Results 1 to 3 of 3
Thread: Help intermitant databus issues and codes i have never seen before skoda Octavia
    Oct 2018
    Anyone recognise this these fault codes ? Intermittant car cuts out or will not start . Leave for some time and starts no problem can last as long as three weeks
    so very hard to catch at the time. I suspected a canbus error but never seen some of these codes.
    Skoda Octavia 2014 1.2 Petrol
    Friday,14,June,2019,17:20:17:43739
    VCDS Version: 19.6.0.2 (x64)  HEX-NET CB: 0.4505.4
    VIN: TMBBB7NE6E0048853   License Plate:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
    VIN: TMBBB7NE6E0048853   Mileage: 112502km-69905miles
    Address 01: Engine (J623-CJZA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 016 H    HW: 04E 907 309 A
       Component: 1.2l R4 TSI   H08 5540
       Revision: WAH08---
       Coding: 01190012230401080000
       Shop #: WSC 73430 031 00000
       ASAM Dataset: EV_ECM12TFS01104E906016H 001006
       ROD: EV_ECM12TFS01104E906016H.rod
       VCID: 271E03A85E47CF77F0-8072
       Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
       Component: EMB8 EHCB     H31 0356
       Revision: 00000000    Serial number: 62203000000819
       Coding: 1A078A9124242974007F060541C6245851249400608224F0002300004002
       Shop #: WSC 62239 001 1048576
       ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
       VCID: 4BD69F18E26FCB1734-801E
    8249 - Databus
              [FCAN: Motor_Code_01 message is received with invalid counter]
                        Reset counter: 160
                        Mileage: 112502 km
                        Date: 2019.06.14
                        Time: 16:29:59
    8252 - Databus
              [FCAN: Motor_11 message is not received]
                        Reset counter: 160
                        Mileage: 112502 km
                        Date: 2019.06.14
                        Time: 16:29:58
    8254 - Databus
              [FCAN: Motor_12 message is not received]
                        Reset counter: 160
                        Mileage: 112502 km
                        Date: 2019.06.14
                        Time: 16:29:58
    8258 - Databus
              [FCAN: Motor_20 message is not received]
                        Reset counter: 160
                        Mileage: 112502 km
                        Date: 2019.06.14
                        Time: 16:29:58
    8291 - Databus
              [FCAN: MO_QBit_Motormomente signal is invalid]
                        Reset counter: 160
                        Mileage: 112502 km
                        Date: 2019.06.14
                        Time: 16:29:59
    Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
       Part No SW: 5E0 820 047 D    HW: 5E0 820 047 D
       Component: AC Manuell    H02 0604
       Revision: 00001K06
       Coding: 01110004000100001000000000400000
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_ACManueBHBVW37X 002017
       ROD: EV_ACManueBHBVW37X_002_VW37.rod
       VCID: 230617B82A7F2357AC-8076
       Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
       Component: BCM MQBAB M   H14 0112
       Serial number: 00011322500981
       Coding: 0F0008424207005307A04082B10407080000000000000000000000000000
       Shop #: WSC 73430 790 00114
       ROD: EV_BCMBOSCH_011.rod
       VCID: 48DCA014F319200F19-801C
       Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 130705  041 0570
       Serial number:         130722090403
       Coding: 065DDD
       Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY1315626B8
       Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
       Serial number: 00000000000057015464
    197904 - Central Locking
              B140A 4B [008] - Over temperature
                        Reset counter: 131
                        Mileage: 111880 km
                        Date: 2019.05.29
                        Time: 18:01:15
       Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
       Component: Airbag VW20   011 0188
       Revision: --------    Serial number: 003P4PG8VQEN
       Coding: 98CCC000000000005C5400CC008800000065
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7F4EFBC8E657A7B7E8-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 000 308 13
       Serial number: 3576U0000008A2506D09
       Subsystem 2 - Part No SW: -----------    HW: 454 000 308 13
       Serial number: 3586U000000A56506D0B
       Subsystem 3 - Part No SW: -----------    HW: 454 800 308 13
       Serial number: 3516R76C29B010000004
       Subsystem 4 - Part No SW: -----------    HW: 454 800 308 13
       Serial number: 3526RE3288F010000008
