Results 1 to 4 of 4
Thread: Audi A6 4F Allroad 2009 MMI replacement problem
    Jun 2019
    Norway
    Hello
    I have a Audi Allroad 2009 2.7.
    I have replaced the MMI unit in my car , after this I have a problem with the bluetooth . When the MMI has booted I have no problem connecting the phone and the phone connection configeration is stored in the unit. The phone is also working properly in the car.
    The problem is when I start the car next time the bluetooth is not starting. I have to manually start the BT service in the phonemeny.
    Also I have to manually connect my phone again. When I looked into "Stored phones" in MMi phone meny I find my phone.
    When I replaced the unit I used The same Longcoding as the old unit.
    I have tryed to look into the green menu, have not be able to fix the problem. When i look into the VCDS scan from the old unit and the new unit it seems to bee an older HW.
    Old defect unit:
       Part No SW: 4E0 035 666 K    HW: 4E0 035 666
       Component: H-BN-EU       H60 0187
       Revision: --------    Serial number: 345J5087528966
       Coding: 010100050002D3ED01002315EF6300030001
       Shop #: WSC 00010 218 72807
       VCID: 2E05F2382013C9673C1-807A
       Subsystem 1 - Part No: 8R0 060 884 EM
       Component: EUR 2017/2018  2503
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356JT081018813
       Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 S
       Component: Bedienteil MM  H01 0060
       Serial number: 00000001202121
    New unit:
       Part No SW: 4E0 035 666 K    HW: 4E0 035 666 B
       Component: H-BN-EU       H41 0187
       Revision: --------    Serial number: 454G+097511797
       Shop #: WSC 02391 823 56573
       VCID: 2E05F2382013C96768D-807A
       Subsystem 1 - Part No: 8R0 060 884 GA
       Component: EUR 2019  2802
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
    Jun 2019
    Norway
    I have not been abel to fix the problem, but I found the security access code for the MMI, its 21055.
    I tried it and it confirmed ok.
    TH
    The MMI in this car is likely in the Component Protection scheme. Has it been matched to the car at the dealer?
    Is there a reason you're not showing us the fault codes, or a complete Auto-Scan?
    Jun 2019
    Norway
    The component protection is removed by my local Audi dealer.
    TH
