I’m having to have the module replaced at a AUDI dealer , there saying the server has gone down and can’t code it at the moment till it’s fixed, so is that correct that they can only code it online and it has to be coded anyway and not just fitted
Might help to know what vehicle you haveI’m having to have the module replaced at a AUDI dealer , there saying the server has gone down and can’t code it at the moment till it’s fixed, so is that correct that they can only code it online and it has to be coded anyway and not just fitted
The dealer tool will likely read the VIN and then ask the mothership servers what the vehicle configuration is and what the correct coding is for the modules in that vehicle (assuming it is as it left the factory with no retrofits...) - so no mothership connection = they cannot code the module.
Most modules need to be coded to match the vehicle and its configuration.
It’s an A4 B8 2014, they kept saying the server was down and couldn’t recode a new one, so I presume there correct then ?
Isn't this Incorrect speculation, offline coding identity or VIN/Immobilizer or CP alignments are always indeed possible & for all modules?
Is it not a matter of course you must have the correct security clearance, this helps too and or make enough noise & so that any VAG/AUDI franchise will react or corporate will consider you to be of importance?
JPPSG
Post an auto-scan......pitch your bitch!
The OEM have the ability to do offline and online.......
IF the technicians have been properly trained - it's not uncommon for dealers in the UK to claim that their tools ONLY work in online mode - which is simply not true (as we know).The OEM have the ability to do offline and online.......
They are supposed to be trained yes, shall question it when I see the £750 bill !
Uh, since when can ODIS do Immo or CP matching without contact with FAZIT? Isn't that the entire foundation of the security model? If they could do it offline, why do you need online?
Yep, in principle, someone from corporate can give you what you need over the phone and it can be manually entered. But corporate will generally deny that this is possible.It can as could VAS for offline functions & if you have security access & string data for manual entry.
