Crash shut down activated, please someone help!
Shuhel
Birmingham, UK
C?ID=368132
Friday,14,June,2019,18:20:10:58999
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
VIN: WVWZZZAWZJU035537   License Plate: GM18LAST1
Mileage: 11476km-7130mi   Repair Order:
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 08 09 13 15 17 19 44 5F
VIN: WVWZZZAWZJU035537   Mileage: 11476km-7130miles
Address 01: Engine (J623-CHYC)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057 AP    HW: 04C 907 309 BE
   Component: R3 1.0l MPI   H20 5636
   Revision: 33H20000
   Coding: 01110012020405080000
   Shop #: WSC 31414 790 00200
   ASAM Dataset: EV_ECM10MPI01104C906057AP 001004
   ROD: EV_ECM10MPI01104C906057AP_VW27.rod
   VCID: 73B3DE575B3B4FEFC73-8026
          U0428 00 [039] - -
                    Mileage: 11476 km
                    Date: 2019.06.14
                    Time: 18:19:45
                    Engine speed: 780.00 /min
                    Normed load value: 19.2 %
                    Coolant temperature: 96 °C
                    Intake air temperature: 68 °C
                    Voltage terminal 30: 12.769 V
                    selected gear-Bits 0-7: 0
Readiness: 1110 0001
   Part No SW: 2Q0 614 517 AA    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0222
   Serial number: 08510103180110
   Coding: 09034A64154490B25201A81924E142A649124926114A242444541254452442659248926488522424222A482AA251D6423D8A6B42BC
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0.rod
   VCID: 6D87C82F3D1F991F117-8038
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
          [Scl_LWI_Lenkradwinkel_Error]
                    Reset counter: 20
                    Mileage: 11476 km
                    Date: 2019.06.14
                    Time: 18:19:42
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 2G2 820 045 D    HW: 2G2 820 045 D
   Component: SG_AC_Manuell H50 0301
   Coding: 012100000800010011000400020000000000000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001011
   ROD: EV_ACManuePrehMQBA0_VW27.rod
   VCID: 221DEB13B4419667FC5-8076
   Part No SW: 2Q0 937 089     HW: 2Q0 937 089
   Component: BCM A0 Std    H97 0916
   Serial number: 07001800600775
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 77ABEA474F4323CFFBB-8022
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 2Q2 959 881 C    HW: 2Q2 959 881 C
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000018668454
   Coding: 1F0000
   Subsystem 2 - Part No SW: 2Q2 959 882     HW: 2Q2 959 882
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000018818593
   Coding: 050000
   Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H02 0233
   Coding: 2A00600100F78748949C8145004087
   VCID: 3E253F6320F9D287F8D-806A
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 20
                    Mileage: 11476 km
                    Date: 2019.06.14
                    Time: 18:19:42
                    Voltage terminal 15: 12.9 V
                    Control Module temperature: 73 °C
                    Longitudinal_acceleration_vehicle_reference: 0.03 m/s²
2052 - Databus
          [FAULT_ALP_STEERINGWHEEL_FAIL]
                    Reset counter: 20
                    Mileage: 11476 km
                    Date: 2019.06.14
                    Time: 18:19:42
                    Voltage terminal 15: 13.0 V
2049 - Databus
          [FAULT_ALP_DT_STEERING_WHEEL_FAIL]
                    Reset counter: 20
                    Mileage: 11476 km
                    Date: 2019.06.14
                    Time: 18:19:42
   Part No SW: 2Q0 959 655 AG    HW: 2Q0 959 655 AG
   Component: VW22Airbag    010 0248
   Revision: --------
   Coding: 88CCC0C0000000005C5400CF008800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 025D8B9314817667DC5-8056
   Subsystem 1 - Part No SW: -----------    HW: 442 060 312 17
   Serial number: 3577Y21BF263F3C354CL
   Subsystem 2 - Part No SW: -----------    HW: 442 062 911 17
   Serial number: 3587Y20AD26D2BC2D47P
   Subsystem 3 - Part No SW: -----------    HW: 442 0B0 701 18
   Serial number: 3517734BD28A7CD6B1FA
   Subsystem 4 - Part No SW: -----------    HW: 442 0B0 701 18
   Serial number: 3527734B928FA39602FZ
   Subsystem 5 - Part No SW: -----------    HW: 442 131 601 18
