Hi
As per the title I have 2010 Phaeton RHD with Sunroof and it will not start or unlock with any of my key fobs x2
I came to the car after a night of torrential rain tried to unlock the car with my key fob and it didn't work so I manually unlocked the car and it started fine took the car for around a 30 minute drive nothing unusual no warning lights other than the cruise control light came on (may have pressed it accidentally) and I think I'm not sure if the key symbol came on, anyway came back to the car and unlocked using key and NOTHING! The car wasn't starting, no ignition, nothing other than mileage & door display working and radio, so my first instinct was the battery has gone flat so luckily my father owns a garage so he brought me his booster pack, put the booster pack on under the bonnet and still nothing, so I manually opened the boot as the car is deadlocked and not allowing me to open any of the doors and tried putting the booster on the starting battery RH directly and still nothing so I thought maybe I've confused the batteries and put it on the other battery LH and still nothing.
He also brought a live tester so I tested all the fuses with a basic live tester and visually inspected the larger fuses all are fine upon first basic inspection, at this point I decided to get the car recovered as the alarm kept going off and I was parked in a hospital car park. Whilst I waiting I started to strip the gearbox surround in order to put the car in neutral, all went well and the car hooked up easily though it was heavy!
Got the car recovered to my fathers workshop and when we where taking the car off the trailer (front end in the air) I noticed the ignition lights turn on and the heater vents opening up so I got excited and tried starting the car but NOTHING, however I had ignition so I did a quick fault code read with a Snap-On machine & the following errors came up:
00288 Steering column lock actuator N360 open circuit or short to ground - Intermittent
00230 Transmission Park Selector Switch (F305) Short with Ground - Intermittent
00166 Access/Start Authorisation Switch (E415) Open Circuit
49682 Steering Column No Communication U0212 Lower Limit Reached - Intermittent
49508 No Communications with HVAC Control Module (J301) U0164 Upper Limit Reached - Intermittent
Whilst the ignition was on the key symbol came on and every time I tried to start the car it wasn't responding, therefore I cleared the codes however the key symbol would come back on straight away & I also got a message like acc battery not connected or something like that, I turned the car off and tried restarting however it returned to its previous state and no ignition lights or anything just the alarm going off every 2 seconds and driving me insane.
Since then I have read all sorts of posts regarding the Kessy module as that was the only code that didn't have intermittent next to it and have read some posts with regards to it getting flooded with water etc, I have checked both batteries and they are producing 12 volts plus and have also recharged the smaller RH battery, I also borrowed my friends VAG COM and got the following log:
As this also indicated a fault with the Kessy module I have started to strip the drivers side to gain access hoping that it is on the drivers side RHD however I am half way through stripping it I can just about peel back the foam and carpet and it is bone dry and I this time I do not think it is on the drivers side, if it is on the passenger side I do not think I can access it without being able to unlock the passenger door in order to remove all the trim and seat etc
Please could someone shed light and confirm that my kessy is the problem and how I go about removing it with the door locked and replacing it or repairing it if possible.
Kind regards
Friday,14,June,2019,18:53:03:32918
VCDS Version: 19.6.0.2 (x64)
Chassis Type: 6N0
Scan: 01 02 03 05 07 08 09 15 16 17 18 19 2E 34 37 38 42 46 47 52
55 56 62 65 68 71 72 76 77
Mileage: 144350km-89694miles
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 D HW: 3D0 909 139 D
Component: Kessy 6850
Revision: 00H22072 Serial number: VWX3Z0J1914203
Coding: 0004328
Shop #: WSC 12345 123 12345
VCID: 2A5A8EAE817FBF1FEF-807E
Component: ELV XXXX
00003 - Control Module
014 - Defective
Fault Status: 01101110
Fault Frequency: 0
Date: 2064.00.00
Time: 00:00:14
Address 07: Control Head Labels: 3D0-907-048.clb
Part No SW: 3D0 907 048 HW: 3D0 907 048
Component: J127 KBT vorn 0031
Revision: ABH13001 Serial number: VWZ6Z7K0072013
VCID: 63C4238AA6D52E57EC-8036
Address 08: Auto HVAC Labels: 3D0-907-040.lbl
Part No: 3D0 907 040 L
Component: Climatronic D1 2038
Coding: 0000001
Shop #: WSC 01065 000 00000
VCID: 275C779A926D8277F0-8072
Address 09: Cent. Elect.
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 K
Component: J527 3601
Coding: 0000011
VCID: 479CD71A322D627710-8012
Address 17: Instruments Labels: 3D0-920-xxx-17.lbl
Part No SW: 3D0 920 983 C HW: 3D0 920 983 C
Component: J285 KOMBI-INST. 0616
Revision: KPH06V02
Coding: 0039401
Shop #: WSC 00845 210 176725
VCID: 295871A28079B407E6-807C
Address 18: Aux. Heat Labels: None
Part No: 3D0 815 005 AP
Component: J737__Standheizung 4405
Revision: 00084000 Serial number: 09020869A00000
VCID: 6BD44BAA4A05661754-803E
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 3D0 920 983 C
Component: J533 GW-K-CAN TP20 0616
Coding: 7FF2FBAC7B011003
VCID: 70EE5CC6632385CF61-8024
Address 2E: Media Player 3
Address 34: Level Control
Address 37: Navigation Labels: None
VCID: 55A00D52BC81C0E792-8000
No Faults Found
Address 38: Roof Electronics Labels: 3D0-907-135.lbl
Part No: 3D0 907 135 E
Component: Dachmodul 0802
Coding: 0004141
VCID: 25407D92E8619067C2-8070
Address 46: Central Conv.
Address 47: Sound System
Address 55: Headlight Range
Address 56: Radio Labels: None
No Faults Found
Address 65: Tire Pressure Labels:. 7L6-907-273.lbl
Part No SW: 7L6 907 273 E HW: 7L6 907 273 E
Component: J0502 RDK 0006
Revision: 00004006 Serial number: 00000900016208
Coding: 264900648C97BF000000000000
Shop #: WSC 09410 000 1048576
VCID: 3A7ABEEE71DF0F9F9F-806E
02214 - Tire Pressure Warning
Reset counter: 194
Mileage: 143682 km
Date: 2019.03.06
Time: 15:19:23
(no units): 84.0
Address 68: Wiper Electr. Labels: 3Dx-955-1xx-V2.clb
Part No: 3D2 955 120 B
Component: Front Wiper 3501
Coding: 0015733
Shop #: WSC 01065 000 376832
VCID: 21486982FC497C47BE-8074
Address 71: Battery Charger
Address 76: Park Assist Labels: None
Part No: 3D0 919 283 E
Component: 10 Einparkhilfe 1107
VCID: 2C5688B68B8BA12F1D-8078
Address 77: Telephone
End-------------------------(Elapsed Time: 13:33)--------------------------
Kind regards