       Subsystem 5 - Part No SW: -----------    HW: 454 801 706 13
       Serial number: 3556V91EFF200000000K
    1053954 - Databus
              [NWD: 0x121 Motor_20 Message counter error]
                        Reset counter: 160
                        Mileage: 112502 km
                        Date: 2019.06.14
                        Time: 16:30:00
    1057794 - Databus
              [NWD: 0x0A8 Motor_12 Message counter error]
                        Reset counter: 160
                        Mileage: 112502 km
                        Date: 2019.06.14
                        Time: 16:29:57
       Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
       Revision: --------    Serial number: 07081304401269
       Coding: 0600
       VCID: 76A01EECC96DE6FFBB-8022
       Part No SW: 5E0 920 951 A    HW: 5E0 920 951 A
       Component: KOMBI         103 3390
       Coding: 272402002000A60001080800040000
       Shop #: WSC 73430 031 00114
       ASAM Dataset: EV_DashBoardJCIMQBAB 008011
       ROD: EV_DashBoardJCIMQBAB_008.rod
       VCID: 250209A0244BDD67C2-8070
    16776988 - Databus
              [TSK_07 keine Kommunikation]
                        Reset counter: 160
                        Mileage: 112502 km
                        Date: 2019.06.14
                        Time: 16:29:57
       Part No SW: 5Q0 907 530 K    HW: 5Q0 907 530 D
       Component: GW MQB Low    123 1144
       Revision: --------    Serial number: 0000783798
       Coding: 030000042B086400EF000048080F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 009013
       ROD: EV_GatewLear_009.rod
       VCID: 393AD5D0B8F3498796-806C
       Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
       Serial number: 8415901003
       Part No SW: 5Q4 959 393     HW: 5Q4 959 393
       Component: TSG FS        007 0006
       Serial number: 0000071730964
       Coding: 001000208001020100001100
       VCID: 55E2796034AB8DE792-8000
       Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
       Component: EPS_MQB_ZFLS  127 1021
       Coding: 01
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D32C1C0ACDB75A7BA-8068
    23298 - Databus
              [MOTOR_CODE_01 Botschaft - MC-Check]
                        Reset counter: 160
                        Mileage: 112502 km
                        Date: 2019.06.14
                        Time: 16:29:57
                        Motor status: 03
                        System status: Driving mode
                        Supply voltage: 12.50 V
                        Temperature: 24.0 °C
                        KFC: 5B
                        KFA: 00 02
                        Environmental conditions: 21
                        uAdSensI_U5VFiltered_xdu16: 5.06842 V
                        uioUdNotFilt_xdu16: 12.59 V
                        uAdSensI_SwitchedKl30_xdu16: 12.59 V
    22274 - Databus
              [KFC_MOTOR_11 Botschaft - MC-Check]
                        Reset counter: 40
                        Mileage: 112502 km
                        Date: 2019.06.14
                        Time: 16:29:57
                        Motor status: 03
                        KFC: 57
                        KFA: 00 02
                        uioUdNotFilt_xdu16: 12.47 V
                        uAdSensI_SwitchedKl30_xdu16: 12.46 V
    22530 - Databus
              [MOTOR_12 Botschaft - MC-Check]
                        Reset counter: 40
                        Mileage: 112502 km
                        Date: 2019.06.14
                        Time: 16:29:57
                        Motor status: 03
                        KFC: 58
                        KFA: 00 02
       Part No SW: 5Q4 959 392     HW: 5Q4 959 392
       Component: TSG BFS       007 0006
       Serial number: 0000071753485
    Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
       Part No SW: 5E0 035 820 A    HW: 5E0 035 820 A
       Component: MU-S-D-ER     040 0475
       Serial number: S5C00501140591
       Coding: 03730100FF0000001111120100A800002F0000860100010000
       Shop #: WSC 30403 000 1048576
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 1D7221400C1B15A79A-8048
       Subsystem 1 - Part No SW: 5E0 919 605     HW: 5E0 919 605
       Component: ABT_Std_Radio  H50 0022
       Serial number: SKZ8Z9NL2003N2
    End----------(Elapsed Time: 00:59, VBatt start/end: 14.2V/14.8V)-----------
    Pretty much all missing messages from ECU.
    ECU sometimes not getting power?
    ECU failing?
    Oct 2018
    Car has been driving fine now for weeks!!! i wish it would just fail ! Uwe i suspect an ecu failing but are you suggesting engine ecu ? anything on that auto scan that makes you think this? to me it just looks a mess
