle Identification No. WA1DVAFP7GA039342
    Model Audi Q5 qu. 3.0 TDI
    AQ5
    Date of production 06.08.2015
    Model year 2016
    Sales type 8RB5VA
    Engine Code CPNB
    Transmission Code QDA
    Emission standard 7GB Emission standard ULEV 2
    Apr 2019
    I changed the pressure differential sensor
    LOL it's spreading!
    Not exactly. I'm not guessing at some nebulous "useful life" warranty here, but rather what the manufacturer (Audi) explicitly promised.
    Yup, I'm with ya on this one. Manufacturer can't void a warranty for (especially an emissions warranty!) due to a crash unless the emissions system was directly damaged by that crash and improperly repaired.
  9. Likes Jack@European_Parts liked this post
  10. #8
    What cloud would that be, the ninth?
    So what's so unclear and vague about a useful life warranty or do you mean how the OEM's try to false interpret it & because people are generally dumb/lazy as dirt like, you know like the SMOG that gets spewed when they illuminate an MIL and 'franchises' basically are curbing cars to sell new ones or sell retail work & bill the OEM directly by means of possible alleged warranty fraud & when they should be under such a promise?
    Isn't this why so many cross check the fraud by lawful VCDS licence & as an instrument of such proof?
    Where is the promise different, because both are made to the consumer and the US Government + CARB?
    Embrace the OBD rules of engagement Uwe, it's how you and many make a living + you employee & by means of regulations you hate to love!
  11. #9
    Apr 2019
    the dealer said it had a dent one to top it was a factory dent they all have them so I took it back. then they said it had dents on the bottom. look like they put them there. they were upset that I would not pay the 8800 to prepare it. then I took it to another dealer they said it needed other parts 7700. so I took it back from them both dealers had a list of different part except for the dpf so I replaced it myself reset code and this is where I am at. I also replaced pd sensor. so this is where I am at. the code came on before the accident. have not had tags in over a year will not pass smog with engine light on. does anyone have an idea. I need help.
  12. #10
    Time to contact NHTSA and EPA + CARB huh & a good Lawyer?
    If I were you, I would contact Audi customer care before you do, because damage to this part isn't normally a damaged AECD or as a result of a fender & unless the damage was far more than you state and if it was, it would be normally covered by comprehensive insurance, if you had that coverage and once it was fixed, it would still be covered because the OEM is still responsible for the replacement vicariously as a result of the engines operation to comport under title 40 now isn't it?
    See this is why I didn't sell mine back or take blood money!
    OP:
    Don't you think you should contact your insurance company to get a supplement if you have such coverage and the documentation from the two dealers stating in writing that this is the result of a collision, then to the lawyer?
