Results 1 to 10 of 15
Thread: Convenience module coding
    Nov 2017
    Iím having to have the module replaced at a AUDI dealer , there saying the server has gone down and canít code it at the moment till itís fixed, so is that correct that they can only code it online and it has to be coded anyway and not just fitted
    Quote Originally Posted by sticky 491 View Post
    I’m having to have the module replaced at a AUDI dealer , there saying the server has gone down and can’t code it at the moment till it’s fixed, so is that correct that they can only code it online and it has to be coded anyway and not just fitted
    Might help to know what vehicle you have
    The dealer tool will likely read the VIN and then ask the mothership servers what the vehicle configuration is and what the correct coding is for the modules in that vehicle (assuming it is as it left the factory with no retrofits...) - so no mothership connection = they cannot code the module.
    Most modules need to be coded to match the vehicle and its configuration.
    Nov 2017
    Coding module
    Itís an A4 B8 2014, they kept saying the server was down and couldnít recode a new one, so I presume there correct then ?
    It’s an A4 B8 2014, they kept saying the server was down and couldn’t recode a new one, so I presume there correct then ?
    Isn't this Incorrect speculation, offline coding identity or VIN/Immobilizer or CP alignments are always indeed possible & for all modules?
    Is it not a matter of course you must have the correct security clearance, this helps too and or make enough noise & so that any VAG/AUDI franchise will react or corporate will consider you to be of importance?
    JPPSG
    Post an auto-scan......pitch your bitch!
    Nov 2017
    JPPSG
    I canít put a scan up as they still have my car, they say the server had gone down which is my query do they have to use online. coding as thatís what they seem to be doing,
    The OEM have the ability to do offline and online.......
    Nov 2017
    The cars not at an Audi dealer but approved one, they service department recon that they could connect to the Audi server which raised my concerns
  9. #8
    IF the technicians have been properly trained - it's not uncommon for dealers in the UK to claim that their tools ONLY work in online mode - which is simply not true (as we know).
  10. Likes Uwe liked this post
  11. #9
    Nov 2017
    They are supposed to be trained yes, shall question it when I see the £750 bill !
  12. #10
