This is my first post. Not a very user friendly process... third try.
Due to #1 injector coming loose while driving (not me) it banged up the head a smidgen last year. Twice reinstalled injector since after helicoil repair. Fuel would begin to leak into cylinder after 2-3 k miles, months in time; long crank to start and much smoke. Then start perfectly rest of the day no matter how long sitting. Next morning same hard start. 43 mpg highway. Around town 30-35.
This time (third) I used tiny bit of JB weld high temp under heat shield gasket and smidgen of form a gasket #2 below bottom o ring. Tight again but raised injector app. 1 mm. Starts fine but rougher idle though smooths out above idle. Readings in scan ridiculous. Glow plugs were unplugged when removing to check for leaking fuel, ignore those fault codes.
Have not driven yet but need help please. Thanks so much.
John
John
Saturday,15,June,2019,09:42:53:07126
VCDS Version: 19.6.0.2 HEX-V2 CB: 0.4505.4
VIN: 3VWRR69M74M078653 License Plate:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
75 76
VIN: 3VWRR69M74M078653 Mileage: 400520km-248871miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 906 016 H HW: 028 101 114 6
Component: R4 1.9L EDC G000AG 5375
Revision: 12345678 Serial number: VWZ7Z0C8501312
Coding: 0150034
VCID: 196FCEEF45880FAF2DF-5184
16685 - Cylinder 1
P0301 - 000 - Misfire Detected
RPM: 903 /min
Torque: 58.0 Nm
Voltage: 13.38 V
Bin. Bits: 00001100
Temperature: 25.2°C
(no units): 46.0
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
RPM: 210 /min
Torque: 88.0 Nm
Voltage: 10.49 V
Bin. Bits: 00001100
Temperature: 24.3°C
Bin. Bits: 01110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
RPM: 210 /min
Torque: 88.0 Nm
Voltage: 10.49 V
Bin. Bits: 00001100
Temperature: 24.3°C
Bin. Bits: 01110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
RPM: 210 /min
Torque: 88.0 Nm
Voltage: 10.49 V
Bin. Bits: 00001100
Temperature: 24.3°C
Bin. Bits: 01110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
RPM: 210 /min
Torque: 88.0 Nm
Voltage: 10.49 V
Bin. Bits: 00001100
Temperature: 24.3°C
Bin. Bits: 01110000
Readiness: 1 1 1 1 1
Address 02: Auto Trans Labels: 09A-927-750.lbl
Part No: 09A 927 750 AM
Component: AG5 Getriebe 09A 0242
VCID: 76B5E55391D680D7E0D-50AE
01045 - Tiptronic Switch (F189)
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
VCID: 34311F5BC22AD2C71E9-5184
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0003
Coding: 12340
Shop #: WSC 00066
VCID: 270BF81706FCA95FABB-513C
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 906 R
Component: KOMBI+WEGFAHRSP VDO V54
Coding: 15234
VCID: 3C21377BEF7A1A87D69-513C
3VWRR69M74M078653 VWZ7Z0C8501312
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: 70B9D34BF3B2AEE73A1-513C
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 372B2857D65C39DF3BB-4B1E
Component: 1H Tõrsteuer.FS KLO 0202
Component: 1H Tõrsteuer.BF KLO 0202
Component: 1H Tõrsteuer.HL KLO 0202
Component: 1H Tõrsteuer.HR KLO 0202
00912 - Window Regulator Switch; Front Left (E40)
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 F
Component: Radio ZSW 0016
Coding: 00401
Shop #: WSC 00066
VCID: 2313EC0772C4457FF73-513C
00881 - Connection to Speaker Rear Right
44-10 - Short Circuit - Intermittent
End----------(Elapsed Time: 05:16, VBatt start/end: 12.1V/12.1V)-----------
Address 01: Engine (038 906 016 H)
09:48:09
945 /min Engine Speed (G28)
5.8 mg/str Injection Quantity
7.1°KW Injection Duration (specified)
5.3 °BTDC Injection Start (specified)
6.1°KW Injection Duration (specified)
36.9°C Coolant Temperature (G62)
2.99 mg/str Injection Quantity Deviation Cyl. 1
-1.91 mg/str Injection Quantity Deviation Cyl. 2
-1.20 mg/str Injection Quantity Deviation Cyl. 3
-0.28 mg/str Injection Quantity Deviation Cyl. 4
0.0 Injector Status Cylinder 1
0.0 Injector Status Cylinder 2
09:48:27
1155 /min Engine Speed (G28)
6.3 mg/str Injection Quantity
6.5 °BTDC Injection Start (specified)
37.8°C Coolant Temperature (G62)
-3.01 mg/str Injection Quantity Deviation Cyl. 2
-1.22 mg/str Injection Quantity Deviation Cyl. 3
1.01 mg/str Injection Quantity Deviation Cyl. 4
09:48:36
1659 /min Engine Speed (G28)
7.7 mg/str Injection Quantity
8.1 °BTDC Injection Start (specified)
38.7°C Coolant Temperature (G62)
-1.15 mg/str Injection Quantity Deviation Cyl. 3
0.96 mg/str Injection Quantity Deviation Cyl. 4
09:48:52
1932 /min Engine Speed (G28)
8.5 mg/str Injection Quantity
5.6°KW Injection Duration (specified)
7.8 °BTDC Injection Start (specified)
39.6°C Coolant Temperature (G62)
09:49:07
2709 /min Engine Speed (G28)
6.9 mg/str Injection Quantity
2.6°KW Injection Duration (specified)
10.9 °BTDC Injection Start (specified)
3.1°KW Injection Duration (specified)
41.4°C Coolant Temperature (G62)
09:49:15
2982 /min Engine Speed (G28)
8.8 mg/str Injection Quantity
13.0 °BTDC Injection Start (specified)
43.2°C Coolant Temperature (G62)
4.0 Injector Status Cylinder 1
4.0 Injector Status Cylinder 2
Address 01: DTCs cleared
09:51:15 Group 001: Injection Quantity
882 /min Engine Speed (G28)
8.0 mg/str Injection Quantity
6.6°KW Injection Duration (specified)
48.6°C Coolant Temperature (G62)
09:51:15 Group 004: Pump-Jet Valves
4.0 °BTDC Injection Start (specified)
-1.1°KW Torsion Value
09:51:15 Group 005: Start Conditions (last Engine Start)
14.8 mg/str Start Injection Quantity
48.0 Start Synchronisation
09:51:54 Group 001: Injection Quantity
903 /min Engine Speed (G28)
50.4°C Coolant Temperature (G62)
09:51:54 Group 004: Pump-Jet Valves
924 /min Engine Speed (G28)
09:51:54 Group 013: Idle Stabilization (Injection Quantity Deviation)
-1.84 mg/str Injection Quantity Deviation Cyl. 2
-0.73 mg/str Injection Quantity Deviation Cyl. 3
-0.75 mg/str Injection Quantity Deviation Cyl. 4
09:52:23 Group 001: Injection Quantity
51.3°C Coolant Temperature (G62)
09:52:23 Group 004: Pump-Jet Valves
09:52:23 Group 018: Piezo Unit Injector Status
0.0 Injector Status Cylinder 3
0.0 Injector Status Cylinder 4
09:52:55 Group 001: Injection Quantity
52.2°C Coolant Temperature (G62)
09:52:55 Group 004: Pump-Jet Valves
09:52:55 Group 023: Injector Switch Time Deviation
36.0 Switch Time Deviat. Cylinder 1
-28.0 Switch Time Deviat. Cylinder 2
-15.0 Switch Time Deviat. Cylinder 3
-19.0 Switch Time Deviat. Cylinder 4