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11BB2796DD3C335
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 20
                    Mileage: 11476 km
                    Date: 2019.06.14
                    Time: 18:19:42
   Part No SW: 2G0 920 930 A    HW: 2G0 920 930 A
   Component: KOMBI         209 0460
   Coding: 24A4010021002600018800010000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001020
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 211FE41FB1478D7FE5F-8074
   Part No SW: 2Q0 909 901     HW: 2Q0 937 089
   Component: GW MQB A0     H97 0916
   Coding: 030000046F085600F8000048080E00010001070000000000000000000000
   ASAM Dataset: EV_GatewA0 013020
   ROD: EV_GatewA0_VW27.rod
   VCID: 6FBBD22737136B0F23B-803A
   Subsystem 2 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 10043DF7
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q2 909 144 J    HW: 2Q2 909 144 F
   Component: TRW_G4L_MQBA0 620 6030
   Serial number: 0342210CB4J0383
   Coding: 00000000000000000000020101000101000001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
   ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
   VCID: 3A2D33733CD1FEA7C45-806E
15788544 - Crash Shut-Down Activated
          P1609 00 [137] - -
          [DEM_FRONT_CRASH_FAULT]
                    Mileage: 11476 km
                    Date: 2019.06.14
                    Time: 18:19:42
                    Engine speed: 781 /min
                    Terminal 15 status: On
                    Voltage terminal 30: 13.02 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.5 A
                    End stage temperature: 215 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 65535 °
                    Electric motor speed: 45535 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: 0.2 Nm
   Part No SW: 3Q0 035 820 C    HW: 3Q0 035 820 C
   Component: MU-S-D-ER     721 0867
   Coding: 02720000BE00000041110101008808001F0500C60120010001
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 290FFC3FC977453FBDF-807C
   Subsystem 1 - Part No SW: 5G6 919 605     HW: 5G6 919 605
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJV0595938
End----------(Elapsed Time: 00:36, VBatt start/end: 13.0V/13.0V)-----------
Got the OP verified; moving to Car Repair Support.
Shuhel
Birmingham, UK
C?ID=368132
Thank you, im looking forward to this
Shuhel
Birmingham, UK
C?ID=368132
Anyone please??
golfi_vend
Tartu, Estonia
C?ID=195131
If I remember correctly, there is basic setting called "reversible crash shut down" or similar.
Shuhel
Birmingham, UK
C?ID=368132
Hi, there is nothing i can find ,reverse crash shut down on vcds
Shuhel
Birmingham, UK
C?ID=368132
Surely someone here has a solution to this problem...??
Iv got 3 vehicles with the same , crash shut down activavted.
Shuhel
Birmingham, UK
C?ID=368132
Hello, yes all with exact steering rack.
Iv follwed the automechs procedure, still nothing. When resetting to factory on basic setting it says running for about 6 seconds and then not running.
Could it be something in uds adaptations..? Anyone..
Tia
Larry Manton
C?ID=112505
learning here, but we're they crashed or not.?
Also, does the vehicle fail to start or just code steering angle?
If CAN, I'd unplug it and see what happens, as is it taking down the can bus?
Dana
Western PA, USA
The newest scan (in Support e-mail) was flagged Intermittent - Confirmed:
> 1 Fault Found:
> P1609 00 [008] - -
> Intermittent - Confirmed - Tested Since Memory Clear​
TRW_G4L_MQBA0 racks aren't used here, and I don't have a procedure to offer, however it almost looks like that will clear at this point in time. You may want to try the Generic OBD2 fault code clear function in addition to clearing it directly in 44 at this point.
Shuhel
Birmingham, UK
C?ID=368132
Hello guys, i have now tried every procedure recommended with no luck!
Cannot find anyone in the uk who has resolved this.
I will wait patiently until someone finds a way. Thanks
Could there be a nefarious behavior linked to a required reset of the aforementioned OBD2 data or is it to circumvent a prior nefarious behavior that failed to comport?
How about a re-code with a "configured VCDS tester" and manual terminal 15 reset?
0x44-07-0342210CB4J0383
