Results 1 to 4 of 4
Thread: 2019 Golf GTI S, 7-speed DSG, TSI(DKFA)
    Jun 2019
    This is how it came from the dealer. The engine doesn't have a label. Should I post a channel map for it?
    Friday,14,June,2019,13:57:21:56301
    VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
    VIN: 3VW6T7AU9KM014312   License Plate:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 08 09 13 15 17 19 32 3C 42 44 52 5F A9
    VIN: 3VW6T7AU9KM014312   Mileage: 864km-536miles
    Address 01: Engine (J623-DKFA)       Labels: None
       Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
       Revision: --H13---
       Coding: 092500124424012F0000
       Shop #: WSC 00066 790 00174
       ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
       ROD: EV_ECM20TFS0205G0906259Q.rod
       VCID: 3C21350716E61937D6D-8068
    15079 - Cold Start Idle Air Control System
              P050A 00 [096] - Malfunction
                        Mileage: 45 km
                        Date: 2019.05.06
                        Time: 11:06:17
                        Engine speed: 1410.75 /min
                        Normed load value: 7.1 %
                        Coolant temperature: 16 °C
                        Intake air temperature: 18 °C
                        Voltage terminal 30: 12.265 V
                        Unlearning counter according OBD: 20
                        Engine: operating status: IS
                        STATE_LS_SAE[1]: OL_CDN
                        T_AST_SAE: 13 s
                        MAP_MES_SAE: 49 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.031 V
                        FAC_TPS_1_SAE: 16.406250 %
                        FUP_H_SAE: 14530.0 kPa
       Part No SW: 0GC 300 020 G    HW: 0GC 927 711 H
       Component: GSG DQ381     H06 2404
       Revision: 00H06V07
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061_VW37.rod
       VCID: 2615F76FF86AB3E7909-8072
       Part No SW: 5Q0 614 517 DR    HW: 5Q0 614 517 BM
       Component: ESC           H45 0108
       Revision: 00000000    Serial number: 50109000000617
       Coding: 01FA6BA150212170807A020160C56880D60A84014006167610415051D0894B0B0000000012121212B835351919323200
       Shop #: WSC 00066 790 00080
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
       ROD: EV_Brake1UDSContiMK100IPB_038.rod
       VCID: 04518DE72E96A1F7EED-8050
       Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
       Component: AC Manuell    H03 2001
       Revision: 00001K05
       Coding: 00020004200110001000000000010004
       ASAM Dataset: EV_ACManueBHBVW37X 004134
       ROD: EV_ACManueBHBVW37X_004.rod
       VCID: 4CC165C74646A9B766D-8018
       Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
       Component: BCM PQ37BOSCH 036 0265
       Revision: --------    Serial number: C864160119055F
       Shop #: WSC 00066 790 00249
       ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 7BA3F61B5368DE0F9F7-802E
       Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    181119  043 0551
       Serial number: 97022066181130230625
       Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  050 0105
       Serial number: S3Y18M12D18H05M43S42
       Coding: 00A8DD
       Steering Column Switch:
       Subsystem 3 - Part No SW: 5Q1 953 521     HW: 5Q1 953 569
       Component: Lenks.Modul  H03 0170
       Serial number: 0300060220190C202132
       Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
       Component: ACC BOSCH MQB H11 0682
       Coding: 3500008101FFC728949C810500401600000000000000000004
       ASAM Dataset: EV_ACCBOSCHVW416 002008
       VCID: 44D14DE76E1661F7AED-8010
       Serial number: 003GCR0AWHG4
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CB5AEB5F204AEF4BF-8012
       Occupant Detection:
       Serial number: IBH00000000000AXJZJX
       Coding: 30305A
       Subsystem 2 - Part No SW: -----------    HW: 480 000 312 18
       Serial number: 35700000000D4D21263G
       Subsystem 3 - Part No SW: -----------    HW: 480 000 312 18
       Serial number: 35800000000ABC31563O
       Subsystem 4 - Part No SW: -----------    HW: 480 402 109 18
       Component: SideSensor_Dr  003 6149
       Serial number: 3510001BB2C06193B3D6
       Subsystem 5 - Part No SW: -----------    HW: 480 401 509 18
       Component: SideSensor_Pr  003 6149
       Serial number: 3520001A72C6D4B2D58I
       Subsystem 6 - Part No SW: -----------    HW: 480 400 701 19
