- Mar 30, 2014
- 226
- 11
- Brighton, MI
- C?ID=102239
Car (2006 B6 Passat 2.0T FWD) was (almost) fine. Then in short period: gas filler flap solenoid not opening, heater fan stopped working, electrical break stopped working, instrument cluster no speedometer and gas gauge goes nuts.
Not sure about ABS/traction control (if that also occurred or was previously already an issue).
Not long ago, I replaced the aftermarket radio from previous owner with stock radio.
Hard to believe that those are not related? Suggestions were to start?
Ran full scan. After first run, erased all DTC.
The ones below are coming right back:
Thursday,13,June,2019,16:35:48:03761
VCDS Version: 19.6.0.2 (x64)
VIN: WVWAK73C66P038605 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 72
VIN: WVWAK73C66P038605 Mileage: 197800km-122907miles
03-ABS Brakes -- Status: Cannot be reached 1100
1C-Position Sensing -- Status: Malfunction 0010
53-Parking Brake -- Status: Cannot be reached 1100
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 F HW: 3C0 907 115 G
Component: 2.0l R4/4V TFSI 0030
Revision: --H10--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 66565 257 00032
VCID: 2344626BE2DB4957AC-8076
049441 - No Communication with ABS Brake Control Module
U0121 - 008 -
Fault Status: 01101000
Mileage: 197809 km
Date: 2019.06.13
Time: 16:33:03
Load: 0.0 %
Temperature: 44.0°C
Temperature: 45.0°C
Absolute Pres.: 960.0 mbar
Voltage: 12.065 V
049448 - No Communications with Parking Brake Control Module
U0128 - 008 -
Mileage: 197809 km
Date: 2019.06.13
Time: 16:33:03
Load: 0.0 %
Temperature: 44.0°C
Temperature: 45.0°C
Voltage: 12.065 V
Readiness: 0110 0101
Part No SW: 09G 927 750 CJ HW: 09G 927 750 CJ
Component: AQ 250 6F 0736
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 00028 028 00001
VCID: 7BF47A0B3AEBD197C4-802E
01316 - ABS Control Module
Address 03: ABS Brakes
Part No: 1K0 820 047 DL
Component: Climatic PQ35 090 0505
VCID: 71E8582368A7ABC76E-8024
013 - Check DTC Memory
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003140567
Coding: 048C8F0340041A00000A00000F00000000285D435C
VCID: 2B548A4B8A0B811714-807E
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 310108 003 0205
Coding: 00046997
Shop #: WSC 00028
02398 - Control Circuit for Rear Windshield Washer Pump
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 71
Mileage: 197809 km
Date: 2019.06.13
Time: 16:33:00
Voltage: 11.90 V
02092 - Enabling Heated Seat
Reset counter: 71
Mileage: 197809 km
Date: 2019.06.13
Time: 16:33:00
Voltage: 11.90 V
02401 - Terminal 75x
Fault Status: 01101100
Reset counter: 71
Mileage: 197809 km
Date: 2019.06.13
Time: 16:33:00
Voltage: 11.90 V
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E0025276
00003 - Control Module
014 - Defective
Fault Status: 01101110
Reset counter: 13
Mileage: 197481 km
Date: 2017.08.11
Time: 16:25:29
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 G HW: 3C0 909 605 G
Component: 0D AIRBAG VW8R 029 2421
Revision: 09029000 Serial number: 0039VSD9M6RJ
Coding: 0012356
VCID: 2A5A8F4F85F1981FEF-807E
Subsystem 1 - Part No: 3C0 959 339
Component: BF-Gewichtsens. 006 0001
Subsystem 2 - Serial number: 000000000333N3
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0A7C333DMÿ†63
Subsystem 5 - Serial number: C333DMÿ†6342MSME0B284438Cÿ†63
Subsystem 6 - Serial number: 84438Cÿ†6351HTS604FUP8I2Pÿ†63
Subsystem 7 - Serial number: UP8I2Pÿ†6361HTS604FU9723.ÿ†63
Subsystem 8 - Serial number: U9723.ÿ†63727TS604F6ONB32ÿ†63
Subsystem 9 - Serial number: 6ONB32ÿ†63827TS604FUOKU2%ÿ
Subsystem 10 - Serial number: UOKU2%ÿ
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507R
Coding: 0002013
VCID: 31689823A827EBC72E-8064
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 970 H HW: 3C0 920 970 H
Component: KOMBIINSTRUMENT VD1 3938
Revision: X0032000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 03163 067 57207
VCID: 2958704380F79307E6-807C
Reset counter: 71
Mileage: 197809 km
Date: 2019.06.13
Time: 16:32:56
Reset counter: 71
Mileage: 197809 km
Date: 2019.06.13
Time: 16:32:57
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05611078B
Coding: 3FFD0C04D31002
VCID: 21486863F8C75B47BE-8074
Reset counter: 71
Mileage: 197809 km
Date: 2019.06.13
Time: 16:34:19
Reset counter: 71
Mileage: 197809 km
Date: 2019.06.13
Time: 16:34:19
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0002
Revision: 00002000 Serial number: 1166279TN51K04
VCID: 6DD04453749F4F274A-8038
Part No SW: 3C0 959 433 Q HW: 3C0 959 433 Q
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 20129 444 100681
VCID: 387EA5074B5D3A8F69-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2359
Coding: 0001205
VCID: 3662AB3F4149CCFF7B-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.12 1502
VCID: 306E9D27A32DE2CF21-8064
00625 - Vehicle Speed Signal
Mileage: 7800 km
Temperature: 21.0°C
Voltage: 11.90 V
Voltage: 11.70 V
Component: KSG PQ46 RDK 051 0218
Coding: 03910F8801863E3F7F02171FE00A0F0F083800
Shop #: WSC 20111 444 54489
Reset counter: 71
Mileage: 197809 km
Date: 2019.06.13
Time: 16:34:54
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001204
VCID: 377CA63B464335F760-8062
Address 53: Parking Brake
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 C HW: 1K0 035 161 C
Component: Radio DE2 014 0019
Revision: 00014000 Serial number: VWZ4Z7G6273476
Coding: 0040401
Shop #: WSC 01279 785 00200
VCID: 1F4C6E9BCEB36DB788-804A
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2417
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 326A972FAD21D0DF57-8066
End-------------------------(Elapsed Time: 02:51)--------------------------