       Component: FrontSensor_D  004 6149
       Serial number: 3550001262BFF575B43E
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 701 19
       Component: FrontSensor_P  004 6149
       Serial number: 3560001262BFF57663CJ
       Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
       Component: KOMBI         351 2700
       Coding: 0BBD090AA188CF0502882A095000000020000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009068
       VCID: 2F3B124BD790F2AF63F-807A
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_TEL_0x28 keine Kommunikation]
                        Reset counter: 45
                        Mileage: 35 km
                        Date: 2019.04.28
                        Time: 18:19:10
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5366
       Serial number: 25011900841416
       Coding: 030100047F085900FB0000691C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 6E85CF4F101ABBA7289-803A
       Component: 0-00-0d-00-04
       Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0052
       Serial number: 29180002740510048467
       Coding: 29FFFF
       Serial number: 4425796100
    Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
       Component: Quersperre    H55 8043
       Serial number: HA1-00028.11.18
       Coding: 0001
       ASAM Dataset: EV_LockElectHA1VW37X 001007
       ROD: EV_LockElectHA1VW37X.rod
       VCID: 52FD7BBFA462FF472C1-8006
       Component: HRE_Master    H12 0081
       Serial number: 0502317260
       Coding: 01011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D2738030DFC103FE13-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0081
       Serial number: 0502568163
       Coding: 010111
       Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
       Component: TSG FS        006 0247
       Serial number: 42038902300736
       Coding: 003E03200000040000000000
       Shop #: WSC 01383 790 50316
       VCID: 4FFB72CBB75092AF03F-801A
       Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000001606038
       Coding: 011000
       Part No SW: 5QN 909 144 A    HW: 5QN 909 144 A
       Component: EPS_MQB_ZFLS  507 5081
       Coding: 811F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 50F971B7AA6E8D571A5-8004
       Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
       Component: TSG BFS       006 0247
       Serial number: 46035900301842
       VCID: 4EC56FCFB05A9BA7089-801A
       Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000001517911
       Coding: 091000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 5G6 035 868     HW: 5G6 035 868
       Component: MU-E--ER      695 8742
       Serial number: 19111800010508
       Coding: 02730000BE00000041220001001000009F0003D40000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001041
       ROD: EV_MUEnt4CGen2LGE_VW37.rod
       VCID: 70B9D1370A2EAD573A5-8024
       Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
       Serial number: 181012201094
       VCID: 323D1B3FC4A2DF470C1-8066
    End----------(Elapsed Time: 01:19, VBatt start/end: 12.5V/12.5V)-----------
    Jon
  2. Likes NEtech, jyoung8607, Uwe, Dana liked this post
  3. #2
    Quote Originally Posted by satterrfi View Post
    A channel map is not really going to help much with making a label file for a UDS ECU. Measuring Values, Adaptations, and Basic Settings intrinsically have (ostensibly meaningful) names on a UDS ECU even without a label file. So Coding and Security Access are generally the only things in label files for those, and a maps aren't going to help get those.
    However: Measuring Value maps both key on / engine off, and engine fully warmed up and running at idle might help someone down the road who's wants to know if the values they're seeing are "normal".
  4. Likes Eric liked this post
  5. #3
    Jun 2017
    Do people still exist who order a car without any PDC?
  6. #4
    Two things:
    1) In the NAR market, we don't get a to choose individual options. We get "packages". This car is a "S' trim, which means it's the least expensive version available.
    2) In most places in the US, parallel parking is not common, and the parking spaces in parking lots are big enough for American-sized SUVs and pickup trucks. That means a GTI is relatively small and very easy to park. Like this.
  7. Likes Dana, jyoung8607, PetrolDave, Eric, hadez16 liked this post
